KDE panel crashes when click on wifi
Hey, as the title says my KDE crashes when I open wifi from the panel or when I connect to different wifi sometimes the panel crashes sometimes the whole plasmashell crashes any fix for this?
i read it could be a driver problem but I have AMD and I choose free drivers when I install manjaro for the first time
Is it crashing, or just hanging for a while? Does it restart after a few minutes?
I had this earlier tonight having clicked the wrong network (list kept shuffling) and then immediately tried clicking on the correct one. Panel inaccessible for 3 or 4 minutes then restored by itself; all fine after that.
Does it crash only the panel or the whole plasmashell (everything becomes black, there is no wallpaper)?
Ah, never mind. I just noticed you already wrote that the plasmashell also crashes sometimes.
Close plasmashell in sysguard and open it in terminal. If it crashes, see what is the output and post it here.
so any fix ?
also i keep getting the (Desktop effects have been suspended by another application.
You can resume using the ‘Alt+Shift+F12’ shortcut. ) idk why
Yeah, this is annoying. Some config is conflicting with kwin but it’s not clear which one. For me it happens when I boot with two monitors. Everything is OK with single monitor. I suspect that latte-dock is causing it. I should probably test it by disabling latte at start and see if the issue still appears.
Anyway, countless any other elements may cause this. Reverting to default configs usually fixes.
Fix to what? We still don’t know what is happening. We don’t have this issue on our machines. More info is needed, hence my request for a terminal output, in hope it will reveal the cause or at least point in the right direction.
As said above, you could revert to defaults so delete all panels and create new ones. See if that fixes your problem. Also, the issue could be triggered by a desktop theme, so revert to breeze or manjaro’s default one for a time being.
here is my main problem, I haven’t touched anything at all i installed manjaro and these problems appeared no configs no nothing no latte or any themes BUT i do have 2 monitors so it could be the case for the alt+ctrl+f12 problem.
also i sometimes notice very high usage of the CPU the plasmashell take all of my CPU and that right after i boot up so tbh idk what cause all of that
ngl, at this point im thinking of leaving KDE
Check if baloo is running. Rub htop and see which process is taking the CPU. Also watch IO with iotop.
i just disabled baloo :+1:
And so? Did it get better?
not at all, i was gonna post rn about if i open chrome with 1/2 tabs my CPU and ram go crazy like my CPU go all way to 100% of usage and my 8gb of ram get fully loaded as well
Did you install the OS on HDD? Accessing slow HDD somehow increases CPU usage from my experience - ironically.
You can check disk activity with iotop. If you have any plugins installed in chrome, uninstall them all, restart chrome and test it.
How about providing some system info the good people here can work with? This might reveal a possible issue with your setup, … e.g.:
inxi --full --admin --verbosity=7 --filter --no-host
Also: [HowTo] Provide System Information
:smiley:
System:    Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
           root=UUID=f240b573-164a-4d17-89c2-0344c3da8e3e rw quiet apparmor=1 security=apparmor
           resume=UUID=a51019b5-56cb-4584-9b29-642a44c03a7e udev.log_priority=3
           Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70 serial: <filter> Chassis:
           type: 10 v: Lenovo G50-70 serial: <filter>
           Mobo: LENOVO model: Lancer 5A2 v: NANANANANO DPK serial: <filter> UEFI: LENOVO
           v: 9ACN32WW date: 07/20/2015
Battery:   ID-1: BAT0 charge: 13.8 Wh condition: 13.8/28.5 Wh (48%) volts: 16.3/14.4
           model: Lenovo IdeaPad type: Unknown serial: <filter> status: Full
Memory:    RAM: total: 7.67 GiB used: 2.30 GiB (29.9%)
CPU:       Topology: Dual Core model: Intel Core i7-4510U bits: 64 type: MT MCP arch: Haswell
           family: 6 model-id: 45 (69) stepping: 1 microcode: 26 L2 cache: 4096 KiB
           bogomips: 20762
           Speed: 798 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
           Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush
           cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
           ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
           nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt
           pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2
           ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
           vpid xsave xsaveopt xtopology xtpr
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0a16
           Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo driver: radeon
           v: kernel alternate: amdgpu bus ID: 03:00.0 chip ID: 1002:666f
           Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus ID: 2-6:3
           chip ID: 5986:055d serial: <filter>
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel,radeon
           FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.6x9.3")
           s-diag: 484mm (19.1")
           Monitor-1: DP1 res: 1600x900 hz: 60 dpi: 92 size: 440x250mm (17.3x9.8")
           diag: 506mm (19.9")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.1.6
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:03.0 chip ID: 8086:0a0c
           Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:9c20
           Sound Server: ALSA v: k5.7.17-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 4000 bus ID: 01:00.0 chip ID: 10ec:8168
           IF: enp1s0 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lenovo
           driver: ath9k v: kernel port: 4000 bus ID: 02:00.0 chip ID: 168c:0036
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           Device-3: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb bus ID: 2-7:5
           chip ID: 0cf3:3004
Drives:    Local Storage: total: 931.51 GiB used: 87.62 GiB (9.4%)
           ID-1: /dev/sda vendor: Western Digital model: WD10JPCX-24UE4T0 size: 931.51 GiB
           block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 1A01 scheme: GPT
           Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DA8A5SH rev: RL61 dev-links: cdrom
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%) used: 87.62 GiB (9.7%)
           fs: ext4 dev: /dev/sda2 label: N/A uuid: f240b573-164a-4d17-89c2-0344c3da8e3e
           ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%)
           fs: vfat dev: /dev/sda1 label: N/A uuid: 1664-14E7
           ID-3: /run/timeshift/backup raw size: 922.42 GiB size: <superuser/root required>
           used: <superuser/root required> fs: ext4 dev: /dev/sda2 label: N/A
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.80 GiB used: 524 KiB (0.0%) priority: -2
           dev: /dev/sda3 label: N/A uuid: a51019b5-56cb-4584-9b29-642a44c03a7e
Unmounted: Message: No unmounted partitions found.
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
           chip ID: 8087:8000
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Device-1: 2-2:6 info: Sunplus Innovation Optical Mouse type: Mouse
           driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 1bcf:0007
           Device-2: 2-3:7 info: China Resource Semico USB Keyboard type: Keyboard,HID
           driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s chip ID: 1a2c:2c27
           Device-3: 2-4:2 info: Realtek RTS5129 Card Reader Controller type: <vendor specific>
           driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s
           chip ID: 0bda:0129 serial: <filter>
           Device-4: 2-6:3 info: Acer Lenovo EasyCamera type: Video driver: uvcvideo
           interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:055d serial: <filter>
           Device-5: 2-7:5 info: Qualcomm Atheros AR3012 Bluetooth 4.0 type: Bluetooth
           driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0cf3:3004
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
           chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 50.0 C mobo: N/A gpu: radeon temp: 45 C
Info:      Processes: 194 Uptime: 1h 02m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages:
           pacman: 1287 lib: 385 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
yup i have HDD :frowning:
Check out swappiness. It’s possible it’s set to 60, so it will try to put files into SWAP even if plenty of RAM is still available. This has two effect:
  • HDD will work like crazy and will slow everything, almost to a freeze
  • CPU will start peaking 100% for unknown reasons and stay that way till swap files are copied
With HDD it can take even 10 minutes or more, so it’s like instant freeze and browsers are usually the trigger. Other apps will cause this will be high RAM intensive programs like Thunderbird, compiling packages, etc.
You need to change swappiness value to 10 or less and then be careful not to have too many tabs and sites eating RAM (with multimedia content or heavy scripts).
HDD based systems are high ineffective and meant for very lightweight work.
This happens to me even after 1yr. on an SSD, have anyone of you guys found a fix?
inxi
System:    Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=2c697afe-8b6f-42bc-8b35-dcb1df41810d rw quiet apparmor=1
           security=apparmor resume=UUID=cb61cf2f-d1bf-446f-a80d-b128f9df4ac1 udev.log_priority=3
           Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: HP model: 8575 v: 21.17 serial: <filter> UEFI: AMI v: F.22 date: 05/03/2021
Battery:   ID-1: BAT0 charge: 30.4 Wh (72.6%) condition: 41.9/41.9 Wh (100.0%) volts: 11.6 min: 11.6 model: HP Primary
           type: Li-ion serial: N/A status: Discharging
Memory:    RAM: total: 7.58 GiB used: 2.04 GiB (26.9%)
CPU:       Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
           model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB bogomips: 62431
           Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
           9: 800 10: 800 11: 800 12: 800
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
           clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
           flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
           smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
           vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
           chip-ID: 8086:3e9b class-ID: 0300
           Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Hewlett-Packard driver: nvidia v: 470.63.01
           alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
           Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2 chip-ID: 0408:5300
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
           alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
           OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.37 running: yes
Network:   Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370
           class-ID: 0280
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
           port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
           IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
           Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
           address: see --recommends
Logical:   Message: No logical block device data found.
RAID:      Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
           chip-ID: 8086.282a rev: 10 class-ID: 0104
Drives:    Local Storage: total: 1.14 TiB used: 339.77 GiB (29.0%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB
           block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10112006
           temp: 36.9 C scheme: GPT
           ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB block-size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
Partition: ID-1: / raw-size: 40 GiB size: 39.12 GiB (97.80%) used: 19.59 GiB (50.1%) fs: ext4 dev: /dev/nvme0n1p5
           maj-min: 259:5 label: N/A uuid: 2c697afe-8b6f-42bc-8b35-dcb1df41810d
           ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 82.1 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1
           maj-min: 259:1 label: SYSTEM uuid: C6FD-5E16
           ID-3: /home raw-size: 58.91 GiB size: 57.73 GiB (98.00%) used: 15.41 GiB (26.7%) fs: ext4 dev: /dev/nvme0n1p6
           maj-min: 259:6 label: N/A uuid: eee647e3-a6c8-4566-9751-88fcfe638cab
           ID-4: /run/media/sayan/Backup raw-size: 103.05 GiB size: 103.05 GiB (100.00%) used: 26.1 GiB (25.3%) fs: btrfs
           dev: /dev/sda2 maj-min: 8:2 label: Backup uuid: afe6cea4-70eb-4e7d-96b4-36cdc962c1d1
           ID-5: /run/media/sayan/Data raw-size: 431.51 GiB size: 431.51 GiB (100.00%) used: 118.4 GiB (27.4%) fs: ntfs
           dev: /dev/sda1 maj-min: 8:1 label: Data uuid: BAB0F348B0F30A21
           ID-6: /run/media/sayan/Linux-Data raw-size: 196.95 GiB size: 192.8 GiB (97.89%) used: 76.01 GiB (39.4%) fs: ext4
           dev: /dev/sda4 maj-min: 8:4 label: Linux-Data uuid: f0b07ff7-7a5b-4ece-8554-0ae7d30a724a
           ID-7: /run/media/sayan/Windows raw-size: 134.75 GiB size: 134.75 GiB (100.00%) used: 84.19 GiB (62.5%) fs: ntfs
           dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: 72962F96962F59BD
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
           label: N/A uuid: cb61cf2f-d1bf-446f-a80d-b128f9df4ac1
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
           ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 558 MiB fs: ntfs label: N/A uuid: 4C1CDE5B1CDE401E
           ID-3: /dev/sda3 maj-min: 8:3 size: 200 GiB fs: ntfs label: Study uuid: 1880FD5780FD3C36
USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 1-6:2 info: Quanta HP Wide Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s power: 500mA chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
           Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb interfaces: 2
           rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0aaa class-ID: e001
           Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Info:      Processes: 314 Uptime: 11m wakeups: 1 Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
           Packages: pacman: 1342 lib: 401 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
Swappiness is at 10
I have the same issue on my ideapad 5 pro 16 ACH with a mediatek wifi chip
