kde kio-grive have to copy a file to the cache folder before I can actually open it, is there any way I can open it directly ?, bcause the file of my project link to a different file on gdrive, automatic copy it to cache folder will lose dependency.
You will need a mount point and a tool to mount your gdrive - and kio-gdrive should be able to this. So a guess is that your configuration is not optimal.
can you guide me a bit, Iam currently using kde setting → add gdrive account, there is no other setting to config kio-gdrive behevior
Note:
If you have a huge dependency tree - you should use git instead.
