This is first time im using Manjaro Linux and i noticed some strange stuff after logout of the GUI.
This is a repeat login after logout of same user (me the only one on system)
The first time is no problem but after that the system has problems to let me login again in the GUI (KDE Plasma).
It gets stuck and the bar does not fill-up completely.
I have to switch to an VT and do CTRL+ALT+DEL to reboot, which also takes some time due to a systemd unit waiting (Session 2 of user)
Is this hapening to anyone else and is there a fix?
PS:
I’m an advanced user of Linux, but a noob when it comes to Arch/Manjaro.
My system info from neofetch:
OS: Manjaro Linux x86_64
Kernel: 5.8.11-1-MANJARO
Uptime: 1 hour, 38 mins
Packages: 1351 (pacman)
Shell: zsh 5.8
Resolution: 2560x1080
DE: Plasma 5.19.5
WM: KWin
Theme: Breath2 [Plasma], Breath [GTK2/3]
Icons: breath2 [Plasma], breath2 [GTK2/3]
Terminal: konsole
Terminal Font: Noto Mono 10
CPU: Intel i7-5820K (12) @ 3.600GHz
GPU: NVIDIA GeForce GTX 1080 Ti
Memory: 3668MiB / 32025MiB
Jtyle6
12 October 2020 08:12
2
manjaro-log-helper.logs:
Generated on 2020-10-12 11:43:1602492180
#################### cat /var/log/Calamares.log ########################
#################### systemd-analyze blame ########################
33.466s systemd-networkd-wait-online.service
16.593s NetworkManager-wait-online.service
6.373s initrd-switch-root.service
6.057s systemd-journal-flush.service
5.323s lvm2-monitor.service
3.494s org.cups.cupsd.service
2.110s systemd-modules-load.service
1.927s systemd-udevd.service
1.908s systemd-boot-system-token.service
1.830s polkit.service
1.822s NetworkManager.service
1.738s sysroot.mount
1.717s systemd-logind.service
1.708s bluetooth.service
1.614s tlp.service
1.505s tor.service
1.317s systemd-fsck@dev-disk-by\x2dlabel-ESP.service
1.284s named.service
1.221s ModemManager.service
1.100s upower.service
531ms systemd-networkd.service
520ms udisks2.service
493ms wpa_supplicant.service
490ms systemd-resolved.service
367ms user@1000.service
320ms systemd-timesyncd.service
300ms systemd-tmpfiles-setup-dev.service
260ms efi.mount
260ms systemd-journald.service
257ms systemd-udev-trigger.service
252ms systemd-random-seed.service
243ms systemd-tmpfiles-clean.service
198ms modprobe@drm.service
192ms dev-mapper-luksSWAP.swap
180ms systemd-tmpfiles-setup.service
174ms snapd.service
157ms systemd-binfmt.service
100ms dev-hugepages.mount
99ms dev-mqueue.mount
99ms sys-kernel-debug.mount
99ms sys-kernel-tracing.mount
86ms initrd-parse-etc.service
60ms systemd-remount-fs.service
56ms proc-sys-fs-binfmt_misc.mount
52ms systemd-sysctl.service
51ms systemd-update-utmp.service
47ms systemd-rfkill.service
46ms sys-kernel-config.mount
45ms linux-module-cleanup.service
42ms kmod-static-nodes.service
37ms user-runtime-dir@1000.service
37ms systemd-user-sessions.service
28ms initrd-cleanup.service
27ms SteamLib.mount
16ms systemd-fsck-root.service
8ms initrd-udevadm-cleanup-db.service
5ms rtkit-daemon.service
4ms boot.mount
3ms snapd.socket
3ms tmp.mount
3ms sys-fs-fuse-connections.mount
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5
Distro: Manjaro Linux
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: X99-PRO/USB 3.1 v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 3902 date: 04/19/2018
CPU: Topology: 6-Core model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell rev: 2
L2 cache: 15.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 79191
Speed: 1200 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1677 2: 1200 3: 1199
4: 1200 5: 1200 6: 1199 7: 1199 8: 1199 9: 1297 10: 1200 11: 1200 12: 1200
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ZOTAC driver: nvidia v: 440.100
bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 2560x1080~60Hz
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Audio: Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GP102 HDMI Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Device-3: Elite Silicon USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2
Sound Server: ALSA v: k5.8.11-1-MANJARO
Network: Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: f000
bus ID: 00:19.0
IF: dmz0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries BCM4352 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel port: e000 bus ID: 05:00.0
IF: wlan0 state: dormant mac: <filter>
Drives: Local Storage: total: 5.60 TiB used: 354.22 GiB (6.2%)
ID-1: /dev/sda vendor: Western Digital model: WD40EZRZ-00WN9B0 size: 3.64 TiB
ID-2: /dev/sdb vendor: Western Digital model: WD20EARX-00PASB0 size: 1.82 TiB
ID-3: /dev/sdc vendor: Samsung model: HD160JJ size: 149.05 GiB
Partition: ID-1: / size: 3.64 TiB used: 354.22 GiB (9.5%) fs: btrfs dev: /dev/dm-0
Swap: ID-1: swap-1 type: partition size: 63.98 GiB used: 0 KiB (0.0%) dev: /dev/dm-1
Sensors: System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 44 C
Info: Processes: 327 Uptime: 2h 52m Memory: 31.27 GiB used: 3.72 GiB (11.9%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1355 Client: KDE Plasma v: 5.19.5 inxi: 3.1.05
And here is the last part of the logs:
#################### journalctl -b -1 ########################
Eki 12 08:48:58 _hostname_ systemd-networkd[705]: wlan0: Link UP
Eki 12 08:50:16 _hostname_ systemd[1]: session-2.scope: Stopping timed out. Killing.
Eki 12 08:50:16 _hostname_ systemd[1]: session-2.scope: Killing process 1975 (kwin_x11) with signal SIGKILL.
Eki 12 08:50:16 _hostname_ systemd[1]: session-2.scope: Killing process 2029 (QQmlThread) with signal SIGKILL.
Eki 12 08:50:17 _hostname_ systemd[1]: session-2.scope: Failed with result 'timeout'.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Session 2 of user _user_.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping User Login Management...
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping User Manager for UID 1000...
Eki 12 08:50:17 _hostname_ systemd[1882]: Removed slice app.slice.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped target Main User Target.
Eki 12 08:50:17 _hostname_ gvfsd[1905]: A connection to the bus can't be made
Eki 12 08:50:17 _hostname_ obexd[2254]: Terminating
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Accessibility services bus...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping D-Bus User Message Bus...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Virtual filesystem service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Bluetooth OBEX service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Multimedia Service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Sound Service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping Portal service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping flatpak document portal service...
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopping sandboxed app permission store...
Eki 12 08:50:17 _hostname_ systemd[1882]: xdg-permission-store.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd-logind[1232]: Removed session 2.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped sandboxed app permission store.
Eki 12 08:50:17 _hostname_ systemd[1882]: obex.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Bluetooth OBEX service.
Eki 12 08:50:17 _hostname_ systemd[1]: run-user-1000-doc.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounted /run/user/1000/doc.
Eki 12 08:50:17 _hostname_ systemd[1882]: run-user-1000-doc.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: run-user-1000-gvfs.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: run-user-1000-gvfs.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounted /run/user/1000/gvfs.
Eki 12 08:50:17 _hostname_ systemd[1882]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Eki 12 08:50:17 _hostname_ systemd[1882]: xdg-document-portal.service: Failed with result 'exit-code'.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped flatpak document portal service.
Eki 12 08:50:17 _hostname_ systemd[1882]: pipewire.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Multimedia Service.
Eki 12 08:50:17 _hostname_ systemd[1882]: gvfs-daemon.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Virtual filesystem service.
Eki 12 08:50:17 _hostname_ systemd[1882]: dbus.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped D-Bus User Message Bus.
Eki 12 08:50:17 _hostname_ systemd[1882]: xdg-desktop-portal.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Portal service.
Eki 12 08:50:17 _hostname_ systemd[1882]: at-spi-dbus-bus.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Accessibility services bus.
Eki 12 08:50:17 _hostname_ systemd[1882]: pulseaudio.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped Sound Service.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped target Basic System.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped target Paths.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped target Sockets.
Eki 12 08:50:17 _hostname_ systemd[1882]: Stopped target Timers.
Eki 12 08:50:17 _hostname_ systemd[1882]: dbus.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed D-Bus User Message Bus Socket.
Eki 12 08:50:17 _hostname_ systemd[1882]: dirmngr.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed GnuPG network certificate management daemon.
Eki 12 08:50:17 _hostname_ systemd[1882]: gpg-agent-browser.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Eki 12 08:50:17 _hostname_ systemd[1882]: gpg-agent-extra.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Eki 12 08:50:17 _hostname_ systemd[1882]: gpg-agent-ssh.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Eki 12 08:50:17 _hostname_ systemd[1882]: gpg-agent.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed GnuPG cryptographic agent and passphrase cache.
Eki 12 08:50:17 _hostname_ systemd[1882]: p11-kit-server.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed p11-kit server.
Eki 12 08:50:17 _hostname_ systemd[1882]: pipewire.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed Multimedia System.
Eki 12 08:50:17 _hostname_ systemd[1882]: pulseaudio.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Closed Sound System.
Eki 12 08:50:17 _hostname_ systemd[1882]: Reached target Shutdown.
Eki 12 08:50:17 _hostname_ systemd[1882]: systemd-exit.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1882]: Finished Exit the Session.
Eki 12 08:50:17 _hostname_ systemd[1882]: Reached target Exit the Session.
Eki 12 08:50:17 _hostname_ systemd[1883]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[_user_] ruser=[<unknown>] rhost=[<unknown>]
Eki 12 08:50:17 _hostname_ systemd[1]: user@1000.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped User Manager for UID 1000.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping User Runtime Directory /run/user/1000...
Eki 12 08:50:17 _hostname_ kernel: kauditd_printk_skb: 4 callbacks suppressed
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.196:349): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: run-user-1000.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounted /run/user/1000.
Eki 12 08:50:17 _hostname_ systemd[1]: user-runtime-dir@1000.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped User Runtime Directory /run/user/1000.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Removed slice User Slice of UID 1000.
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.210:350): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Permit User Sessions...
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-user-sessions.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Permit User Sessions.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Network.
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.223:351): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Remote File Systems.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Network Manager...
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Network Name Resolution...
Eki 12 08:50:17 _hostname_ dbus-daemon[1226]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=1227 comm="/usr/bin/NetworkManager --no-daemon ")
Eki 12 08:50:17 _hostname_ systemd-networkd[705]: wlan0: Link DOWN
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping WPA supplicant...
Eki 12 08:50:17 _hostname_ systemd-networkd[705]: wlan0: Link UP
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-resolved.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Network Name Resolution.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-resolved comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ dbus-daemon[1226]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Network Service...
Eki 12 08:50:17 _hostname_ systemd-networkd[705]: dmz0: DHCPv6 lease lost
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.236:352): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-resolved comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: NetworkManager.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Network Manager.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.256:353): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-networkd.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Network Service.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-networkd.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-networkd.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-networkd.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-networkd.socket: Failed with result 'resources'.
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.290:354): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ wpa_supplicant[1332]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Eki 12 08:50:17 _hostname_ wpa_supplicant[1332]: wlan0: CTRL-EVENT-TERMINATING
Eki 12 08:50:17 _hostname_ systemd[1]: wpa_supplicant.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped WPA supplicant.
Eki 12 08:50:17 _hostname_ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping D-Bus System Message Bus...
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.370:355): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: dbus.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped D-Bus System Message Bus.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.383:356): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-logind.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped User Login Management.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Basic System.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Paths.
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.716:357): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: org.cups.cupsd.path: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped CUPS Scheduler.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Slices.
Eki 12 08:50:17 _hostname_ systemd[1]: Removed slice User and Session Slice.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Sockets.
Eki 12 08:50:17 _hostname_ systemd[1]: dbus.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Closed D-Bus System Message Bus Socket.
Eki 12 08:50:17 _hostname_ systemd[1]: org.cups.cupsd.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Closed CUPS Scheduler.
Eki 12 08:50:17 _hostname_ systemd[1]: snapd.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Closed Socket activation for snappy daemon.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target System Initialization.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Local Encrypted Volumes.
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-ask-password-console.path: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-ask-password-wall.path: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Set Up Additional Binary Formats...
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-sysctl.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Apply Kernel Variables.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-modules-load.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Load Kernel Modules.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Network Time Synchronization...
Eki 12 08:50:17 _hostname_ kernel: audit: type=1131 audit(1602481817.756:358): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-update-done.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Update is Completed.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: ldconfig.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-journal-catalog-update.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Rebuild Journal Catalog.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-binfmt.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Set Up Additional Binary Formats.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-timesyncd.service: Succeeded.
Eki 12 08:50:17 _hostname_ audit[23736]: SYSTEM_SHUTDOWN pid=23736 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Network Time Synchronization.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-update-utmp.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Create Volatile Files and Directories.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Local File Systems.
Eki 12 08:50:17 _hostname_ systemd[1]: Games.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount Games Library.
Eki 12 08:50:17 _hostname_ systemd[1]: LutrisGames.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount Lutris Game Library.
Eki 12 08:50:17 _hostname_ systemd[1]: boot.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount /boot.
Eki 12 08:50:17 _hostname_ systemd[1]: efi.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount ESP.
Eki 12 08:50:17 _hostname_ systemd[1]: srv-http.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount Webserver Data.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounting Steam Game Library...
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounting Temporary Directory (/tmp)...
Eki 12 08:50:17 _hostname_ systemd[1]: SteamLib.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounted Steam Game Library.
Eki 12 08:50:17 _hostname_ systemd[1]: SteamLib.automount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unset automount Steam Game Library.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Local File Systems (Pre).
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Create Static Device Nodes in /dev.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-sysusers.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Create System Users.
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-remount-fs.service: Succeeded.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Remount Root and Kernel File Systems.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: tmp.mount: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Unmounted Temporary Directory (/tmp).
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped target Swap.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivating swap /dev/disk/by-id/dm-name-luksSWAP...
Eki 12 08:50:17 _hostname_ systemd[1]: lvm2-monitor.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Stopping LVM2 metadata daemon...
Eki 12 08:50:17 _hostname_ systemd[1]: lvm2-lvmetad.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Stopped LVM2 metadata daemon.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Reached target Shutdown.
Eki 12 08:50:17 _hostname_ systemd[1]: lvm2-lvmetad.socket: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Closed LVM2 metadata daemon socket.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-disk-by\x2did-dm\x2dname\x2dluksSWAP.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/disk/by-id/dm-name-luksSWAP.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-disk-by\x2duuid-66acf908\x2db988\x2d4ff1\x2d9840\x2d453a496bb7ef.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/disk/by-uuid/66acf908-b988-4ff1-9840-453a496bb7ef.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-disk-by\x2did-dm\x2duuid\x2dCRYPT\x2dLUKS2\x2db0f99c9c14154e8fb53414b77a623d9b\x2dluksSWAP.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/disk/by-id/dm-uuid-CRYPT-LUKS2-b0f99c9c14154e8fb53414b77a623d9b-luksSWAP.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-disk-by\x2dlabel-Swap.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/disk/by-label/Swap.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-dm\x2d1.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/dm-1.
Eki 12 08:50:17 _hostname_ systemd[1]: dev-mapper-luksSWAP.swap: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Deactivated swap /dev/mapper/luksSWAP.
Eki 12 08:50:17 _hostname_ systemd[1]: Reached target Unmount All Filesystems.
Eki 12 08:50:17 _hostname_ systemd[1]: Reached target Final Step.
Eki 12 08:50:17 _hostname_ systemd[1]: systemd-reboot.service: Succeeded.
Eki 12 08:50:17 _hostname_ systemd[1]: Finished Reboot.
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Eki 12 08:50:17 _hostname_ systemd[1]: Reached target Reboot.
Eki 12 08:50:17 _hostname_ systemd[1]: Shutting down.
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=20 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=19 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=24 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=23 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=18 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=17 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=29 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=28 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=16 op=UNLOAD
Eki 12 08:50:17 _hostname_ audit: BPF prog-id=15 op=UNLOAD
Eki 12 08:50:17 _hostname_ systemd[1]: Hardware watchdog 'iTCO_wdt', version 0
Eki 12 08:50:17 _hostname_ systemd[1]: Set hardware watchdog to 10min.
Eki 12 08:50:17 _hostname_ kernel: watchdog: watchdog0: watchdog did not stop!
Eki 12 08:50:18 _hostname_ systemd-shutdown[1]: Syncing filesystems and block devices.
Eki 12 08:50:18 _hostname_ systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Eki 12 08:50:18 _hostname_ haveged[685]: haveged: Stopping due to signal 15
Eki 12 08:50:18 _hostname_ haveged[685]: haveged starting up
Eki 12 08:50:18 _hostname_ systemd-journald[687]: Journal stopped
Jtyle6
12 October 2020 14:03
5
I don’t know what is going on.
I was waiting for someone to have a look at problem.
Try removing systemd from passwd and group in /etc/nsswitch.conf.
You must be kidding right?
If that was the case the problem would have occurred 100% every boot…
Those lines you quoted are for network interface management, and i have a static ethernet port set to be ignored by NetworkManager, NM only controls the Wifi which is not being connected to at moment by choice…
Also i am running BIND as DNS server on same machine, which is functioning properly…
TriMoon:
I was giving you that advice based upon how much time those two services needed at boot time, and it is possible that something else is waiting for those services to finish starting before you can get to your login screen.
By consequence, there was no need for you to come back at me with an attitude, and especially not if you’re a newbie who doesn’t even properly understand how the different components in the system work together.
The problem happens after logout and login again, eg. not the initial login.
Aragorn:
Please read my profile before you jump to conclusions… (Click my avatar here)
And yes i appreciate help, but not when it involves removing systemd settings…
You wouldn’t be removing systemd settings. You would simply be reconfiguring /etc/nsswitch.conf so that it doesn’t depend on systemd anymore.
And why would that help in this case?
You want to decouple systemd from a system that is managed by systemd, not very logical or advisable…
SystemD is already setting the UTP connection to a static config, and my local (on same machine) DNS server is properly operating and starting from boot.
nsswitch.conf is only to select which name server will be used for DNS lookups, which in my setup is the local BIND9 in all cases…
~ >>> networkctl status -a|xclip
â—Ź 1: lo
Link File: /usr/lib/systemd/network/99-default.link
Network File: n/a
Type: loopback
State: carrier (unmanaged)
MTU: 65536
QDisc: noqueue
IPv6 Address Generation Mode: eui64
Queue Length (Tx/Rx): 1/1
Address: 127.0.0.1
::1
â—Ź 2: dmz0
Link File: /etc/systemd/network/10-mb-eth0.link
Network File: /etc/systemd/network/10-mb-eth0.network
Type: ether
State: routable (configured)
Path: pci-0000:00:19.0
Driver: e1000e
Vendor: Intel Corporation
Model: Ethernet Connection (2) I218-V
HW Address: 08:62:66:82:45:a0 (ASUSTek COMPUTER INC.)
MTU: 1492 (min: 68, max: 9000)
QDisc: fq_codel
Auto negotiation: yes
Speed: 100Mbps
Duplex: full
Port: tp
Address: 192.168.0.2
192.168.1.254
192.168.2.254
xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:1
xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx
fe80::a62:66ff:fe82:45a0
Gateway: 192.168.0.1 (HUAWEI TECHNOLOGIES CO.,LTD)
DNS: 127.0.0.1
::1
Search Domains: lan
dev.lan
home.dev.lan
xxxx.dev.lan
xxxx.dev.lan
other.dev.lan
Route Domains: .
DHCP6 Client DUID: DUID-EN/Vendor:0000ab11e026bd46947bf11a0000
Eki 12 08:52:59 manjaro systemd-networkd[700]: dmz0: IPv6 successfully enabled
Eki 12 08:52:59 manjaro systemd-networkd[700]: dmz0: Link UP
Eki 12 08:53:23 manjaro systemd-networkd[700]: dmz0: Gained carrier
Eki 12 08:53:25 manjaro systemd-networkd[700]: dmz0: Gained IPv6LL
â—Ź 3: wlan0
Link File: /etc/systemd/network/10-mb-wlan0.link
Network File: n/a
Type: wlan
State: dormant (unmanaged)
Path: pci-0000:05:00.0
Driver: wl0
Vendor: Broadcom Inc. and subsidiaries
Model: BCM4352 802.11ac Wireless Network Adapter
HW Address: e6:ca:a2:d6:f7:df
HW Permanent Address: 30:10:b3:be:d9:f2 (Liteon Technology Corporation)
MTU: 1500 (min: 68, max: 1500)
QDisc: fq_codel
IPv6 Address Generation Mode: none
Eki 13 09:09:04 manjaro systemd-networkd[700]: wlan0: Link DOWN
Eki 13 09:09:04 manjaro systemd-networkd[700]: wlan0: Link UP
Eki 13 09:16:02 manjaro systemd-networkd[700]: wlan0: Link DOWN
Eki 13 09:16:02 manjaro systemd-networkd[700]: wlan0: Link UP
Eki 13 09:23:00 manjaro systemd-networkd[700]: wlan0: Link DOWN
Eki 13 09:23:00 manjaro systemd-networkd[700]: wlan0: Link UP
Eki 13 09:29:58 manjaro systemd-networkd[700]: wlan0: Link DOWN
Eki 13 09:29:58 manjaro systemd-networkd[700]: wlan0: Link UP
Eki 13 09:36:56 manjaro systemd-networkd[700]: wlan0: Link DOWN
Eki 13 09:36:56 manjaro systemd-networkd[700]: wlan0: Link UP
~ >>> resolvectl status|xclip
Global
LLMNR setting: yes
MulticastDNS setting: yes
DNSOverTLS setting: no
DNSSEC setting: allow-downgrade
DNSSEC supported: yes
Fallback DNS Servers: 1.1.1.1
9.9.9.10
8.8.8.8
2606:4700:4700::1111
2620:fe::10
2001:4860:4860::8888
Link 2 (dmz0)
Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 mDNS/IPv4 mDNS/IPv6
DefaultRoute setting: yes
LLMNR setting: yes
Current DNS Server: 127.0.0.1
DNS Servers: 127.0.0.1
::1
DNS Domain: lan
dev.lan
home.dev.lan
xxxxx.dev.lan
xxxxx.dev.lan
other.dev.lan
Link 3 (wlan0)
Current Scopes: none
DefaultRoute setting: no
LLMNR setting: yes
MulticastDNS setting: no
PS:
The problem is not at boot time…it is after a logout from the GUI and trying to login back again.
No, it is not managed by systemd. This here below is what I’m talking about…
passwd: files mymachines systemd
group: files mymachines systemd
shadow: files
It determines how logins on your system are handled. In the event of the snippet above ─ taken from my system ─ it validates logins against the local files on my machine as the first verification ─ i.e. /etc/passwd, /etc/shadow, /etc/group and /etc/gshadow ─ and if the login was not found in the local files, then it will look inside any running containers as covered by the mymachines entry, and if it cannot find the login credentials there either, then it will appeal unto systemd for doing its magic via a centralized LDAP server.
In other words, the settings I’ve referred to are pertinent to login/logout. It has nothing to do with IP addresses, TCP or UTP packets, but most likely it is trying to resolve the FQDN (“fully qualified domain name”) of the machine that the expected LDAP server is installed on.
And there we have your mistake…
If the login would come to that point it would behave the same at boot time / first login, which is NOT the case…
I don’t have a LDAP running, and the login account is present in /etc/passwd…
The advice I gave you was also the advice given by @philm as a solution for the same type of problem you have, as introduced in one of the updates of a while ago, and he’s only one of the main Manjaro developers.
But okay, you’re the newbie and I guess you know better than the people who put this distribution together, so I will now bow out of this exchange and leave the solving of this problem into your expert hands.
Now that you have mentioned that file and pointed me at a strange mymachines entry in it…
Where is that mymachines defined?
(I could as well remove that instead)
Aragorn:
No need to be like that, because in that case those that put this distribution together would be the newbie’s…
I have Many, and i emphesize the capital M here,years of experience with many Linux distributions.
This problem is specific to Manjaro…
A solution that removes a problem caused by another piece of software by eliminating some other software is the newbee style of fixing which always bites back in the long run…
mymachines ─ see the manual ─ pertains to locally running containers. systemd is the entry that will look for an LDAP server.
I’ve got 20+ years of experience in exclusively running GNU/Linux on my desktop workstations and on servers. And the problem wasn’t introduced by Manjaro, because Manjaro sources most of its packages from Arch.
Hmm looking at this They do have systemd in those lines but no mymachines
I will remove the mymachines and see if that solves it
And if you can count you will know that i have a multitude of that (See my profile)
That man page probably needs updating ─ the most recent one dates back to 2017, and that includes the copy installed here on my system. Containerization wasn’t fully supported by the mainline kernel yet back then, and systemd is not the init system in all distributions.
So the mymachines entry may indeed be specific to distributions with systemd and how that interacts with containers.
I am older than you are, and I find it a little hard to believe you’d have a multitude of “20+ years” of experience with GNU/Linux when the Linux kernel itself is only 29 years old as of this year.
TriMoon:
(See my profile)
Yes, yes, I have.
