Having wifi issue
Hi Manjaro Team,
I am using Manjaro Linux, and whenever I connect to the 5GHz WiFi, the speed decreases. I mean when i connected it with 5g network it is not getting the actual speed. The speed is fine when connecting to the 2.4GHz WiFi. In the case of Ubuntu, it works well.
kindly help
  Kernel: 6.5.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=37bcf712-d0fd-40bb-8d9b-1b3f9e42dddd rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: LENOVO product: 83BF v: IdeaPad Slim 5 14IAH8
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 5 14IAH8
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
    serial: <superuser required> UEFI: LENOVO v: LACN29WW date: 09/01/2023
  ID-1: BAT1 charge: 54.2 Wh (94.8%) condition: 57.2/56.6 Wh (101.0%)
    power: 12.8 W volts: 13.1 min: 11.5 model: LGES L22L3PA42 type: Unknown
    serial: <filter> status: charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
    charge: 50% (should be ignored) rechargeable: yes status: N/A
  Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x430
  Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
    cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB L2: 7 MiB
    desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 471 high: 1025 min/max: 400/4400:3300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 636 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 1025 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a3
    class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 04f2:b7b9
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1457 built: 2022 res: 1920x1200
    dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a3 memory: 14.99 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: N/A device: 0 type: integrated-gpu
    name: Intel Graphics (ADL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
    device-ID: 8086:46a3 surfaces: xcb,xlib
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.5.13-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:4853
  Report: rfkill ID: hci0 rfk-id: 12 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 18.78 GiB (3.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN740 SDDPMQD-512G-1101 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 73110001 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 90 GiB size: 88.03 GiB (97.81%) used: 18.74 GiB (21.3%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    used: 35.7 MiB (37.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 298 Uptime: 12h 5m wakeups: 9 Memory: total: 16 GiB note: est.
  available: 15.35 GiB used: 6.07 GiB (39.5%) Init: systemd v: 254
  Packages: 1230 pm: pacman pkgs: 1224 libs: 350 tools: pamac,yay pm: flatpak
  pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole
  inxi: 3.3.31
Hello @Nobita and welcome :wink:
I am not part of the Manjaro Team, but maybe I can help you.
First we need your system information. Here is a tutorial how to do it right:
i have given , thanks for giving me the tutorial for system information.
how can i fix that wifi problem. pls help
Without knowing which module/driver and/or chipset is being used, no one can help as it would be a guess on assumptions.
EDIT: Alright you added the inxi. I’ll take a look.
i have given now inxi@megavolt
please help
@Nobita Questions:
  1. Is Bluetooth enabled when you use WiFi? In reality that can reduce latency and therefore speed, more over on chipset which has both on one chip.
  2. Can you test the signal strength? wavemon is a great terminal tool for that purpose.
pamac install wavemon
then run:
wavemon
So test it with 2.4Ghz/5Ghz with and without Bluetooth enabled.
Sorry, there is no general solution, so we need to troubleshoot it and get the correct conditions when it happens.
This a topic seems to be related: Realtek 8852BE Bluetooth and Wifi But the OP sees the problem when bluetooth is enabled.
but in other distro like garuda or ubuntu
it works fine even bluetooth is on.
when it comes to manjaro it’s speed goes slow.
Well, then switch to Manjaro unstable branch, which is actually ArchLinux stable and what Garuda uses. Also use the most current stable kernel. See if that works for you then.
how to switch ?
https://www.kernel.org/
