Hibernation stopped working with kernel 6.11
Apparently, all kernels >= 6.11 have regressions on machine GMKTec M5 Plus, Ryzen 7 5825U with AMD Radeon Renoir Graphics card, Bluetooth Mediatek ver. 2.22 WiFi MT7921e, and cannot resume from hibernation. Kernel 6.6 LTS was fine, so I downgraded OS to this kernel.
This is nasty, because after the last stable upgrade it leaves no fully working kernel on this machine:
6.6.x can hibernate/resume, but has graphical artifacts
6.11.10 no hibernation/resume
6.12.1 no hibernation/resume
There is no DE dependency, I think only HW.
Any help please ?
Update your system. The stable branch has 6.12.4. Don’t use 6.11 because it’s unsupported.
I tried kernel 6.12.4. But without WiFi Mediatek, Bluetooth Mediatek and Hibernate(swapfile & swap partition doesn’t work) success. Only latest stable is 6.6 is worth for daily work(Hibernate works out-of-the box).
Thank you
Logs? System info? Do you have adequate swap? Are you dual-booting Windows?
More information is needed to address the issue. Please read the following:
Manjaro Logs:
https://dpaste.com/BH5GX3H39
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e3e2a6be-17b4-4361-8830-5e1aa34a206c rw
    resume=UUID=126b5adf-1338-464e-8a9d-df8619d0eeb0 quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Mini-pc Mobo: GMKtec model: GMKtec v: Version 1.0
    serial: <superuser required> part-nu: M5 PLUS-001 uuid: <superuser required>
    UEFI: American Megatrends LLC. v: M5 PLUS 1.03 date: 09/13/2024
  Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 400 min/max: 400/4546 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    bogomips: 63919
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Barcelo driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-1
    empty: DP-2,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:15e7 class-ID: 0300
    temp: 46.0 C
  Device-2: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1.1:5
    chip-ID: 0bda:58b0 class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DisplayPort-0 model: LG (GoldStar) HDR 4K
    serial: <filter> built: 2023 res: mode: 3840x2160 hz: 60 scale: 100% (1)
    dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39") diag: 690mm (27.2")
    ratio: 16:9 modes: max: 3840x2160 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.54 6.6.65-1-MANJARO) device-ID: 1002:15e7 memory: 500 MiB
    unified: no
  API: Vulkan v: 1.4.303 layers: 1 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:15e7
    surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
    vendor: Conexant Systems driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
  Device-5: Walmart AB13X Headset Adapter
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.1.3:6 chip-ID: 001f:0b21 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  Device-3: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0e8d:c616
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 1.13 TiB used: 141.97 GiB (12.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Patriot model: M.2 P310 240GB
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: APF1M3R1 temp: 44.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1.2.N.1A temp: 51.9 C
    scheme: MBR
  ID-1: / raw-size: 81.06 GiB size: 79.23 GiB (97.74%) used: 19.44 GiB (24.5%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:8
    used: 30.8 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
  ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:9
  System Temperatures: cpu: 55.1 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.02 GiB used: 5.56 GiB (37.0%)
  Processes: 359 Power: uptime: 3h 12m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.99 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1263 libs: 363 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
My swap partition is the size of the RAM. In this case it is 16GB. With swapfile I used 20GB for this memory. This worked for me approx. 12+ years on many Linux distros. This PC have dual-boot with Windows.
Here are the Recommended swap sizes… and yes replace kernel 6.11.x with 6.12.x
The RAM size is not a problem. With kernel 6.6.65-1 all is correct, run smoothly. But kernel 6.12.4 doesn’t support hibernation yet or some not supported HW hooks ? for my PC.
Your system support various modes.
As it is a desktop pc - s2idle is the best choice - even a laptop can be kept alive for days only powered by battery.
If you are referring to the old method where ramstate was written to file or partition - the s2idle is preferred over the old method as it wakes instantly and does not cause excessive writes to your ssd.
Hi, just to add data. My PC suspends and resumes ok with kernel 6.6.65 but fails to resume with 6.12.4. Pushing the on/off button or the keyboard, the on/off button stops flashing (as it should), but the machine is dead and needs a hard reset. Nothing appears in the logs.
It’s just suspend-to-ram here; I never tried hibernation, but it could be the same problem…
  Info: 8-core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 4 MiB
  Speed (MHz): avg: 400 min/max: 400/4680 cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel
  Device-2: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
    type: USB
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell v: 47.2 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
    1: 2560x1440~60Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
    renderer: AMD Radeon Graphics (radeonsi renoir LLVM 18.1.8 DRM 3.54
    6.6.65-1-MANJARO)
  Info: Tools: api: clinfo, eglinfo, glxinfo gpu: amd-smi x11: xprop,xrandr
Full report hidden here:
Summary
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=51a3a5b3-a6d6-456e-bbe3-935c914bd2fe rw rootflags=subvol=@
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: N/A model: HX90 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.19
    date: 10/11/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 32 GiB available: 30.78 GiB used: 7.71 GiB (25.0%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: CBD32D4S2S8MF-16 serial: <filter>
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
  Speed (MHz): avg: 400 min/max: 400/4680 scaling: driver: amd-pstate-epp
    bogomips: 105445
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    affected
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,HDMI-A-2
    empty: DP-1,DP-2 bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
    temp: 38.0 C
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.3:5
    chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: BenQ LCD serial: <filter> built: 2022
    res: 2560x1440 dpi: 123 gamma: 1.2 chroma: red: x: 0.663 y: 0.333 green:
    x: 0.298 y: 0.631 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-2 model: LG (GoldStar) IPS224 built: 2011 res: 1920x1080
    dpi: 102 gamma: 1.2 chroma: red: x: 0.631 y: 0.349 green: x: 0.341 y: 0.624
    blue: x: 0.153 y: 0.055 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    renoir LLVM 18.1.8 DRM 3.54 6.6.65-1-MANJARO) device-ID: 1002:1638
    memory: 500 MiB unified: no display-ID: :0.0
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Realtek driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
  Device-4: C-Media Audio Adapter (Unitek Y-247A)
    driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0d8c:0014 class-ID: 0300
  Device-5: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
  Server-3: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0608
    class-ID: 0280
  IF-ID-1: gpd0 state: down mac: N/A
  Info: services: httpd, NetworkManager, sshd, systemd-timesyncd,
    wpa_supplicant
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0e8d:0608
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 3.64 TiB used: 1.52 TiB (41.7%)
    model: WD Green SN350 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 33006000 temp: 35.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 935.57 GiB (50.2%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 51a3a5b3-a6d6-456e-bbe3-935c914bd2fe
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 37FC-2E88
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 935.57 GiB (50.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 51a3a5b3-a6d6-456e-bbe3-935c914bd2fe
  ID-4: /mnt/data raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 618.95 GiB (33.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: data
    uuid: 22ba0a6a-ff75-47be-a46b-5b76e6f3e011
  ID-5: /swap raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-6: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-7: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Device-1: 1-1:2 info: C-Media Audio Adapter (Unitek Y-247A)
    type: audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-2: 1-2:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Hub-3: 1-2.2:4 info: Genesys Logic USB 1.1 Hub ports: 4 rev: 1.0
    chip-ID: 05e3:0604 class-ID: 0900
  Device-1: 1-2.2.1:6 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-2.2.2:7 info: Trust Wireless Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:0263 class-ID: 0301
  Device-3: 1-2.3:5 info: Creative Live! Cam Sync 1080p V2 type: video,audio
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
  Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-5: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 3-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
  Device-1: 3-4:3 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 4-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
  System Temperatures: cpu: 51.2 C mobo: 36.0 C gpu: amdgpu temp: 38.0 C
  Packages: 2446 pm: pacman pkgs: 2378 libs: 521
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 54 pm: snap pkgs: 14
    1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://manjaro.kurdy.org/stable/$repo/$arch
    4: https://mirror.23m.com/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 453
  1: cpu: 12.5% command: localsearch-extractor-3 pid: 42632
    mem: 29.3 MiB (0.0%)
  2: cpu: 9.3% command: firefox pid: 40796 mem: 351.0 MiB (1.1%)
  3: cpu: 4.7% command: gnome-shell pid: 2276 mem: 606.7 MiB (1.9%)
  4: cpu: 4.3% command: clementine pid: 21874 mem: 238.7 MiB (0.7%)
  5: cpu: 3.2% command: firefox pid: 3803 mem: 791.1 MiB (2.5%)
  Memory top: 5 of 453
  1: mem: 791.1 MiB (2.5%) command: firefox pid: 3803 cpu: 3.2%
  2: mem: 740.7 MiB (2.3%) command: thunderbird pid: 3890 cpu: 1.2%
  3: mem: 606.7 MiB (1.9%) command: gnome-shell pid: 2276 cpu: 4.7%
  4: mem: 574.7 MiB (1.8%) command: firefox pid: 4087 cpu: 0.5%
  5: mem: 433.4 MiB (1.3%) command: firefox pid: 7543 cpu: 0.1%
  Processes: 453 Power: uptime: 9h 9m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.3 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.37
@Rmano
Maybe it’s time to change the title of the post a bit ?
Hibernation stopped working with kernel 6.12 and 6.11.
I’ve been following your reports with enthusiasm. In my case, I’ve been switching branches repeatedly this past January, from stable to testing, testing to stable, stable to unstable, etc. I always make a full backup. I can always revert. I also have three manjaro installations to compare problems with, and I select them with grub.
The problem I couldn’t stand was the problem from hibernation.
Currently, I’m on the latest 6.12.11-1-MANJARO testing branch. I don’t have the above problem.
ā± pacman-mirrors -G ; uname -r ; systemd-analyze
testing
6.12.11-1-MANJARO
Startup finished in 20.548s (firmware) + 12.262s (loader) + 6.607s (kernel) + 17.032s (userspace) = 56.450s
graphical.target reached after 15.802s in userspace.
Yep, the title should be changed, but it’s @mrstanlez the owner, not me :wink:
A quick update: My machine suspends and restarts correctly with the newly released kernel 6.12.11 (installed today, 2025-02-04).
I just tested it once, so there can be hidden ā€œifsā€, but it seems all well now.
Linux 6.11 is no longer supported.
Topic closed.
