I’ve been having this problem for quite some time now. It comes and goes. Sometimes after reboot, I see the speaker icon in the taskbar as crossed out and when I go to audio settings it sees the mic device but renders “Internal Microphone (unplugged)”, which is impossible (right?). At times, a simple turn off, wait for a couple of hours, turn on helps, but not always. It may persist for days and days.
Here’s the system info from inxi
System: Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=b690e382-8229-45bb-b76d-587815f2e180 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Convertible System: HP product: HP Spectre x360 Convertible 13-ac0XX v: N/A serial: <filter> Chassis:
type: 31 serial: <filter>
Mobo: HP model: 827E v: 94.55 serial: <filter> UEFI: American Megatrends v: F.22 date: 02/17/2017
Battery: ID-1: BAT0 charge: 36.7 Wh (76.6%) condition: 47.9/47.9 Wh (100.0%) volts: 11.9 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging
Device-1: hid-0018:04F3:24DB.0001-battery model: ELAN0732:00 04F3:24DB serial: N/A charge: N/A status: N/A
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
Speed: 2147 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 2147 2: 2134 3: 1962 4: 1987
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Suyin HP TrueVision FHD RGB-IR type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 064e:3401 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting,vesa
alternate: fbdev display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040 bus-ID: 01:00.0 chip-ID: 8086:24fd
class-ID: 0280
IF-ID-1: br-2369d16f70b8 state: down mac: <filter>
IF-ID-2: br-64171360b7db state: down mac: <filter>
IF-ID-3: br-759eab5b057e state: down mac: <filter>
IF-ID-4: br-7d933f1cefd5 state: down mac: <filter>
IF-ID-5: br-84c8f8427c15 state: down mac: <filter>
IF-ID-6: br-c128182cec46 state: down mac: <filter>
IF-ID-7: br-c78ec93a4fec state: down mac: <filter>
IF-ID-8: br-d77b80b9c448 state: down mac: <filter>
IF-ID-9: docker0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:4 chip-ID: 8087:0a2b
class-ID: e001
Drives: Local Storage: total: 476.94 GiB used: 120.27 GiB (25.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW512HMJP-000H1 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CXY70H1Q temp: 29.9 C
scheme: GPT
Partition: ID-1: / raw-size: 232.83 GiB size: 228.17 GiB (98.00%) used: 120.18 GiB (52.7%) fs: ext4 dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 93.5 MiB (36.5%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
Info: Processes: 191 Uptime: 38m wakeups: 4 Memory: 15.51 GiB used: 3.46 GiB (22.3%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1754 pacman: 1749 lib: 437 flatpak: 0 snap: 5 Shell: fish v: 3.3.1
running-in: yakuake inxi: 3.3.06
And list-cards output:
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdc228000 irq 152"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:analog-surround-40: Analog Surround 4.0 Output (priority 33968, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 34033, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: unknown)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: unknown)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <input:analog-stereo>
sources:
alsa_input.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
