Hello!
I am now using Manjaro for over 2 years and I love it - until now I had no noteworthy trouble with the hardware detection, particularly when I installed the last time Manjaro on the device I installed it today. This time it is a little bit different, there are some “problems” I will focus on in the next few days (WLAN-Password, graphics) but one issue I need to get solved today - that is the sound… I tried some tipps mentioned here in the forum, but until now nothing worked.
The problem:
There are as far as I can see / assess that no error-messages or something in that way - I just don’t get any sounds (neither system sounds nor sounds of videos / audios / etc.).
What a little bit “annoying” is, that Manjaro 19 worked everything out of the box on that device - I had nothing to configure concerning sound and so on. When I first booted the system from USB, I was not very “attentive”, so even there is no sound, but I ignored that - that means for me, that the hardware-detection does not work properly concerning my device.
The “setting”:
HP ENVY i7-10510u, Intel onboard sound.
Kernel: 5.8.6-1-MANJARO x86_64 (64bit)
lspci
00:00.0 Host bridge: Intel Corporation Device 9b61 (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
00:13.0 Serial controller: Intel Corporation Comet Lake Integrated Sensor Solution
00:14.0 USB controller: Intel Corporation Device 02ed
00:14.2 RAM memory: Intel Corporation Device 02ef
00:14.3 Network controller: Intel Corporation Wireless-AC 9462
00:15.0 Serial bus controller [0c80]: Intel Corporation Serial IO I2C Host Controller
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake Serial IO I2C Host Controller
00:16.0 Communication controller: Intel Corporation Comet Lake Management Engine Interface
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode]
00:1c.0 PCI bridge: Intel Corporation Device 02b8 (rev f0)
00:1c.4 PCI bridge: Intel Corporation Device 02bc (rev f0)
00:1d.0 PCI bridge: Intel Corporation Device 02b0 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Device 02b4 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 0284
00:1f.3 Multimedia audio controller: Intel Corporation Device 02c8
00:1f.4 SMBus: Intel Corporation Device 02a3
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake SPI (flash) Controller
02:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX250] (rev a1)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
04:00.0 Non-Volatile memory controller: Toshiba Corporation BG3 NVMe SSD Controller (rev 01)
inxi -Fza (just audio related output)
Device-1: Intel vendor: Hewlett-Packard driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.8.6-1-MANJARO
What I did until now based on discussions here in forum concerning similar “problems” with sound:
- sudo pacman -S sof-firmware alsa-ucm-conf
- blacklist snd_hda_intel + snd_soc_skl
- add load-module module-alsa-sink device=hw:0,0 channels=4
- add load-module module-alsa-source device=hw:0,6 channels=4
Many thanks for all help in that matter!
Kind regards,
Deniz
