Internal laptop microphones not working
After several years, I am very happy that the problem of the hdmi port not working has finally been solved after this thread that I created.
Laptop model: acer aspire v15 nitro (( vn7-592g-71dc ))
my hybrid gpu => nvidia 960m && intel 530
Today I tried to install Manjaro again and I managed to have an hdmi port!
But still the microphone problem has made me unable to use Manjaro as the main operating system. I would be happy if you could help me solve this problem and finally migrate from Windows to Linux!
What is the problem ?
After installation, I have no problems with the speakers, but the internal microphones of the laptop and also the headphones that I connect to the laptop through the 3.5 jack do not work!
But the headphones that I connect via USB work without any problems with the microphone!
Also when by alsamixer
I check the entries and see the following message with realtek alc255 chip
this sound device does not have any controls
But this is not the case for headphones with a USB port!
Thank you in advance for your advice :slight_smile:
Hdmi port And Microphone not Working ! hybrid gpu
For the microphone issue I suggest you start a new topic in Support > Sound category and
post more information about audio devices detected in ALSA
sudo alsa-info.sh --upload
You might also glean some useful information from More tools for Optimus laptops are now available and The state of optimus-manager.
@Yochanan may (or may not) have something to add if it’s related.
Hello
Result:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.3
!!Script ran on: Wed Nov 29 20:35:18 UTC 2023
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Acer
Product Name:      Aspire VN7-592G
Product Version:   V1.12
Firmware Version:  V1.12
System SKU:        Aspire VN7-592G_1039_1.12
Board Vendor:      Acer
Board Name:        Aspire VN7-592G
!!ACPI Device Status Information
/sys/bus/acpi/devices/10250759:00/status 	 15
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/INT340E:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/LNXVIDEO:00/status 	 15
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:00/status 	 3
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C02:04/status 	 3
/sys/bus/acpi/devices/PNP0C04:00/status 	 31
/sys/bus/acpi/devices/PNP0C09:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0D:00/status 	 15
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/SYN1B7F:00/status 	 15
/sys/bus/acpi/devices/device:26/status 	 15
/sys/bus/acpi/devices/device:30/status 	 15
/sys/bus/acpi/devices/device:31/status 	 15
/sys/bus/acpi/devices/device:3b/status 	 15
/sys/bus/acpi/devices/device:82/status 	 11
!!Kernel Information
Kernel release:    #1 SMP PREEMPT_DYNAMIC Mon Nov 20 13:00:47 UTC 2023
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k6.6.2-1-MANJARO
Library version:    1.2.10
Utilities version:  1.2.10
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x94320000 irq 141
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
	Subsystem: Acer Incorporated [ALI] 100 Series/C230 Series Chipset Family HD Audio Controller [1025:1039]
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	ctl_dev_id : N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 10
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC255
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0255
Subsystem Id: 0x10251039
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
    rates [0x560]: 44100 48000 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 D3cold CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Speaker Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
  Amp-Out vals:  [0x00 0x00]
  Converter: stream=0, channel=0
  PCM:
    rates [0x60]: 44100 48000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  Device: name="ALC255 Analog", type="Audio", device=0
  Amp-Out vals:  [0x57 0x57]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x5e0]: 44100 48000 88200 96000 192000
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
  Amp-In vals:  [0x97 0x97]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Device: name="ALC255 Alt Analog", type="Audio", device=2
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 5
     0x18 0x19 0x1a 0x1b 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
  Connection: 1
     0x0d
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00000020: IN
  Pin Default 0x411111c0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xc, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Speaker Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00010014: OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x90172120: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Grey
    DefAssociation = 0x2, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x0c
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
  Amp-Out vals:  [0x80]
  Pincap 0x00000010: OUT
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Pincap 0x00003724: IN Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
    Misc = NO_PRESENCE
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
    Misc = NO_PRESENCE
  Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0001373c: IN OUT HP EAPD Detect
  EAPD 0x2: EAPD
    Misc = NO_PRESENCE
  Connection: 2
     0x0c* 0x0d
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40700001: [N/A] Modem Hand at Ext N/A
    DefAssociation = 0x0, Sequence = 0x1
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=76
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x02211030: [Jack] HP Out at Ext Front
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x0c 0x0d*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 6
     0x18 0x19 0x1a 0x1b 0x1d 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 7
     0x18 0x19 0x1a 0x1b 0x1d 0x0b 0x12
Codec: Intel Skylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862809
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled KAE
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
  Power: setting=D3, actual=D3
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Devices: 0
  Connection: 3
     0x02* 0x03 0x04
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 10 Nov 30 00:00 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  8 Nov 30 00:00 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  9 Nov 30 00:00 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116,  3 Nov 30 00:00 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  2 Nov 30 00:00 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  4 Nov 30 00:00 /dev/snd/pcmC0D2c
crw-rw----+ 1 root audio 116,  5 Nov 30 00:00 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  6 Nov 30 00:00 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  7 Nov 30 00:00 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  1 Nov 30 00:00 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Nov 30 00:00 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Nov 30 00:00 .
drwxr-xr-x 3 root root 280 Nov 30 00:00 ..
lrwxrwxrwx 1 root root  12 Nov 30 00:00 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [VG240Y]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC255 Alt Analog [ALC255 Alt Analog]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x94320000 irq 141'
  Mixer name	: 'Realtek ALC255'
  Components	: 'HDA:10ec0255,10251039,00100002 HDA:80862809,80860101,00100000'
  Controls      : 37
  Simple ctrls  : 10
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -6525
			dbvalue.1 -6525
	control.4 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.6 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.7 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.8 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.9 {
		iface MIXER
		name 'Master Playback Volume'
		value 87
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
	control.10 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.11 {
		iface CARD
		name 'Front Headphone Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.12 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.13 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.14 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.15 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.16 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.18 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.19 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.20 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.21 {
		iface PCM
		device 3
		name ELD
		value '100007006610000100000000000000000472bf06564732343059090707000000'
		comment {
			access 'read volatile'
			type BYTES
			count 32
	control.22 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.23 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.24 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.25 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.26 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.27 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.28 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.29 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.30 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.31 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.32 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.33 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.34 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.35 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.36 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.37 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acer_wmi
acpi_pad
aesni_intel
af_alg
algif_hash
algif_skcipher
ath
ath3k
ath9k
ath9k_common
ath9k_hw
atkbd
bluetooth
bnep
bpf_preload
btbcm
btintel
btmtk
btrtl
btusb
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_mod
drm_buddy
drm_display_helper
ecdh_generic
ee1004
ext4
fat
fuse
gf128mul
ghash_clmulni_intel
hid_multitouch
i2c_algo_bit
i2c_dev
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_tcc_cooling
intel_uncore
intel_wmi_thunderbolt
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mei_pxp
memstick
mmc_core
mousedev
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
nvme
nvme_common
nvme_core
pcspkr
polyval_clmulni
polyval_generic
qrtr
r8169
rapl
realtek
rfcomm
rfkill
rtsx_usb
rtsx_usb_ms
rtsx_usb_sdmmc
serio
serio_raw
sha512_ssse3
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_avs
snd_soc_core
snd_soc_hda_codec
snd_timer
soundcore
sparse_keymap
ttm
usbhid
uvc
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111c0
0x14 0x90172120
0x17 0x40000000
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40700001
0x1e 0x411111f0
0x21 0x02211030
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[    0.318210] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.318227] pci 0000:01:00.0: Enabling HDA controller
[    0.318613] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    4.936933] AES CTR mode by8 optimization enabled
[    5.048568] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    5.063467] ath: phy0: ASPM enabled: 0x42
[    6.741010] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input14
[    6.741156] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    6.906845] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[    7.317414] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    7.649598] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    7.649604] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.649606] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    7.649608] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    7.649609] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    7.716641] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  535.129.03  Thu Oct 19 18:42:12 UTC 2023
[    7.790432] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    7.922659] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    7.922772] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    7.922883] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    7.922990] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    8.674493] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[   12.849771] r8169 0000:07:00.0 enp7s0: Link is Up - 100Mbps/Full - flow control rx/tx
[   14.401210] nvidia 0000:01:00.0: Enabling HDA controller
[   15.235164] usb 1-7: New USB device found, idVendor=04ca, idProduct=300d, bcdDevice= 0.02
[   15.469709] NET: Registered PF_ALG protocol family
[   17.281204] nvidia 0000:01:00.0: Enabling HDA controller
[   17.310955] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
Thank you for the information you posted
I don’t understand much and I just tried to move on the road to work
please post the output of
to get an image what sound-modules are installed.
there are some problems with sound-modules that cause inoperability of the microphone.
to check this the output of inxi is mandatory.
Hello
The result of the command:
  Kernel: 6.6.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=ab110f4c-50b6-4f0a-9535-a09296810b86 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Acer product: Aspire VN7-592G v: V1.12
    serial: <superuser required>
  Mobo: Acer model: Aspire VN7-592G v: V1.12 serial: <superuser required>
    UEFI: Insyde v: 1.12 date: 10/06/2016
  ID-1: BAT0 charge: 1.0 Wh (16.7%) condition: 6.0/52.5 Wh (11.4%) volts: 12.7
    min: 11.4 model: LGC AC14A8L type: Li-ion serial: <filter> status: charging
  System RAM: total: 16 GiB available: 15.49 GiB used: 2.23 GiB (14.4%)
  Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 41621
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 530 vendor: Acer Incorporated ALI driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:191b
    class-ID: 0300
  Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Acer Incorporated ALI
    driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:139b
    class-ID: 0302
  Device-3: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 04f2:b520
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x046f built: 2014 res: 1920x1080 hz: 60
    dpi: 141 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
    device-ID: 8086:191b memory: 15.12 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 960M driver: nvidia v: 535.129.03
    device-ID: 10de:139b surfaces: xcb,xlib
  Device-1: Intel 100 Series/C230 Series Family HD Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0401
  API: ALSA v: k6.6.2-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.85 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
    driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0
    chip-ID: 168c:0034 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-1: Lite-On Atheros AR3012 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 04ca:300d
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 1.82 TiB used: 11.23 GiB (0.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 34.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ02ABD100H
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 5A scheme: GPT
  ID-1: / raw-size: 47.83 GiB size: 46.78 GiB (97.80%) used: 11.23 GiB (24.0%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: ab110f4c-50b6-4f0a-9535-a09296810b86
    used: 300 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 3605-D1CC
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: D40F-4773
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 837.74 GiB fs: ntfs label: N/A
    uuid: 8EC21D92C21D7F9F
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 522 MiB fs: ntfs label: N/A
    uuid: D65A38AA5A3888EF
  ID-5: /dev/sda1 maj-min: 8:1 size: 882.68 GiB fs: ntfs label: N/A
    uuid: 3C34B5F734B5B46C
  Device-1: 1-7:5 info: Lite-On Atheros AR3012 Bluetooth type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04ca:300d class-ID: e001
  Device-2: 1-9:3 info: Chicony HD WebCam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b520 class-ID: 0e02
  Device-3: 1-10:4 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 231 Uptime: 5m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1119 libs: 314 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
type or paste code here
please check if your latest bios is installed.
According to the updates of the main site, I have the latest version 1.12 installed.
Is it possible that I am wrong?
Onboard audio device (ALC 255) is using snd_hda_intel driver
Device and subdevice IDs can be used to search for online scans for the audio device
https://linux-hardware.org/?id=pci:8086-a170-1025-1039
Information shows systems with this device were using snd_hda_intel driver up to kernel 6.3 (
that does not support internal digital microphones) but later kernels are using snd_soc_avs driver
Try this to force use of snd_soc_avs driver
sudo tee /etc/modprobe.d/alsa-avs.conf <<< 'options snd_intel_dspcfg dsp_driver=4'
Dummy Output on Asus C302 - #25 by u2human
Unfortunately, I didn’t really understand the things you explained! But after executing the command, and rebooted the system, not only the microphone problem was not solved, the previous sound card also failed, and in addition to the microphone, the speakers also do not work!
Delete the file created by previous command to get speakers back to working state
sudo rm /etc/modprobe.d/alsa-avs.conf
It is true that the status of the speaker is ok again. But the microphone problem still persists! What can be done?
Any ideas to solve my problem?
only for UP !
Finally I was able to enable the headphone microphone by adding the following settings
options snd_hda_intel model=dell-headset-multi,aspire-headset-mic
The only current problem is that the laptop’s internal microphone is not working, and I think that fixing it is not too far away
Does anyone know if there is an equivalent for the internal microphone that I can add to the settings?
Laptop systems with 6th generation Intel (Skylake) CPU were the first to include digital array microphones (to support Cortana audio surveillance software) instead of a single analog microphone
Digital array microphones do not work with legacy driver snd_hda_intel and require Intel SST drivers
ALSA data in post #3 shows that system can detect the analog outputs for Speakers and Headphones
but cannot detect any microphone inputs
I checked scans for similar systems and found one that has a modprobe option
options snd-hda-intel model=dell-headset-multi
for external microphone. Data from dmesg shows external inputs detected
HW probe of Acer Aspire VN7-592G #a313fa3b83: dmesg
[    5.528902] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    5.528908] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.528911] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    5.528914] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.528915] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.528917] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[    5.528919] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
