Damn i think i misread, i only have 1 (nvidia) GPU. I should uninstall 450xx,
and reinstall nvidia 450xx. Is there any guide you’d recommend?
Yes, you do have just one dGPU = Nvidia (dedicated GPU)
That GPU is supported by the 450xx drivers you have already installed.
The iGPU is the AMD one (integrated GPU). If your system works, then you can let it enabled. Do a test with it disabled. In that case the only driver you have to remove is the video-linux
If you insist on reinstalling the video-nvidia-450xx
driver, then the /etc/X11/mhwd.d/nvidia.conf file will be rewritten to default.
As i mentioned here
regarding the nvidia-settings --load-config-only
failing to load at startup. So it might be an issue that needs addressed elsewhere.
For what exactly? We just went trough the install and custom config part
Oh i thought me dont being able to save the configs was primarily related to having selected non-free drivers and that that was reflected on having a non nvidia driver
For disabling the igpu -that i now get what it is-. I understood you suggested it may solve the issue
Im going to try this first
Ive just replaced video-nvidia-450xx with video-hybrid-amd-nvidia-450xx-prime, since i forgot it was the default from the Auto-Installer. No noticeable changes even after repasting your nvidia.conf. Would you advice downgrading the 450xx with any other .ver in particular? Im open to follow any suggestions
ps. I succeeded in applying the GWE recommended custom fan profile, althought im at a loss when trying to set the min and max clock speed.
ps2. Im not sure if its worth mentioning, when i sudo nvidia-settings, I get
(nvidia-settings:1841): GLib-GObject-CRITICAL **: 09:12:45.721: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
If you open Nvidia X Server Settings, do you have options in it?
Why are you using sudo
If you do that and save the .nvidia-settings-rc
has no longer your permissions and ownership. Because of that it will fail to load. There, now you know why is not working
Since you went the road on installing video-hybrid-amd-nvidia-450xx-prime
when i don’t think has any positive effect installed on a Desktop PC where the dGPU is totally independent from the iGPU, then try them all
Yes “Sync to this display device” -Auto -VGA-0
Ouch, because at the start of this journey if i didnt use sudo it wouldnt let me save the display config and from then on i continued using it
Okay so, i could save the .nvidia-settings-rc in my /home, but the issue persists …
You can’t save it in another place to take effect when you log in. It needs to be there and with your user permission and ownership.
Im not entirely sure where my /home is, i may have changed it some days ago. : /
