So on my laptop, I have 2 GPUs the intel one and the Nvidia GPU. I have two options on how to use them but none of them are good, so the first one is using Optimus Manager and switching to the Nvidia GPU, though it impacts the performance significantly. The second one is using the Intel GPU and when I want to run some software on the Nvidia GPU use a command, the downside is that the intel GPU makes the desktop work slower and has quite a lot of visual glitches. So it’s basically smoothly working desktop or smoothly running apps.
Hi @Gl0b,
It sounds like the driver you need isn’t installed at the moment. More information is neccessary to confirm the diagnoses, though.
To that end, please see How to provide good information and, if applicable, [HowTo] post screenshots and links.
Please also provide the output for:
mhwd --list
- As well as for:
mhwd --listinstalled
This information would be necessary for anyone to assist you. So, while it might not be me, the information is still required.
So the output for mhwd --list is:
> 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0302:10de:139b) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.04 false PCI
> 0000:00:02.0 (0300:8086:191b) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
And for mhwd --listinstalled
> Installed PCI configs:
