Continuing the discussion from KDE panel crashes when click on wifi:
Sometimes, clicking on the wifi widget, makes the entire panel, and plasma in general freeze( krunner, application launcher,yakuake, event calendar, etc.). The previous forum answers( a year ago) didn’t give any conclusive answer so I’m creating this topic.
inxi --full --admin --verbosity=7 --filter --no-host:
System: Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=2c697afe-8b6f-42bc-8b35-dcb1df41810d rw quiet apparmor=1
security=apparmor resume=UUID=cb61cf2f-d1bf-446f-a80d-b128f9df4ac1 udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 8575 v: 21.17 serial: <filter> UEFI: AMI v: F.22 date: 05/03/2021
Battery: ID-1: BAT0 charge: 30.4 Wh (72.6%) condition: 41.9/41.9 Wh (100.0%) volts: 11.6 min: 11.6 model: HP Primary
type: Li-ion serial: N/A status: Discharging
Memory: RAM: total: 7.58 GiB used: 2.04 GiB (26.9%)
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Hewlett-Packard driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2 chip-ID: 0408:5300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370
class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Logical: Message: No logical block device data found.
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
chip-ID: 8086.282a rev: 10 class-ID: 0104
Drives: Local Storage: total: 1.14 TiB used: 339.77 GiB (29.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10112006
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
Partition: ID-1: / raw-size: 40 GiB size: 39.12 GiB (97.80%) used: 19.59 GiB (50.1%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 2c697afe-8b6f-42bc-8b35-dcb1df41810d
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 82.1 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: C6FD-5E16
ID-3: /home raw-size: 58.91 GiB size: 57.73 GiB (98.00%) used: 15.41 GiB (26.7%) fs: ext4 dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: eee647e3-a6c8-4566-9751-88fcfe638cab
ID-4: /run/media/sayan/Backup raw-size: 103.05 GiB size: 103.05 GiB (100.00%) used: 26.1 GiB (25.3%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2 label: Backup uuid: afe6cea4-70eb-4e7d-96b4-36cdc962c1d1
ID-5: /run/media/sayan/Data raw-size: 431.51 GiB size: 431.51 GiB (100.00%) used: 118.4 GiB (27.4%) fs: ntfs
dev: /dev/sda1 maj-min: 8:1 label: Data uuid: BAB0F348B0F30A21
ID-6: /run/media/sayan/Linux-Data raw-size: 196.95 GiB size: 192.8 GiB (97.89%) used: 76.01 GiB (39.4%) fs: ext4
dev: /dev/sda4 maj-min: 8:4 label: Linux-Data uuid: f0b07ff7-7a5b-4ece-8554-0ae7d30a724a
ID-7: /run/media/sayan/Windows raw-size: 134.75 GiB size: 134.75 GiB (100.00%) used: 84.19 GiB (62.5%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: 72962F96962F59BD
Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: cb61cf2f-d1bf-446f-a80d-b128f9df4ac1
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 558 MiB fs: ntfs label: N/A uuid: 4C1CDE5B1CDE401E
ID-3: /dev/sda3 maj-min: 8:3 size: 200 GiB fs: ntfs label: Study uuid: 1880FD5780FD3C36
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-6:2 info: Quanta HP Wide Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 314 Uptime: 11m wakeups: 1 Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 1342 lib: 401 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
