Hello,
I’m trying to use espeak for my code and I downloaded espeak-ng from the Manjaro App store and tested it by doing: espeak-ng "This is a test" and it works. But when I try to use it in my code it won’t work. I tried using the regular engine = pyttsx3.init() but I get an error.
Does anyone know how I can get espeak to work or if there’s another offline tts alternative I can use?
Thanks.
If I run this I get no speech output (but the code recognizes and executes the commands properly)
import json
import random
import datetime
import operator
import wikipedia
import wolframalpha
import pyttsx3
import espeakng
import speech_recognition as sr
Commander = "Commander"
print ("Initializing B.A.X.T.E.R...")
def speak(text):
mySpeaker = espeakng.Speaker()
#mySpeaker.say('Initializing Baxter')
def wishMe():
hour = int(datetime.datetime.now().hour)
if hour>=0 and hour<12:
speak("Good Morning" + Commander)
elif hour>=12 and hour<18:
speak("Good Afternoon" + Commander)
else:
speak("Good Evening" + Commander)
speak("How may I be of service?")
def listenCommand():
command=0
hear = sr.Recognizer()
with sr.Microphone() as source:
print("Listening...")
audio = hear.listen(source)
# Uses google API to listen
try:
print("Recognizing...")
command = hear.recognize_google(audio, language='en-in')
print(f'{Commander} : {command}\n')
except:
pass
return command
speak("Initializing Baxter..........")
wishMe()
def main():
command = listenCommand()
command=str(command).lower()
if ('who is' in command) or ('what is' in command):
speak('Searching Wikipedia...')
command = command.replace("who is","")
command = command.replace("what is","")
results = wikipedia.summary(command, sentences = 1)
print("Baxter:",results)
return speak(results)
elif 'stop' in command:
speak("Shutting Down...")
return exit()
else:
return 0
while True:
main()
If I use this code (my original one. It doesn’t work and I get an error):
import json
import random
import datetime
import operator
import wikipedia
import wolframalpha
import pyttsx3
print ("Initialising B.A.X.T.E.R...")
def speak(text):
voices = engine.getProperty('voices')
engine.setProperty('voice',voices[1].id)
engine.setProperty('rate', 125 )
engine.setProperty('volume',1.0)
engine.say(text)
engine.runAndWait()
def wishMe():
else:
command=0
try:
print(f'{BOSS} : {command}\n')
except:
pass
return command
speak("Initialising Baxter..........")
wishMe()
def main():
return exit()
else:
return 0
while True:
main()
This is the error I get:
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/__init__.py", line 20, in init
eng = _activeEngines[driverName]
File "/usr/lib/python3.9/weakref.py", line 137, in __getitem__
o = self.data[key]()
KeyError: None
During handling of the above exception, another exception occurred:
File "/home/commander/BAXTERTest2.py", line 53, in <module>
File "/home/commander/BAXTERTest2.py", line 14, in speak
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/__init__.py", line 22, in init
eng = Engine(driverName, debug)
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/engine.py", line 30, in __init__
self.proxy = driver.DriverProxy(weakref.proxy(self), driverName, debug)
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/driver.py", line 50, in __init__
self._module = importlib.import_module(name)
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/drivers/espeak.py", line 9, in <module>
from . import _espeak, toUtf8, fromUtf8
File "/home/commander/.local/lib/python3.9/site-packages/pyttsx3/drivers/_espeak.py", line 18, in <module>
dll = cdll.LoadLibrary('libespeak.so.1')
File "/usr/lib/python3.9/ctypes/__init__.py", line 452, in LoadLibrary
return self._dlltype(name)
File "/usr/lib/python3.9/ctypes/__init__.py", line 374, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libespeak.so.1: cannot open shared object file: No such file or directory
