Kdenlive dependency knotifyconfig conflicts with default notifications
Recently a couple of things on my laptop stopped working; brightness and volume controls freeze/delay and only respond after a minute and the usual notification I get doesn’t activate. Flameshot, the screenshot program I use, freezes as well and won’t copypaste. I think this has to do with my notification service because when checking the logs, I get errors that mention a timeout, but I’m not sure what is causing it. I did not have this issue around a week ago (not sure what started it).
Checking journalctl -g notif yields messages like this:
session uid=1000 pid=1095] Activated service ‘org.freedesktop.Notifications’ failed: Process org.freedesktop.Notifications exited with status 1
session uid=1000 pid=1095] Activating service name=‘org.freedesktop.Notifications’ requested by ‘:1.4’ (uid=1000 pid=1114 comm="xfce4-power-manager “)
649]: org.kde.knotifications: WaitForName: Service was not registered within timeout
session uid=1000 pid=1095] Activating service name=‘org.freedesktop.Notifications’ requested by ‘:1.36’ (uid=1000 pid=1516 comm=”/usr/lib/firefox/firefox ")
805]: org.kde.knotifications: WaitForName: Service was not registered within timeout
session uid=1000 pid=1095] Activating service name=‘org.freedesktop.Notifications’ requested by ‘:1.8’ (uid=1000 pid=1106 comm="pa-applet “)
245]: org.kde.knotifications: WaitForName: Service was not registered within timeout
session uid=1000 pid=1095] Activating service name=‘org.freedesktop.Notifications’ requested by ‘:1.79’ (uid=1000 pid=9416 comm=”/usr/bin/flameshot ")
The only notification service is have is:
>find /usr/share/dbus-1/services/ -name '*Notif*'
/usr/share/dbus-1/services/org.kde.plasma.Notifications.service
If someone could work this through with me I’d greatly appreciate it.
System information:
  Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=4a72765e-c51f-4a44-ac54-7a41652bdee8 rw quiet apparmor=1
  Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0
  Type: Laptop System: LENOVO product: 2344BMU v: ThinkPad T430
  Mobo: LENOVO model: 2344BMU v: Win8 Pro DPK TPG
    serial: <superuser required> UEFI-[Legacy]: LENOVO v: G1ETC1WW (2.81 )
    date: 06/18/2019
  ID-1: BAT0 charge: 25.1 Wh (65.0%) condition: 38.6/86.6 Wh (44.6%)
    volts: 10.9 min: 11.1 model: LGC 45N1011 type: Li-ion serial: <filter>
    status: Discharging
  RAM: total: 7.45 GiB used: 2.43 GiB (32.6%)
  RAM Report:
  Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2338 high: 2499 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2050 2: 2370 3: 2433
    4: 2499 bogomips: 20761
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
    v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: NVIDIA GF108M [NVS 5400M] vendor: Lenovo driver: N/A
    alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:0def class-ID: 0300
  Device-3: Chicony Thinkpad T430 camera type: USB driver: uvcvideo
    bus-ID: 1-1.6:6 chip-ID: 04f2:b2db class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.3 compositor: picom v: git-dac85 driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
    s-diag: 485mm (19.1")
  Monitor-1: LVDS-1 res: 1600x900 hz: 60 dpi: 131
    size: 310x174mm (12.2x6.9") diag: 355mm (14")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
    v: 4.2 Mesa 21.3.5 compat-v: 3.0 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0bea
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.45 running: no
  Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
    v: kernel port: 7080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
  Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
    v: 0.8 bus-ID: 1-1.4:5 chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
  Local Storage: total: 476.94 GiB used: 69.44 GiB (14.6%)
  ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 61.5 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT50N rev: LT20
    dev-links: cdrom
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 69.44 GiB (14.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 4a72765e-c51f-4a44-ac54-7a41652bdee8
  Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.2:7 info: Razer USA Abyssus 1800 type: Mouse,Keyboard
    power: 100mA chip-ID: 1532:0020 class-ID: 0301
  Device-2: 1-1.3:4
    info: Upek TouchChip Fingerprint Coprocessor (WBF advanced mode)
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 147e:2020 class-ID: 0000
  Device-3: 1-1.4:5 info: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad]
    type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
  Device-4: 1-1.6:6 info: Chicony Thinkpad T430 camera type: Video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
  Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 59.0 C mobo: N/A
  Fan Speeds (RPM): fan-1: 3978
  Processes: 186 Uptime: 1h 0m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1724 apt: 0 pacman: 1721
  lib: 484 snap: 3 Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.12
How to increase your chances of solving your issue:
Please provide Information:
Hi, I thought mentioning my system and giving logs were enough, but I’ve tried provided more context based on those links. Please let me know if there’s anything else I can provide.
I’ve fixed the issue. As suspected, there was a conflict between kde and whatever notification service came with i3manjaro, I went to /usr/share/dbus-1/services/ and renamed org.kde.plasma.Notifications.service to something else for now as a backup. Rebooted and problem was gone; leaving this here in case someone else runs into this issue.
