KDE Wayland: screen frozen after suspend, KWin atomic modeset loop, cursor missing
Hello,
I am running Manjaro Testing with KDE Plasma on Wayland, on a system using an AMD GPU and two monitors.
After resuming the system from suspend, one of the monitors did not refresh anymore. The displayed image appears to be the last frame shown before suspend (for example, a clock widget remains stuck at the time when the system went to sleep). The mouse cursor is not visible on that screen, although the system remains responsive.
When attempting to change the screen orientation (portrait to landscape ; I tried that to un-jam the thing), the rendering becomes visibly incorrect (windows appear skewed or diagonally projected).
At the moment of resume, KWin started logging errors continuously, several times per second. A subsequent suspend episode resumed without the issue. All this happened before this update.
journalctl
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: Atomic modeset test failed! Invalid argument
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: drmPrimeFDToHandle() failed
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: Failed to create framebuffer: Invalid argument
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: Rendering a layer failed!
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: Failed to find a working output layer configuration! Enabled layers:
dez 13 12:17:23 jorge-machine kwin_wayland[1634]: src QRectF(0,0 1920x1200) -> dst QRect(0,0 1920x1200)
dez 13 12:17:24 jorge-machine kwin_wayland[1634]: drmPrimeFDToHandle() failed
dez 13 12:17:24 jorge-machine kwin_wayland[1634]: Failed to create framebuffer: Invalid argument
dez 13 12:17:24 jorge-machine kwin_wayland[1634]: Rendering a layer failed!
dez 13 12:17:24 jorge-machine kwin_wayland[1634]: Failed to find a working output layer configuration! Enabled layers:
dez 13 12:17:24 jorge-machine kwin_wayland[1634]: src QRectF(0,0 1920x1200) -> dst QRect(0,0 1920x1200)
inxi -zv8
 inxi -zv8         ✔
  Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=67c4e3fb-311e-4604-9383-d9cc274cf0fa rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
    Firmware: UEFI vendor: American Megatrends v: 5002 date: 01/13/2025
  ID-1: hidpp_battery_0 charge: 42% condition: N/A volts: 3.79 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> charging: status: discharging cycles: N/A
  System RAM: total: 32 GiB available: 31.25 GiB used: 20.59 GiB (65.9%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3200C14-8GFX serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3616 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3616 2: 3616 3: 3616
    4: 3616 5: 3616 6: 3616 7: 3616 8: 3616 9: 3616 10: 3616 11: 3616 12: 3616
    13: 3616 14: 3616 15: 3616 16: 3616 bogomips: 121605
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: ASUSTeK TUF Gaming driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
    empty: DP-2,DP-3,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2.2:7
    chip-ID: 046d:085b class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5760x2160 display-ID: 0
  Monitor-1: DP-1 pos: right model: LG (GoldStar) 27GN950 serial: <filter>
    built: 2021 res: mode: 3840x2160 hz: 120 scale: 170% (1.7) to: 2259x1271
    dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.267
    y: 0.686 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 1920x1080, 1280x720, 1024x768, 800x600, 720x480,
    640x480
  EDID-Errors: 1: bad sync value: bad horizontal values: min: 30 max: 15
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: HDMI-A-1 pos: primary,left model: Idek Iiyama PLE2607WS
    serial: <filter> built: 2008 res: mode: 1920x1200 hz: 60 scale: 160% (1.6)
    to: 1200x1920 dpi: 89 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.282 y: 0.600 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 550x344mm (21.65x13.54") diag: 649mm (25.5") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 21.1.6 DRM 3.64 6.18.0-1-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:744c surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0d:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
    vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:11b1
    class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  IF-ID-1: br-466c45b29e42 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
    driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-3.1:5 chip-ID: 045e:0745 class-ID: 0300
  Local Storage: total: 8.3 TiB used: 1.59 TiB (19.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 52.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 990 PRO 4TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 54.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B1Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH14NS40 rev: 1.05
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 2.59 TiB size: 2.59 TiB (100.00%) used: 178.3 GiB (6.7%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro root
    uuid: 67c4e3fb-311e-4604-9383-d9cc274cf0fa
    used: 32.1 MiB (6.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: 5BFB-F55D
  ID-3: /home raw-size: 3.49 TiB size: 3.44 TiB (98.40%)
    used: 1.42 TiB (41.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:6
    label: Home uuid: 1763d5a3-375c-4e17-a4cf-f96bde772b42
  ID-4: /var/cache raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
    used: 178.3 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Manjaro root uuid: 67c4e3fb-311e-4604-9383-d9cc274cf0fa
  ID-5: /var/log raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
  ID-1: swap-1 type: partition size: 63.5 GiB used: 578.2 MiB (0.9%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
    uuid: 2fb0f355-cde7-4eb9-9259-9822d28c5af2
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 1013.73 GiB fs: btrfs label: N/A
    uuid: 2012bb20-12df-40ac-a630-2ed115853dc0
  ID-2: /dev/nvme1n1p2 maj-min: 259:7 size: 150 GiB fs: btrfs
    label: snapshots backup syst\xc3\xa8me
    uuid: e51dc2b8-8026-4865-99e5-09216373f6af
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sda2 maj-min: 8:2 size: 118.5 GiB fs: ntfs label: N/A
    uuid: 648AA69E8AA66C6C
  ID-5: /dev/sda3 maj-min: 8:3 size: 743 MiB fs: ntfs label: N/A
    uuid: FADE7F8FDE7F4345
  ID-6: /dev/sdb1 maj-min: 8:17 size: 868 MiB fs: vfat label: N/A
    uuid: A567-7EF7
  ID-7: /dev/sdb2 maj-min: 8:18 size: 930.66 GiB fs: ext4 label: N/A
    uuid: f18e7382-b9e7-4ab1-84ec-8fc5127f31d3
  Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.3:4 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Device-2: 1-5.4:5 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
    serial: <filter>
  Device-3: 1-6:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.1:4 info: Advanced Card Systems ACR38 SmartCard Reader
    type: smart card driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 072f:90cc class-ID: 0b00
  Hub-6: 3-2.2:6 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
  Device-1: 3-2.2.2:7 info: Logitech Logitech Webcam C925e type: video,audio
  Device-2: 3-2.2.4:13 info: LG USA Monitor Controls
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a8a class-ID: 0a00 serial: <filter>
  Hub-7: 3-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Device-1: 3-3.1:5 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  Device-2: 3-3.2:8 info: HP HP Color LaserJet Pro M478f-9f type: printer
    driver: usblp interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 2mA chip-ID: 03f0:c52a class-ID: 0701 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-10: 4-2.2:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    chip-ID: 0451:8140 class-ID: 0900
  Hub-11: 4-3:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Logitech Lightspeed Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c539 class-ID: 0300
  Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 52.0 C mobo: 40.0 C gpu: amdgpu temp: 61.0 C
    mem: 64.0 C
  Fan Speeds (rpm): cpu: 891 gpu: amdgpu fan: 621
  Packages: pm: pacman pkgs: 1475 libs: 372 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/testing/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    3: https://mirrors.manjaro.org/repo/testing/$repo/$arch
Processes:
  CPU top: 5 of 584
  1: cpu: 10.3% command: firefox pid: 353599 mem: 623.5 MiB (1.9%)
  2: cpu: 4.5% command: firefox pid: 361423 mem: 446.0 MiB (1.3%)
  3: cpu: 3.9% command: kwin_wayland pid: 1634 mem: 1113.6 MiB (3.4%)
  4: cpu: 3.7% command: firefox pid: 359259 mem: 448.7 MiB (1.4%)
  5: cpu: 3.0% command: firefox pid: 4571 mem: 1629.6 MiB (5.0%)
  Memory top: 5 of 584
  1: mem: 1629.6 MiB (5.0%) command: firefox pid: 4571 cpu: 3.0%
  2: mem: 1260.2 MiB (3.9%) command: firefox pid: 7375 cpu: 0.8%
  3: mem: 1189.4 MiB (3.7%) command: firefox pid: 34867 cpu: 0.9%
  4: mem: 1113.6 MiB (3.4%) command: kwin_wayland pid: 1634 cpu: 3.9%
  5: mem: 1104.9 MiB (3.4%) command: firefox pid: 10726 cpu: 2.2%
  Processes: 584 Power: uptime: 2d 1h 23m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 4 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Make sure your system is fully up-to-date. There was a Testing update yesterday:
That update includes kwin version 6.5.4-3, as shown in my logs:
[2025-12-13T16:28:53+1100] [ALPM] upgraded kwin (6.5.4-1 -> 6.5.4-3)
That hopefully should fix the issue:
The last few comments from that bug report:
Comment 30 Belanthiel 2025-12-12 20:59:51 UTC
Installed the updated kwin 6.5.4-2.1 and it does allow the PC to wake from sleep now. It does not however allow the video to recover if I set KDE to dim and then turn off the monitor. I have to unplug the HDMI to regain video (6900XT) when this happens. Till this is resolved I have disabled both dim and turn off monitor in KDE settings.
Comment 31 Perfect Gentleman 2025-12-13 05:09:37 UTC
I’ve set “Turn off screen” to “Never” so far it’s okay.
Comment 32 Belanthiel 2025-12-13 07:09:23 UTC
With kwin 6.5.4-3.1 everything seems to be working well again. Will let it sleep tonight with dim, and turn screen off enabled.
I appreciate the time you put into it, and I am glad to know it is solved. I knew there was an update, but I noticed it just after this bug surfaced, and I thought I’d document it and report it before proceeding with the update.
Thank you!
