Hey, running nvidia 450xx and kernel 5.4, massive stutters and fps drops, cant get the nvidia configs to save [OpenGL high performance and PowerMIzer prefer max performance, saved as .nvidia-settings-rc, edited the xinit:
exec nvidia-settings --load-config-only
exec $(get_session)
Doesnt work.
probably because i chose free drivers by mistake. Im trying to reinstall manjaro but booting from the old usb gets stuck in “ a start job in running for livemedia mhwd script
Know of any different way of reinstalling it or solving the drivers issue without having the need for it?. Thanks
Hello,
Can we have a confirmation that by
you refer to the ~/.xinitrc
aka the .xinitrc
in your home directory?
This in the Live Media or when? If you installed the 450xx by MHWD and previously of that you removed video-linux
and rebooted the system, then the nonfree drivers are loaded.
That can be caused by something else. Please provide from your installed system:
inxi -Fxza --no-host
mhwd -li
cat /etc/X11/mhwd.d/nvidia.conf
Yes
I installed manjaro kde from rufus live usb, and chose free drivers :))
wow i didnt know that. Should I uninstall 450xx, remove video-linux, and reinstall?
System: Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=20da062c-e348-4031-b050-7cbb1fc46c9e rw quiet apparmor=1 security=apparmor
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0 serial: <filter>
UEFI: American Megatrends v: 8.3 date: 04/07/2016
CPU: Topology: Quad Core model: AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G bits: 64
type: MCP arch: Steamroller family: 15 (21) model-id: 30 (48) stepping: 1
microcode: 6003106 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 24760
Speed: 2183 MHz min/max: 1400/3100 MHz boost: enabled Core speeds (MHz): 1: 2312
2: 2131 3: 2365 4: 2383
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Kaveri [Radeon R7 Graphics] vendor: Micro-Star MSI driver: radeon
v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:1313
Device-2: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia v: 450.66
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1380
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia display ID: :0
screens: 1
Screen-1: 0 s-res: 1368x768 s-dpi: 75 s-size: 463x260mm (18.2x10.2")
s-diag: 531mm (20.9")
Monitor-1: VGA-0 res: 1368x768 hz: 60
OpenGL: renderer: GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Audio: Device-1: AMD Kaveri HDMI/DP Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:1308
Device-2: AMD FCH Azalia vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbc
Device-4: Focusrite-Novation Scarlett 18i8 type: USB driver: snd-usb-audio
bus ID: 4-2:3 chip ID: 1235:8014 serial: <filter>
Sound Server: ALSA v: k5.4.64-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8168 v: 8.048.03-NAPI modules: r8169 port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 937.12 GiB used: 780.48 GiB (83.3%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: B1E1 scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST3750640NS size: 698.64 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: L scheme: MBR
ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Blade size: 14.91 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 2.01 scheme: MBR
Partition: ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%) used: 94.71 GiB (43.3%) fs: ext4
dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 11.4 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 30 C fan: 32% device: radeon temp: 15 C
Info: Processes: 214 Uptime: 1h 37m Memory: 6.82 GiB used: 3.59 GiB (52.6%) Init: systemd
v: 246 Compilers: gcc: 10.2.0 Packages: 1486 pacman: 1476 lib: 463 flatpak: 10
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
video-nvidia-450xx 2019.10.25 false PCI
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 450.66
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 450.66
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Section "Monitor"
# HorizSync source: builtin, VertRefresh source: builtin
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 28.0 - 55.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 750 Ti"
Option "NoLogo" "1"
EndSection
Section "Screen"
# Removed Option "metamodes" "1368x768 +0+0"
# Removed Option "metamodes" "1368x768_60 +0+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "CRT-0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
BTW really appreciate it
Ok, so you have a Desktop PC with iGPU from AMD + dGPU Nvidia GeForce GTX 750 Ti. Your monitor is connected to dGPU and you can’t set the maximum performance.
We can try this:
- disable iGPU from BIOS, but, if you plan later to use that as passtrough or attach more screens to it, i think that might not be what you want.
- depending what you will want, there might be a need to tweak the conf file
- to get things work better with the dGPU and since you use KDE Plasma, this is my proposal:
Test this for /etc/X11/mhwd.d/nvidia.conf but make sure you backup yours, so you can restore it if something goes wrong:
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
EndSection
Section "Monitor"
ModelName "CRT-0"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
Option "TripleBuffer" "On"
Option "ConnectToAcpid" "Off"
Option "Coolbits" "12"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "1368x768 +0+0 {ForceCompositionPipeline=On}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
EndSection
EndSection
Since i added the Option "TripleBuffer" "On"
in the Section "Device"
then, for KWin to use it, we create the kwin.sh file in the correct place with this command from terminal:
echo "export KWIN_TRIPLE_BUFFER=1" | sudo tee /etc/profile.d/kwin.sh
Reboot and if that doesn’t help, then modify /etc/profile.d/kwin.sh to be like this:
export __GL_YIELD=USLEEP
export __GL_MaxFramesAllowed=1
If i’m not mistaken, if you want to use PowerMizer to maximum Performance, you have to enable Coolbits
, so i added that too.
Once you have done this changes, run this command:
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
Then reboot.
Please don’t do that … I specified where that file has to be and how to create it.
heheh sorry that was just a lame attempt i had made before talking with you
No worries. Is better to keep things consistent so we know where to look next if other issues might rise along the way. The most important is to solve those issues you have.
And if works, then is even better!
Makes total sense…
After rebooting, the kwin.sh stayed the same (with only
export KWIN_TRIPLE_BUFFER=1). So i added the last two lines. Im not sure if thats what you meant
The last two lines, if added, should make things smoother. Also, if none of that helps, try disabling vsync in Compositor settings.
Ohh thats right, I really didnt consider the idea that anyone would write the entire config file so I forgot to add that I also needed to turn off “Sync to VBlan” and “Allow Flipping”. Anyway im rebooting
Okay so i rebooted, the Display configuration has reset, OpenGL Image and the PowerMizer pref mode remain automatic as before, althought theres a new menu available on the latter.
How did i missed that? Please change it to:
exec $(get_session)
No need for the exec part. Reboot and test again.
Hahah, my b.
I fixed it and rebooted, its still the same automatic config
I guess i wouldnt mind disabling iGPU.
Apparently you are not the only one with this issue
https://bbs.archlinux.org/viewtopic.php?id=258556
Later i will do a test on my other install.
Alright
thanks.
Im not planning on using 2 screens in the future, but what do you mean with
The passthrough is if you will use one GPU for virtualbox or qemu
https://wiki.archlinux.org/index.php/PCI_passthrough_via_OVMF
Like plugging a 2nd GPU to power the VM?
Exactly! It will use it as if was native.
By the way, have you tried to create profiles for the Nvidia GPU with the gwe
from repository? GreenWithEnvy
