Installation of an asus usb-n13 dongle
Hi,
I am stuck with the installation of this device. I gave it various trials following this page. It didn’t work. The out of lsusb with the dongle plugged in is
Blockquote
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 0b05:18f1 ASUSTek Computer, Inc. 802.11n WLAN Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 007: ID 046d:c534 Logitech, Inc. Nano Receiver
Bus 003 Device 008: ID 4146:ba63 USBest Technology USB Mass Storage Device
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Can anybody help me, please?
bilem
That adapter was released with different chipsets, apparently:
ASUS USB-N13 rev B1 (0b05:17ab) • Realtek RTL8192CU
ASUS USB-N13 rev C1 (0b05:18f1) • Realtek RTL8192FU
So, if you have tried installing rtl8192CU and it doesn’t work, try installing
the updated rtl8xxxu-dkms-git ( last update Sept.2023) or maybe
rtl8192fu-dkms-git
pamac build rtl8xxxu-dkms-git
pamac build rtl8192fu-dkms-git
AUR (en) - rtl8xxxu-dkms-git (read commenters’ notes)
AUR (en) - rtl8192fu-dkms-git
Make certain that the appropriate linux kernel headers are installed for your running kernel. Also make sure that dkms is installed and that CUPS services are active .
Thanks a lot jrichard326 for your prompt answer and your efficiency. It worked straight forwards after I applied the command
and rebooted. This is great!
It seems that you mixed up to posts. The second being related to a printing issue - you also mention the CUPS services which are related to the same point. Just to make sure that the other guy will get his answer.
Thank you very much again.
bilem
