Hello,
I’m runing a NVidia RTX 2060 on Manjaro 22.0.3 with kernel 6.1.11-1.
Here’s what I got regarding the drivers :
~ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
I’m just wondering something :
I can’t manage to have Ray Tracing on my latest video games, like Returnal I just bought and playing on steam/epic.
Do you know what I should do to improve performance and activate rtx support ?
Thanks !
ydar
17 February 2023 15:05
2
Isn’t that something that you change in the game’s graphics settings?
omano
17 February 2023 15:44
3
Why do you have both open source and proprietary driver installed? Provide proper system information.
anagrama:
steam/epic
Which one? There is no general “do that” for things to work. Depending how you start the game and from where, this is not the same.
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY …
Ray Tracing will be available only if you launch game properly, but first things first, provide system information.
It may, but Ray Tracing will not be available anyway as all graphics cards are seen as AMD card in Proton, without forcing some settings at launch time.
TLDR; launch options in Steam with latest Proton
PROTON_ENABLE_NVAPI=1 PROTON_HIDE_NVIDIA_GPU=0 VKD3D_CONFIG=dxr11 %command%
Hello all and thanks for the help !
First of all, regarding the Ydar comment : yeah I can’t change it on the game, ray tracing seems not to be activated:
As you can see it’s grey and when I start a game on Win11, it’s not and I can activate it.
And for Omano (sorry I don’t know how to embed a part of your messages)
I launch it with steam, but it launches Epic (I think Returnal needs Epic Game Launcher to start)
Here are my system information
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=037b75f4-def3-442d-810c-672ffa1a1eb5 rw nouveau.modeset=0 quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.80
date: 12/30/2021
RAM: total: 31.27 GiB used: 16.11 GiB (51.5%)
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 3007 high: 3954 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3615 2: 2948
3: 2955 4: 2888 5: 3954 6: 2993 7: 3150 8: 2879 9: 2880 10: 2878 11: 2877
12: 2200 13: 3644 14: 2200 15: 3180 16: 2880 bogomips: 121650
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 2b:00.0 chip-ID: 10de:1f08 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: uvcvideo
bus-ID: 1-9:6 chip-ID: 0c45:6366 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 2b:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.96 TiB used: 222.7 GiB (7.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 222.7 GiB (24.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 037b75f4-def3-442d-810c-672ffa1a1eb5
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9AA3-93B9
ID-1: /dev/sda1 maj-min: 8:1 size: 500 MiB fs: ntfs label: N/A
uuid: B4FC7F32FC7EEE4C
ID-2: /dev/sda2 maj-min: 8:2 size: 300 MiB fs: vfat label: N/A
uuid: 1D0C-20B8
ID-3: /dev/sda3 maj-min: 8:3 size: 930.06 GiB fs: ntfs label: N/A
uuid: DE6C66296C65FD21
ID-4: /dev/sda4 maj-min: 8:4 size: 684 MiB fs: ntfs label: N/A
uuid: C4C2233FC2233558
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: HDD
uuid: B68E78D48E788E9D
ID-6: /dev/sdc1 maj-min: 8:33 size: 300 MiB fs: vfat label: NO_LABEL
uuid: A66A-3039
ID-7: /dev/sdc2 maj-min: 8:34 size: 232.59 GiB fs: ext4 label: SSD
uuid: 4f6e9318-4b89-4973-8ef0-7d4b30ec6adf
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.3:9 info: Microsoft Xbox360 Controller
type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 1-5:3 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c318 class-ID: 0300
Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 1462:7c56 class-ID: 0300 serial: <filter>
Device-4: 1-9:6 info: Microdia Webcam Vitade AF type: Video
Device-5: 1-10:7 info: Logitech G402 Gaming Mouse type: Mouse,HID
chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 65.4 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 417 Uptime: 19h 0m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1334 pm: pacman pkgs: 1327 libs: 355 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
I pasted the code you provided in Steam and it works ! Thanks ! But it’s really slow and stuttering tho.
I’m gonna check on the configuration setup.
Thanks a lot.
Yeah it’s working but the framrate is really low on “medium” pressets, and I checked I have the recommanded configuration to play on “high” pressets.
Maybe there’s something I should do with Proton to improve the performance ?
omano
17 February 2023 17:51
6
So you launch it through Steam.
Running the game through Proton is not the same that playing on Windows, especially if you enable advanced features like Ray Tracing, you will not get same performance as on Windows.
There is a feature for Proton game called Shader Pre Caching in Steam, it grabs and compiles shaders ahead of time for Proton so it does less/no stuttering when you need them in game. The shader stuttering should calm itself at some point if you stay in same area of game though without shader pre caching enabled.
If you have low framerate then, it is because you need to tune the game settings. The 2000 Nvidia series are almost a joke when it comes to Ray Tracing, I consider them a proof of concept, especially the 2060. The functionality is there, the power is not.
Honestly I wouldn’t bother enabling Ray Tracing under Proton. You show you have 35 FPS in the menu without Ray Tracing on High settings, I don’t know where you get the impression you could then enable Ray Tracing and have an acceptable experience.
I would set it to Medium @ 1080p without Ray Tracing, using DLSS maybe if it improves performance, or maybe using a startup option to use AMD FSR from Proton, I don’t know at this point you need to tinker a bit I don’t have the game.
https://www.protondb.com/ and Returnal (1649240) · Issue #6538 · ValveSoftware/Proton · GitHub can be information source
select the part of my message you want, click QUOTE.
PS: you can remove the video-linux driver from MHWD, as it appears you have correctly installed the proprietary driver from Manjaro repositories (so I don’t know why video-linux is still present, weird).
Okay thanks a lot I’ll try all this
system
Closed
20 February 2023 09:11
8
