KDE error for sddm-greeter: Could not find the Qt platform plugin „xcb obs“ in
Hi guys,
after this topic has been split out of the original, I will give more context to my problem.
This is a Manjaro KDE edition install and I guess this specific one has been installed with 20.x something, if not 19. I have only very few customizations, and none to the base system, just in the GUI. I mainly use Plasma X11, but have tried the Wayland Session from time to time to see the state of affairs.
This last round of updates (21.1.0 → 21.1.1) broke my sddm and plasma session. System boots up with a blank screen and mouse cursor. I can switch to a tty.
journalctl -b0 -p4 reveals an error for sddm-greeter: Could not find the Qt platform plugin „xcb obs“ in „“
I did try to get obs to work last week but was unsuccessful with screencapture in a wayland session. I did not change anything, I just installed one obs plugin that was supposed to make it work with waylan. Everything worked, even after reboots.
I tried uninstalling obs, but this did not help. I don’t even know if the current sddm or plasma problem stems from obs, I just assumed due to the error message above.
I setup ssh so I can easily access logs and stuff from outside to post here if needed.
I also stopped sddm and tried to start a manual plasma session, either wayland or xorg. both do not start up as they used to.
Any idea/help welcome :pray:
EDIT: As adviced I am updating with system information:
  Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/vmlinuz-5.13-x86_64
  root=UUID=b7a1223e-c31d-42b9-866e-e07dade54bce rw quiet apparmor=1
  security=apparmor resume=UUID=4b8fcfa2-ea30-44ee-b932-b8b6b466dc67
  udev.log_priority=3
  Console: tty pts/0 DM: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: Z390 GAMING X v: N/A serial: N/A
  Mobo: Gigabyte model: Z390 GAMING X-CF v: x.x serial: N/A
  UEFI: American Megatrends v: F10i date: 01/19/2021
  RAM: total: 31.29 GiB used: 766.6 MiB (2.4%)
  Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
  note: est.
  Device-1: ChannelA-DIMM0 size: 8 GiB speed: 3200 MT/s type: DDR4
  detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: G.Skill
  part-no: F4-3200C16-8GVKB serial: N/A
  Device-2: ChannelA-DIMM1 size: 8 GiB speed: 3200 MT/s type: DDR4
  Device-3: ChannelB-DIMM0 size: 8 GiB speed: 3200 MT/s type: DDR4
  Device-4: ChannelB-DIMM1 size: 8 GiB speed: 3200 MT/s type: DDR4
  Info: 8-Core model: Intel Core i7-9700K socket: LGA1151 (U3E1) note: check
  bits: 64 type: MCP arch: Kaby Lake note: check family: 6 model-id: 9E (158)
  stepping: D (13) microcode: EA cache: L1: 512 KiB L2: 12 MiB L3: 12 MiB
  bogomips: 57616
  Speed: 800 MHz min/max: 800/4900 MHz base/boost: 4600/8300 volts: 1.2 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
  6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
  vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 03:00.0
  chip-ID: 1002:731f class-ID: 0300
  Device-2: Lenovo 500 RGB Camera type: USB driver: uvcvideo bus-ID: 1-2:3
  chip-ID: 17ef:482f class-ID: 0e02 serial: <filter>
  Display: server: X.org 1.20.13 driver: loaded: amdgpu,ati
  unloaded: modesetting,radeon alternate: fbdev,vesa tty: 152x37
  Message: Advanced graphics data unavailable in console for root.
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
  bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Device-2: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
  driver: brcmfmac v: kernel port: 3000 bus-ID: 06:00.0 chip-ID: 14e4:43ba
  class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB
  driver: btusb,hid-generic,usbhid bus-ID: 1-12:7 chip-ID: 05ac:8290
  class-ID: fe01
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
  bt-service: enabled,running rfk-block: hardware: no software: no
  address: <filter>
  Local Storage: total: 3.64 TiB used: 172.25 GiB (4.6%)
  model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  SMART: yes health: PASSED on: 343d 23h cycles: 2,693
  read-units: 19,533,212 [10.0 TB] written-units: 14,549,447 [7.44 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
  rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
  SMART: yes health: PASSED on: 263d 15h cycles: 2,706
  read-units: 27,444,962 [14.0 TB] written-units: 7,996,501 [4.09 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
  family: Micron Client SSDs size: 1.82 TiB block-size: physical: 4096 B
  logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023
  temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 371d 22h cycles: 2666
  written: 15.44 TiB
  ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
  family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
  logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter> rev: 033
  temp: 32 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 182d 1h cycles: 1105
  written: 4.21 TiB
  ID-1: / raw-size: 244.14 GiB size: 239.31 GiB (98.02%)
  used: 172.19 GiB (72.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb4
  maj-min: 8:20 label: N/A uuid: b7a1223e-c31d-42b9-866e-e07dade54bce
  ID-2: /boot raw-size: 1024 MiB size: 975.9 MiB (95.30%)
  used: 63.5 MiB (6.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
  maj-min: 8:18 label: N/A uuid: c1bf9228-b7ac-4044-a466-ff273d643336
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
  used: 344 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
  label: N/A uuid: 22C9-F4C2
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: 4b8fcfa2-ea30-44ee-b932-b8b6b466dc67
  ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 100 MiB fs: vfat label: SYSTEM
  uuid: 50CC-B6EE
  ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 128 MiB fs: N/A label: N/A
  uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 464.9 GiB fs: ntfs label: Windows
  uuid: 4E38CED738CEBCE9
  ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 650 MiB fs: ntfs
  label: Recovery image uuid: D2C0CF11C0CEFAAD
  ID-5: /dev/nvme1n1p1 maj-min: 259:3 size: 200 MiB fs: vfat label: EFI
  uuid: 67E3-17ED
  ID-6: /dev/nvme1n1p2 maj-min: 259:4 size: 465.57 GiB fs: apfs label: N/A
  uuid: d70e6a0b-517d-4008-96fa-ad4c7056d840
  ID-7: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI
  uuid: 67E3-17ED
  ID-8: /dev/sda2 maj-min: 8:2 size: 1.36 TiB fs: apfs label: N/A
  uuid: d1866be0-3b7b-41d5-87eb-54f4b4062f33
  ID-9: /dev/sda3 maj-min: 8:3 size: 465.54 GiB fs: ntfs label: WindowsData
  uuid: 54985531985512BA
  ID-10: /dev/sdb5 maj-min: 8:21 size: 678.08 GiB fs: ntfs label: Gaming
  uuid: 1040C41E40C40C82
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 2109:2812 class-ID: 0900
  Device-1: 1-2:3 info: Lenovo 500 RGB Camera type: Video driver: uvcvideo
  interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 17ef:482f
  Device-2: 1-9:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-3: 1-10:5 info: Logitech Gaming Mouse G300 type: Mouse,Keyboard
  power: 200mA chip-ID: 046d:c246 class-ID: 0300
  Device-4: 1-11:6 info: Razer USA Razer Chroma Addressable RGB Controller
  type: HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1532:0f1f class-ID: 0300
  Device-5: 1-12:7 info: Apple Bluetooth Host Controller
  type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid
  interfaces: 6 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8290 class-ID: fe01
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-4: 2-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 2109:0812 class-ID: 0900
  System Temperatures: cpu: 59.0 C mobo: 27.8 C gpu: amdgpu temp: 46.0 C
  mem: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 252 Uptime: 1m wakeups: 0 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1609 pacman: 1600 lib: 450
  flatpak: 9 Shell: Zsh (sudo) v: 5.8 running-in: tty pts/0 (SSH) inxi: 3.3.06 ```
Plasma? On Wayland??? :scream:
Go back to Xorg until KDE decides to make Wayland the default…
:crossed_fingers:
This happens regardless if I use wayland OR xorg…
Only now saw that you’re very new here, so:
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
Hi, thanks for the welcome. I am actually not a new Linux user OR a new manjaro user at that. Have been here for years and using manjaro for quite some. Using Linux since the early 90s, although I am now mostly on macOS and Windows due to work, I still sport Manjaro on my home Desktop and Home laptop.
Somehow, my old forum user was deleted after years of not using it, and I could not revive it, so I created a new one :slight_smile:
I updated my post above with the info you requested and am happy to provide ANY and ALL info you need and want and am glad about any help I might recieve.
Found the error.
Just in case anybody else ever stumbles over that problem: It was an environment variable that I myself put into place because of obs and wayland tests in /etc/environment
→ QT_QPA_PLATFORM=xcb obs
my sddm and kde did work without problem, even through reboots. Somehow, something in the update broke, but without this, it works again!
So, I ended up removing obs and yeah, thats that.
