Hello i have a issue with scrolling when i scroll down is sometimes scrolls up and down and its a reall mess its making scrolling pages and playing games impossible for me cant attacha video (whyy) It happens on any DE and ive tried evdev drivers and libinput drivers no luck tried posing on r/manjaro linux no answers i hope someone answers me here
Hello, please read here:
https://forum.manjaro.org/t/how-to-provide-good-information/
I think you’ll get more responses if you provide more detail.
Which apps does it occur. Just the browser or others?
Does this fault occur when your system is loaded or at all times. By loaded, I mean running the browser with 100 tabs or playing 4K video.
When did it first appear? Immediately after installation or after a system update? What other events/changes happened between installation and the first occurrence of the fault.
Have you checked the logs at the time it occurs?
I think it’s to do with new user restrictions;
you must prove yourself a genuine user and not a spambot. ![]()
Next time, refer the user posing a question like this here:
Difficulty: ★☆☆☆☆ You’ve probably been sent here by a more experienced user because you cannot post links nor screenshotsso please follow the simple instructions of this tutorial below to allow you to post both screenshots and links in any post and have a short explanation of why you can’t do this easily…
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial itself. If you …
Please? Pretty please with
and
It occurs everywhere and at all times strange how i didnt notice when it appeared but it was around a month ago it happens only on manjaro havent checked logs i dunno how but im pretty sure theres something wrong with a driver Imgur: The magic of the Internet
IMGUR doesn’t always work:
Therefore, better use the methodology in the [HowTo] described above
An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=4a577d1f-0744-4967-befe-53f2ca3c6c42 rw quiet splash apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, vala-panel, plank
wm: xfwm4 dm: GDM 3.38.2.1, LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: 960GM-GS3 FX serial: <filter>
BIOS: American Megatrends v: P1.10 date: 09/22/2011
Info: Triple Core model: AMD Athlon II X3 450 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 5 stepping: 3 microcode: 10000C8 L2 cache: 1.5 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 19243
Speed: 800 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 2000 2: 800
3: 800
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM] vendor: Tul
driver: radeon v: kernel alternate: amdgpu bus ID: 01:00.0
chip ID: 1002:6811 class ID: 0300
Display: x11 server: X.org 1.20.10 driver: loaded: ati,radeon
unloaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.5 Mesa 20.3.4 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383 class ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Tul driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aab0 class ID: 0403
Device-3: Logitech Webcam Pro 9000 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 2-2:3 chip ID: 046d:0809 class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: ASRock driver: r8169 v: kernel port: e800 bus ID: 02:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus ID: 3-3:2 chip ID: 0a12:0001 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.59 TiB used: 162.64 GiB (10.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3750641NS EIT
size: 698.64 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 4LEW scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-60WN4A1
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A03 scheme: MBR
ID-1: / raw size: 93.13 GiB size: 91.17 GiB (97.89%) used: 30.4 GiB (33.3%)
fs: ext4 dev: /dev/sdb8 maj-min: 8:24
ID-2: /home raw size: 229.92 GiB size: 225.31 GiB (98.00%)
used: 132.24 GiB (58.7%) fs: ext4 dev: /dev/sdb7 maj-min: 8:23
ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 28.5 C mobo: N/A gpu: radeon temp: 36.0 C
Processes: 203 Uptime: 5m wakeups: 0 Memory: 7.77 GiB used: 2.06 GiB (26.5%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1674 lib: 483
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.3.01
~ >>> sudo dmesg | grep usb
[sudo] password for rippanda12:
[ 0.328952] usbcore: registered new interface driver usbfs
[ 0.328952] usbcore: registered new interface driver hub
[ 0.331975] usbcore: registered new device driver usb
[ 0.459113] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x6e0 took 89184 usecs
[ 0.485768] pci 0000:00:12.1: quirk_usb_early_handoff+0x0/0x6e0 took 26016 usecs
[ 0.509112] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x6e0 took 22570 usecs
[ 0.532437] pci 0000:00:13.1: quirk_usb_early_handoff+0x0/0x6e0 took 22762 usecs
[ 0.555773] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x6e0 took 22552 usecs
[ 1.023724] usbcore: registered new interface driver usbserial_generic
[ 1.023730] usbserial: USB Serial support registered for generic
[ 1.875444] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.875445] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.875447] usb usb1: Product: EHCI Host Controller
[ 1.875448] usb usb1: Manufacturer: Linux 5.9.16-1-MANJARO ehci_hcd
[ 1.875449] usb usb1: SerialNumber: 0000:00:12.2
[ 1.888759] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.888761] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.888762] usb usb2: Product: EHCI Host Controller
[ 1.888763] usb usb2: Manufacturer: Linux 5.9.16-1-MANJARO ehci_hcd
[ 1.888764] usb usb2: SerialNumber: 0000:00:13.2
[ 1.949423] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 1.949426] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.949427] usb usb3: Product: OHCI PCI host controller
[ 1.949428] usb usb3: Manufacturer: Linux 5.9.16-1-MANJARO ohci_hcd
[ 1.949429] usb usb3: SerialNumber: 0000:00:12.0
[ 2.009415] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 2.009417] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.009418] usb usb4: Product: OHCI PCI host controller
[ 2.009419] usb usb4: Manufacturer: Linux 5.9.16-1-MANJARO ohci_hcd
[ 2.009420] usb usb4: SerialNumber: 0000:00:12.1
[ 2.069405] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 2.069407] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.069409] usb usb5: Product: OHCI PCI host controller
[ 2.069410] usb usb5: Manufacturer: Linux 5.9.16-1-MANJARO ohci_hcd
[ 2.069410] usb usb5: SerialNumber: 0000:00:13.0
[ 2.129423] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 2.129425] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.129426] usb usb6: Product: OHCI PCI host controller
[ 2.129427] usb usb6: Manufacturer: Linux 5.9.16-1-MANJARO ohci_hcd
[ 2.129428] usb usb6: SerialNumber: 0000:00:13.1
[ 2.189443] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 2.189445] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.189446] usb usb7: Product: OHCI PCI host controller
[ 2.189447] usb usb7: Manufacturer: Linux 5.9.16-1-MANJARO ohci_hcd
[ 2.189448] usb usb7: SerialNumber: 0000:00:14.5
[ 2.425336] usb 5-1: new full-speed USB device number 2 using ohci-pci
[ 2.488677] usb 3-3: new full-speed USB device number 2 using ohci-pci
[ 2.609419] usb 5-1: New USB device found, idVendor=2563, idProduct=0575, bcdDevice= 2.01
[ 2.609421] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.609423] usb 5-1: Product: PS3/PC Gamepad
[ 2.609424] usb 5-1: Manufacturer: SHANWAN
[ 2.620663] usbcore: registered new interface driver usbhid
[ 2.620665] usbhid: USB HID core driver
[ 2.623368] input: SHANWAN PS3/PC Gamepad as /devices/pci0000:00/0000:00:13.0/usb5/5-1/5-1:1.0/0003:2563:0575.0001/input/input2
[ 2.623456] hid-generic 0003:2563:0575.0001: input,hidraw0: USB HID v1.10 Gamepad [SHANWAN PS3/PC Gamepad] on usb-0000:00:13.0-1/input0
[ 2.696435] usb 3-3: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=31.64
[ 2.696437] usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.102000] usb 1-4: new high-speed USB device number 3 using ehci-pci
[ 3.115336] usb 2-2: new high-speed USB device number 3 using ehci-pci
[ 3.249298] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 3.249300] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.249302] usb 1-4: Product: USB 2.0 Hub
[ 3.481681] usb 2-2: New USB device found, idVendor=046d, idProduct=0809, bcdDevice= 0.10
[ 3.481683] usb 2-2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 3.481685] usb 2-2: SerialNumber: 9BB11DA3
[ 3.628669] usb 1-4.1: new high-speed USB device number 4 using ehci-pci
[ 3.826011] usb 1-4.1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 3.826013] usb 1-4.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.826015] usb 1-4.1: Product: USB 2.0 Hub
[ 3.998669] usb 1-4.2: new high-speed USB device number 5 using ehci-pci
[ 4.195989] usb 1-4.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 4.195991] usb 1-4.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.195992] usb 1-4.2: Product: USB 2.0 Hub
[ 4.575333] usb 1-4.2.1: new full-speed USB device number 6 using ehci-pci
[ 4.776703] usb 1-4.2.1: New USB device found, idVendor=24ae, idProduct=2010, bcdDevice= 1.10
[ 4.776705] usb 1-4.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.776706] usb 1-4.2.1: Product: Rapoo 2.4G Wireless Device
[ 4.776707] usb 1-4.2.1: Manufacturer: RAPOO
[ 4.778612] input: RAPOO Rapoo 2.4G Wireless Device as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.1/1-4.2.1:1.0/0003:24AE:2010.0002/input/input3
[ 4.778686] hid-generic 0003:24AE:2010.0002: input,hidraw1: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:12.2-4.2.1/input0
[ 4.781250] input: RAPOO Rapoo 2.4G Wireless Device System Control as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.1/1-4.2.1:1.1/0003:24AE:2010.0003/input/input5
[ 4.835392] input: RAPOO Rapoo 2.4G Wireless Device Consumer Control as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.1/1-4.2.1:1.1/0003:24AE:2010.0003/input/input6
[ 4.835472] hid-generic 0003:24AE:2010.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:12.2-4.2.1/input1
[ 4.837065] input: RAPOO Rapoo 2.4G Wireless Device as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.1/1-4.2.1:1.2/0003:24AE:2010.0004/input/input7
[ 4.892084] hid-generic 0003:24AE:2010.0004: input,hidraw3: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:12.2-4.2.1/input2
[ 5.065346] usb 1-4.2.4: new full-speed USB device number 7 using ehci-pci
[ 5.264421] usb 1-4.2.4: New USB device found, idVendor=1ea7, idProduct=0064, bcdDevice= 2.00
[ 5.264423] usb 1-4.2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.264425] usb 1-4.2.4: Product: 2.4G Mouse
[ 5.267154] input: 2.4G Mouse as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.4/1-4.2.4:1.0/0003:1EA7:0064.0005/input/input8
[ 5.267179] input: 2.4G Mouse as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4.2/1-4.2.4/1-4.2.4:1.0/0003:1EA7:0064.0005/input/input9
[ 5.267254] hid-generic 0003:1EA7:0064.0005: input,hiddev1,hidraw4: USB HID v1.10 Mouse [2.4G Mouse] on usb-0000:00:12.2-4.2.4/input0
[ 13.982056] usb 2-2: reset high-speed USB device number 3 using ehci-pci
[ 14.565486] usbcore: registered new interface driver btusb
[ 14.778554] usb 2-2: set resolution quirk: cval->res = 384
[ 14.778907] usbcore: registered new interface driver snd-usb-audio
[ 14.818468] input: UVC Camera (046d:0809) as /devices/pci0000:00/0000:00:13.2/usb2/2-2/2-2:1.0/input/input22
[ 14.818886] usbcore: registered new interface driver uvcvideo
Heres more info any ways on how to attach the video lmk
5.9.16-1-MANJARO
That kernel is EOL. Upgrade to 5.4 LTS or 5.10 (which is an LTS candidate)
Could you also elaborate on how you scroll?
- Keyboard
- Mouse wheel
- TrackPoint / TrackPad
Are the symptoms similar with all of the above?
i use mouse wheel only but scrolling with the arrows is fine will try upgrating to a lts kernel
EDIT: updating the kerned did nothing
anything to provide?
Does this also happen in a newly created user (E.G. rippanda13)
Yes it does I dont know whats causing it i tried different kernels DE’s compositors nothing still that wierd and jumpy scroll making it impossible to play games
Desktop: Xfce
and I’m on KDE, so I can’t help you any further. I did edit your post and added a few tags to attract people better suited to help you.
I tried installing a different distro same issue theres no info on the net Kubuntu is what i tried same issue
In that case: Have you tried a different mouse??? (Sorry for not asking that first)
Yep ive tried different mice same also i hope this works to better show the issue ive shot it in gnome but its the same for XFCE KDE GNOME OPENBOX CINNAMON https://youtu.be/zrJ2_YPV3x4
The video contains me scrolling ONLY down
No further clue then. Let’s wait for an XFCE expert…
Solved Turns out my mouse was nasty on the inside and the scroll was doing something i dont know but i cleaned it and it works fine but im confused why it didnt do it in windows
I’m confused: so you’ve changed/cleaned your mouse?
cleaned it stopped doing the jumpy scroll and now its starting to do it again
i dunno whats happening
Have you tried a different brand of mouse when you used another one?
(this really smells like a hardware problem)
P.S. Removed the Solution otherwise you will definitely not attract smarter people than me!
