whoff
February 23, 2023, 11:46pm
1
After the update, my password for my user completely stopped working-- in the gui and terminal. No change was made, can’t update any packages via pacman because of this. What gives?
My DE is KDE Plasma 5.26.5, which I am running on the Framework laptop.
your regular user or the root password?
also what process did you use to update?
Someone else mentioned something similar in another recent post.
Background info needed for both this and that.
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi
in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading )
TriMoon
February 24, 2023, 9:50am
5
Please be more verbose and explain what you tried to do.
Are you able to login into your user account:
Via the GUI.
Via the console CTRL+ALT+F2
If you are able todo the above, it is not an issue with your user accounts password…
whoff
February 26, 2023, 10:57pm
6
Hi, I would love to be more verbose about my issue, but running this command as sudo isn’t feasible as it requires my password in order to run it as it uses sudo.
That being said, here’s the output if I run the command as my normal user:
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a48ce6a4-e93c-4281-bd96-5ba0f3e7d50a rw quiet
cryptdevice=UUID=b126dae2-8deb-400e-b9ae-dd4e9d3511f3:luks-b126dae2-8deb-400e-b9ae-dd4e9d3511f3
root=/dev/mapper/luks-b126dae2-8deb-400e-b9ae-dd4e9d3511f3
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Framework product: Laptop v: AB
serial: <superuser required>
Mobo: Framework model: FRANBMCP0B v: AB serial: <superuser required>
UEFI: INSYDE v: 03.10 date: 07/19/2022
ID-1: BAT1 charge: 9.0 Wh (18.9%) condition: 47.6/55.0 Wh (86.5%) volts: 16.2
min: 15.4 model: NVT Framewo type: Li-ion serial: <filter> status: charging
cycles: 234
RAM: total: 31.14 GiB used: 3.22 GiB (10.3%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2248 high: 2573 min/max: 400/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 2385 2: 2367 3: 2573
4: 2416 5: 2089 6: 1910 7: 1759 8: 2491 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0403
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp170s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0032 class-ID: e001
Device-1: luks-b126dae2-8deb-400e-b9ae-dd4e9d3511f3 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 331 GiB (35.5%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 41.9 C scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%) used: 331 GiB (36.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b126dae2-8deb-400e-b9ae-dd4e9d3511f3 label: N/A
uuid: a48ce6a4-e93c-4281-bd96-5ba0f3e7d50a
used: 620 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 4A23-B99A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Framework HDMI Expansion Card type: Billboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 32ac:0002 class-ID: 0300 serial: <filter>
Device-2: 3-9:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
Device-3: 3-10:4 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 256 Uptime: 11m wakeups: 2089 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1727 libs: 441 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
whoff
7
Logging in works, but actions performed within the system that require the user password cannot be executed.
whoff
February 26, 2023, 10:58pm
8
I ran pacman -Syyu
and tried the updates tab within the KDE discover store. Neither work as they both require my user password.
TriMoon
February 27, 2023, 6:03am
9
whoff:
Logging in works,
Because you are able to login using your password, i am changing the topic title…
Can you provide output of:
sudo -l
Plus to see what is going wrong you should open, in a separate terminal, the following command prior/before trying to perform your action that needs your password:
journalctl --follow
check whether your user account is a member of the wheel group:
groups
it should be
See the linked post (the sixth) in the other thread.
How to boot from USB into live Manjaro (for repair):
Hi newbi question my desktop is XFCE my pc is 64bit 60gig hardrive. I did a recent up date and now manjaro won’t boot up. I get a message saying I need to have a kernel installed first. I’ve tried advanced option but even the fallback won’t boot. I did some research that it’s possible to recover my installed system by chroot using usb but not really sure what to do after I get the message below. In the terminal I typed “manjaro-chroot -a” below is the message I got.
“Mounting (ManjaroLinux) …
When you use chroot then, you can alter the root-password of your installed system.
TriMoon
February 27, 2023, 7:01am
12
The OP has problems using his user password for administrative actions, it has nothing todo with the password on the root account.
(The root account should not have any password by default or be able tobe loged into…)
A house must have at least 2 doors. For the safety of the resident.
If it doesn’t, you may have to use the window to get out.
TriMoon
February 27, 2023, 7:10am
14
An intruder can’t sneak into an house without an open Window
There already is an emergency door by default, to enter for the resident
whoff
February 27, 2023, 11:05pm
15
Thanks for the help-- as the machine I am using is my primary device, I had to give up and timeshift back to an earlier point in time, which solved my issue. It sucks that this happened, but it’s great that I have the option to revert. Thanks for all the help.
TriMoon
February 28, 2023, 7:20am
16
A work-around without the knowledge what caused it, and thus how to prevent it, will not do you any good.
It’s just a matter of time for it to repeat again if you don’t know the reason…
system
Closed
March 2, 2023, 9:20pm
17
