The kernels 5.11 and 5.12 are limiting my clock in games, with kernel 5.4 and 5.10 the clock is always over 3 ghz while gaming, in 5.11 and 5.12 it’s just slightly over 2 ghz.
see this topic
To me the issue only happens in games, if i run cpupower frequency-info my cpu clock is always near max which is 3.90 ghz, but in games it’s slightly over 2 ghz.
Are temperatures too high for the cpu to reach higher clock speeds under heavy loads?
No, temperatures are fine and there’s no difference between kernels, the temp is always below 80 celsius.
Any reason keeping you from using the 5.10 kernel when it does not show this problem?
Check for differences in choosen governor and/or enabled boost beetween 5.10 and later kernels.
$ sudo cpupower frequency-info
Also see
I am using 5.10, there’s no difference between them when running cpupower frequency-info, the cpu is always running over 3 ghz, except in games, in games my cpu clock is lower than usual, this issue doesn’t happen with kernel 5.10,
export LANG=C
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=408d4cc4-d6ab-4db7-8273-3a97bfd9f402 rw quiet apparmor=1
security=apparmor resume=UUID=027ea994-9cd5-4c97-854a-114351085eea
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: SAMSUNG product: 550XBE/350XBE v: P10REU
serial: Chassis: type: 10 serial:
Mobo: SAMSUNG model: NP350XBE-KD1BR v: SGL9970A0B-C01-G001-S0001+10.0.17763
serial: UEFI: American Megatrends v: P10REU.088.200306.JJ
date: 03/06/2020
ID-1: BAT1 charge: 22.2 Wh (64.9%) condition: 34.2/43.1 Wh (79.4%)
volts: 12.2 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: status: Charging cycles: 1216
RAM: total: 7.67 GiB used: 2.34 GiB (30.6%)
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE cache: L2: 6 MiB bogomips: 28808
Speed: 3911 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3911 2: 3798
3: 3792 4: 3807 5: 3854 6: 3896 7: 3744 8: 3880
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Silicon Motion Web Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 2232:1080 class-ID: 0e02 serial:
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel port: efa0 bus-ID: 01:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp1s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Samsung Co
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
broadcast:
WAN IP:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 0cf3:e500 class-ID: e001
Local Storage: total: 931.51 GiB used: 162.5 GiB (17.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-35Z10T0
rotation: 5400 rpm serial: rev: 1A04 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 162.5 GiB (17.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 408d4cc4-d6ab-4db7-8273-3a97bfd9f402
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 0561-FF67
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 027ea994-9cd5-4c97-854a-114351085eea
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 1-6:3 info: Silicon Motion Web Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2232:1080
Device-3: 1-7:4 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C mobo: 50.0 C
Processes: 245 Uptime: 3h 35m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1255 lib: 363
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
export LANG=C inxi --admin --verbosity=7 --filter --no-host --width
May i re-run those commands under kernels 5.11 and 5.12?
if possible check under htop memory ,
8Go may be not enough for all
This is under kernel 5.12
export LANG=C
Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
udev.log_priority=3
date: 03/06/2020
ID-1: BAT1 charge: 26.3 Wh (76.9%) condition: 34.2/43.1 Wh (79.4%)
volts: 12.4 min: 11.4 model: SAMSUNG Electronics SR Real Battery
RAM: total: 7.66 GiB used: 1.54 GiB (20.2%)
Speed: 3187 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3187 2: 3809
3: 3762 4: 3876 5: 3807 6: 3858 7: 3751 8: 3865
diag: 389mm (15.3")
direct render: Yes
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
broadcast:
class-ID: 0200
broadcast:
WAN IP:
Local Storage: total: 931.51 GiB used: 162.71 GiB (17.5%)
used: 162.71 GiB (17.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0561-FF67
class-ID: e001
Processes: 233 Uptime: 6m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1258 lib: 363 flatpak: 0
I don’t really get what you mean.
I’ve got some news, i checked out CPU-X and it seems that those kernels are limiting my cpu clock to 1.8 ghz.
