spi12
January 5, 2022, 5:33pm
1
Hi,
i am the new guy here I installed Manjaro to my laptop (Lenovo Ideapad 5 Pro 16"). Afterwards i installed the ICA Client via git. (http s://au r.archl inux.or g/icaclient.git), so far, everything worked fine. I was able to connect to citrix sessions.
Maybe important: I am using the experimental Kernel 5.16rc6, instead of 5.15.12. There was no wifi with the stable kernel.
I do not know if you need any more infos from me, but just ask
Not sure if this is the right category, feel free to move
Thank you very much
spi12
January 5, 2022, 5:34pm
2
Had to break the link from above, as i was not allowed to post links.
spi12
January 6, 2022, 9:18pm
4
Thank you very much for your post Here is the output of the inxi:
ξ² β ξ² 15s ο
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=78c1631b-1cd7-459f-b0b2-ec4f079e5034 rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: GSCN23WW date: 05/11/2021
ID-1: BAT0 charge: 69.2 Wh (90.3%) condition: 76.6/75.0 Wh (102.1%)
volts: 17.2 min: 15.4 model: SMP L20M4PE1 type: Li-ion serial: <filter>
status: Charging
RAM: total: 13.57 GiB used: 2.57 GiB (19.0%)
RAM Report:
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1290 high: 1682 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1437 2: 1396
3: 1197 4: 1197 5: 1682 6: 1394 7: 1197 8: 1197 9: 1196 10: 1197 11: 1194
12: 1197 bogomips: 79091
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.0-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Realtek vendor: Lenovo driver: rtw89_pci v: kernel port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 8 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 90.75 GiB (19.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512TDV
lanes: 4 type: SSD serial: <filter> rev: 3006P4LN temp: 33.9 C scheme: GPT
ID-1: / raw-size: 371.09 GiB size: 364.2 GiB (98.14%)
used: 90.71 GiB (24.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 78c1631b-1cd7-459f-b0b2-ec4f079e5034
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 41.9 MiB (16.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: DA33-721C
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 104.6 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: A004349B043475FE
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Device-2: 3-4:3 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 20.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
Processes: 329 Uptime: 1d 6h 1m wakeups: 9503 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1238 lib: 390
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
ο ξ° ο ~ ξ° ξ² ο ξ° ο ~ ξ° inxi --admin --verbosity=7 --filter --width ξ² β
ID-1: BAT0 charge: 69.5 Wh (90.7%) condition: 76.6/75.0 Wh (102.1%)
volts: 17.3 min: 15.4 model: SMP L20M4PE1 type: Li-ion serial: <filter>
status: Charging
RAM: total: 13.57 GiB used: 2.64 GiB (19.5%)
RAM Report:
Speed (MHz): avg: 1403 high: 3167 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1312
3: 1197 4: 1197 5: 1397 6: 1395 7: 1196 8: 1196 9: 1197 10: 1196 11: 3167
lanes: 4 type: SSD serial: <filter> rev: 3006P4LN temp: 30.9 C scheme: GPT
System Temperatures: cpu: 20.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 330 Uptime: 1d 6h 2m wakeups: 9779 Init: systemd v: 250
I willtest 5.10. But why exactly this one? 5.15.12 was pre-installed.
spi12
January 7, 2022, 6:21am
5
Tried 5.10, but there was no Wifi again And i cannot tell if i my headset works without a citrix connection.
5.10 is an older (proven) LTS kernel. 5.15 is the newest LTS kernel (but not as proven yet)
spi12
January 7, 2022, 9:21pm
7
Guess i was wrong all the time
No Headset is connecting at all, it just flaps between connected and not connected. Just a few tries and stays unconnected.
My iphone was already connected to Bluetooth, this way i got the new kernel installed.
Any idea?
