Hi, I have a laptop which has the Realtek RTW8852BE device, and it has bluetooth and wifi support. I am trying to use bluetooth headphones at the same time as using wifi. I have tried both using kernel versions 6.5 and 6.1 (LTS). Wifi works fine (it works in 6.1 if you install the 61 headers and rtw89 drivers from the AUR, and works out-of-the-box with 6.5).
The bluetooth is able to connect and play audio, but the audio goes silent for about a second or so every few seconds. If I turn off wifi, this does not happen and the bluetooth is fine. I have tried using the network manager to set the WIFI to only operate on the 5GHz band, but that also did not help.
The laptop is dual booted with manjaro and windows 11. I do not experience this problem on windows 11.
Here is some system information:
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=30b0338a-fead-4e6a-9db6-a652666ba555 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: LENOVO product: 82RQ v: IdeaPad 3 17ABA7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 17ABA7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465WIN
serial: <superuser required> UEFI: LENOVO v: JTCN37WW date: 07/20/2022
ID-1: BAT0 charge: 12.3 Wh (26.8%) condition: 45.9/45.0 Wh (102.0%)
power: 8.8 W volts: 10.8 min: 11.1 model: LGC L20L3PF0 type: Li-poly
serial: <filter> status: discharging cycles: 40
System RAM: total: 24 GiB note: est. available: 21.35 GiB
used: 3.08 GiB (14.4%)
Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1715 high: 2542 min/max: 1600/4387 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1600
3: 2271 4: 1398 5: 1982 6: 1600 7: 1600 8: 1600 9: 1398 10: 2542 11: 1600
12: 1600 bogomips: 55124
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300
temp: 38.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2465
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x09c1 built: 2020 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.49 6.1.55-1-MANJARO) device-ID: 1002:15e7 memory: 1.95 GiB
unified: no
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:15e7 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: N/A
modules: rtw_8852be pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.81 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
Local Storage: total: 931.51 GiB used: 75.23 GiB (8.1%)
model: WD Green SN350 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 33006000 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 450.52 GiB size: 442.37 GiB (98.19%) used: 75.2 GiB (17.0%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 30b0338a-fead-4e6a-9db6-a652666ba555
used: 31.7 MiB (33.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CCEB-8AFD
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 480.27 GiB fs: ntfs label: N/A
uuid: 422EEC182EEC072F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 625 MiB fs: ntfs label: N/A
uuid: AE5667BD566784C5
Device-1: 1-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-3:3 info: Syntek Integrated Camera type: video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 174f:2465 class-ID: fe01 serial: <filter>
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:550a class-ID: ff00
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
System Temperatures: cpu: 45.9 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (rpm): N/A
Processes: 280 Uptime: 36m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1868 libs: 357 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.31
Does anyone know how I can fix this?
Update: I tested in an Ubuntu live environment, and the bluetooth and wifi work fine together in Ubuntu. So it must be specific to Manjaro. I honestly like Manjaro more than Ubuntu overall, so I would like to get this working in Manjaro, and I feel like it must somehow be possible. Thanks!
