Hello,
I followed the tutorial step by step, but when I want to launch my 127.0.0.1/phpmyadmin, I have a blank page.
I have started the tutorial three times, but for phpmyadmin, nothing works.
Can you help me please?
Thank you.
Remove the string with /var/tmp from phpmyadmin conf file that is mentioned in that tutorial.
The cause was a missing semi-colon - a subtle - but very important detail.
Corrected.
All is good. Excepted phpmyadmin : a white page.
I don’t understand how to phpmyadmin start.
Check your phpmyadmin config file.
All lines (except comments) must be terminated with a semicolon ( ; )
After a lot of searching and reading on regex - especially on using shell expansion inside a regex - which generated a lot of trial and error - completely by accident I ended with the following - of course you need to be root to do this
sed -i -e "/blowfish/s/''/'$(openssl rand -hex 16)'/gi" /etc/webapps/phpmyadmin/config.inc.php
