it came with a disk for Linux.
I’m unfamiliar with the correct way to show you what I have on the disk and what I need help with . basically I need to be walked thru installing the driver. my kernel is 5.15.60-1.
I found a topic , yesterday , for this exact hardware and issue - which is now closed and which I cannot find today. hmmm, search terms . small sample -
#!/bin/bash
# Auto install for 8192cu
# September, 1 2010 v1.0.0, willisTang
# Add make_drv to select chip type
# Novembor, 21 2011 v1.1.0, Jeff Hung
echo "##################################################"
echo "Realtek Wi-Fi driver Auto installation script"
echo "Novembor, 21 2011 v1.1.0"
# Decompress the driver source tal ball
cd driver
Drvfoulder=`ls |grep .tar.gz`
echo "Decompress the driver source tar ball:"
echo " "$Drvfoulder
tar zxvf $Drvfoulder
there may be a question of changing the kernel headers?
ok. thanks. that is done but the dongle doesn’t show up in inxi -Fazy. at the moment I’m using an old , old 2.0 dongle as my only way to get internet. no ethernet available. is there more I have to do ? oh! I neglected to reboot .
[me@ailoailo ~]$ inxi -xxN
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8125
Device-2: ASUSTek USB-N13 802.11n Network Adapter (rev. B1) [Realtek
RTL8192CU] type: USB driver: rtl8192cu bus-ID: 5-3:5 chip-ID: 0b05:17ab
[me@ailoailo ~]$ lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 005: ID 0b05:17ab ASUSTek Computer, Inc. USB-N13 802.11n Network Adapter (rev. B1) [Realtek RTL8192CU]
Bus 005 Device 003: ID 258a:1007 SINOWEALTH Wired Gaming Mouse
Bus 005 Device 002: ID 046d:c315 Logitech, Inc. Classic Keyboard 200
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 2109:0711 VIA Labs, Inc. VL711 SATA 6Gb/s bridge
Bus 002 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 0b05:1939 ASUSTek Computer, Inc. AURA LED Controller
[me@ailoailo ~]$
so create this file: sudo nano /etc/modprobe.d/blacklist.conf
and put there this line: blacklist rtl8192cu
save the file with ctrl+x and run this: sudo mkinitcpio -P
reboot and test
well, funny thing happened on the way to the forum. the new dongle still doesn’t show up when I plug it into the same usb port. but the old dongle is now showing 90+ to 100% since we did what you suggested - some of the time . it’s still fluctuating down to 70% and probably lower but the signal is much better. I would like to get the new one running . any idea what we can do further ? what output do you need ?
so we were installing drivers for this one:
RTL8192CU]
which was the wrong one … you have nineplus and for that we need the RTL8812BU driver … but we have a problem, the nineplus is not being detected with the lsusb command …
is the nineplus connected to the pc? try different usb port and post again output from: lsusb
ok. also I’m at a motel . the router is a good 100 ft. away thru a couple of block walls. the old dongle randomly disconnects etc. .
each time I followed an instruction and restarted I unplugged the old dongle and plugged in the nineplus; gave it a few seconds , enough time to come up but it hasn’t so far.
I just plugged the new dongle into the port that I’ve been using - with no effect and also plugged the old dongle into another port and it works. both are now plugged in . now I’ll do lsusb .
Bus 005 Device 007: ID 0bda:b812 Realtek Semiconductor Corp. RTL88x2bu [AC1200 Techkey]
Bus 001 Device 004: ID 0b05:17ab ASUSTek Computer, Inc. USB-N13 802.11n Network Adapter (rev. B1) [Realtek RTL8192CU]
[me@ailoailo ~]$ ```
Oh, ok I did the last command. lsusb still shows the N13 and rtl8192cu . I unplugged the N13 and lose the wifi with the nineplus plugged in . plug it back in and regain wifi .
did you rebooted after you installed the driver?
so keep unplugged the n13 and the AC1200 Techkey plugged in, then reboot and check if you have wifi …
also provide again output from: lsusb && inxi -xN
while the n13 remains unplugged
ok. well it’s working . thanks a lot. but now I’m back down to 74%. what the heck ? also I went ahead and plugged them both in and network connections shows them both connected and offering to disconnect from either/both.
I was ecstatic with the 90-100% . did I just waste 28$ ?
there is a different driver we can try, so remove this one: pamac remove rtl88x2bu-cilynx-dkms-git
and install this: pamac build rtl88x2bu-dkms-git
REBOOT
