Hi Manjaronies,
I’m dual booting Manjaro and Windows through a grub boot-loader that (should be) owned by Manjaro. I’d like to try the newer LTS Kernels, changing from my 5.15 LTS (Running, Installed) to 6.6 LTS (Installed)
Problem: none of the installed Kernels except 5.10 and 5.15 are showing in the Advanced Options Grub boot menu.
Following this thread, this thread and this thread I’ve gathered some info. As shown, I installed the newer Kernels:
mhwd-kernel --listinstalled
Currently running: 5.15.185-1-MANJARO (linux515)
* linux510
* linux515
* linux612
* linux66
sudo grub-install --recheck --no-rs-codes runs with no errors but the the 6.X Kernels keep missing in the Grub Boot - Advanced Options.
update-grub is missing from my system, command not found.
The grub entries seem to stay the same:
awk -F\' '/menuentry / {print $2}' /boot/grub/grub.cfg
Manjaro Linux
Manjaro Linux (Kernel: 5.15.114-2-MANJARO x64)
Manjaro Linux (Kernel: 5.15.114-2-MANJARO x64 - fallback initramfs)
Manjaro Linux (Kernel: 5.10.181-2-MANJARO x64)
Manjaro Linux (Kernel: 5.10.181-2-MANJARO x64 - fallback initramfs)
Windows Boot Manager (on /dev/nvme1n1p1)
UEFI Firmware Settings
But the newer Kernels are present in /boot/:
ls -lah /boot/
total 428M
drwxr-xr-x 5 root root 4,0K 25. Jun 14:37 .
drwxr-xr-x 18 root root 4,0K 11. Jun 10:40 ..
drwx------ 4 root root 4,0K 1. Jan 1970 efi
drwxr-xr-x 6 root root 4,0K 11. Apr 11:40 grub
-rw------- 1 root root 44M 23. Jun 15:23 initramfs-5.10-x86_64-fallback.img
-rw------- 1 root root 12M 23. Jun 15:23 initramfs-5.10-x86_64.img
-rw------- 1 root root 52M 23. Jun 15:23 initramfs-5.15-x86_64-fallback.img
-rw------- 1 root root 12M 23. Jun 15:23 initramfs-5.15-x86_64.img
-rw------- 1 root root 115M 23. Jun 15:33 initramfs-6.12-x86_64-fallback.img
-rw------- 1 root root 57M 23. Jun 15:32 initramfs-6.12-x86_64.img
-rw------- 1 root root 66M 25. Jun 14:37 initramfs-6.6-x86_64-fallback.img
-rw------- 1 root root 15M 25. Jun 14:36 initramfs-6.6-x86_64.img
-rw-r--r-- 1 root root 13M 12. Mai 19:56 intel-ucode.img
-rw-r--r-- 1 root root 23 2. Mai 09:36 linux510-x86_64.kver
-rw-r--r-- 1 root root 23 5. Jun 08:04 linux515-x86_64.kver
-rw-r--r-- 1 root root 22 19. Jun 17:49 linux612-x86_64.kver
-rw-r--r-- 1 root root 21 19. Jun 17:50 linux66-x86_64.kver
drwxr-xr-x 2 root root 4,0K 11. Apr 11:41 memtest86+
-rw-r--r-- 1 root root 9,5M 11. Jun 10:42 vmlinuz-5.10-x86_64
-rw-r--r-- 1 root root 11M 23. Jun 15:23 vmlinuz-5.15-x86_64
-rw-r--r-- 1 root root 14M 23. Jun 15:32 vmlinuz-6.12-x86_64
-rw-r--r-- 1 root root 13M 25. Jun 14:36 vmlinuz-6.6-x86_64
What might I be missing? It seems like the only thing needed to do is to properly update Grub. Cheers ![]()
