Hi everyone,
today I noticed, KDE popup of “Disks & Device” does not open automatically when any USB stick is plugged into my computer for second time. But it works fine with the first time USB plugging into PC after reboot.
I see there is no error in log.
lsusb and lsblk show my USB is present and KDE Dolphin shows it too, but only KDE popup “Disks & Device” Widget does not show it.
Can you check it if you also have the same issue with the latest stable branch of Manjaro?
Steps to reproduce the behavior:
- Your USB stick plugged into your computer.
- KDE popup shows automatically, then remove USB from your computer.
- Again the same USB stick or other USB stick plugged into your computer, if KDE popup works?
I do not know if it is just me or a KDE bug.
