sudo pacman -Syu 1 ✘
[sudo] password for reza:
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
1) qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1):
:: installing pacman (6.1.0-3) breaks dependency 'libalpm.so=13-64' required by libpamac
Your profile says you are on stable branch, but pacman 6.1.0-3 is… well actually, it doesn’t exist anywhere in Manjaro repos. This is version from Arch.
So remove unsupported repos you added in your pacman.conf.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
thanks
i did not change anything in pacman.conf, but i added in mirror list the server from my country.
after removing that server, the problem solved!
