Kernel 4.19 does not recognize battery
Hi there,
After latest update my laptop with 4.19 does not recognize the battery,
I tried KDE and Gnome same behavior,
Everything worked fine before with kernels 4.14 and 4.19
With higher kernels laptop sees the battery but does not go into Sleep mode.
So I need either
  • Find a way to recognize battery in kernel 4.19
  • Find a way to go to sleep mode with kernel 5.4 and up
Any suggestions appreciated.
Thank you
Start with the basics
Hi there,
#################### inxi -Fxzc0 ########################
  Kernel: 4.19.248-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0 Desktop: KDE Plasma
    v: 5.24.5 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro6,2 v: 1.0 serial: <superuser required>
  Mobo: Apple model: Mac-F22586C8 v: MacBookPro6,2 serial: <superuser required> UEFI: Apple
    v: 99.0.0.0.0 date: 06/13/2019
  Info: dual core model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Westmere rev: 5 cache:
    L1: 128 KiB L2: 512 KiB L3: 4 MiB
  Speed (MHz): avg: 2474 high: 3185 min/max: 1197/2661 boost: enabled cores: 1: 3185 2: 3112
    3: 2002 4: 1598 bogomips: 21279
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel arch: Gen5.75
    bus-ID: 00:02.0
  Device-2: NVIDIA GT216M [GeForce GT 330M] vendor: Apple driver: nouveau v: kernel arch: Tesla
    bus-ID: 01:00.0
  Device-3: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-1.1:3
  Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting gpu: i915,nouveau
    resolution: 1: N/A 2: 1440x900~60Hz
  OpenGL: renderer: NVA5 v: 3.3 Mesa 22.1.1 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0
  Device-2: NVIDIA GT216 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Sound Server-1: ALSA v: k4.19.248-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 16.0 running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: no
  Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3 v: 3.137 port: N/A
    bus-ID: 02:00.0
  Device-2: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
    driver: bcma-pci-bridge v: N/A bus-ID: 03:00.0
  IF-ID-1: wlp3s0b1 state: up mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8 bus-ID: 1-1.1.3:8
  Local Storage: total: 111.79 GiB used: 7.35 GiB (6.6%)
  ID-1: /dev/sda vendor: Kingston model: SV300S37A120G size: 111.79 GiB
  ID-1: / size: 54.09 GiB used: 7.34 GiB (13.6%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 196.9 MiB used: 15.3 MiB (7.8%) fs: vfat dev: /dev/sda1
  System Temperatures: cpu: 74.0 C mobo: N/A gpu: nouveau temp: 70.0 C
  Processes: 173 Uptime: 21m Memory: 7.72 GiB used: 1.46 GiB (18.9%) Init: systemd Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: 1059 Client: KDE Plasma v: 5.24.5 inxi: 3.3.19
So I need either
Thank you
