my laptop keyboard has some problems and i guess some key is being pressed automatically in the grub menu which makes grub wait forever .
So i want to know if i can make grub timeout stop only when a certain key( arrow key) is pressed
I can’t find anything on setting the grub keys, I think you might have to edit the source to stop it being any key (I don’t really know though). However if your keyboard problems are software related they might be fixable if you can post the output of
As shown here: [HowTo] Provide System Information
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d62b0b2e-bfac-4cc0-8645-d4b67e3c6632 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 2324FV6 v: ThinkPad X230
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 2324FV6 serial: <filter> UEFI-[Legacy]: LENOVO
v: G2ETB7WW (2.77 ) date: 09/24/2019
ID-1: BAT0 charge: 38.7 Wh (99.5%) condition: 38.9/57.7 Wh (67.3%)
volts: 12.6 min: 11.1 model: SANYO 45N1031 type: Li-ion serial: <filter>
status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
RAM: total: 7.45 GiB used: 4.15 GiB (55.7%)
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 20761
Speed: 3093 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 3093 2: 3093
3: 3093 4: 3093
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:5 chip-ID: 04f2:b2eb class-ID: 0e02
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 125 size: 277x156mm (10.9x6.1")
diag: 318mm (12.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
Device-3: Sierra Wireless Sierra Wireless Gobi 3000 Modem device (MC8355)
type: USB driver: qcserial,qmi_wwan bus-ID: 3-4:4 chip-ID: 1199:9013
class-ID: 0000
IF: wwp0s20u4 state: down mac: <filter>
Local Storage: total: 119 GiB used: 42.51 GiB (35.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Morebeck model: V602 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: TDK model: LoR TF10
size: 7.21 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 85.48 GiB size: 83.58 GiB (97.78%) used: 42.51 GiB (50.9%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d62b0b2e-bfac-4cc0-8645-d4b67e3c6632
ID-1: swap-1 type: file size: 3 GiB used: 26.8 MiB (0.9%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 1024 MiB fs: ext4 label: N/A
uuid: 61ab7529-70f0-4bb0-9386-bcb4bc84f4c0
ID-2: /dev/sda3 maj-min: 8:3 size: 24.82 GiB fs: btrfs
label: fedora_localhost-live uuid: 528b07af-d548-4d5b-8845-273e91dc5b4d
ID-3: /dev/sdb1 maj-min: 8:17 size: 1.87 GiB fs: iso9660
ID-4: /dev/sdb2 maj-min: 8:18 size: 9.9 MiB fs: vfat label: ANACONDA
uuid: 33F0-62AA
ID-5: /dev/sdb3 maj-min: 8:19 size: 20.8 MiB fs: hfsplus label: ANACONDA
uuid: d8adcba8-6e8b-3d45-a7d3-fc90ddee833c
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: Imation TF10 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0718:0619
class-ID: 0806 serial: <filter>
Device-2: 1-1.6:5 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 3-2:3 info: A4Tech 2.4G Device type: Keyboard,Mouse
power: 100mA chip-ID: 09da:2403 class-ID: 0301
Device-3: 3-4:4
info: Sierra Wireless Sierra Wireless Gobi 3000 Modem device (MC8355)
type: Network driver: qcserial,qmi_wwan interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1199:9013 class-ID: 0000
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 89.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5373 fan-1:
Processes: 227 Uptime: 50m wakeups: 19 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1292 pacman: 1280 lib: 334 flatpak: 0
snap: 12 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
I do not know of any grub configuration to achieve that.
You could however not use grub at all and take a look at other boot loaders or directly load the kernel from UEFI (EFISTUB.
Mind you, you’d still have to deactivate the keyboard once the system is up as random keypresses won’t do well on a running system either.
Best way forward seems to be to just open up the device and disconnect/replace the faulty keyboard.
I think you to use the any key - during boot any of these Shift, Esc,F8 will enable the menu depending on how far in the proces the system are.
i dont get random key presses after loading the os though . i do remember that my up array key stays pressed when i was using windows but it somehow vanished after installing linux.
i actually assumed that it is random key press that makes the menu wait forever .
i do see a timer for like a second in the grub menu.
From searching your laptop model the only thing I found was this: https://github.com/hamishcoleman/thinkpad-ec, it is designed to allow other keyboards to be mounted on the X230.
If you (or a previous owner) have used this then you will need try and fix it in the controller, but that is way beyond my skill.
If your internal keyboard is still the original then what I would do (as long as you are comfortable and know what you are doing) is remove the internal keyboard and see if there is still a problem. if not then try just reseating the cable, it might work again, but you might need to buy a new keyboard.
Also make sure you have tried the obvious - unplugging all usb devices just in case it is an external keyboard, because I can see a few external devices in your inxi output.
If you are seeing a timer and then it dissappears then it is almost certainly an incorrect keypress. does this happen on every boot, and, if so, does the timer dissappear at the same time after the menu loads each boot, and, if so, does the timer dissappear any faster if you deliberatly hold a key down?
