Hi all. I noticed some random panel and window freezes on KDE.
Any components of the desktop can be frozen: dolphin windows, the taskbar (panel) and even the start menu.
KDE Plasma Version: 5.25.5
KDE Frameworks Version: 5.97.0
Qt Version: 5.15.5
Kernel Version: 5.19.7-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × AMD Ryzen 5 2400G with Radeon Vega Graphics
Memory: 29.3 GiB of RAM
Graphics Processor: AMD Radeon Vega 11 Graphics
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B450M H
I suspect this is because of the Intellij IDEA that is open at the moment. I use IntelliJ IDEA 2022.2.2 (Community Edition) Build #IC-222.4167.29, which was downloaded via Jetbrains Toolbox. I rebooted the system several times, I meet this behavior every time.
UPD. I was right, the taskbar “freezes” and stops responding to the mouse cursor after switching to the IDEA window. This appears to be due to the active IDEA window (even if it is hidden by another window). Minimizing the window solves the problem… sometimes.
If this issue appears without reboot, then check journalctl -p err -b 0 --no-page that will show some error messages.
I have no issue with Intellij IDEA Ultimate Edition (from the official website) on KDE Plasma 5.25 Wayland on AMD system. It looks smooth to me.
But I use my customize KDE theme very close to “vanilla” (a uncustomized version) KDE theme. I’m not fan of any heavy custom theme e.g. third-party theme app that would not be compatible with KDE 5.25 or newer in the future.
$ journalctl -p err -b 0 --no-page
сен 30 04:13:58 baroness-b450mh kernel: kvm: support for 'kvm_amd' disabled by bios
сен 30 04:14:00 baroness-b450mh kernel: kvm: support for 'kvm_amd' disabled by bios
сен 30 04:14:03 baroness-b450mh kded5[596]: org.kde.plasma.dataengine.geolocation: error: "Неизвестный узел location.services.mozilla.com: Узел не найден"
сен 30 04:14:07 baroness-b450mh wpa_supplicant[659]: bgscan simple: Failed to enable signal strength monitoring
сен 30 04:14:29 baroness-b450mh pulseaudio[922]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
No, I still see that issue sometimes. There are no anything different at journalctl -p err -b 0 --no-page.
Can I downgrade KDE to 2.24? Before 2.25.5 everything was perfect.
Longer answer: Create a new user, see if problems persist. If they don’t, you just have to selectively clean your ~/.config and perhaps ~/.cache to get rid of old plasma settings.
Same here, I forgot to backup everything(but it’s done now…a bit late though).
So I dunno take a thumb drive(or other) and try to reinstall with your ISO. If it’s Plasma version 2.24 you might be saved(hence, do NOT update your system).
Otherwise, you’ll just have to ride this out till 5.26 ends up in Stable Branch. And, that’s not for tomorrow: 5.26 is previewed for October 6, and not before… So Testing Branch are going to see what gives before anything hits Stable. You are forewarned
The problem is that sometimes I can work for several hours without problems until the freezes begin. After creating a new user, I can’t be sure that this problem won’t come back to me
I usually create a timeshift snapshot before updating and delete it after a while if everything is fine. And everything was really normal, the problems did not start right away
Maybe now I just have to be patient and wait for the release of the fix. I can’t believe the Manjaro team merged this version into the stable branch, I’m not the only one with problems
There is little to no chance there will be a fix for “random freezing”. This is what happens over time. If you just installed your system with 5.25, then it might happen when you are on 5.29. And you can’t even be sure it’s (solely) Plasma’s fault. That’s how it is with “random freezes”, sadly - near impossible to pinpoint the cause.
I have been using Manjaro for several years. The last time I reinstalled the system was July 15th, updating every time a stable update came out. Windows works perfectly, I do not see any problems. I didn’t change the system settings, I didn’t install anything new, I literally didn’t change anything - after the update, friezes appeared and these are not only my problems - other users also complain about it
Therefore, it seems to me that something was broken in 2.25, which is why many users began to have similar problems. And I hope KDE will release a fix. I can try reinstalling Manjaro, but I’m afraid I’ll be wasting my time because nothing will change
I’m sad that it’s not possible to stay on the LTS version of KDE. Everything about her was perfect
Or some old settings have become incompatible with new plasma version (I agree this is a bit of a stretch if you reinstalled not even 3 months ago, but still… Also, why are you reinstalling? ). Hence, try a new user, or delete relevant plasma config files and start fresh.
It seems to me you have already answered your question.
If the new user works OK, then the problem must be in your current or old user settings. Finding out what is different, or even ditching the old user would probably go a long way to solving your problem.
Continuing to operate in the old user, in the hope that things will turn out different this time seems, to me, futile.
