Installing manjaro to usb
I tried another approach that might be easier, but I bumped.
Here’s what I tried.
  1. Install arch-bootstrap with pacman
  2. Mount USB and navigate to location
  3. Run script from TeArch Linux / Applications and Tools / archstrap · GitLab
    Original script:
    # create archlinux rootfs (no need any parameters)
    archstrap airootfs
    # create hyperbola-linux rootfs (community section not available for hyperbola-linux)
    archstrap hyperbola -i community -r 'https://mirror.fsf.org/hyperbola/gnu-plus-linux-libre/testing/$repo/os/$arch'
    # create manjaro rootfs (need only repo changes)
    archstrap manjaro -r ''https://mirrors.fossho.st/manjaro/stable/$repo/$arch'
    # Note: the last line is missing a single quote I think.
    Modified script:
    arch-bootstrap airootfs
    arch-bootstrap hyperbola -i community -r 'https://mirror.fsf.org/hyperbola/gnu-plus-linux-libre/testing/$repo/os/$arch'
    arch-bootstrap manjaro -r ''https://mirrors.fossho.st/manjaro/stable/$repo/$arch''
  4. Error: cannot find package: acl
    acl is installed though in pamac…
    Bump.
Also, I want to install KDE Plasma on persistent USB, but I don’t see how that script can let me define KDE.
Edit:
I got the USB installed with VirtualBox, had to install virtualbox-ext-oracle with pacman. Configuring VirtualBox to use the extension I did with the help of this tutorial https://www.tecmint.com/enable-usb-in-virtualbox
Installing Manjaro on the USB (inside VirtualBox), I did with the help of this video https://www.youtube.com/watch?v=5-xsVl-e29I
Already a bit old but maybe it contains some hints:
It is a third party script - unsupported by Manjaro.
I suggest you talk to the creator.
[root tip] [How To] Do a manual Manjaro installation
[root tip] [How To] Manjaro-To-Go LXDE with persistance
[root tip] [Utility Script] Encrypted Manjaro Linux using Verified Boot
Mapare - manjaro package restore
[HowTo] portable manjaro USB with XFCE, btrfs (part1)
