I cannot get any audio output from my speakers on my LG Gram 14T90R-K.AAB8U1. I’m very new to Linux in general, but I wouldn’t say I’m completely lost. I have tried every avenue that I know of or can find to fix this. My machines audio output worked in windows before I made the switch to Manjaro, but in Linux I get nothing unless i have headphones plugged in or Bluetooth connected. Any help with this would be a god send. Thanks!
I’ve supplied my inxi
output bellow in the thread [update]
This is my inxi
output:
Kernel: 6.8.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=9aac239d-7b23-466a-8500-20048508de79 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Convertible System: LG product: 14T90R-K.AAB8U1 v: Type1Version
serial: <superuser required> Chassis: Quanta type: 31 v: Type3Version
Mobo: LG model: 14T90R v: FAB1 serial: <superuser required> part-nu: EVO
uuid: <superuser required> UEFI: American Megatrends v: GP121
date: 03/07/2023
ID-1: BAT0 charge: 28.5 Wh (39.4%) condition: 72.4/72.4 Wh (100.0%)
volts: 7.6 min: 7.8 model: CB Primary type: Li-ion serial: N/A
status: discharging
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x411C
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 441 high: 1064 min/max: 400/5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 1064 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 83584
Type: reg_file_data_sampling status: Vulnerable: No microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: LG driver: i915
v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: Quanta USB webcam driver: hid-generic,usbhid,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 0408:50c3
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 15 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.0.2-manjaro1.1
device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: LG
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.8.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 1.39 TiB used: 13.97 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00B00
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: GXA7601Q temp: 35.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: PNY model: CS1030 500GB SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CS103900 temp: 27.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 13.97 GiB (1.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 3.06 GiB (19.9%)
Processes: 350 Power: uptime: 22m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.13 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1202 libs: 363 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
