After applyying the latest update and rebooting, things appear to be okay… login was good, all my startup apps loaded (Steam, FireFox, Thunderbird, conky, ksystemlog, gufw, and KDE Connect SMS)… however, I have noticed a lot of “metadata complaining” in the logs. Are these safe to ignore or does an action need to be taken?
kde5d (2 entries)
2021-09-04 2:27 P.M. kded5 kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/desktop.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/desktop.so'"
2021-09-04 2:27 P.M. kded5 kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/applications.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/applications.so'"
kde-open5 (2 entries)
2021-09-04 2:27 P.M. kde-open5 kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/desktop.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/desktop.so'"
2021-09-04 2:27 P.M. kde-open5 kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/applications.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/applications.so'"
kdeconnectd (4 entries)
2021-09-04 2:29 P.M. kdeconnectd kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/desktop.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/desktop.so'"
2021-09-04 2:29 P.M. kdeconnectd kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/applications.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/applications.so'"
2021-09-04 2:29 P.M. kdeconnectd Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
2021-09-04 2:29 P.M. kdeconnectd kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
2021-09-04 2:29 P.M. kdeconnectd kdeconnect.plugin.battery: Total quantity of batteries found: 1
plasmashell (too many entries to count)
2021-09-04 2:29 P.M. plasmashell kdeconnect.interfaces: QDBusError("org.freedesktop.DBus.Error.UnknownObject", "No such object path '/modules/kdeconnect/devices/0fde265dd6c7da22/notifications'")
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_opengl.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilglobalconfig.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_about_distro.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cddb.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-gps.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_view1394.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_language_packages.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_devinfo.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/appimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/appimagethumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_dictionary.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_usb.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/textthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/textthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_runcommand_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kgamma.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_networkmanagement.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3bsoxencoder.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_mouse.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/mltpreview.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/mltpreview.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_multisegkiofactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_oxygen_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_activities.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphingeneral.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_pausemusic_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_memory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_kill.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/attica_kde.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/opendocumentthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/opendocumentthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_kernel.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilprofilesconfig.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_timedate.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/cursorthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/cursorthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_webshortcuts.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilkeyboardbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_device_automounter.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_desktoppaths.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfileaudiopreview.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinoptions.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/exrthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/exrthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilwirelesspowersavingaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/jpegthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/jpegthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/djvuthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/djvuthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_keyboard.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3bexternalencoder.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_fontinst.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilsuspendsessionaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_pci.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_bluetooth.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_bluetooth.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_plasmasearch.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_smb.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_systemd.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_proxy.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/rawthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/rawthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ffmpegthumbs.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintouchscreen.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_info.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwin_scripts.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/audiothumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/audiothumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_spellcheck.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_share_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kamera.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mirrorsearchfactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_findthisdevice_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_breeze_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilrunscriptaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_checksumsearchfactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-ip.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kded_touchpad.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_charrunner.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/comicbookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/comicbookthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilhandlebuttoneventsaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_mhwd.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_joystick.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kget_browser_integration.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kritathumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kritathumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_netpref.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mmsfactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_locale.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_metalinkfactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_fonts.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_fonts.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_obexftp.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_obexftp.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_hotkeys.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_users.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/imagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/imagethumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/miloutextplugin.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_qtquicksettings.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsexethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsexethumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/okularpart.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_bittorrentfactory.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilactivitiesconfig.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/svgthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/svgthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildpmsaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_filetypes.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_clock.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/baloofilepropertiesplugin.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintabbox.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cookies.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsimagethumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libplasmanetworkmanagement_openconnectui.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/blenderthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/blenderthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ebookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ebookthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_keyboard.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3blameencoder.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwallet5.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinscreenedges.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcmspellchecking.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kwincompositing.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/gsthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3boggvorbisencoder.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinviewmodes.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_sendnotifications_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinnavigation.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfontviewpart.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kdeconnect.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildimdisplayaction_config.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_ssl.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/fontthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/fontthumbnail.so'"
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_solid_actions.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_trash.so" does not have a valid 'MetaData' object
2021-09-04 2:29 P.M. plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_printer_manager.so" does not have a valid 'MetaData' object
Note: I just so happened to update my steam beta client prior to installing the manjaro update, and I was able to browse the store and launch a game without issues.
