For 24 hours I have not been able to access any of my Netlify sites: I get the error:
Firefox detected a potential security threat and did not continue to bidforgame.netlify.app because this website requires a secure connection.
I suspect it might be a dns-cache problem and I am following the responses to this question
sudo systemd-resolve --flush-caches
Gives the error
Failed to flush caches: Could not activate remote peer: activation request failed: unknown unit.
as does
sudo resolvectl flush-caches
another answer states:
You need to use systemd-resolved otherwise the flush-caches command has no effect.
However, I enter
systemd-resolved
The command is not found
On the Archwiki it states that
systemd-resolved is a part of the systemd package that is installed by default.
Where do I go from here?
Manjaro uses openresov by default, if I recall. Did you actually enable systemd-resoved?
try without sudo:
See here also:
Here is quick overview from Wikipedia that gives you an idea about where DNS caches reside:
[image]
However, the Linux TCP/IP stack does not come with a DNS cache. So if you want to cache DNS request on a Linux system, you will need to install a DNS resolver with caching function. Popular examples are: nscd, dnsmasq , unbound
Manjaro doesn’t seem to use any of these and therefore doesn’t seem to have a DNS cache in the OS layer:
[Screenshot from 2022-01-17 20-14-09]
Your applications (for …
It’s not. Glibc resolver doesn’t even cache queries. Maybe clean firefox cache.
cscs
9 March 2024 20:16
4
Manjaro (or most editions) dont use the systemd-resolved resolver by default.
Most likely you are using openresolv.
(why? I dunno.)
https://wiki.archlinux.org/title/Systemd-resolved
Thanks for your replies, but I’m afraid I’m none the wiser
The problem occurs on Firefox and Chrome (and Opera). It only occurs on sites from that particular domain (which is why I was led down the DNS rabbit hole - but I don’t know that that is the real problem)
I did a system update that day before I noticed this issue. Could that have a bearing?
Not very likely
Then it is a domain related issue - perhaps they have been changing hosting platform and you have been caught up in the changes?
In any case - using systemd-resolved is the better option.
One reason is the increased everyday use of VPN where using systemd-resolved solves a common issue where the resolv.conf is not reset correct when you disconnect your VPN.
It is also easy to switch - only takes a few commands
sudo mv /etc/resolv.conf /etc/resolv.conf.bak
sudo systemctl enable systemd-resolved --now
sudo ln -s /run/systemd/resolve/stub-resolv.conf
sudo pacman -R openresolv
If I switch to systemd-resolved given your recipe, I cannot access the internet at all, so I reinstalled /etc/resolv.conf.bak
On the the other hand, if I use a VPN (in Opera) then I can access the domain. What does that suggest?
Well - you will need to restart your system or add --now to the service enable command
As you stated it is only a specific web site so I have no idea
I have rebooted and I can access the web now with systemd-resolved
It’s not a single web site, but any site with the domain netlify.app e.g.
https://visionary-flan-f5c377.netlify.app
I can access them with a VPN but not otherwise
cscs
10 March 2024 21:58
10
If using systemd-resolved
Then also make sure to have systemd-resolvconf
sudo pacman -Syu systemd-resolvconf
And for openvpn vpns you should also get the update script
pamac build openvpn-update-systemd-resolved
Now reboot (and check).
I’ve flagged this as resolved because it appears to relate to only one domain and therefore is an internet issue and not the OS
