How to clean/delete DNS Cache in Manjaro Linux?
In windows
we use ipconfig /flushdns in cmd(command prompt)
so how to do it in Manjaro linux
Hi @Nightpanda, and welcome!
I’ve never don it myself, but according to this page:
Flush DNS using systemd-resolved
The easiest way to flush the DNS on Linux, if you are using systemd-resolved, is to use the systemd-resolv command followed by --flush-caches.
Alternatively, you can use the resolvectl command followed by the flush-caches option.
$ sudo systemd-resolve --flush-caches
$ sudo resolvectl flush-caches
So give that a go:
Hope this helps!
didnt know this before, apparently arch has no dns cache by default (if you are not using systemd-resolved). is this still true?
I didn’t know this, either. But looking at systemctl status systemd-resolved.service:
$ systemctl status systemd-resolved.service
○ systemd-resolved.service - Network Name Resolution
Loaded: loaded (/usr/lib/systemd/system/systemd-resolved.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:systemd-resolved.service(8)
man:org.freedesktop.resolve1(5)
https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers
https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
I see that it’s inactive. So it would seem so.
Manjaro defaults to use openresolv
man resolvconf
The equivalent of the windows command would be
Here is quick overview from Wikipedia that gives you an idea about where DNS caches reside:
However, the Linux TCP/IP stack does not come with a DNS cache. So if you want to cache DNS request on a Linux system, you will need to install a DNS resolver with caching function. Popular examples are: nscd, dnsmasq, unbound
Manjaro doesn’t seem to use any of these and therefore doesn’t seem to have a DNS cache in the OS layer:
Your applications (for example browsers) might still come with their own DNS cache. I would not expect applications to cache DNS requests on disk (for performance and other reasons), so you can likely flush the application’s DNS cache by restarting the app.
when i type this command sudo systemd-resolve
*** too few arguments**
and when i type this sudo resolvectl flush-caches
*failed to flush caches: unit dbus-org.freedesktop.resolve1.service not found
See @linux-aarhus’s answer:
This command does not work. I’ve tried without and without sudo. Any other suggestions would be greatly appreciated
    ~  resolvectl flush-caches                             ✔
Failed to flush caches: Unit dbus-org.freedesktop.resolve1.service not found.
    ~  sudo resolvectl flush-caches                      1 ✘
[sudo] password for whacker:
You need to use systemd-resolved otherwise the flush-caches command has no effect.
If you want to use systemd-resolved enable it and make sure it is correctly configured.
See the arch wiki for more information on systemd-resolved.
systemd-resolved - ArchWiki (archlinux.org)
@Nightpanda
You can have NetworkManager
(if that is what you use - it is the default for most Manjaro variants)
use dnsmasq
as a resolver.
Simply create a file:
/etc/NetworkManager/conf.d//dns.conf
with the content:
[main]
dns=dnsmasq
Then you have dns caching and can use the procedure for dnsmasq to clear the cache if desired.
I do use this.
It can create issues (and has to be disabled) with certain vpn’s
(Mullvad VPN, for example - the instructions explicitely state to disable this).
When I use Mullvad VPN (from time to time)
I must remember to disable that NetworkManager configuration (comment it out).
