[HowTo] Faster application experience on hybrid-intel-nvidia
Difficulty: ★☆☆☆☆
Tutorial for Intel & NVIDIA GPU (Optimus laptop)
LibreOffice - fully working openCL
You need install the cuda package, it’s a hefty 5,4GB large!*.
When you install the cuda package, openCL will be fully usable in every application.(LibreOffice, Darktable, RawTherapee, etc.)
To install this package use:
pamac install cuda
Gaming experience (fps improvements)
Install the vulkan-intel and vulkan-mesa-layers packages. I’ve got more fps and stability in all games that I have (Trackmania, Star Trek online, Xonotic, Quake, etc.), now everything is smooth with a stable FPS.
To install these packages use:
pamac install vulkan-mesa-layers
pamac install vulkan-intel
All packages in this tutorial can also be installes through the official Manjaro repositories. (See screenshots below)
Note: I’ve never been able to play Trackmania on max graphic settings with my laptop before, but now it’s possible! (Better experience than Windows 10)
Thank u
Anyone knows what does this package bring for the Vulkan/Mesa stacks?
After install this package, Intel GPU is capable fully working Vulkan (without this package only openGL). Why optimus laptop get more fps and better stability? I’m not sure, but i think Intel gpu can handle environment better now.
Discrate GPU (nvidia) must push data flow through integrated gpu (intel). I think if vulkan is fully working on the intel gpu, it helps nvidia gpu reach better raw performance. There is a screenshot with solutions for grahpics cards in a laptops.(I have laptop with MUXless)
  1. Thank you for editing your original and replying to questions.
  2. The above could be placed in your original post as well under a section:
    Why do this?
  1. I’ve edited your [HowTo] a bit to include standard Manjaro tools (pamac) instead of Arch (pacman) and added a difficulty as is standard for all our [HowTo]s.
  2. :+1: Thank you for sharing back with the community :+1: (Original post deleted)
:wink:
Which means it also is only effective for things that use vulkan.
(it wont matter for, example, your browser or tetris)
And only for these hybrid setups, as its already included in nvidia-utils.
(if this were amd+nvidia, it would be amdvlk instead of vulkan-intel)
Also dont forget about 32bit versions (steam probably cares)
lib32-vulkan-intel  #for intel
lib32-amdvlk  #for amd
lib32-nvidia-utils  #for nvidia
lib32-vulkan-mesa-layers #this is the mesa-vulkan layers, for everybody, an optional dep of mesa
See more here:
https://wiki.archlinux.org/index.php/Vulkan
