How to achieve texlive (texlive-full) installation?
I want to use texstudio, since it is the latex-Editor I’m used to.
Installation via pamac was easy.
My initial problem was, that .tex files don’t get compiled because of missing packages.
So I thought installing texlive-full might help.
Search on the forum provided this post from @megavolt on
https://forum.manjaro.org/t/texlive-most-on-manjaro/30414/2?u=katzengold
If you want texlive-full, then just install everything:
pamac install texlive-*
I happily tried to execute the command, but got:
>>>zsh: no matches found: texlive-*
(additional info: pamac search texlive- provides a long list of results.)
Can anybody point out, what I’m missing? Thanks!!
I would probably use the groups:
sudo pacman -Syyu texlive-most texlive-bin
(there is also group texlive-lang if you need chinese, cyrillic, etc)
@cscs that worked for me! Thanks!
