Having trouble updating with pacman - corrupted signatures
I get this error when trying to update the system with pacman -Syu:
error: ncdu: signature from "Daurnimator [daurnimator@archlinux.org](mailto:daurnimator@archlinux.org)" is unknown trust :: File /var/cache/pacman/pkg/ncdu-2.8.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] Y error: failed to commit transaction (invalid or corrupted package) Errors occurred, no packages were upgraded
I originally had a different error, it’s a pretty long story, I probably tried already the basic things, but I would really appreciate if someone more experienced could try troubleshooting this issue with me from the beggining.
Pretty common problem. See:
Use the aggressive method. It is safe to use.
I tried it and unfortunately it didn’t work
Not helpful. Post the terminal output if you really need support. Otherwise: Good luck! And please no pictures… you can copy and paste it and preformat it as code. Thanks.
I wasn’t sure which part to paste and I couldn’t paste it all in a comment (it’s too long) so I pasted it here, I hope it’s fine:
https://paste.ofcode.org/3ZB2mGwAnyx4tg2d7CdBMS
No, all good…
That is a bit strange. The script delete the whole pacman cache, so all downloaded packages and signatures, but still there is only one package downloaded?
Total Download Size:       0.25 MiB
Total Installed Size:  10332.50 MiB
Net Upgrade Size:        603.14 MiB
ncdu-2.8.2-2-x86_64     261.0 KiB  1813 KiB/s 00:00 [###########################] 100%
Is your pacman cache somewhere else?
Not that I know. Is there anyway to check it?
Please share:
cat /etc/pacman.conf
cat /etc/pacman.conf                                          1 ✘  26s 
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
#ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
#SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Normal path… :thinking:
Remove cache:
sudo rm -Rfv /var/cache/pacman/pkg/*
Share the output.
sudo rm -Rfv /var/cache/pacman/pkg/*                                    ✔
[sudo] password for gideon:
removed '/var/cache/pacman/pkg/abseil-cpp-20250512.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/abseil-cpp-20250512.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/accent-color-change-r155.f57e60f-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/accent-color-change-r155.f57e60f-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/addwater-1.2.6-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/addwater-1.2.6-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/adwaita-cursors-48.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/adwaita-cursors-48.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/adwaita-fonts-48.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/adwaita-fonts-48.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/adwaita-icon-theme-48.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/adwaita-icon-theme-48.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/adw-gtk-theme-6.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/adw-gtk-theme-6.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/alacarte-1:3.56.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/alacarte-1:3.56.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/alsa-card-profiles-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/alsa-card-profiles-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/alsa-lib-1.2.14-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/alsa-lib-1.2.14-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/alsa-ucm-conf-1.2.14-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/alsa-ucm-conf-1.2.14-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/alsa-utils-1.2.14-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/alsa-utils-1.2.14-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/android-udev-20250525-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/android-udev-20250525-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/aom-3.12.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/aom-3.12.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/apache-2.4.63-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/apache-2.4.63-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/apparmor-4.1.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/apparmor-4.1.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/appstream-1.0.5-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/appstream-1.0.5-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/apr-1.7.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/apr-1.7.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/archlinux-appstream-data-20250529-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/archlinux-appstream-data-20250529-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/at-spi2-core-2.56.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/at-spi2-core-2.56.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/audit-4.0.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/audit-4.0.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/baobab-48.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/baobab-48.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bash-5.2.037-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bash-5.2.037-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bc-1.08.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bc-1.08.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/binutils-2.44+r94+gfe459e33c676-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/binutils-2.44+r94+gfe459e33c676-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bluez-5.83-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bluez-5.83-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bluez-libs-5.83-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bluez-libs-5.83-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bluez-obex-5.83-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bluez-obex-5.83-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/bolt-0.9.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/bolt-0.9.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/boost-libs-1.88.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/boost-libs-1.88.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/breeze-icons-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/breeze-icons-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/btop-1.4.3-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/btop-1.4.3-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/btrfs-progs-6.14-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/btrfs-progs-6.14-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ca-certificates-mozilla-3.112-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ca-certificates-mozilla-3.112-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cairo-1.18.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cairo-1.18.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/capstone-5.0.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/capstone-5.0.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/chromaprint-1.5.1-10-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/chromaprint-1.5.1-10-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/chromium-138.0.7204.92-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/chromium-138.0.7204.92-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cifs-utils-7.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cifs-utils-7.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ckbcomp-1.227-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ckbcomp-1.227-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/clang-20.1.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/clang-20.1.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cmus-2.12.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cmus-2.12.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/compiler-rt-20.1.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/compiler-rt-20.1.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/composefs-1.0.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/composefs-1.0.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/coreutils-9.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/coreutils-9.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cpupower-6.15-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cpupower-6.15-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cups-2:2.4.12-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cups-2:2.4.12-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cups-pdf-3.0.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cups-pdf-3.0.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/curl-8.14.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/curl-8.14.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/cython-3.1.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/cython-3.1.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dbus-1.16.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dbus-1.16.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dbus-broker-37-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dbus-broker-37-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dbus-broker-units-37-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dbus-broker-units-37-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dbus-glib-0.114-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dbus-glib-0.114-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dconf-editor-45.0.1-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dconf-editor-45.0.1-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/deja-dup-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/deja-dup-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/device-mapper-2.03.32-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/device-mapper-2.03.32-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dhcpcd-10.2.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dhcpcd-10.2.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dialog-1:1.3_20250116-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dialog-1:1.3_20250116-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/diffutils-3.12-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/diffutils-3.12-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dnsmasq-2.91-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dnsmasq-2.91-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/dnssec-anchors-20250524-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dnssec-anchors-20250524-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/double-conversion-3.3.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/double-conversion-3.3.1-1-x86_64.pkg.tar.zst.sig'
removed directory '/var/cache/pacman/pkg/download-pmG1Q6'
removed directory '/var/cache/pacman/pkg/download-WajfHF'
removed '/var/cache/pacman/pkg/dtc-1.7.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/dtc-1.7.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/duplicity-3.0.4.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/duplicity-3.0.4.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/e2fsprogs-1.47.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/e2fsprogs-1.47.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/eglexternalplatform-1.2.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/eglexternalplatform-1.2.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/egl-gbm-1.1.2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/egl-gbm-1.1.2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/egl-wayland-4:1.1.19-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/egl-wayland-4:1.1.19-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/egl-x11-1.0.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/egl-x11-1.0.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/enchant-2.8.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/enchant-2.8.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/evince-48.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/evince-48.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/evolution-data-server-3.56.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/evolution-data-server-3.56.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/exempi-2.6.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/exempi-2.6.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/exfatprogs-1.2.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/exfatprogs-1.2.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/exiv2-0.28.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/exiv2-0.28.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/expat-2.7.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/expat-2.7.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/faac-1.31.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/faac-1.31.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/faad2-2.11.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/faad2-2.11.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fakeroot-1.37.1.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fakeroot-1.37.1.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ffmpeg-2:7.1.1-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ffmpeg-2:7.1.1-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/file-5.46-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/file-5.46-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/file-roller-44.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/file-roller-44.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/filesystem-2025.05.03-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/filesystem-2025.05.03-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/flac-1.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/flac-1.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/flatpak-1:1.16.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/flatpak-1:1.16.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fluidsynth-2.4.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fluidsynth-2.4.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/folks-0.15.9-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/folks-0.15.9-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fontconfig-2:2.16.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fontconfig-2:2.16.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/foomatic-db-engine-5:20200131-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/foomatic-db-engine-5:20200131-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/foomatic-db-gutenprint-ppds-5.3.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/foomatic-db-gutenprint-ppds-5.3.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fprintd-1.94.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fprintd-1.94.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/freeglut-3.6.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/freeglut-3.6.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fribidi-1.0.16-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fribidi-1.0.16-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fuse3-3.17.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fuse3-3.17.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fuse-common-3.17.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fuse-common-3.17.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fwupd-2.0.12-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fwupd-2.0.12-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/fzf-0.62.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/fzf-0.62.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gawk-5.3.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gawk-5.3.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gcc-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gcc-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gcr-4-4.4.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gcr-4-4.4.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gdbm-1.25-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gdbm-1.25-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gdm-48.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gdm-48.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/geary-1:46.0-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/geary-1:46.0-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gedit-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gedit-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gettext-0.25-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gettext-0.25-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gfxstream-0.1.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gfxstream-0.1.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ghostscript-10.05.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ghostscript-10.05.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/giflib-5.2.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/giflib-5.2.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/git-2.50.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/git-2.50.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gjs-2:1.84.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gjs-2:1.84.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glib2-2.84.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glib2-2.84.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glib2-devel-2.84.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glib2-devel-2.84.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glibc-locales-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glibc-locales-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glibmm-2.66.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glibmm-2.66.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glibmm-2.68-2.84.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glibmm-2.68-2.84.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glm-1.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glm-1.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/glslang-1:1.4.313.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/glslang-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gmime3-3.2.15-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gmime3-3.2.15-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-backgrounds-48.2.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-backgrounds-48.2.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-bluetooth-3.0-47.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-bluetooth-3.0-47.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-boxes-48.0-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-boxes-48.0-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-calculator-48.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-calculator-48.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-calendar-48.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-calendar-48.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-characters-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-characters-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-chess-48.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-chess-48.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-clocks-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-clocks-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-console-48.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-console-48.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-contacts-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-contacts-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-control-center-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-control-center-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-desktop-1:44.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-desktop-1:44.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-desktop-4-1:44.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-desktop-4-1:44.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-desktop-common-1:44.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-desktop-common-1:44.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-disk-utility-46.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-disk-utility-46.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-firmware-47.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-firmware-47.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-font-viewer-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-font-viewer-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-keybindings-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-keybindings-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-keyring-1:48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-keyring-1:48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-layout-switcher-0.8.39-3-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-layout-switcher-0.8.39-3-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-logs-45.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-logs-45.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-mimeapps-0.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-mimeapps-0.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-mines-48.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-mines-48.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-online-accounts-3.54.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-online-accounts-3.54.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-session-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-session-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-settings-daemon-48.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-settings-daemon-48.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-1:48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-1:48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-appindicator-1:60-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-appindicator-1:60-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-arc-menu-66-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-arc-menu-66-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-dash-to-panel-68-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-dash-to-panel-68-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-forge-88-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-forge-88-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gnome-ui-tune-1.10.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gnome-ui-tune-1.10.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gsconnect-66-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gsconnect-66-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gtk4-desktop-icons-ng-1:100.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-gtk4-desktop-icons-ng-1:100.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-legacy-theme-auto-switcher-r25.3d6b167-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-legacy-theme-auto-switcher-r25.3d6b167-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extensions-48.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extensions-48.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-space-bar-33-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-space-bar-33-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-shell-extension-x11gestures-25-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-shell-extension-x11gestures-25-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-system-monitor-48.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-system-monitor-48.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-terminal-3.56.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-terminal-3.56.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-user-docs-48.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-user-docs-48.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-user-share-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-user-share-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnome-weather-48.0-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnome-weather-48.0-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnuchess-6.2.11-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnuchess-6.2.11-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gnutls-3.8.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gnutls-3.8.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gobject-introspection-runtime-1.84.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gobject-introspection-runtime-1.84.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gpgme-2.0.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gpgme-2.0.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gpgmepp-2.0.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gpgmepp-2.0.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/grep-3.12-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/grep-3.12-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/grilo-0.3.19-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/grilo-0.3.19-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/grilo-plugins-1:0.3.17-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/grilo-plugins-1:0.3.17-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gsettings-desktop-schemas-48.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gsettings-desktop-schemas-48.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gsettings-system-schemas-48.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gsettings-system-schemas-48.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gspell-1.14.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gspell-1.14.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-devtools-libs-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-devtools-libs-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-editing-services-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-editing-services-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-libav-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-libav-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugin-gtk-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugin-gtk-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugin-gtk4-0.13.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugin-gtk4-0.13.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugin-pipewire-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugin-pipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-bad-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-bad-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-bad-libs-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-bad-libs-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-base-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-base-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-base-libs-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-base-libs-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-good-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-good-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-plugins-ugly-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-plugins-ugly-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gst-python-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gst-python-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gstreamer-1.26.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gstreamer-1.26.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtest-1.17.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtest-1.17.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gthumb-3.12.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gthumb-3.12.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtk3-1:3.24.49-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtk3-1:3.24.49-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtk4-1:4.18.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtk4-1:4.18.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtkmm3-3.24.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtkmm3-3.24.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtkmm-4.0-4.18.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtkmm-4.0-4.18.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtksourceview3-1:3.24.11+r30+gd880929f-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtksourceview3-1:3.24.11+r30+gd880929f-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtksourceview4-4.8.4-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtksourceview4-4.8.4-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtksourceview5-5.16.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtksourceview5-5.16.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtk-update-icon-cache-1:4.18.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtk-update-icon-cache-1:4.18.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gtk-vnc-1.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gtk-vnc-1.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gufw-26.04-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gufw-26.04-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gupnp-1:1.6.8-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gupnp-1:1.6.8-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gupnp-av-0.14.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gupnp-av-0.14.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gupnp-dlna-0.12.0-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gupnp-dlna-0.12.0-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gupnp-igd-1.6.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gupnp-igd-1.6.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gutenprint-5.3.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gutenprint-5.3.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-afc-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-afc-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-goa-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-goa-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-google-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-google-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-gphoto2-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-gphoto2-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-mtp-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-mtp-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-nfs-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-nfs-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gvfs-smb-1.57.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gvfs-smb-1.57.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/gzip-1.14-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/gzip-1.14-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/harfbuzz-11.2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/harfbuzz-11.2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/harfbuzz-icu-11.2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/harfbuzz-icu-11.2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/hidapi-0.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/hidapi-0.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/hplip-1:3.25.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/hplip-1:3.25.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/htop-3.4.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/htop-3.4.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/hwdata-0.396-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/hwdata-0.396-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/hwinfo-24.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/hwinfo-24.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/hwloc-2.12.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/hwloc-2.12.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iagno-3.38.1+r125+ge144444-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iagno-3.38.1+r125+ge144444-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iana-etc-20250502-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iana-etc-20250502-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ibus-1.5.32-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ibus-1.5.32-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/icu-76.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/icu-76.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iio-sensor-proxy-3.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iio-sensor-proxy-3.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/imagemagick-7.1.1.47-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/imagemagick-7.1.1.47-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/imath-3.1.12-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/imath-3.1.12-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/imlib2-1.12.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/imlib2-1.12.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/inetutils-2.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/inetutils-2.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iniparser-4.2.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iniparser-4.2.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/intel-ucode-20250512-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/intel-ucode-20250512-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/inxi-3.3.38.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/inxi-3.3.38.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iperf-2.2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iperf-2.2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iproute2-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iproute2-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iptables-1:1.8.11-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iptables-1:1.8.11-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iputils-20250605-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iputils-20250605-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/iso-codes-4.18.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/iso-codes-4.18.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/jansson-2.14.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/jansson-2.14.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/js115-115.24.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/js115-115.24.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/js128-128.11.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/js128-128.11.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/json-c-0.18-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/json-c-0.18-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/karchive-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/karchive-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kauth-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kauth-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kbd-2.8.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kbd-2.8.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kbookmarks-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kbookmarks-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kcodecs-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kcodecs-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kcolorscheme-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kcolorscheme-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kcompletion-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kcompletion-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kconfig-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kconfig-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kconfigwidgets-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kconfigwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kcoreaddons-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kcoreaddons-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kcrash-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kcrash-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kdbusaddons-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kdbusaddons-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kdialog-25.04.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kdialog-25.04.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kguiaddons-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kguiaddons-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ki18n-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ki18n-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kiconthemes-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kiconthemes-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kio5-5.116.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kio5-5.116.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kio-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kio-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kitemviews-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kitemviews-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kjobwidgets-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kjobwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kmod-34.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kmod-34.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/knotifications-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/knotifications-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kservice-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kservice-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ktextwidgets-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ktextwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kwallet5-5.116.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kwallet5-5.116.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kwallet-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kwallet-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kwidgetsaddons-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kwidgetsaddons-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/kwindowsystem-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/kwindowsystem-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lcms2-2.17-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lcms2-2.17-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ldb-2:4.22.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ldb-2:4.22.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/leancrypto-1.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/leancrypto-1.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-curl-8.14.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-curl-8.14.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-expat-2.7.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-expat-2.7.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-icu-76.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-icu-76.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-json-c-0.18-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-json-c-0.18-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libelf-0.193-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libelf-0.193-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libffi-3.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libffi-3.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libldap-2.6.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libldap-2.6.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libnghttp2-1.66.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libnghttp2-1.66.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libnghttp3-1.10.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libnghttp3-1.10.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libssh2-1.11.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libssh2-1.11.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libunistring-1.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libunistring-1.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libx11-1.8.12-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libx11-1.8.12-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libxml2-2.14.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libxml2-2.14.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-libxshmfence-1.3.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-libxshmfence-1.3.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-llvm-libs-1:20.1.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-llvm-libs-1:20.1.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-lm_sensors-1:3.6.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-lm_sensors-1:3.6.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-mesa-1:25.1.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-mesa-1:25.1.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-ncurses-6.5-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-ncurses-6.5-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-nvidia-utils-575.64-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-nvidia-utils-575.64-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-openssl-1:3.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-openssl-1:3.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-xz-5.8.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-xz-5.8.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lib32-zstd-1.5.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lib32-zstd-1.5.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libadwaita-1:1.7.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libadwaita-1:1.7.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libaemu-0.1.2-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libaemu-0.1.2-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libarchive-3.8.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libarchive-3.8.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libavif-1.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libavif-1.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libayatana-appindicator-0.5.94-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libayatana-appindicator-0.5.94-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-crypto-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-crypto-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-fs-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-fs-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-loop-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-loop-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-mdraid-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-mdraid-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-nvme-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-nvme-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-part-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-part-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libblockdev-swap-3.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libblockdev-swap-3.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libbluray-1.3.4-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libbluray-1.3.4-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libbpf-1.5.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libbpf-1.5.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcamera-0.5.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcamera-0.5.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcamera-ipa-0.5.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcamera-ipa-0.5.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcap-2.76-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcap-2.76-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcbor-0.12.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcbor-0.12.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcloudproviders-0.3.6-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcloudproviders-0.3.6-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcups-2:2.4.12-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcups-2:2.4.12-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libcupsfilters-2.1.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libcupsfilters-2.1.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libde265-1.0.16-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libde265-1.0.16-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libdecor-0.2.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libdecor-0.2.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libdiscid-0.6.5-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libdiscid-0.6.5-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libdrm-2.4.125-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libdrm-2.4.125-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libebur128-1.2.6-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libebur128-1.2.6-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libedataserverui4-3.56.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libedataserverui4-3.56.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libedit-20250104_3.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libedit-20250104_3.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libei-1.4.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libei-1.4.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libelf-0.193-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libelf-0.193-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libevdev-1.13.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libevdev-1.13.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libfabric-2.1.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libfabric-2.1.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libffi-3.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libffi-3.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libfprint-1.94.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libfprint-1.94.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libfreeaptx-0.2.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libfreeaptx-0.2.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgcrypt-1.11.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgcrypt-1.11.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgdata-0.18.1-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgdata-0.18.1-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgdm-48.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgdm-48.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgedit-amtk-5.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgedit-amtk-5.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgedit-gfls-1:0.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgedit-gfls-1:0.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgedit-gtksourceview-299.5.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgedit-gtksourceview-299.5.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgedit-tepl-6.13.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgedit-tepl-6.13.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgexiv2-0.14.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgexiv2-0.14.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgirepository-1.84.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgirepository-1.84.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgit2-1:1.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgit2-1:1.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libglvnd-1.7.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libglvnd-1.7.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgme-0.6.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgme-0.6.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgnome-games-support-2-2.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgnome-games-support-2-2.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgoa-3.54.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgoa-3.54.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgpg-error-1.55-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgpg-error-1.55-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgphoto2-2.5.31-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgphoto2-2.5.31-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgrss-0.7.0+16+g971c421-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgrss-0.7.0+16+g971c421-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgsf-1.14.53-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgsf-1.14.53-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgudev-238-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgudev-238-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgusb-0.4.9-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgusb-0.4.9-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libgweather-4-4.4.4-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libgweather-4-4.4.4-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libheif-1.19.8-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libheif-1.19.8-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libibus-1.5.32-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libibus-1.5.32-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libical-3.0.20-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libical-3.0.20-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libidn-1.43-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libidn-1.43-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libimagequant-4.3.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libimagequant-4.3.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libimobiledevice-1.3.0-16-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libimobiledevice-1.3.0-16-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libimobiledevice-glue-1.3.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libimobiledevice-glue-1.3.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libinput-1.28.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libinput-1.28.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libinstpatch-1.1.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libinstpatch-1.1.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libjcat-0.2.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libjcat-0.2.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libjxl-0.11.1-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libjxl-0.11.1-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libksba-1.6.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libksba-1.6.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/liblc3-1.1.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/liblc3-1.1.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libldap-2.6.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libldap-2.6.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmanette-0.2.12-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmanette-0.2.12-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmbim-1.32.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmbim-1.32.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmediaart-1.9.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmediaart-1.9.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmfx-23.2.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmfx-23.2.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmm-glib-1.24.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmm-glib-1.24.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libmysofa-1.3.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libmysofa-1.3.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnautilus-extension-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnautilus-extension-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnbd-1.22.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnbd-1.22.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnewt-0.52.25-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnewt-0.52.25-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnfs-6.0.2-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnfs-6.0.2-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnftnl-1.2.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnftnl-1.2.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnghttp2-1.66.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnghttp2-1.66.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnghttp3-1.10.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnghttp3-1.10.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnice-0.1.22-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnice-0.1.22-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnm-1.52.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnm-1.52.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnotify-0.8.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnotify-0.8.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libnvme-1.13-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libnvme-1.13-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libopenmpt-0.8.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libopenmpt-0.8.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libosinfo-1.12.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libosinfo-1.12.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpamac-11.7.3-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpamac-11.7.3-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpamac-flatpak-plugin-11.7.3-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpamac-flatpak-plugin-11.7.3-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpamac-snap-plugin-11.7.3-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpamac-snap-plugin-11.7.3-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpcap-1.10.5-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpcap-1.10.5-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpeas-1.36.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpeas-1.36.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libphonenumber-1:9.0.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libphonenumber-1:9.0.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpipewire-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libplacebo-7.351.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libplacebo-7.351.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libplist-2.7.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libplist-2.7.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libpng-1.6.49-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libpng-1.6.49-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libportal-0.9.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libportal-0.9.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libportal-gtk3-0.9.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libportal-gtk3-0.9.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libportal-gtk4-0.9.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libportal-gtk4-0.9.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libppd-2.1.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libppd-2.1.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libqmi-1.36.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libqmi-1.36.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libqrtr-glib-1.2.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libqrtr-glib-1.2.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/librest-0.9.1-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/librest-0.9.1-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/librsvg-2:2.60.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/librsvg-2:2.60.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libseccomp-2.5.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libseccomp-2.5.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsecret-0.21.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsecret-0.21.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libshout-1:2.4.6-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libshout-1:2.4.6-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libslirp-4.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libslirp-4.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsm-1.2.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsm-1.2.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsndfile-1.2.2-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsndfile-1.2.2-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsoup-2.74.3-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsoup-2.74.3-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsoup3-3.6.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsoup3-3.6.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libspeechd-0.12.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libspeechd-0.12.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsrtp-1:2.7.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsrtp-1:2.7.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libstemmer-3.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libstemmer-3.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsynctex-2025.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsynctex-2025.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libsysprof-capture-48.0-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libsysprof-capture-48.0-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libtasn1-4.20.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libtasn1-4.20.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libtheora-1.2.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libtheora-1.2.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libtirpc-1.3.6-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libtirpc-1.3.6-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libtool-2.5.4+r23+g5b582aed-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libtool-2.5.4+r23+g5b582aed-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libtracefs-1.8.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libtracefs-1.8.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/liburcu-0.15.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/liburcu-0.15.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/liburing-2.11-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/liburing-2.11-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libusb-1.0.29-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libusb-1.0.29-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libusbmuxd-2.1.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libusbmuxd-2.1.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libutempter-1.2.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libutempter-1.2.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libvirt-1:11.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libvirt-1:11.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libvirt-glib-5.0.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libvirt-glib-5.0.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libvpl-2.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libvpl-2.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libwacom-2.16.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libwacom-2.16.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libwbclient-2:4.22.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libwbclient-2:4.22.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libwireplumber-0.5.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libwireplumber-0.5.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libwpe-1.16.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libwpe-1.16.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libx11-1.8.12-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libx11-1.8.12-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libx86emu-3.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libx86emu-3.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxdp-1.5.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxdp-1.5.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxft-2.3.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxft-2.3.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxkbcommon-1.10.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxkbcommon-1.10.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxkbcommon-x11-1.10.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxkbcommon-x11-1.10.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxklavier-5.4-6-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxklavier-5.4-6-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxml2-2.14.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxml2-2.14.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxmlb-0.3.22-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxmlb-0.3.22-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxnvctrl-575.64-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxnvctrl-575.64-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/libxslt-1.1.43-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/libxslt-1.1.43-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lilv-0.24.26-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lilv-0.24.26-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/linux515-5.15.185-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/linux515-5.15.185-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/linux515-nvidia-575.64-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/linux515-nvidia-575.64-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/linux-api-headers-6.15-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/linux-api-headers-6.15-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/linux-firmware-20250508.788aadc8-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/linux-firmware-20250508.788aadc8-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/linux-firmware-whence-20250508.788aadc8-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/linux-firmware-whence-20250508.788aadc8-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/llvm-20.1.6-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/llvm-20.1.6-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/llvm-libs-20.1.6-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/llvm-libs-20.1.6-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lm_sensors-1:3.6.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lm_sensors-1:3.6.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/localsearch-3.9.0-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/localsearch-3.9.0-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lollypop-1.4.41-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lollypop-1.4.41-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lua-5.4.8-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lua-5.4.8-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/lvm2-2.03.32-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/lvm2-2.03.32-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/man-db-2.13.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/man-db-2.13.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-application-utility-1.4.1-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-application-utility-1.4.1-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-gnome-extension-settings-20250311-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-gnome-extension-settings-20250311-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-gnome-settings-20250504-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-gnome-settings-20250504-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-hello-0.8.1-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-hello-0.8.1-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-release-25.0.4-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-release-25.0.4-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-settings-manager-0.5.8-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-settings-manager-0.5.8-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-settings-manager-notifier-0.5.8-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-settings-manager-notifier-0.5.8-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/manjaro-zsh-config-0.26-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/manjaro-zsh-config-0.26-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/man-pages-6.14-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/man-pages-6.14-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mbedtls2-2.28.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mbedtls2-2.28.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mbedtls-3.6.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mbedtls-3.6.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mesa-1:25.1.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mesa-1:25.1.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mesa-utils-9.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mesa-utils-9.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mhwd-0.6.6-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mhwd-0.6.6-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mhwd-db-20250113-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mhwd-db-20250113-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mhwd-nvidia-390xx-390.157-21-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mhwd-nvidia-390xx-390.157-21-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mhwd-nvidia-470xx-470.256.02-14-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mhwd-nvidia-470xx-470.256.02-14-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mhwd-nvidia-575.64-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mhwd-nvidia-575.64-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/miniupnpc-2.3.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/miniupnpc-2.3.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/modemmanager-1.24.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/modemmanager-1.24.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mpdecimal-4.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mpdecimal-4.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mpfr-4.2.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mpfr-4.2.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mpg123-1.33.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mpg123-1.33.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mtools-1:4.0.49-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mtools-1:4.0.49-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/mutter-48.3.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/mutter-48.3.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nano-8.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nano-8.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nautilus-48.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nautilus-48.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nautilus-admin-1:1.2.0-3-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nautilus-admin-1:1.2.0-3-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ncurses-6.5-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ncurses-6.5-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/neon-0.34.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/neon-0.34.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/networkmanager-1.52.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/networkmanager-1.52.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/networkmanager-openconnect-1.2.10-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/networkmanager-openconnect-1.2.10-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/networkmanager-strongswan-1.6.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/networkmanager-strongswan-1.6.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nfsidmap-2.8.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nfsidmap-2.8.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nfs-utils-2.8.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nfs-utils-2.8.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nftables-1:1.1.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nftables-1:1.1.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/noto-fonts-1:2025.06.01-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/noto-fonts-1:2025.06.01-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nss-3.112-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nss-3.112-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ntfs-3g-2022.10.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ntfs-3g-2022.10.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ntp-4.2.8.p18-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ntp-4.2.8.p18-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nvidia-driver-assistant-0.21.57.08-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nvidia-driver-assistant-0.21.57.08-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/nvidia-utils-575.64-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/nvidia-utils-575.64-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/oath-toolkit-2.6.12-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/oath-toolkit-2.6.12-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ocl-icd-2.3.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ocl-icd-2.3.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/onlyoffice-desktopeditors-9.0.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/onlyoffice-desktopeditors-9.0.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openal-1.24.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openal-1.24.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openconnect-1:9.12-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openconnect-1:9.12-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openexr-3.3.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openexr-3.3.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openh264-2.6.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openh264-2.6.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openmpi-5.0.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openmpi-5.0.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openpmix-5.0.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openpmix-5.0.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openresolv-3.16.5-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openresolv-3.16.5-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openssh-10.0p1-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openssh-10.0p1-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openssl-3.5.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openssl-3.5.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openucx-1.18.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openucx-1.18.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/openvpn-2.6.14-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/openvpn-2.6.14-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/orc-0.4.41-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/orc-0.4.41-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/osinfo-db-20250606-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/osinfo-db-20250606-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/os-prober-1.83-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/os-prober-1.83-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ostree-2025.2-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ostree-2025.2-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pacman-7.0.0.r10.ga2d0293-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pacman-7.0.0.r10.ga2d0293-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pacman-contrib-1.12.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pacman-contrib-1.12.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pacman-mirrors-5.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pacman-mirrors-5.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pacui-1.14+100+g4fb3daa-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pacui-1.14+100+g4fb3daa-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pam-1.7.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pam-1.7.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pamac-cli-11.7.3-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pamac-cli-11.7.3-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pamac-gnome-integration-11.7.3-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pamac-gnome-integration-11.7.3-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pamac-gtk-11.7.3-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pamac-gtk-11.7.3-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pango-1:1.56.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pango-1:1.56.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/papirus-icon-theme-20250501-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/papirus-icon-theme-20250501-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/papirus-maia-icon-theme-20201007-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/papirus-maia-icon-theme-20201007-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/passim-0.1.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/passim-0.1.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pcre2-10.45-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pcre2-10.45-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pcsclite-2.3.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pcsclite-2.3.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-5.40.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-5.40.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-alien-libxml2-0.20-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-alien-libxml2-0.20-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-error-0.17030-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-error-0.17030-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-libwww-6.78-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-libwww-6.78-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-path-tiny-0.148-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-path-tiny-0.148-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/perl-xml-libxml-2.0210-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/perl-xml-libxml-2.0210-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/phodav-3.0-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/phodav-3.0-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pipewire-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pipewire-audio-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pipewire-audio-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pipewire-session-manager-1:1.4.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pipewire-session-manager-1:1.4.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pixman-0.46.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pixman-0.46.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pkcs11-helper-1.30.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pkcs11-helper-1.30.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pkgfile-24-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pkgfile-24-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/plymouth-24.004.60-12-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/plymouth-24.004.60-12-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/poppler-25.06.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/poppler-25.06.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/poppler-glib-25.06.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/poppler-glib-25.06.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/power-profiles-daemon-0.30-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/power-profiles-daemon-0.30-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/procps-ng-4.0.5-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/procps-ng-4.0.5-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/protobuf-31.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/protobuf-31.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/protobuf-c-1.5.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/protobuf-c-1.5.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/prrte-3.0.11-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/prrte-3.0.11-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pugixml-1.15-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pugixml-1.15-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/pyside6-6.9.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/pyside6-6.9.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-3.13.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-3.13.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-aiohappyeyeballs-2.6.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-aiohappyeyeballs-2.6.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-aiohttp-3.12.13-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-aiohttp-3.12.13-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-aiosignal-1.3.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-aiosignal-1.3.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-argcomplete-3.5.3-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-argcomplete-3.5.3-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-attrs-25.3.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-attrs-25.3.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-bcrypt-4.3.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-bcrypt-4.3.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-beautifulsoup4-4.13.3-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-beautifulsoup4-4.13.3-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-cairo-1.28.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-cairo-1.28.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-certifi-2025.06.15-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-certifi-2025.06.15-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-cgi-3.13.0-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-cgi-3.13.0-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-charset-normalizer-3.4.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-charset-normalizer-3.4.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-click-8.1.8-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-click-8.1.8-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-cryptography-45.0.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-cryptography-45.0.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-cssselect2-0.8.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-cssselect2-0.8.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-dbus-1.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-dbus-1.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-filelock-3.18.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-filelock-3.18.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-frozenlist-1.7.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-frozenlist-1.7.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-gobject-3.52.3-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-gobject-3.52.3-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-googleapis-common-protos-1.70.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-googleapis-common-protos-1.70.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-google-auth-2.38.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-google-auth-2.38.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-jinja-1:3.1.6-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-jinja-1:3.1.6-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-legacy-cgi-2.6.3-2-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-legacy-cgi-2.6.3-2-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-lxml-5.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-lxml-5.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-markupsafe-3.0.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-markupsafe-3.0.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-more-itertools-10.7.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-more-itertools-10.7.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-multidict-6.4.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-multidict-6.4.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-packaging-25.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-packaging-25.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pillow-11.2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pillow-11.2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-ply-3.11-15-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-ply-3.11-15-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-propcache-0.3.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-propcache-0.3.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-protobuf-31.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-protobuf-31.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pyaml-24.12.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pyaml-24.12.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pycurl-7.45.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pycurl-7.45.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pydantic-2.11.7-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pydantic-2.11.7-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pydantic-core-2:2.33.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pydantic-core-2:2.33.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pyopenssl-25.1.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pyopenssl-25.1.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pyparsing-3.2.3-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pyparsing-3.2.3-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-pytz-2025.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-pytz-2025.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-requests-2.32.4-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-requests-2.32.4-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-setproctitle-1.3.5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-setproctitle-1.3.5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-setuptools-1:80.9.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-setuptools-1:80.9.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-tldextract-5.3.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-tldextract-5.3.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-trove-classifiers-2025.5.9.12-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-trove-classifiers-2025.5.9.12-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-typeguard-4.4.4-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-typeguard-4.4.4-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-typing_extensions-4.13.2-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-typing_extensions-4.13.2-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-typing-inspection-0.4.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-typing-inspection-0.4.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-uritemplate-4.2.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-uritemplate-4.2.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-urllib3-2.4.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-urllib3-2.4.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-validate-pyproject-0.24.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-validate-pyproject-0.24.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-wheel-0.45.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-wheel-0.45.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/python-yarl-1.21.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/python-yarl-1.21.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qca-qt5-2.3.10-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qca-qt5-2.3.10-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qca-qt6-2.3.10-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qca-qt6-2.3.10-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-alsa-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-alsa-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-dbus-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-dbus-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-jack-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-jack-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-oss-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-oss-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-pa-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-pa-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-pipewire-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-pipewire-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-sdl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-sdl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-audio-spice-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-audio-spice-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-base-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-base-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-block-curl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-block-curl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-block-dmg-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-block-dmg-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-block-nfs-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-block-nfs-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-block-ssh-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-block-ssh-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-chardev-spice-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-chardev-spice-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-common-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-common-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-desktop-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-desktop-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-qxl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-qxl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-gl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-gl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-gl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-gl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-rutabaga-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-rutabaga-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-gl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-gl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-rutabaga-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-s390x-virtio-gpu-ccw-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-s390x-virtio-gpu-ccw-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-uefi-vars-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-uefi-vars-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-usb-host-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-usb-host-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-usb-redirect-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-usb-redirect-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-hw-usb-smartcard-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-hw-usb-smartcard-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-img-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-img-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-pr-helper-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-pr-helper-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-system-x86-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-system-x86-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-system-x86-firmware-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-system-x86-firmware-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-tools-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-tools-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-curses-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-curses-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-dbus-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-dbus-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-egl-headless-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-egl-headless-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-gtk-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-gtk-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-opengl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-opengl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-sdl-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-sdl-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-spice-app-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-spice-app-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-ui-spice-core-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-ui-spice-core-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qemu-vhost-user-gpu-10.0.0-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qemu-vhost-user-gpu-10.0.0-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qpdf-12.2.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qpdf-12.2.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qrencode-4.1.1-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qrencode-4.1.1-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-base-5.15.17+kde+r123-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-base-5.15.17+kde+r123-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-declarative-5.15.17+kde+r21-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-declarative-5.15.17+kde+r21-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-multimedia-5.15.17+kde+r2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-multimedia-5.15.17+kde+r2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-quickcontrols2-5.15.17+kde+r5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-quickcontrols2-5.15.17+kde+r5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-speech-5.15.17+kde+r1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-speech-5.15.17+kde+r1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-svg-5.15.17+kde+r5-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-svg-5.15.17+kde+r5-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-translations-5.15.17-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-translations-5.15.17-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-wayland-5.15.17+kde+r57-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-wayland-5.15.17+kde+r57-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt5-x11extras-5.15.17-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt5-x11extras-5.15.17-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-5compat-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-5compat-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-base-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-base-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-declarative-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-declarative-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-multimedia-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-multimedia-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-multimedia-ffmpeg-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-multimedia-ffmpeg-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-shadertools-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-shadertools-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-speech-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-speech-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-svg-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-svg-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-translations-6.9.1-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-translations-6.9.1-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/qt6-wayland-6.9.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/qt6-wayland-6.9.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/quadrapassel-40.2-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/quadrapassel-40.2-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ranger-1.9.4-4-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ranger-1.9.4-4-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/raptor-2.0.16-7-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/raptor-2.0.16-7-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/re2-1:20240702-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/re2-1:20240702-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/readline-8.2.013-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/readline-8.2.013-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/run-parts-5.22-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/run-parts-5.22-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/rutabaga-ffi-0.1.6-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/rutabaga-ffi-0.1.6-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/rygel-1:0.44.2-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/rygel-1:0.44.2-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sane-1.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sane-1.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sdl2-compat-2.32.56-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sdl2-compat-2.32.56-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sdl2_image-2.8.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sdl2_image-2.8.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sdl3-3.2.16-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sdl3-3.2.16-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/seahorse-1:47.0.1-3-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/seahorse-1:47.0.1-3-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/shaderc-2025.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/shaderc-2025.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/shadow-4.17.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/shadow-4.17.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/shared-mime-info-2.4-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/shared-mime-info-2.4-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/shiboken6-6.9.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/shiboken6-6.9.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/simple-scan-48.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/simple-scan-48.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/smbclient-2:4.22.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/smbclient-2:4.22.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/s-nail-14.9.25-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/s-nail-14.9.25-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/snapd-2.68.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/snapd-2.68.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/snapd-glib-1.68-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/snapd-glib-1.68-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/snappy-1.2.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/snappy-1.2.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sof-firmware-2025.05-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sof-firmware-2025.05-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/solid-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/solid-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sonnet-6.15.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sonnet-6.15.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/soundtouch-2.4.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/soundtouch-2.4.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/spice-0.16.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/spice-0.16.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/spice-protocol-0.14.5-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/spice-protocol-0.14.5-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sqlite-3.50.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sqlite-3.50.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/squashfs-tools-4.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/squashfs-tools-4.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sratom-0.6.18-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sratom-0.6.18-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/stoken-0.92-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/stoken-0.92-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/strongswan-6.0.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/strongswan-6.0.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/sudo-1.9.17.p1-0.1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/sudo-1.9.17.p1-0.1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/svt-av1-3.0.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/svt-av1-3.0.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/systemd-257.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/systemd-257.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/systemd-libs-257.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/systemd-libs-257.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/systemd-sysvcompat-257.6-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/systemd-sysvcompat-257.6-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/taglib-2.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/taglib-2.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/talloc-2.4.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/talloc-2.4.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/tdb-1.4.13-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/tdb-1.4.13-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/tecla-48.0.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/tecla-48.0.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/tevent-1:0.16.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/tevent-1:0.16.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/texinfo-7.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/texinfo-7.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/tinysparql-3.9.2-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/tinysparql-3.9.2-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/totem-43.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/totem-43.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/totem-pl-parser-3.26.6+r30+g51b8439-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/totem-pl-parser-3.26.6+r30+g51b8439-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/touche-2.0.15-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/touche-2.0.15-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/touchegg-2.0.18-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/touchegg-2.0.18-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/transmission-cli-4.0.6-10-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/transmission-cli-4.0.6-10-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ttf-hack-nerd-3.4.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ttf-hack-nerd-3.4.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/ttf-noto-nerd-3.4.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/ttf-noto-nerd-3.4.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/tzdata-2025b-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/tzdata-2025b-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/unrar-1:7.1.7-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/unrar-1:7.1.7-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/update-grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/update-grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/upower-1.90.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/upower-1.90.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/usb_modeswitch-2.6.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/usb_modeswitch-2.6.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/util-linux-2.41-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/util-linux-2.41-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/util-linux-libs-2.41-4-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/util-linux-libs-2.41-4-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/v4l-utils-1.30.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/v4l-utils-1.30.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/virglrenderer-1.1.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/virglrenderer-1.1.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/virtiofsd-1.13.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/virtiofsd-1.13.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/volume_key-0.3.12-11-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/volume_key-0.3.12-11-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/vte3-0.80.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/vte3-0.80.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/vte4-0.80.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/vte4-0.80.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/vte-common-0.80.2-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/vte-common-0.80.2-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/vulkan-headers-1:1.4.313.0-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/vulkan-headers-1:1.4.313.0-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wayland-1.23.1-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wayland-1.23.1-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wayland-protocols-1.45-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wayland-protocols-1.45-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/webkit2gtk-2.48.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/webkit2gtk-2.48.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/webkit2gtk-4.1-2.48.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/webkit2gtk-4.1-2.48.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/webkitgtk-6.0-2.48.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/webkitgtk-6.0-2.48.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/webrtc-audio-processing-1-1.3-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/webrtc-audio-processing-1-1.3-5-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wget-1.25.0-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wget-1.25.0-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/which-2.23-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/which-2.23-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wireless-regdb-2025.02.20-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wireless-regdb-2025.02.20-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wireplumber-0.5.10-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wireplumber-0.5.10-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/woff2-1.0.2-6-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/woff2-1.0.2-6-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wolfssl-5.8.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wolfssl-5.8.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/wpebackend-fdo-1.16.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/wpebackend-fdo-1.16.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/x265-4.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/x265-4.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xapp-2.8.9-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xapp-2.8.9-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-1.20.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-1.20.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-gnome-48.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-gnome-48.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-gtk-1.15.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xdg-desktop-portal-gtk-1.15.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xfsprogs-6.14.0-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xfsprogs-6.14.0-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xkeyboard-config-2.45-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xkeyboard-config-2.45-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xmlsec-1.3.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xmlsec-1.3.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-server-21.1.18-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-server-21.1.18-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-server-common-21.1.18-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-server-common-21.1.18-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-twm-1.0.13.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-twm-1.0.13.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-xauth-1.1.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-xauth-1.1.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-xinit-1.4.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-xinit-1.4.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xorg-xwayland-24.1.8-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xorg-xwayland-24.1.8-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/xz-5.8.1-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/xz-5.8.1-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/yelp-42.3-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/yelp-42.3-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/yelp-xsl-42.4-1-any.pkg.tar.zst'
removed '/var/cache/pacman/pkg/yelp-xsl-42.4-1-any.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zenity-4.1.90-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zenity-4.1.90-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zlib-ng-2.2.4-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zlib-ng-2.2.4-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zsh-theme-powerlevel10k-1.20.15-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zsh-theme-powerlevel10k-1.20.15-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zstd-1.5.7-2-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zstd-1.5.7-2-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zvbi-0.2.44-1-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zvbi-0.2.44-1-x86_64.pkg.tar.zst.sig'
removed '/var/cache/pacman/pkg/zxing-cpp-2.3.0-5-x86_64.pkg.tar.zst'
removed '/var/cache/pacman/pkg/zxing-cpp-2.3.0-5-x86_64.pkg.tar.zst.sig'
Okay now:
sudo pacman -Syu ncdu
sudo pacman -Syu ncdu                                            ✔  9s 
[sudo] password for gideon:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
resolving dependencies...
warning: dependency cycle detected:
warning: pam will be installed before its systemd-libs dependency
warning: mesa will be installed before its libglvnd dependency
warning: nvidia-utils will be installed before its libglvnd dependency
warning: eglexternalplatform will be installed before its libglvnd dependency
warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd dependency
warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Packages (789) abseil-cpp-20250512.1-1  accent-color-change-r155.f57e60f-1
               addwater-1.2.6-1  adw-gtk-theme-6.2-1  adwaita-cursors-48.1-1
               adwaita-fonts-48.2-1  adwaita-icon-theme-48.1-1  alacarte-1:3.56.0-1
               alsa-card-profiles-1:1.4.5-1  alsa-lib-1.2.14-1  alsa-ucm-conf-1.2.14-2
               alsa-utils-1.2.14-1  android-udev-20250525-1  aom-3.12.1-1
               apache-2.4.63-3  apparmor-4.1.1-1  appstream-1.0.5-2  apr-1.7.6-1
               archlinux-appstream-data-20250529-1  at-spi2-core-2.56.2-1
               audit-4.0.5-1  baobab-48.0-3  bash-5.2.037-4  bc-1.08.2-1
               binutils-2.44+r94+gfe459e33c676-1  bluez-5.83-1  bluez-libs-5.83-1
               bluez-obex-5.83-1  bolt-0.9.9-1  boost-libs-1.88.0-3
               breeze-icons-6.15.0-1  btop-1.4.3-3  btrfs-progs-6.14-1
               ca-certificates-mozilla-3.112-1  cairo-1.18.4-1  capstone-5.0.6-1
               chromaprint-1.5.1-10  chromium-138.0.7204.92-1  cifs-utils-7.4-1
               ckbcomp-1.227-2  clang-20.1.6-1  cmus-2.12.0-3  compiler-rt-20.1.6-1
               composefs-1.0.8-1  coreutils-9.7-1  cpupower-6.15-1  cups-2:2.4.12-2
               cups-pdf-3.0.2-1  curl-8.14.1-1  cython-3.1.2-1  dbus-1.16.2-1
               dbus-broker-37-2  dbus-broker-units-37-2  dbus-glib-0.114-1
               dconf-editor-45.0.1-3  deja-dup-48.2-1  device-mapper-2.03.32-1
               dhcpcd-10.2.4-1  dialog-1:1.3_20250116-1  diffutils-3.12-2
               dnsmasq-2.91-1  dnssec-anchors-20250524-1  double-conversion-3.3.1-1
               dtc-1.7.2-4  duplicity-3.0.4.1-1  e2fsprogs-1.47.2-2  egl-gbm-1.1.2.1-1
               egl-wayland-4:1.1.19-1  egl-x11-1.0.2-1  eglexternalplatform-1.2.1-1
               enchant-2.8.2-2  evince-48.0-3  evolution-data-server-3.56.2-2
               exempi-2.6.6-1  exfatprogs-1.2.9-1  exiv2-0.28.5-1  expat-2.7.1-1
               faac-1.31.1-1  faad2-2.11.2-1  fakeroot-1.37.1.2-1  ffmpeg-2:7.1.1-4
               file-5.46-4  file-roller-44.5-1  filesystem-2025.05.03-1  flac-1.5.0-1
               flatpak-1:1.16.1-1  fluidsynth-2.4.6-1  folks-0.15.9-2
               fontconfig-2:2.16.2-1  foomatic-db-engine-5:20200131-2
               foomatic-db-gutenprint-ppds-5.3.5-1  fprintd-1.94.5-1  freeglut-3.6.0-2
               fribidi-1.0.16-2  fuse-common-3.17.1-1  fuse3-3.17.1-1  fwupd-2.0.12-1
               fzf-0.62.0-1  gawk-5.3.2-1  gcc-15.1.1+r7+gf36ec88aa85a-1
               gcc-libs-15.1.1+r7+gf36ec88aa85a-1  gcr-4-4.4.0.1-1  gdbm-1.25-1
               gdm-48.0-2  geary-1:46.0-5  gedit-48.2-1  gettext-0.25-1
               gfxstream-0.1.2-2  ghostscript-10.05.1-2  giflib-5.2.2-2  git-2.50.0-1
               gjs-2:1.84.2-1  glib2-2.84.3-1  glib2-devel-2.84.3-1
               glibc-2.41+r48+g5cb575ca9a3d-1  glibc-locales-2.41+r48+g5cb575ca9a3d-1
               glibmm-2.66.8-1  glibmm-2.68-2.84.0-1  glm-1.0.1-1
               glslang-1:1.4.313.0-1  gmime3-3.2.15-2  gnome-backgrounds-48.2.1-1
               gnome-bluetooth-3.0-47.1-2  gnome-boxes-48.0-4  gnome-calculator-48.1-2
               gnome-calendar-48.1-1  gnome-characters-48.0-1  gnome-chess-48.0-2
               gnome-clocks-48.0-1  gnome-console-48.0.1-1  gnome-contacts-48.0-1
               gnome-control-center-48.2-1  gnome-desktop-1:44.3-1
               gnome-desktop-4-1:44.3-1  gnome-desktop-common-1:44.3-1
               gnome-disk-utility-46.1-2  gnome-firmware-47.0-2
               gnome-font-viewer-48.0-1  gnome-keybindings-48.2-1
               gnome-keyring-1:48.0-1  gnome-layout-switcher-0.8.39-3
               gnome-logs-45.0-2  gnome-mimeapps-0.1-1  gnome-mines-48.1-1
               gnome-online-accounts-3.54.3-1  gnome-session-48.0-1
               gnome-settings-daemon-48.1-1  gnome-shell-1:48.2-1
               gnome-shell-extension-appindicator-1:60-1
               gnome-shell-extension-arc-menu-66-1
               gnome-shell-extension-dash-to-panel-68-2
               gnome-shell-extension-forge-88-1
               gnome-shell-extension-gnome-ui-tune-1.10.2-1
               gnome-shell-extension-gsconnect-66-1
               gnome-shell-extension-gtk4-desktop-icons-ng-1:100.2-1
               gnome-shell-extension-legacy-theme-auto-switcher-r25.3d6b167-1
               gnome-shell-extension-space-bar-33-1
               gnome-shell-extension-x11gestures-25-1  gnome-shell-extensions-48.2-1
               gnome-system-monitor-48.1-1  gnome-terminal-3.56.2-1
               gnome-user-docs-48.2-1  gnome-user-share-48.0-1  gnome-weather-48.0-2
               gnuchess-6.2.11-1  gnutls-3.8.9-1
               gobject-introspection-runtime-1.84.0-2  gpgme-2.0.0-1  gpgmepp-2.0.0-2
               grep-3.12-2  grilo-0.3.19-1  grilo-plugins-1:0.3.17-1
               grub-2:2.12.r292.g73d1c959-1  gsettings-desktop-schemas-48.0-1
               gsettings-system-schemas-48.0-1  gspell-1.14.0-2
               gst-devtools-libs-1.26.2-2  gst-editing-services-1.26.2-2
               gst-libav-1.26.2-2  gst-plugin-gtk-1.26.2-2  gst-plugin-gtk4-0.13.6-1
               gst-plugin-pipewire-1:1.4.5-1  gst-plugins-bad-1.26.2-2
               gst-plugins-bad-libs-1.26.2-2  gst-plugins-base-1.26.2-2
               gst-plugins-base-libs-1.26.2-2  gst-plugins-good-1.26.2-2
               gst-plugins-ugly-1.26.2-2  gst-python-1.26.2-2  gstreamer-1.26.2-2
               gtest-1.17.0-1  gthumb-3.12.7-1  gtk-update-icon-cache-1:4.18.6-1
               gtk-vnc-1.5.0-1  gtk3-1:3.24.49-2  gtk4-1:4.18.6-1  gtkmm-4.0-4.18.0-2
               gtkmm3-3.24.10-1  gtksourceview3-1:3.24.11+r30+gd880929f-1
               gtksourceview4-4.8.4-2  gtksourceview5-5.16.0-2  gufw-26.04-1
               gupnp-1:1.6.8-2  gupnp-av-0.14.3-2  gupnp-dlna-0.12.0-4
               gupnp-igd-1.6.0-2  gutenprint-5.3.5-1  gvfs-1.57.2-4  gvfs-afc-1.57.2-4
               gvfs-goa-1.57.2-4  gvfs-google-1.57.2-4  gvfs-gphoto2-1.57.2-4
               gvfs-mtp-1.57.2-4  gvfs-nfs-1.57.2-4  gvfs-smb-1.57.2-4  gzip-1.14-2
               harfbuzz-11.2.1-1  harfbuzz-icu-11.2.1-1  hidapi-0.15.0-1
               hplip-1:3.25.2-1  htop-3.4.1-1  hwdata-0.396-1  hwinfo-24.0-1
               hwloc-2.12.1-1  iagno-3.38.1+r125+ge144444-1  iana-etc-20250502-1
               ibus-1.5.32-1  icu-76.1-1  iio-sensor-proxy-3.7-1
               imagemagick-7.1.1.47-2  imath-3.1.12-4  imlib2-1.12.5-1
               inetutils-2.6-1  iniparser-4.2.6-1  intel-ucode-20250512-1
               inxi-3.3.38.1-1  iperf-2.2.1-1  iproute2-6.15.0-1  iptables-1:1.8.11-2
               iputils-20250605-1  iso-codes-4.18.0-1  jansson-2.14.1-1
               js115-115.24.0-1  js128-128.11.0-1  json-c-0.18-2  karchive-6.15.0-1
               kauth-6.15.0-1  kbd-2.8.0-1  kbookmarks-6.15.0-1  kcodecs-6.15.0-1
               kcolorscheme-6.15.0-1  kcompletion-6.15.0-1  kconfig-6.15.0-1
               kconfigwidgets-6.15.0-1  kcoreaddons-6.15.0-1  kcrash-6.15.0-1
               kdbusaddons-6.15.0-1  kdialog-25.04.2-1  kguiaddons-6.15.0-1
               ki18n-6.15.0-1  kiconthemes-6.15.0-1  kio-6.15.0-1  kio5-5.116.0-2
               kitemviews-6.15.0-1  kjobwidgets-6.15.0-1  kmod-34.2-1
               knotifications-6.15.0-1  kservice-6.15.0-1  ktextwidgets-6.15.0-1
               kwallet-6.15.0-1  kwallet5-5.116.0-3  kwidgetsaddons-6.15.0-1
               kwindowsystem-6.15.0-1  lcms2-2.17-1  ldb-2:4.22.2-1
               leancrypto-1.4.0-1  lib32-curl-8.14.1-1  lib32-expat-2.7.1-1
               lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1
               lib32-glibc-2.41+r48+g5cb575ca9a3d-1  lib32-icu-76.1-1
               lib32-json-c-0.18-2  lib32-libelf-0.193-1  lib32-libffi-3.5.0-1
               lib32-libldap-2.6.10-1  lib32-libnghttp2-1.66.0-1
               lib32-libnghttp3-1.10.1-1  lib32-libssh2-1.11.1-1
               lib32-libunistring-1.3-1  lib32-libx11-1.8.12-1  lib32-libxml2-2.14.4-1
               lib32-libxshmfence-1.3.3-1  lib32-llvm-libs-1:20.1.6-1
               lib32-lm_sensors-1:3.6.2-2  lib32-mesa-1:25.1.4-1  lib32-ncurses-6.5-2
               lib32-nvidia-utils-575.64-1  lib32-openssl-1:3.5.0-1
               lib32-spirv-tools-1:1.4.313.0-1  lib32-vulkan-icd-loader-1.4.313.0-1
               lib32-xz-5.8.1-1  lib32-zstd-1.5.7-2  libadwaita-1:1.7.4-1
               libaemu-0.1.2-5  libarchive-3.8.1-1  libavif-1.3.0-1
               libayatana-appindicator-0.5.94-1  libblockdev-3.3.0-1
               libblockdev-crypto-3.3.0-1  libblockdev-fs-3.3.0-1
               libblockdev-loop-3.3.0-1  libblockdev-mdraid-3.3.0-1
               libblockdev-nvme-3.3.0-1  libblockdev-part-3.3.0-1
               libblockdev-swap-3.3.0-1  libbluray-1.3.4-3  libbpf-1.5.1-1
               libcamera-0.5.1-2  libcamera-ipa-0.5.1-2  libcap-2.76-1
               libcbor-0.12.0-1  libcloudproviders-0.3.6-2  libcups-2:2.4.12-2
               libcupsfilters-2.1.1-2  libde265-1.0.16-1  libdecor-0.2.3-1
               libdiscid-0.6.5-2  libdrm-2.4.125-1  libebur128-1.2.6-2
               libedataserverui4-3.56.2-2  libedit-20250104_3.1-1  libei-1.4.1-1
               libelf-0.193-2  libevdev-1.13.4-1  libfabric-2.1.0-1  libffi-3.5.0-1
               libfprint-1.94.9-1  libfreeaptx-0.2.2-1  libgcrypt-1.11.1-1
               libgdata-0.18.1-4  libgdm-48.0-2  libgedit-amtk-5.9.1-1
               libgedit-gfls-1:0.3.0-1  libgedit-gtksourceview-299.5.0-2
               libgedit-tepl-6.13.0-1  libgexiv2-0.14.5-1  libgirepository-1.84.0-2
               libgit2-1:1.9.1-1  libglvnd-1.7.0-3  libgme-0.6.4-1
               libgnome-games-support-2-2.0.1-1  libgoa-3.54.3-1  libgpg-error-1.55-1
               libgphoto2-2.5.31-4  libgrss-0.7.0+16+g971c421-4  libgsf-1.14.53-2
               libgudev-238-3  libgusb-0.4.9-2  libgweather-4-4.4.4-2
               libheif-1.19.8-3  libibus-1.5.32-1  libical-3.0.20-2  libidn-1.43-1
               libimagequant-4.3.4-1  libimobiledevice-1.3.0-16
               libimobiledevice-glue-1.3.2-1  libinput-1.28.1-1  libinstpatch-1.1.7-2
               libjcat-0.2.3-2  libjxl-0.11.1-3  libksba-1.6.7-2  liblc3-1.1.3-1
               libldap-2.6.10-1  libmanette-0.2.12-1  libmbim-1.32.0-1
               libmediaart-1.9.7-1  libmfx-23.2.2-4  libmm-glib-1.24.0-1
               libmysofa-1.3.3-1  libnautilus-extension-48.2-1  libnbd-1.22.1-2
               libnewt-0.52.25-1  libnfs-6.0.2-5  libnftnl-1.2.9-1
               libnghttp2-1.66.0-1  libnghttp3-1.10.1-1  libnice-0.1.22-2
               libnm-1.52.0-1  libnotify-0.8.6-1  libnvme-1.13-1  libopenmpt-0.8.0-1
               libosinfo-1.12.0-2  libpamac-11.7.3-5  libpamac-flatpak-plugin-11.7.3-5
               libpamac-snap-plugin-11.7.3-5  libpcap-1.10.5-3  libpeas-1.36.0-7
               libphonenumber-1:9.0.7-2  libpipewire-1:1.4.5-1  libplacebo-7.351.0-1
               libplist-2.7.0-1  libpng-1.6.49-1  libportal-0.9.1-2
               libportal-gtk3-0.9.1-2  libportal-gtk4-0.9.1-2  libppd-2.1.1-1
               libqmi-1.36.0-1  libqrtr-glib-1.2.2-4  librest-0.9.1-3
               librsvg-2:2.60.0-2  libseccomp-2.5.6-1  libsecret-0.21.7-1
               libshout-1:2.4.6-5  libslirp-4.9.1-1  libsm-1.2.6-1  libsndfile-1.2.2-3
               libsoup-2.74.3-3  libsoup3-3.6.5-1  libspeechd-0.12.1-1
               libsrtp-1:2.7.0-1  libstemmer-3.0.1-1  libsynctex-2025.2-1
               libsysprof-capture-48.0-5  libtasn1-4.20.0-1  libtheora-1.2.0-1
               libtirpc-1.3.6-2  libtool-2.5.4+r23+g5b582aed-1  libtracefs-1.8.2-1
               liburcu-0.15.1-1  liburing-2.11-1  libusb-1.0.29-1  libusbmuxd-2.1.1-1
               libutempter-1.2.3-1  libvirt-1:11.4.0-1  libvirt-glib-5.0.0-3
               libvpl-2.15.0-1  libwacom-2.16.1-1  libwbclient-2:4.22.2-1
               libwireplumber-0.5.10-1  libwpe-1.16.2-1  libx11-1.8.12-1
               libx86emu-3.7-1  libxdp-1.5.5-1  libxft-2.3.9-1  libxkbcommon-1.10.0-1
               libxkbcommon-x11-1.10.0-1  libxklavier-5.4-6  libxml2-2.14.4-1
               libxmlb-0.3.22-1  libxnvctrl-575.64-1  libxslt-1.1.43-2  lilv-0.24.26-1
               linux-api-headers-6.15-1  linux-firmware-20250508.788aadc8-2
               linux-firmware-whence-20250508.788aadc8-2  linux515-5.15.185-1
               linux515-nvidia-575.64-1  llvm-20.1.6-3  llvm-libs-20.1.6-3
               lm_sensors-1:3.6.2-1  localsearch-3.9.0-3  lollypop-1.4.41-1
               lua-5.4.8-2  lvm2-2.03.32-1  man-db-2.13.1-1  man-pages-6.14-1
               manjaro-gnome-settings-20250504-1  manjaro-hello-0.8.1-2
               manjaro-release-25.0.4-1  manjaro-settings-manager-0.5.8-5
               manjaro-settings-manager-notifier-0.5.8-5  manjaro-zsh-config-0.26-2
               mbedtls-3.6.3-1  mbedtls2-2.28.10-1  mesa-1:25.1.4-1
               mesa-utils-9.0.0-7  mhwd-0.6.6-4  mhwd-db-20250113-1
               mhwd-nvidia-575.64-1  mhwd-nvidia-390xx-390.157-21
               mhwd-nvidia-470xx-470.256.02-14  miniupnpc-2.3.3-1
               modemmanager-1.24.0-1  mpdecimal-4.0.1-1  mpfr-4.2.2-1  mpg123-1.33.0-1
               mtools-1:4.0.49-1  mutter-48.3.1-2  nano-8.5-1  nautilus-48.2-1
               nautilus-admin-1:1.2.0-3  ncurses-6.5-4  neon-0.34.2-1
               networkmanager-1.52.0-1  networkmanager-openconnect-1.2.10-3
               networkmanager-strongswan-1.6.1-1  nfs-utils-2.8.3-2  nfsidmap-2.8.3-2
               nftables-1:1.1.3-1  noto-fonts-1:2025.06.01-1  nss-3.112-1
               ntfs-3g-2022.10.3-2  ntp-4.2.8.p18-3
               nvidia-driver-assistant-0.21.57.08-1  nvidia-utils-575.64-1
               oath-toolkit-2.6.12-2  ocl-icd-2.3.3-1
               onlyoffice-desktopeditors-9.0.0-1  openal-1.24.3-1
               openconnect-1:9.12-4  openexr-3.3.4-1  openh264-2.6.0-1
               openmpi-5.0.8-1  openpmix-5.0.8-1  openresolv-3.16.5-1
               openssh-10.0p1-3  openssl-3.5.0-1  openucx-1.18.1-2  openvpn-2.6.14-1
               orc-0.4.41-1  os-prober-1.83-1  osinfo-db-20250606-1  ostree-2025.2-3
               pacman-7.0.0.r10.ga2d0293-3  pacman-contrib-1.12.0-1
               pacman-mirrors-5.0-1  pacui-1.14+100+g4fb3daa-1  pam-1.7.0-2
               pamac-cli-11.7.3-2  pamac-gnome-integration-11.7.3-3
               pamac-gtk-11.7.3-3  pango-1:1.56.3-1  papirus-icon-theme-20250501-1
               papirus-maia-icon-theme-20201007-1  passim-0.1.10-1  pcre2-10.45-1
               pcsclite-2.3.3-1  perl-5.40.2-1  perl-alien-libxml2-0.20-1
               perl-error-0.17030-1  perl-libwww-6.78-1  perl-path-tiny-0.148-1
               perl-xml-libxml-2.0210-3  phodav-3.0-4  pipewire-1:1.4.5-1
               pipewire-audio-1:1.4.5-1  pipewire-session-manager-1:1.4.5-1
               pixman-0.46.2-1  pkcs11-helper-1.30.0-2  pkgfile-24-1
               plymouth-24.004.60-12  poppler-25.06.0-1  poppler-glib-25.06.0-1
               power-profiles-daemon-0.30-1  procps-ng-4.0.5-3  protobuf-31.1-1
               protobuf-c-1.5.2-4  prrte-3.0.11-1  pugixml-1.15-2  pyside6-6.9.1-2
               python-3.13.3-1  python-aiohappyeyeballs-2.6.1-1
               python-aiohttp-3.12.13-1  python-aiosignal-1.3.2-1
               python-argcomplete-3.5.3-1  python-attrs-25.3.0-1
               python-bcrypt-4.3.0-1  python-beautifulsoup4-4.13.3-1
               python-cairo-1.28.0-1  python-certifi-2025.06.15-1  python-cgi-3.13.0-2
               python-charset-normalizer-3.4.2-1  python-click-8.1.8-1
               python-cryptography-45.0.4-1  python-cssselect2-0.8.0-1
               python-dbus-1.4.0-1  python-filelock-3.18.0-1
               python-frozenlist-1.7.0-1  python-gobject-3.52.3-3
               python-google-auth-2.38.0-1  python-googleapis-common-protos-1.70.0-1
               python-jinja-1:3.1.6-1  python-legacy-cgi-2.6.3-2  python-lxml-5.4.0-1
               python-markupsafe-3.0.2-1  python-more-itertools-10.7.0-1
               python-multidict-6.4.4-1  python-packaging-25.0-1
               python-pillow-11.2.1-1  python-ply-3.11-15  python-propcache-0.3.2-1
               python-protobuf-31.1-1  python-pyaml-24.12.0-1  python-pycurl-7.45.6-1
               python-pydantic-2.11.7-1  python-pydantic-core-2:2.33.2-2
               python-pyopenssl-25.1.0-1  python-pyparsing-3.2.3-1
               python-pytz-2025.2-1  python-requests-2.32.4-1
               python-setproctitle-1.3.5-1  python-setuptools-1:80.9.0-1
               python-tldextract-5.3.0-1  python-trove-classifiers-2025.5.9.12-1
               python-typeguard-4.4.4-1  python-typing-inspection-0.4.1-1
               python-typing_extensions-4.13.2-1  python-uritemplate-4.2.0-1
               python-urllib3-2.4.0-1  python-validate-pyproject-0.24.1-1
               python-wheel-0.45.1-1  python-yarl-1.21.1-1  qca-qt5-2.3.10-2
               qca-qt6-2.3.10-2  qemu-audio-alsa-10.0.0-7  qemu-audio-dbus-10.0.0-7
               qemu-audio-jack-10.0.0-7  qemu-audio-oss-10.0.0-7
               qemu-audio-pa-10.0.0-7  qemu-audio-pipewire-10.0.0-7
               qemu-audio-sdl-10.0.0-7  qemu-audio-spice-10.0.0-7  qemu-base-10.0.0-7
               qemu-block-curl-10.0.0-7  qemu-block-dmg-10.0.0-7
               qemu-block-nfs-10.0.0-7  qemu-block-ssh-10.0.0-7
               qemu-chardev-spice-10.0.0-7  qemu-common-10.0.0-7
               qemu-desktop-10.0.0-7  qemu-hw-display-qxl-10.0.0-7
               qemu-hw-s390x-virtio-gpu-ccw-10.0.0-7  qemu-hw-uefi-vars-10.0.0-7
               qemu-hw-usb-host-10.0.0-7  qemu-hw-usb-redirect-10.0.0-7
               qemu-hw-usb-smartcard-10.0.0-7  qemu-img-10.0.0-7
               qemu-pr-helper-10.0.0-7  qemu-system-x86-10.0.0-7
               qemu-system-x86-firmware-10.0.0-7  qemu-tools-10.0.0-7
               qemu-ui-curses-10.0.0-7  qemu-ui-dbus-10.0.0-7
               qemu-ui-egl-headless-10.0.0-7  qemu-ui-gtk-10.0.0-7
               qemu-ui-opengl-10.0.0-7  qemu-ui-sdl-10.0.0-7
               qemu-ui-spice-app-10.0.0-7  qemu-ui-spice-core-10.0.0-7
               qemu-vhost-user-gpu-10.0.0-7  qpdf-12.2.0-1  qrencode-4.1.1-4
               qt5-base-5.15.17+kde+r123-1  qt5-declarative-5.15.17+kde+r21-1
               qt5-multimedia-5.15.17+kde+r2-1  qt5-quickcontrols2-5.15.17+kde+r5-1
               qt5-speech-5.15.17+kde+r1-1  qt5-svg-5.15.17+kde+r5-1
               qt5-translations-5.15.17-1  qt5-wayland-5.15.17+kde+r57-1
               qt5-x11extras-5.15.17-1  qt6-5compat-6.9.1-1  qt6-base-6.9.1-1
               qt6-declarative-6.9.1-1  qt6-multimedia-6.9.1-1
               qt6-multimedia-ffmpeg-6.9.1-1  qt6-shadertools-6.9.1-1
               qt6-speech-6.9.1-1  qt6-svg-6.9.1-1  qt6-translations-6.9.1-1
               qt6-wayland-6.9.1-1  quadrapassel-40.2-4  ranger-1.9.4-4
               raptor-2.0.16-7  re2-1:20240702-5  readline-8.2.013-2  run-parts-5.22-1
               rutabaga-ffi-0.1.6-2  rygel-1:0.44.2-3  s-nail-14.9.25-1  sane-1.4.0-1
               sdl2-compat-2.32.56-1  sdl2_image-2.8.8-1  sdl3-3.2.16-1
               seahorse-1:47.0.1-3  shaderc-2025.2-2  shadow-4.17.4-1
               shared-mime-info-2.4-2  shiboken6-6.9.1-2  simple-scan-48.1-1
               smbclient-2:4.22.2-1  snapd-2.68.4-1  snapd-glib-1.68-1  snappy-1.2.2-2
               sof-firmware-2025.05-1  solid-6.15.0-1  sonnet-6.15.0-1
               soundtouch-2.4.0-1  spice-0.16.0-1  spice-protocol-0.14.5-1
               spirv-tools-1:1.4.313.0-1  sqlite-3.50.1-1  squashfs-tools-4.7-1
               sratom-0.6.18-1  stoken-0.92-5  strongswan-6.0.1-1  sudo-1.9.17.p1-0.1
               svt-av1-3.0.2-1  systemd-257.6-1  systemd-libs-257.6-1
               systemd-sysvcompat-257.6-1  taglib-2.1-1  talloc-2.4.3-1  tdb-1.4.13-1
               tecla-48.0.2-1  tevent-1:0.16.2-1  texinfo-7.2-1  tinysparql-3.9.2-2
               totem-43.2-1  totem-pl-parser-3.26.6+r30+g51b8439-2  touche-2.0.15-1
               touchegg-2.0.18-1  transmission-cli-4.0.6-10  ttf-hack-nerd-3.4.0-1
               ttf-noto-nerd-3.4.0-1  tzdata-2025b-1  unrar-1:7.1.7-1
               update-grub-2:2.12.r292.g73d1c959-1  upower-1.90.9-1
               usb_modeswitch-2.6.2-1  util-linux-2.41-4  util-linux-libs-2.41-4
               v4l-utils-1.30.1-1  virglrenderer-1.1.1-1  virtiofsd-1.13.1-1
               volume_key-0.3.12-11  vte-common-0.80.2-1  vte3-0.80.2-1  vte4-0.80.2-1
               vulkan-headers-1:1.4.313.0-1  vulkan-icd-loader-1.4.313.0-1
               wayland-1.23.1-2  wayland-protocols-1.45-1  webkit2gtk-2.48.3-1
               webkit2gtk-4.1-2.48.3-1  webkitgtk-6.0-2.48.3-1
               webrtc-audio-processing-1-1.3-5  wget-1.25.0-2  which-2.23-1
               wireless-regdb-2025.02.20-1  wireplumber-0.5.10-1  woff2-1.0.2-6
               wolfssl-5.8.0-1  wpebackend-fdo-1.16.0-1  x265-4.1-1  xapp-2.8.9-1
               xdg-desktop-portal-1.20.3-1  xdg-desktop-portal-gnome-48.0-1
               xdg-desktop-portal-gtk-1.15.3-1  xfsprogs-6.14.0-1
               xkeyboard-config-2.45-1  xmlsec-1.3.7-2  xorg-server-21.1.18-1
               xorg-server-common-21.1.18-1  xorg-twm-1.0.13.1-1  xorg-xauth-1.1.4-1
               xorg-xinit-1.4.4-1  xorg-xwayland-24.1.8-1  xz-5.8.1-1  yelp-42.3-1
               yelp-xsl-42.4-1  zenity-4.1.90-1  zlib-ng-2.2.4-1
               zsh-theme-powerlevel10k-1.20.15-1  zstd-1.5.7-2  zvbi-0.2.44-1
               zxing-cpp-2.3.0-5  ncdu-2.8.2-2
Total Download Size:    2737.85 MiB
Total Installed Size:  10332.50 MiB
Net Upgrade Size:        603.14 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 onlyoffice-desktop...   383.8 MiB  21.5 MiB/s 00:18 [###########################] 100%
 nvidia-utils-575.6...   333.6 MiB  16.0 MiB/s 00:21 [###########################] 100%
 linux-firmware-202...   243.5 MiB  18.0 MiB/s 00:14 [###########################] 100%
 chromium-138.0.720...   111.2 MiB  16.7 MiB/s 00:07 [###########################] 100%
 linux515-5.15.185-...   100.7 MiB  18.5 MiB/s 00:05 [###########################] 100%
 linux515-nvidia-57...    83.2 MiB  15.6 MiB/s 00:05 [###########################] 100%
 ttf-noto-nerd-3.4....    78.4 MiB  14.5 MiB/s 00:05 [###########################] 100%
 lib32-nvidia-utils...    72.3 MiB  15.5 MiB/s 00:05 [###########################] 100%
 gcc-15.1.1+r7+gf36...    54.0 MiB  15.7 MiB/s 00:03 [###########################] 100%
 clang-20.1.6-1-x86_64    45.1 MiB  17.8 MiB/s 00:03 [###########################] 100%
 lib32-llvm-libs-1:...    42.4 MiB  17.0 MiB/s 00:02 [###########################] 100%
 llvm-libs-20.1.6-3...    37.8 MiB  16.0 MiB/s 00:02 [###########################] 100%
 gcc-libs-15.1.1+r7...    35.9 MiB  14.7 MiB/s 00:02 [###########################] 100%
 gnome-backgrounds-...    35.3 MiB  12.0 MiB/s 00:03 [###########################] 100%
 webkit2gtk-4.1-2.4...    33.5 MiB  13.2 MiB/s 00:03 [###########################] 100%
 webkit2gtk-2.48.3-...    33.4 MiB  13.4 MiB/s 00:03 [###########################] 100%
 webkitgtk-6.0-2.48...    33.4 MiB  12.0 MiB/s 00:03 [###########################] 100%
 foomatic-db-gutenp...    32.2 MiB  13.8 MiB/s 00:02 [###########################] 100%
 lib32-gcc-libs-15....    31.8 MiB  12.8 MiB/s 00:02 [###########################] 100%
 noto-fonts-1:2025....    27.9 MiB  16.7 MiB/s 00:02 [###########################] 100%
 snapd-2.68.4-1-x86_64    26.9 MiB  19.0 MiB/s 00:01 [###########################] 100%
 hplip-1:3.25.2-1-x...    22.2 MiB  20.6 MiB/s 00:01 [###########################] 100%
 papirus-icon-theme...    21.4 MiB  15.6 MiB/s 00:01 [###########################] 100%
 llvm-20.1.6-3-x86_64     21.2 MiB  13.5 MiB/s 00:02 [###########################] 100%
 archlinux-appstrea...    21.0 MiB  14.0 MiB/s 00:01 [###########################] 100%
 perl-5.40.2-1-x86_64     20.0 MiB  11.4 MiB/s 00:02 [###########################] 100%
 ghostscript-10.05....    19.7 MiB  11.7 MiB/s 00:02 [###########################] 100%
 grub-2:2.12.r292.g...    15.7 MiB  12.2 MiB/s 00:01 [###########################] 100%
 qt6-declarative-6....    15.2 MiB  12.1 MiB/s 00:01 [###########################] 100%
 qt6-base-6.9.1-1-x...    14.3 MiB  11.3 MiB/s 00:01 [###########################] 100%
 js128-128.11.0-1-x...    14.2 MiB  12.3 MiB/s 00:01 [###########################] 100%
 qt5-base-5.15.17+k...    13.1 MiB  12.1 MiB/s 00:01 [###########################] 100%
 python-3.13.3-1-x86_64   12.2 MiB  11.0 MiB/s 00:01 [###########################] 100%
 ffmpeg-2:7.1.1-4-x...    12.1 MiB  12.2 MiB/s 00:01 [###########################] 100%
 glibc-locales-2.41...    11.7 MiB  12.5 MiB/s 00:01 [###########################] 100%
 ibus-1.5.32-1-x86_64     11.5 MiB  12.4 MiB/s 00:01 [###########################] 100%
 icu-76.1-1-x86_64        11.4 MiB  13.0 MiB/s 00:01 [###########################] 100%
 js115-115.24.0-1-x...    11.3 MiB  13.3 MiB/s 00:01 [###########################] 100%
 gnome-user-docs-48...    11.3 MiB  14.1 MiB/s 00:01 [###########################] 100%
 systemd-257.6-1-x86_64   10.7 MiB  9.88 MiB/s 00:01 [###########################] 100%
 lib32-icu-76.1-1-x...    10.6 MiB  12.2 MiB/s 00:01 [###########################] 100%
 intel-ucode-202505...    10.4 MiB  12.2 MiB/s 00:01 [###########################] 100%
 lib32-mesa-1:25.1....    10.3 MiB  12.9 MiB/s 00:01 [###########################] 100%
 mesa-1:25.1.4-1-x86_64   10.2 MiB  13.2 MiB/s 00:01 [###########################] 100%
 glibc-2.41+r48+g5c...    10.0 MiB  13.9 MiB/s 00:01 [###########################] 100%
 pyside6-6.9.1-2-x86_64    8.9 MiB  9.76 MiB/s 00:01 [###########################] 100%
 libvirt-1:11.4.0-1...     8.7 MiB  11.0 MiB/s 00:01 [###########################] 100%
 gtk4-1:4.18.6-1-x86_64    8.7 MiB  11.1 MiB/s 00:01 [###########################] 100%
 gtk3-1:3.24.49-2-x...     8.7 MiB  11.3 MiB/s 00:01 [###########################] 100%
 imagemagick-7.1.1....     8.7 MiB  11.8 MiB/s 00:01 [###########################] 100%
 binutils-2.44+r94+...     7.7 MiB  11.5 MiB/s 00:01 [###########################] 100%
 breeze-icons-6.15....     7.6 MiB  11.7 MiB/s 00:01 [###########################] 100%
 gnome-control-cent...     7.4 MiB  11.2 MiB/s 00:01 [###########################] 100%
 kio5-5.116.0-2-x86_64     7.1 MiB  11.1 MiB/s 00:01 [###########################] 100%
 smbclient-2:4.22.2...     7.0 MiB  11.2 MiB/s 00:01 [###########################] 100%
 git-2.50.0-1-x86_64       6.7 MiB  11.6 MiB/s 00:01 [###########################] 100%
 fwupd-2.0.12-1-x86_64     6.5 MiB  11.4 MiB/s 00:01 [###########################] 100%
 qemu-system-x86-10...     6.1 MiB  10.8 MiB/s 00:01 [###########################] 100%
 manjaro-settings-m...     5.5 MiB  10.9 MiB/s 00:01 [###########################] 100%
 man-pages-6.14-1-any      5.5 MiB  7.87 MiB/s 00:01 [###########################] 100%
 openssl-3.5.0-1-x86_64    5.2 MiB  10.5 MiB/s 00:00 [###########################] 100%
 gthumb-3.12.7-1-x86_64    5.2 MiB  10.1 MiB/s 00:01 [###########################] 100%
 cups-2:2.4.12-2-x86_64    5.2 MiB  10.4 MiB/s 00:00 [###########################] 100%
 util-linux-2.41-4-...     5.1 MiB  11.4 MiB/s 00:00 [###########################] 100%
 glib2-2.84.3-1-x86_64     4.9 MiB  10.9 MiB/s 00:00 [###########################] 100%
 qt5-declarative-5....     4.8 MiB  9.90 MiB/s 00:00 [###########################] 100%
 gutenprint-5.3.5-1...     4.7 MiB  10.9 MiB/s 00:00 [###########################] 100%
 protobuf-31.1-1-x86_64    4.3 MiB  9.99 MiB/s 00:00 [###########################] 100%
 evolution-data-ser...     4.1 MiB  5.49 MiB/s 00:01 [###########################] 100%
 imath-3.1.12-4-x86_64     3.9 MiB  10.6 MiB/s 00:00 [###########################] 100%
 openmpi-5.0.8-1-x86_64    3.9 MiB  10.2 MiB/s 00:00 [###########################] 100%
 sane-1.4.0-1-x86_64       3.8 MiB  10.1 MiB/s 00:00 [###########################] 100%
 compiler-rt-20.1.6...     3.7 MiB  10.3 MiB/s 00:00 [###########################] 100%
 kio-6.15.0-1-x86_64       3.6 MiB  10.1 MiB/s 00:00 [###########################] 100%
 networkmanager-1.5...     3.6 MiB  9.92 MiB/s 00:00 [###########################] 100%
 cython-3.1.2-1-x86_64     3.5 MiB  9.79 MiB/s 00:00 [###########################] 100%
 glm-1.0.1-1-x86_64        3.4 MiB  9.70 MiB/s 00:00 [###########################] 100%
 lib32-glibc-2.41+r...     3.4 MiB  9.60 MiB/s 00:00 [###########################] 100%
 iso-codes-4.18.0-1-any    3.4 MiB  9.22 MiB/s 00:00 [###########################] 100%
 libgweather-4-4.4....     3.0 MiB  6.99 MiB/s 00:00 [###########################] 100%
 gnome-shell-1:48.2...     2.9 MiB  8.19 MiB/s 00:00 [###########################] 100%
 gst-plugins-bad-li...     2.9 MiB  6.25 MiB/s 00:00 [###########################] 100%
 exiv2-0.28.5-1-x86_64     2.8 MiB  8.80 MiB/s 00:00 [###########################] 100%
 ttf-hack-nerd-3.4....     2.8 MiB  8.11 MiB/s 00:00 [###########################] 100%
 gettext-0.25-1-x86_64     2.8 MiB  8.42 MiB/s 00:00 [###########################] 100%
 coreutils-9.7-1-x86_64    2.8 MiB  9.09 MiB/s 00:00 [###########################] 100%
 mutter-48.3.1-2-x86_64    2.7 MiB  9.15 MiB/s 00:00 [###########################] 100%
 aom-3.12.1-1-x86_64       2.7 MiB  9.14 MiB/s 00:00 [###########################] 100%
 geary-1:46.0-5-x86_64     2.5 MiB  7.85 MiB/s 00:00 [###########################] 100%
 zenity-4.1.90-1-x86_64    2.5 MiB  8.47 MiB/s 00:00 [###########################] 100%
 boost-libs-1.88.0-...     2.5 MiB  8.52 MiB/s 00:00 [###########################] 100%
 gst-plugins-base-l...     2.3 MiB  8.08 MiB/s 00:00 [###########################] 100%
 glslang-1:1.4.313....     2.3 MiB  8.24 MiB/s 00:00 [###########################] 100%
 sudo-1.9.17.p1-0.1...     2.3 MiB  8.02 MiB/s 00:00 [###########################] 100%
 nautilus-48.2-1-x86_64    2.3 MiB  7.93 MiB/s 00:00 [###########################] 100%
 librsvg-2:2.60.0-2...     2.3 MiB  8.04 MiB/s 00:00 [###########################] 100%
 appstream-1.0.5-2-...     2.2 MiB  4.59 MiB/s 00:00 [###########################] 100%
 bash-5.2.037-4-x86_64     2.2 MiB  6.76 MiB/s 00:00 [###########################] 100%
 sqlite-3.50.1-1-x86_64    2.2 MiB  9.29 MiB/s 00:00 [###########################] 100%
 gst-plugins-good-1...     2.2 MiB  9.03 MiB/s 00:00 [###########################] 100%
 kwidgetsaddons-6.1...     2.1 MiB  9.15 MiB/s 00:00 [###########################] 100%
 qemu-img-10.0.0-7-...     2.1 MiB  9.07 MiB/s 00:00 [###########################] 100%
 evince-48.0-3-x86_64      2.1 MiB  7.61 MiB/s 00:00 [###########################] 100%
 adwaita-fonts-48.2...     2.1 MiB  8.82 MiB/s 00:00 [###########################] 100%
 gstreamer-1.26.2-2...     2.0 MiB  8.77 MiB/s 00:00 [###########################] 100%
 libx11-1.8.12-1-x86_64    2.0 MiB  8.44 MiB/s 00:00 [###########################] 100%
 v4l-utils-1.30.1-1...  2042.4 KiB  8.67 MiB/s 00:00 [###########################] 100%
 openucx-1.18.1-2-x...  2037.5 KiB  8.43 MiB/s 00:00 [###########################] 100%
 svt-av1-3.0.2-1-x86_64 2036.3 KiB  8.65 MiB/s 00:00 [###########################] 100%
 texinfo-7.2-1-x86_64   2035.9 KiB  8.39 MiB/s 00:00 [###########################] 100%
 libjxl-0.11.1-3-x86_64 2019.4 KiB  8.46 MiB/s 00:00 [###########################] 100%
 lib32-openssl-1:3....  2007.6 KiB  6.93 MiB/s 00:00 [###########################] 100%
 x265-4.1-1-x86_64      1984.0 KiB  6.68 MiB/s 00:00 [###########################] 100%
 libcamera-ipa-0.5....  1937.5 KiB  3.62 MiB/s 00:01 [###########################] 100%
 gnome-calculator-4...  1924.7 KiB  6.62 MiB/s 00:00 [###########################] 100%
 qemu-common-10.0.0...  1923.2 KiB  6.14 MiB/s 00:00 [###########################] 100%
 qt5-translations-5...  1906.9 KiB  6.65 MiB/s 00:00 [###########################] 100%
 flatpak-1:1.16.1-1...  1893.2 KiB  6.53 MiB/s 00:00 [###########################] 100%
 libqmi-1.36.0-1-x86_64 1865.1 KiB  7.92 MiB/s 00:00 [###########################] 100%
 qt6-translations-6...  1854.1 KiB  7.54 MiB/s 00:00 [###########################] 100%
 gedit-48.2-1-x86_64    1843.3 KiB  7.83 MiB/s 00:00 [###########################] 100%
 lvm2-2.03.32-1-x86_64  1827.3 KiB  7.63 MiB/s 00:00 [###########################] 100%
 ntp-4.2.8.p18-3-x86_64 1819.7 KiB  6.83 MiB/s 00:00 [###########################] 100%
 xorg-server-21.1.1...  1797.8 KiB  7.84 MiB/s 00:00 [###########################] 100%
 gnutls-3.8.9-1-x86_64  1796.1 KiB  7.73 MiB/s 00:00 [###########################] 100%
 spirv-tools-1:1.4....  1769.6 KiB  7.51 MiB/s 00:00 [###########################] 100%
 apache-2.4.63-3-x86_64 1708.9 KiB  6.57 MiB/s 00:00 [###########################] 100%
 ki18n-6.15.0-1-x86_64  1707.4 KiB  6.78 MiB/s 00:00 [###########################] 100%
 poppler-25.06.0-1-...  1694.6 KiB  7.29 MiB/s 00:00 [###########################] 100%
 hwdata-0.396-1-any     1675.6 KiB  6.73 MiB/s 00:00 [###########################] 100%
 python-pydantic-co...  1659.3 KiB  6.75 MiB/s 00:00 [###########################] 100%
 nss-3.112-1-x86_64     1649.9 KiB  7.13 MiB/s 00:00 [###########################] 100%
 pcre2-10.45-1-x86_64   1619.7 KiB  6.88 MiB/s 00:00 [###########################] 100%
 qt6-shadertools-6....  1614.4 KiB  6.95 MiB/s 00:00 [###########################] 100%
 sof-firmware-2025....  1606.0 KiB  6.91 MiB/s 00:00 [###########################] 100%
 pipewire-audio-1:1...  1575.6 KiB  6.81 MiB/s 00:00 [###########################] 100%
 qt5-quickcontrols2...  1532.6 KiB  6.59 MiB/s 00:00 [###########################] 100%
 fzf-0.62.0-1-x86_64    1519.5 KiB  6.18 MiB/s 00:00 [###########################] 100%
 lib32-spirv-tools-...  1512.5 KiB  6.62 MiB/s 00:00 [###########################] 100%
 vulkan-headers-1:1...  1509.5 KiB  6.70 MiB/s 00:00 [###########################] 100%
 gtkmm-4.0-4.18.0-2...  1485.9 KiB  6.60 MiB/s 00:00 [###########################] 100%
 systemd-libs-257.6...  1469.1 KiB  6.43 MiB/s 00:00 [###########################] 100%
 gawk-5.3.2-1-x86_64    1462.4 KiB  6.49 MiB/s 00:00 [###########################] 100%
 gtkmm3-3.24.10-1-x...  1427.6 KiB  5.91 MiB/s 00:00 [###########################] 100%
 sdl3-3.2.16-1-x86_64   1410.7 KiB  6.26 MiB/s 00:00 [###########################] 100%
 python-lxml-5.4.0-...  1373.6 KiB  6.10 MiB/s 00:00 [###########################] 100%
 totem-43.2-1-x86_64    1366.1 KiB  6.06 MiB/s 00:00 [###########################] 100%
 xfsprogs-6.14.0-1-...  1351.8 KiB  6.00 MiB/s 00:00 [###########################] 100%
 libgoa-3.54.3-1-x86_64 1349.3 KiB  5.99 MiB/s 00:00 [###########################] 100%
 folks-0.15.9-2-x86_64  1330.7 KiB  5.91 MiB/s 00:00 [###########################] 100%
 shiboken6-6.9.1-2-...  1327.9 KiB  5.89 MiB/s 00:00 [###########################] 100%
 linux-api-headers-...  1309.9 KiB  5.89 MiB/s 00:00 [###########################] 100%
 leancrypto-1.4.0-1...  1307.9 KiB  5.70 MiB/s 00:00 [###########################] 100%
 apparmor-4.1.1-1-x...  1299.8 KiB  5.52 MiB/s 00:00 [###########################] 100%
 libgphoto2-2.5.31-...  1295.4 KiB  5.75 MiB/s 00:00 [###########################] 100%
 gfxstream-0.1.2-2-...  1268.2 KiB  5.71 MiB/s 00:00 [###########################] 100%
 openssh-10.0p1-3-x...  1265.3 KiB  5.62 MiB/s 00:00 [###########################] 100%
 python-cryptograph...  1265.1 KiB  5.69 MiB/s 00:00 [###########################] 100%
 e2fsprogs-1.47.2-2...  1264.2 KiB  5.61 MiB/s 00:00 [###########################] 100%
 kbd-2.8.0-1-x86_64     1258.1 KiB  5.66 MiB/s 00:00 [###########################] 100%
 seahorse-1:47.0.1-...  1255.7 KiB  5.57 MiB/s 00:00 [###########################] 100%
 transmission-cli-4...  1254.6 KiB  5.65 MiB/s 00:00 [###########################] 100%
 qt6-wayland-6.9.1-...  1254.1 KiB  4.12 MiB/s 00:00 [###########################] 100%
 btrfs-progs-6.14-1...  1250.5 KiB  5.63 MiB/s 00:00 [###########################] 100%
 shadow-4.17.4-1-x86_64 1244.6 KiB  5.60 MiB/s 00:00 [###########################] 100%
 gnome-terminal-3.5...  1241.6 KiB  5.51 MiB/s 00:00 [###########################] 100%
 abseil-cpp-2025051...  1226.2 KiB  5.52 MiB/s 00:00 [###########################] 100%
 python-setuptools-...  1216.6 KiB  5.48 MiB/s 00:00 [###########################] 100%
 curl-8.14.1-1-x86_64   1211.7 KiB  5.56 MiB/s 00:00 [###########################] 100%
 libfabric-2.1.0-1-...  1203.8 KiB  5.34 MiB/s 00:00 [###########################] 100%
 alsa-utils-1.2.14-...  1202.9 KiB  5.52 MiB/s 00:00 [###########################] 100%
 strongswan-6.0.1-1...  1201.8 KiB  5.48 MiB/s 00:00 [###########################] 100%
 pacman-7.0.0.r10.g...  1179.2 KiB  5.41 MiB/s 00:00 [###########################] 100%
 man-db-2.13.1-1-x86_64 1169.0 KiB  5.36 MiB/s 00:00 [###########################] 100%
 qt6-multimedia-6.9...  1160.1 KiB  5.29 MiB/s 00:00 [###########################] 100%
 ncurses-6.5-4-x86_64   1158.7 KiB  5.24 MiB/s 00:00 [###########################] 100%
 modemmanager-1.24....  1153.1 KiB  5.29 MiB/s 00:00 [###########################] 100%
 gst-plugins-bad-1....  1144.1 KiB  5.25 MiB/s 00:00 [###########################] 100%
 libmysofa-1.3.3-1-...  1136.1 KiB  5.11 MiB/s 00:00 [###########################] 100%
 libphonenumber-1:9...  1127.6 KiB  5.17 MiB/s 00:00 [###########################] 100%
 iproute2-6.15.0-1-...  1126.6 KiB  1865 KiB/s 00:01 [###########################] 100%
 harfbuzz-11.2.1-1-...  1121.2 KiB  5.07 MiB/s 00:00 [###########################] 100%
 plymouth-24.004.60...  1116.1 KiB  5.09 MiB/s 00:00 [###########################] 100%
 qt5-wayland-5.15.1...  1102.5 KiB  5.13 MiB/s 00:00 [###########################] 100%
 glibmm-2.68-2.84.0...  1082.2 KiB  4.54 MiB/s 00:00 [###########################] 100%
 mbedtls-3.6.3-1-x86_64 1080.3 KiB  4.93 MiB/s 00:00 [###########################] 100%
 hwinfo-24.0-1-x86_64   1077.0 KiB  4.94 MiB/s 00:00 [###########################] 100%
 simple-scan-48.1-1...  1068.1 KiB  4.97 MiB/s 00:00 [###########################] 100%
 tinysparql-3.9.2-2...  1063.4 KiB  4.95 MiB/s 00:00 [###########################] 100%
 gnome-disk-utility...  1052.9 KiB  4.76 MiB/s 00:00 [###########################] 100%
 gdm-48.0-2-x86_64      1039.3 KiB  4.74 MiB/s 00:00 [###########################] 100%
 rygel-1:0.44.2-3-x...  1031.7 KiB  4.80 MiB/s 00:00 [###########################] 100%
 qpdf-12.2.0-1-x86_64   1029.2 KiB  4.43 MiB/s 00:00 [###########################] 100%
 zsh-theme-powerlev...  1025.9 KiB  4.77 MiB/s 00:00 [###########################] 100%
 glibmm-2.66.8-1-x86_64 1020.3 KiB  6.35 MiB/s 00:00 [###########################] 100%
 lollypop-1.4.41-1-any  1004.7 KiB  4.61 MiB/s 00:00 [###########################] 100%
 gtksourceview5-5.1...   983.1 KiB  5.89 MiB/s 00:00 [###########################] 100%
 capstone-5.0.6-1-x...   978.6 KiB  5.83 MiB/s 00:00 [###########################] 100%
 libgit2-1:1.9.1-1-...   974.3 KiB  5.70 MiB/s 00:00 [###########################] 100%
 openexr-3.3.4-1-x86_64  970.8 KiB  5.58 MiB/s 00:00 [###########################] 100%
 gtksourceview4-4.8...   969.0 KiB  4.83 MiB/s 00:00 [###########################] 100%
 xorg-xwayland-24.1...   959.8 KiB  3.31 MiB/s 00:00 [###########################] 100%
 gvfs-1.57.2-4-x86_64    952.0 KiB  5.57 MiB/s 00:00 [###########################] 100%
 gsettings-desktop-...   949.3 KiB  5.79 MiB/s 00:00 [###########################] 100%
 gnome-settings-dae...   948.1 KiB  4.98 MiB/s 00:00 [###########################] 100%
 virtiofsd-1.13.1-1...   944.2 KiB  5.76 MiB/s 00:00 [###########################] 100%
 libadwaita-1:1.7.4...   922.8 KiB  5.53 MiB/s 00:00 [###########################] 100%
 grilo-plugins-1:0....   922.4 KiB  5.63 MiB/s 00:00 [###########################] 100%
 wolfssl-5.8.0-1-x86_64  920.8 KiB  5.73 MiB/s 00:00 [###########################] 100%
 openpmix-5.0.8-1-x...   912.5 KiB  5.94 MiB/s 00:00 [###########################] 100%
 libbluray-1.3.4-3-...   903.6 KiB  5.52 MiB/s 00:00 [###########################] 100%
 libopenmpt-0.8.0-1...   889.5 KiB  5.43 MiB/s 00:00 [###########################] 100%
 libnm-1.52.0-1-x86_64   886.6 KiB  5.41 MiB/s 00:00 [###########################] 100%
 qca-qt6-2.3.10-2-x...   880.1 KiB  5.47 MiB/s 00:00 [###########################] 100%
 python-pillow-11.2...   877.3 KiB  5.49 MiB/s 00:00 [###########################] 100%
 gnome-boxes-48.0-4...   876.4 KiB  5.45 MiB/s 00:00 [###########################] 100%
 duplicity-3.0.4.1-...   875.9 KiB  4.57 MiB/s 00:00 [###########################] 100%
 procps-ng-4.0.5-3-...   873.6 KiB  4.49 MiB/s 00:00 [###########################] 100%
 xkeyboard-config-2...   867.2 KiB  5.39 MiB/s 00:00 [###########################] 100%
 openconnect-1:9.12...   863.6 KiB  5.37 MiB/s 00:00 [###########################] 100%
 libgdata-0.18.1-4-...   861.4 KiB  5.26 MiB/s 00:00 [###########################] 100%
 libpamac-11.7.3-5-...   850.9 KiB  5.29 MiB/s 00:00 [###########################] 100%
 gnome-system-monit...   830.0 KiB  5.26 MiB/s 00:00 [###########################] 100%
 gufw-26.04-1-any        827.7 KiB  5.05 MiB/s 00:00 [###########################] 100%
 openal-1.24.3-1-x86_64  827.3 KiB  5.05 MiB/s 00:00 [###########################] 100%
 ostree-2025.2-3-x86_64  815.9 KiB  4.69 MiB/s 00:00 [###########################] 100%
 python-pydantic-2....   814.5 KiB  4.68 MiB/s 00:00 [###########################] 100%
 xz-5.8.1-1-x86_64       812.1 KiB  5.05 MiB/s 00:00 [###########################] 100%
 deja-dup-48.2-1-x86_64  806.1 KiB  5.01 MiB/s 00:00 [###########################] 100%
 yelp-42.3-1-x86_64      804.4 KiB  4.70 MiB/s 00:00 [###########################] 100%
 libxml2-2.14.4-1-x...   794.6 KiB  4.82 MiB/s 00:00 [###########################] 100%
 libcap-2.76-1-x86_64    774.9 KiB  4.64 MiB/s 00:00 [###########################] 100%
 qca-qt5-2.3.10-2-x...   774.2 KiB  4.94 MiB/s 00:00 [###########################] 100%
 libnbd-1.22.1-2-x86_64  764.7 KiB  4.76 MiB/s 00:00 [###########################] 100%
 file-roller-44.5-1...   764.4 KiB  4.85 MiB/s 00:00 [###########################] 100%
 xmlsec-1.3.7-2-x86_64   762.8 KiB  4.87 MiB/s 00:00 [###########################] 100%
 qt5-multimedia-5.1...   747.5 KiB  4.48 MiB/s 00:00 [###########################] 100%
 wget-1.25.0-2-x86_64    726.9 KiB  4.64 MiB/s 00:00 [###########################] 100%
 libgcrypt-1.11.1-1...   715.2 KiB  3.49 MiB/s 00:00 [###########################] 100%
 kcoreaddons-6.15.0...   710.2 KiB  4.45 MiB/s 00:00 [###########################] 100%
 gnome-keyring-1:48...   709.1 KiB  4.62 MiB/s 00:00 [###########################] 100%
 localsearch-3.9.0-...   708.3 KiB  4.49 MiB/s 00:00 [###########################] 100%
 gnome-chess-48.0-2...   707.2 KiB  4.51 MiB/s 00:00 [###########################] 100%
 zxing-cpp-2.3.0-5-...   693.3 KiB  4.34 MiB/s 00:00 [###########################] 100%
 python-aiohttp-3.1...   687.1 KiB  1503 KiB/s 00:00 [###########################] 100%
 libimobiledevice-1...   677.6 KiB  4.30 MiB/s 00:00 [###########################] 100%
 papirus-maia-icon-...   666.7 KiB  4.26 MiB/s 00:00 [###########################] 100%
 perl-xml-libxml-2....   661.4 KiB  4.22 MiB/s 00:00 [###########################] 100%
 libgedit-gtksource...   654.3 KiB  4.18 MiB/s 00:00 [###########################] 100%
 pipewire-1:1.4.5-1...   651.6 KiB  4.05 MiB/s 00:00 [###########################] 100%
 openh264-2.6.0-1-x...   650.0 KiB  4.15 MiB/s 00:00 [###########################] 100%
 gjs-2:1.84.2-1-x86_64   642.8 KiB  3.92 MiB/s 00:00 [###########################] 100%
 openvpn-2.6.14-1-x...   630.2 KiB  3.92 MiB/s 00:00 [###########################] 100%
 iagno-3.38.1+r125+...   626.6 KiB  4.00 MiB/s 00:00 [###########################] 100%
 libcupsfilters-2.1...   623.7 KiB  4.06 MiB/s 00:00 [###########################] 100%
 gnome-logs-45.0-2-...   623.1 KiB  3.98 MiB/s 00:00 [###########################] 100%
 cairo-1.18.4-1-x86_64   620.1 KiB  4.04 MiB/s 00:00 [###########################] 100%
 lib32-libx11-1.8.1...   618.9 KiB  4.03 MiB/s 00:00 [###########################] 100%
 libelf-0.193-2-x86_64   614.8 KiB  4.00 MiB/s 00:00 [###########################] 100%
 shared-mime-info-2...   614.4 KiB  4.08 MiB/s 00:00 [###########################] 100%
 gtksourceview3-1:3...   608.2 KiB  3.96 MiB/s 00:00 [###########################] 100%
 dconf-editor-45.0....   607.9 KiB  3.96 MiB/s 00:00 [###########################] 100%
 rutabaga-ffi-0.1.6...   607.0 KiB  3.87 MiB/s 00:00 [###########################] 100%
 libical-3.0.20-2-x...   600.4 KiB  3.91 MiB/s 00:00 [###########################] 100%
 nano-8.5-1-x86_64       597.4 KiB  3.49 MiB/s 00:00 [###########################] 100%
 libcamera-0.5.1-2-...   595.1 KiB  3.70 MiB/s 00:00 [###########################] 100%
 mbedtls2-2.28.10-1...   593.8 KiB  3.87 MiB/s 00:00 [###########################] 100%
 pam-1.7.0-2-x86_64      593.8 KiB  3.87 MiB/s 00:00 [###########################] 100%
 lib32-libelf-0.193...   586.4 KiB  3.74 MiB/s 00:00 [###########################] 100%
 imlib2-1.12.5-1-x86_64  573.1 KiB  3.73 MiB/s 00:00 [###########################] 100%
 at-spi2-core-2.56....   572.9 KiB  3.66 MiB/s 00:00 [###########################] 100%
 prrte-3.0.11-1-x86_64   568.9 KiB  3.70 MiB/s 00:00 [###########################] 100%
 libmm-glib-1.24.0-...   566.5 KiB  3.59 MiB/s 00:00 [###########################] 100%
 bluez-5.83-1-x86_64     565.5 KiB  3.68 MiB/s 00:00 [###########################] 100%
 hwloc-2.12.1-1-x86_64   563.4 KiB  3.74 MiB/s 00:00 [###########################] 100%
 networkmanager-ope...   561.2 KiB  3.56 MiB/s 00:00 [###########################] 100%
 libarchive-3.8.1-1...   558.3 KiB  3.56 MiB/s 00:00 [###########################] 100%
 lib32-libunistring...   557.7 KiB  3.63 MiB/s 00:00 [###########################] 100%
 btop-1.4.3-3-x86_64     555.2 KiB  3.61 MiB/s 00:00 [###########################] 100%
 kwallet-6.15.0-1-x...   551.1 KiB  3.59 MiB/s 00:00 [###########################] 100%
 exempi-2.6.6-1-x86_64   550.6 KiB  3.51 MiB/s 00:00 [###########################] 100%
 s-nail-14.9.25-1-x...   550.2 KiB  3.58 MiB/s 00:00 [###########################] 100%
 gcr-4-4.4.0.1-1-x86_64  547.3 KiB  3.56 MiB/s 00:00 [###########################] 100%
 ntfs-3g-2022.10.3-...   545.4 KiB  3.48 MiB/s 00:00 [###########################] 100%
 webrtc-audio-proce...   535.4 KiB  3.49 MiB/s 00:00 [###########################] 100%
 qt6-multimedia-ffm...   535.2 KiB  3.48 MiB/s 00:00 [###########################] 100%
 gst-editing-servic...   534.9 KiB  3.48 MiB/s 00:00 [###########################] 100%
 libheif-1.19.8-3-x...   533.1 KiB  3.47 MiB/s 00:00 [###########################] 100%
 gnome-calendar-48....   531.4 KiB  2.44 MiB/s 00:00 [###########################] 100%
 zstd-1.5.7-2-x86_64     510.6 KiB  3.39 MiB/s 00:00 [###########################] 100%
 lib32-libxml2-2.14...   506.4 KiB  3.15 MiB/s 00:00 [###########################] 100%
 libplacebo-7.351.0...   505.3 KiB  3.29 MiB/s 00:00 [###########################] 100%
 kconfig-6.15.0-1-x...   498.2 KiB  3.24 MiB/s 00:00 [###########################] 100%
 alsa-lib-1.2.14-1-...   491.5 KiB  3.18 MiB/s 00:00 [###########################] 100%
 util-linux-libs-2....   488.0 KiB  2.92 MiB/s 00:00 [###########################] 100%
 gnome-shell-extens...   483.1 KiB  3.15 MiB/s 00:00 [###########################] 100%
 ranger-1.9.4-4-any      479.7 KiB  3.12 MiB/s 00:00 [###########################] 100%
 libmbim-1.32.0-1-x...   473.4 KiB  3.08 MiB/s 00:00 [###########################] 100%
 snapd-glib-1.68-1-...   472.8 KiB  3.08 MiB/s 00:00 [###########################] 100%
 qt6-5compat-6.9.1-...   471.3 KiB  3.01 MiB/s 00:00 [###########################] 100%
 python-protobuf-31...   469.1 KiB  3.05 MiB/s 00:00 [###########################] 100%
 gnome-contacts-48....   467.8 KiB  3.13 MiB/s 00:00 [###########################] 100%
 libpipewire-1:1.4....   461.2 KiB  3.08 MiB/s 00:00 [###########################] 100%
 qemu-tools-10.0.0-...   455.0 KiB  2.96 MiB/s 00:00 [###########################] 100%
 ldb-2:4.22.2-1-x86_64   454.8 KiB  3.04 MiB/s 00:00 [###########################] 100%
 taglib-2.1-1-x86_64     452.6 KiB  2.95 MiB/s 00:00 [###########################] 100%
 libsoup-2.74.3-3-x...   450.9 KiB  3.00 MiB/s 00:00 [###########################] 100%
 mpg123-1.33.0-1-x86_64  450.2 KiB  2.99 MiB/s 00:00 [###########################] 100%
 inxi-3.3.38.1-1-any     446.7 KiB  2.78 MiB/s 00:00 [###########################] 100%
 gnome-desktop-comm...   446.1 KiB  2.90 MiB/s 00:00 [###########################] 100%
 mpfr-4.2.2-1-x86_64     436.8 KiB  2.92 MiB/s 00:00 [###########################] 100%
 file-5.46-4-x86_64      432.3 KiB  2.95 MiB/s 00:00 [###########################] 100%
 libtheora-1.2.0-1-...   431.9 KiB  2.81 MiB/s 00:00 [###########################] 100%
 xdg-desktop-portal...   425.8 KiB  2.77 MiB/s 00:00 [###########################] 100%
 libtool-2.5.4+r23+...   423.9 KiB  1308 KiB/s 00:00 [###########################] 100%
 solid-6.15.0-1-x86_64   423.7 KiB  2.82 MiB/s 00:00 [###########################] 100%
 libibus-1.5.32-1-x...   423.2 KiB  2.81 MiB/s 00:00 [###########################] 100%
 pango-1:1.56.3-1-x...   421.4 KiB  2.80 MiB/s 00:00 [###########################] 100%
 iptables-1:1.8.11-...   419.0 KiB  2.78 MiB/s 00:00 [###########################] 100%
 nftables-1:1.1.3-1...   416.1 KiB  2.66 MiB/s 00:00 [###########################] 100%
 sdl2-compat-2.32.5...   413.9 KiB  2.69 MiB/s 00:00 [###########################] 100%
 dnsmasq-2.91-1-x86_64   412.9 KiB  2.69 MiB/s 00:00 [###########################] 100%
 audit-4.0.5-1-x86_64    405.3 KiB  2.69 MiB/s 00:00 [###########################] 100%
 gnome-characters-4...   404.7 KiB  2.28 MiB/s 00:00 [###########################] 100%
 virglrenderer-1.1....   400.1 KiB  2.61 MiB/s 00:00 [###########################] 100%
 gnome-online-accou...   398.9 KiB  2.58 MiB/s 00:00 [###########################] 100%
 iana-etc-20250502-...   398.7 KiB  2.60 MiB/s 00:00 [###########################] 100%
 gnome-clocks-48.0-...   396.7 KiB  2.58 MiB/s 00:00 [###########################] 100%
 kwallet5-5.116.0-3...   396.5 KiB  2.65 MiB/s 00:00 [###########################] 100%
 nfs-utils-2.8.3-2-...   393.7 KiB  2.63 MiB/s 00:00 [###########################] 100%
 libsoup3-3.6.5-1-x...   392.6 KiB  2.68 MiB/s 00:00 [###########################] 100%
 sonnet-6.15.0-1-x86_64  388.0 KiB  2.58 MiB/s 00:00 [###########################] 100%
 ca-certificates-mo...   386.4 KiB  2.52 MiB/s 00:00 [###########################] 100%
 gtest-1.17.0-1-x86_64   384.8 KiB  2.56 MiB/s 00:00 [###########################] 100%
 gmime3-3.2.15-2-x86_64  383.2 KiB  2.49 MiB/s 00:00 [###########################] 100%
 gnome-shell-extens...   383.0 KiB  2.49 MiB/s 00:00 [###########################] 100%
 vte4-0.80.2-1-x86_64    372.7 KiB  2.53 MiB/s 00:00 [###########################] 100%
 lib32-curl-8.14.1-...   372.6 KiB  2.48 MiB/s 00:00 [###########################] 100%
 vte3-0.80.2-1-x86_64    372.6 KiB  2.49 MiB/s 00:00 [###########################] 100%
 fontconfig-2:2.16....   368.1 KiB  2.45 MiB/s 00:00 [###########################] 100%
 libfprint-1.94.9-1...   368.0 KiB  1840 KiB/s 00:00 [###########################] 100%
 zvbi-0.2.44-1-x86_64    367.2 KiB  2.44 MiB/s 00:00 [###########################] 100%
 lua-5.4.8-2-x86_64      362.1 KiB  2.36 MiB/s 00:00 [###########################] 100%
 adwaita-cursors-48...   360.0 KiB  2.39 MiB/s 00:00 [###########################] 100%
 kconfigwidgets-6.1...   352.7 KiB  2.34 MiB/s 00:00 [###########################] 100%
 qemu-pr-helper-10....   351.4 KiB  2.40 MiB/s 00:00 [###########################] 100%
 poppler-glib-25.06...   351.3 KiB  2.35 MiB/s 00:00 [###########################] 100%
 libdrm-2.4.125-1-x...   347.7 KiB  2.31 MiB/s 00:00 [###########################] 100%
 tzdata-2025b-1-x86_64   347.2 KiB  2.31 MiB/s 00:00 [###########################] 100%
 python-beautifulso...   346.3 KiB  2.25 MiB/s 00:00 [###########################] 100%
 dbus-1.16.2-1-x86_64    346.1 KiB  2.30 MiB/s 00:00 [###########################] 100%
 baobab-48.0-3-x86_64    344.1 KiB  2024 KiB/s 00:00 [###########################] 100%
 spice-0.16.0-1-x86_64   342.4 KiB  2.27 MiB/s 00:00 [###########################] 100%
 diffutils-3.12-2-x...   341.9 KiB  2.32 MiB/s 00:00 [###########################] 100%
 flac-1.5.0-1-x86_64     335.2 KiB  2.27 MiB/s 00:00 [###########################] 100%
 gnome-session-48.0...   332.9 KiB  2.21 MiB/s 00:00 [###########################] 100%
 libglvnd-1.7.0-3-x...   326.2 KiB  2.18 MiB/s 00:00 [###########################] 100%
 readline-8.2.013-2...   325.5 KiB  2.18 MiB/s 00:00 [###########################] 100%
 lib32-zstd-1.5.7-2...   324.4 KiB  2.20 MiB/s 00:00 [###########################] 100%
 libppd-2.1.1-1-x86_64   318.3 KiB  2.16 MiB/s 00:00 [###########################] 100%
 gpgme-2.0.0-1-x86_64    317.7 KiB  2.11 MiB/s 00:00 [###########################] 100%
 gnome-shell-extens...   317.1 KiB  1910 KiB/s 00:00 [###########################] 100%
 libaemu-0.1.2-5-x86_64  316.4 KiB  2.10 MiB/s 00:00 [###########################] 100%
 inetutils-2.6-1-x86_64  315.7 KiB  2.06 MiB/s 00:00 [###########################] 100%
 libsndfile-1.2.2-3...   315.5 KiB  2.10 MiB/s 00:00 [###########################] 100%
 grilo-0.3.19-1-x86_64   315.3 KiB  2.09 MiB/s 00:00 [###########################] 100%
 libnice-0.1.22-2-x...   312.0 KiB  2.07 MiB/s 00:00 [###########################] 100%
 ktextwidgets-6.15....   306.4 KiB  1964 KiB/s 00:00 [###########################] 100%
 libinput-1.28.1-1-...   306.3 KiB  2.09 MiB/s 00:00 [###########################] 100%
 python-jinja-1:3.1...   305.0 KiB  2.07 MiB/s 00:00 [###########################] 100%
 libinstpatch-1.1.7...   303.7 KiB  2.03 MiB/s 00:00 [###########################] 100%
 python-gobject-3.5...   302.9 KiB  2.07 MiB/s 00:00 [###########################] 100%
 libidn-1.43-1-x86_64    301.6 KiB  2.06 MiB/s 00:00 [###########################] 100%
 libnvme-1.13-1-x86_64   295.8 KiB  2012 KiB/s 00:00 [###########################] 100%
 libvirt-glib-5.0.0...   292.3 KiB  1989 KiB/s 00:00 [###########################] 100%
 raptor-2.0.16-7-x86_64  292.0 KiB  1987 KiB/s 00:00 [###########################] 100%
 libpcap-1.10.5-3-x...   288.1 KiB  2001 KiB/s 00:00 [###########################] 100%
 pixman-0.46.2-1-x86_64  284.6 KiB  1936 KiB/s 00:00 [###########################] 100%
 cmus-2.12.0-3-x86_64    284.2 KiB  1946 KiB/s 00:00 [###########################] 100%
 libldap-2.6.10-1-x...   282.0 KiB  1932 KiB/s 00:00 [###########################] 100%
 apr-1.7.6-1-x86_64      281.5 KiB  1969 KiB/s 00:00 [###########################] 100%
 device-mapper-2.03...   280.2 KiB  1360 KiB/s 00:00 [###########################] 100%
 libgsf-1.14.53-2-x...   276.2 KiB  1932 KiB/s 00:00 [###########################] 100%
 qt6-svg-6.9.1-1-x86_64  276.1 KiB  1878 KiB/s 00:00 [###########################] 100%
 libwireplumber-0.5...   274.8 KiB  1922 KiB/s 00:00 [###########################] 100%
 libgedit-tepl-6.13...   273.6 KiB  1861 KiB/s 00:00 [###########################] 100%
 manjaro-settings-m...   273.4 KiB  1860 KiB/s 00:00 [###########################] 100%
 gst-plugin-gtk4-0....   273.3 KiB  1859 KiB/s 00:00 [###########################] 100%
 libavif-1.3.0-1-x86_64  272.6 KiB  1867 KiB/s 00:00 [###########################] 100%
 libcups-2:2.4.12-2...   272.2 KiB  1851 KiB/s 00:00 [###########################] 100%
 libosinfo-1.12.0-2...   269.9 KiB  1888 KiB/s 00:00 [###########################] 100%
 libgpg-error-1.55-...   269.1 KiB  1869 KiB/s 00:00 [###########################] 100%
 libimagequant-4.3....   267.5 KiB  1408 KiB/s 00:00 [###########################] 100%
 orc-0.4.41-1-x86_64     267.4 KiB  1819 KiB/s 00:00 [###########################] 100%
 python-google-auth...   267.0 KiB  1669 KiB/s 00:00 [###########################] 100%
 quadrapassel-40.2-...   266.1 KiB  1810 KiB/s 00:00 [###########################] 100%
 gnome-bluetooth-3....   264.5 KiB  1799 KiB/s 00:00 [###########################] 100%
 libde265-1.0.16-1-...   262.9 KiB  1801 KiB/s 00:00 [###########################] 100%
 ncdu-2.8.2-2-x86_64     261.0 KiB  1825 KiB/s 00:00 [###########################] 100%
 xdg-desktop-portal...   259.8 KiB  1767 KiB/s 00:00 [###########################] 100%
 fluidsynth-2.4.6-1...   258.9 KiB  1773 KiB/s 00:00 [###########################] 100%
 qemu-vhost-user-gp...   256.1 KiB  1742 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...   255.7 KiB  1739 KiB/s 00:00 [###########################] 100%
 libbpf-1.5.1-1-x86_64   254.7 KiB  1781 KiB/s 00:00 [###########################] 100%
 gdbm-1.25-1-x86_64      253.9 KiB  1693 KiB/s 00:00 [###########################] 100%
 libpng-1.6.49-1-x86_64  253.1 KiB  1770 KiB/s 00:00 [###########################] 100%
 libblockdev-3.3.0-...   252.2 KiB  1716 KiB/s 00:00 [###########################] 100%
 oath-toolkit-2.6.1...   244.6 KiB  1675 KiB/s 00:00 [###########################] 100%
 gnome-user-share-4...   244.3 KiB  1708 KiB/s 00:00 [###########################] 100%
 gnome-mines-48.1-1...   243.1 KiB  1373 KiB/s 00:00 [###########################] 100%
 squashfs-tools-4.7...   243.0 KiB  1688 KiB/s 00:00 [###########################] 100%
 libxkbcommon-1.10....   242.9 KiB  1698 KiB/s 00:00 [###########################] 100%
 kservice-6.15.0-1-...   237.5 KiB  1650 KiB/s 00:00 [###########################] 100%
 grep-3.12-2-x86_64      235.6 KiB  1648 KiB/s 00:00 [###########################] 100%
 wireplumber-0.5.10...   234.8 KiB  1631 KiB/s 00:00 [###########################] 100%
 python-urllib3-2.4...   231.8 KiB  1621 KiB/s 00:00 [###########################] 100%
 python-pyparsing-3...   229.5 KiB  1561 KiB/s 00:00 [###########################] 100%
 faad2-2.11.2-1-x86_64   228.0 KiB  1551 KiB/s 00:00 [###########################] 100%
 gnuchess-6.2.11-1-...   228.0 KiB  1594 KiB/s 00:00 [###########################] 100%
 libtracefs-1.8.2-1...   227.8 KiB  1582 KiB/s 00:00 [###########################] 100%
 kwindowsystem-6.15...   225.9 KiB  1580 KiB/s 00:00 [###########################] 100%
 libvpl-2.15.0-1-x86_64  225.3 KiB  1565 KiB/s 00:00 [###########################] 100%
 lcms2-2.17-1-x86_64     220.0 KiB  1496 KiB/s 00:00 [###########################] 100%
 lib32-ncurses-6.5-...   219.6 KiB  1536 KiB/s 00:00 [###########################] 100%
 neon-0.34.2-1-x86_64    217.6 KiB  1480 KiB/s 00:00 [###########################] 100%
 xapp-2.8.9-1-x86_64     216.7 KiB  1548 KiB/s 00:00 [###########################] 100%
 gst-devtools-libs-...   216.0 KiB  1510 KiB/s 00:00 [###########################] 100%
 python-bcrypt-4.3....   215.0 KiB  1434 KiB/s 00:00 [###########################] 100%
 mtools-1:4.0.49-1-...   213.3 KiB  1451 KiB/s 00:00 [###########################] 100%
 python-click-8.1.8...   212.1 KiB  1178 KiB/s 00:00 [###########################] 100%
 dhcpcd-10.2.4-1-x86_64  211.5 KiB  1479 KiB/s 00:00 [###########################] 100%
 gst-plugins-base-1...   211.0 KiB  1507 KiB/s 00:00 [###########################] 100%
 osinfo-db-20250606...   210.2 KiB  1470 KiB/s 00:00 [###########################] 100%
 pacman-mirrors-5.0...   209.5 KiB  1465 KiB/s 00:00 [###########################] 100%
 foomatic-db-engine...   209.1 KiB  1462 KiB/s 00:00 [###########################] 100%
 cpupower-6.15-1-x86_64  207.4 KiB  1411 KiB/s 00:00 [###########################] 100%
 libxslt-1.1.43-2-x...   203.7 KiB  1425 KiB/s 00:00 [###########################] 100%
 liburing-2.11-1-x86_64  202.6 KiB  1407 KiB/s 00:00 [###########################] 100%
 yelp-xsl-42.4-1-any     201.4 KiB  1379 KiB/s 00:00 [###########################] 100%
 gnome-font-viewer-...   200.3 KiB  1276 KiB/s 00:00 [###########################] 100%
 dialog-1:1.3_20250...   200.1 KiB  1399 KiB/s 00:00 [###########################] 100%
 adwaita-icon-theme...   198.5 KiB  1378 KiB/s 00:00 [###########################] 100%
 bluez-obex-5.83-1-...   198.4 KiB  1388 KiB/s 00:00 [###########################] 100%
 kguiaddons-6.15.0-...   197.0 KiB  1368 KiB/s 00:00 [###########################] 100%
 libsecret-0.21.7-1...   188.2 KiB  1316 KiB/s 00:00 [###########################] 100%
 unrar-1:7.1.7-1-x86_64  183.2 KiB  1272 KiB/s 00:00 [###########################] 100%
 pamac-gtk-11.7.3-3...   181.4 KiB  1242 KiB/s 00:00 [###########################] 100%
 gnome-console-48.0...   180.0 KiB  1250 KiB/s 00:00 [###########################] 100%
 libnfs-6.0.2-5-x86_64   179.0 KiB  1252 KiB/s 00:00 [###########################] 100%
 karchive-6.15.0-1-...   179.0 KiB  1098 KiB/s 00:00 [###########################] 100%
 gst-plugins-ugly-1...   177.6 KiB  1184 KiB/s 00:00 [###########################] 100%
 libwacom-2.16.1-1-...   175.7 KiB  1255 KiB/s 00:00 [###########################] 100%
 libtirpc-1.3.6-2-x...   172.8 KiB  1209 KiB/s 00:00 [###########################] 100%
 kiconthemes-6.15.0...   171.3 KiB  1189 KiB/s 00:00 [###########################] 100%
 re2-1:20240702-5-x...   167.1 KiB  1193 KiB/s 00:00 [###########################] 100%
 kjobwidgets-6.15.0...   166.9 KiB  1159 KiB/s 00:00 [###########################] 100%
 libplist-2.7.0-1-x...   165.6 KiB  1134 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...   162.5 KiB  1128 KiB/s 00:00 [###########################] 100%
 shaderc-2025.2-2-x...   160.3 KiB  1121 KiB/s 00:00 [###########################] 100%
 htop-3.4.1-1-x86_64     160.0 KiB  1119 KiB/s 00:00 [###########################] 100%
 lib32-libldap-2.6....   159.9 KiB  1110 KiB/s 00:00 [###########################] 100%
 kdialog-25.04.2-1-...   159.6 KiB  1116 KiB/s 00:00 [###########################] 100%
 glib2-devel-2.84.3...   159.0 KiB  1104 KiB/s 00:00 [###########################] 100%
 knotifications-6.1...   158.7 KiB  1110 KiB/s 00:00 [###########################] 100%
 python-googleapis-...   156.2 KiB  1092 KiB/s 00:00 [###########################] 100%
 bolt-0.9.9-1-x86_64     156.1 KiB  1062 KiB/s 00:00 [###########################] 100%
 kcodecs-6.15.0-1-x...   156.1 KiB  1115 KiB/s 00:00 [###########################] 100%
 upower-1.90.9-1-x86_64  153.7 KiB  1046 KiB/s 00:00 [###########################] 100%
 gpgmepp-2.0.0-2-x86_64  153.0 KiB  1070 KiB/s 00:00 [###########################] 100%
 gnome-weather-48.0...   152.7 KiB  1039 KiB/s 00:00 [###########################] 100%
 mesa-utils-9.0.0-7...   151.6 KiB  1083 KiB/s 00:00 [###########################] 100%
 libxmlb-0.3.22-1-x...   151.4 KiB  1059 KiB/s 00:00 [###########################] 100%
 gtk-vnc-1.5.0-1-x86_64  151.3 KiB  1050 KiB/s 00:00 [###########################] 100%
 adw-gtk-theme-6.2-...   151.1 KiB  1080 KiB/s 00:00 [###########################] 100%
 dtc-1.7.2-4-x86_64      150.6 KiB  1046 KiB/s 00:00 [###########################] 100%
 fprintd-1.94.5-1-x...   150.4 KiB  1044 KiB/s 00:00 [###########################] 100%
 qt5-svg-5.15.17+kd...   149.3 KiB  1044 KiB/s 00:00 [###########################] 100%
 libgirepository-1....   147.9 KiB  1034 KiB/s 00:00 [###########################] 100%
 gnome-firmware-47....   147.7 KiB  1025 KiB/s 00:00 [###########################] 100%
 dbus-broker-37-2-x...   146.8 KiB  1026 KiB/s 00:00 [###########################] 100%
 libgme-0.6.4-1-x86_64   144.6 KiB  1004 KiB/s 00:00 [###########################] 100%
 vulkan-icd-loader-...   142.7 KiB   811 KiB/s 00:00 [###########################] 100%
 lib32-vulkan-icd-l...   142.2 KiB   995 KiB/s 00:00 [###########################] 100%
 libksba-1.6.7-2-x86_64  142.2 KiB   968 KiB/s 00:00 [###########################] 100%
 wayland-1.23.1-2-x...   140.1 KiB   960 KiB/s 00:00 [###########################] 100%
 iputils-20250605-1...   139.7 KiB   890 KiB/s 00:00 [###########################] 100%
 iperf-2.2.1-1-x86_64    138.7 KiB   851 KiB/s 00:00 [###########################] 100%
 protobuf-c-1.5.2-4...   136.0 KiB   944 KiB/s 00:00 [###########################] 100%
 libstemmer-3.0.1-1...   135.4 KiB   947 KiB/s 00:00 [###########################] 100%
 dbus-glib-0.114-1-...   134.0 KiB   931 KiB/s 00:00 [###########################] 100%
 lm_sensors-1:3.6.2...   133.6 KiB   954 KiB/s 00:00 [###########################] 100%
 libtasn1-4.20.0-1-...   133.4 KiB   933 KiB/s 00:00 [###########################] 100%
 qt6-speech-6.9.1-1...   132.5 KiB   947 KiB/s 00:00 [###########################] 100%
 gupnp-av-0.14.3-2-...   132.1 KiB   917 KiB/s 00:00 [###########################] 100%
 perl-libwww-6.78-1-any  131.9 KiB   923 KiB/s 00:00 [###########################] 100%
 libgexiv2-0.14.5-1...   131.1 KiB   910 KiB/s 00:00 [###########################] 100%
 fuse3-3.17.1-1-x86_64   130.9 KiB   915 KiB/s 00:00 [###########################] 100%
 liburcu-0.15.1-1-x...   130.8 KiB   890 KiB/s 00:00 [###########################] 100%
 kmod-34.2-1-x86_64      130.3 KiB   708 KiB/s 00:00 [###########################] 100%
 pkgfile-24-1-x86_64     130.1 KiB   723 KiB/s 00:00 [###########################] 100%
 volume_key-0.3.12-...   130.1 KiB   929 KiB/s 00:00 [###########################] 100%
 wayland-protocols-...   129.5 KiB   906 KiB/s 00:00 [###########################] 100%
 libpeas-1.36.0-7-x...   129.3 KiB   904 KiB/s 00:00 [###########################] 100%
 python-packaging-2...   128.8 KiB   920 KiB/s 00:00 [###########################] 100%
 kitemviews-6.15.0-...   127.1 KiB   908 KiB/s 00:00 [###########################] 100%
 kcompletion-6.15.0...   126.5 KiB   885 KiB/s 00:00 [###########################] 100%
 kbookmarks-6.15.0-...   126.1 KiB   900 KiB/s 00:00 [###########################] 100%
 gupnp-1:1.6.8-2-x86_64  124.9 KiB   892 KiB/s 00:00 [###########################] 100%
 totem-pl-parser-3....   121.8 KiB   846 KiB/s 00:00 [###########################] 100%
 python-requests-2....   121.1 KiB   847 KiB/s 00:00 [###########################] 100%
 python-dbus-1.4.0-...   120.2 KiB   835 KiB/s 00:00 [###########################] 100%
 alacarte-1:3.56.0-...   119.7 KiB   798 KiB/s 00:00 [###########################] 100%
 libgdm-48.0-2-x86_64    119.3 KiB   834 KiB/s 00:00 [###########################] 100%
 touche-2.0.15-1-x86_64  119.3 KiB   829 KiB/s 00:00 [###########################] 100%
 gnome-desktop-4-1:...   117.3 KiB   838 KiB/s 00:00 [###########################] 100%
 expat-2.7.1-1-x86_64    116.5 KiB   832 KiB/s 00:00 [###########################] 100%
 python-more-iterto...   116.4 KiB   808 KiB/s 00:00 [###########################] 100%
 liblc3-1.1.3-1-x86_64   116.3 KiB   831 KiB/s 00:00 [###########################] 100%
 touchegg-2.0.18-1-...   115.6 KiB   786 KiB/s 00:00 [###########################] 100%
 python-yarl-1.21.1...   115.3 KiB   807 KiB/s 00:00 [###########################] 100%
 kauth-6.15.0-1-x86_64   115.0 KiB   804 KiB/s 00:00 [###########################] 100%
 lib32-libssh2-1.11...   114.9 KiB   803 KiB/s 00:00 [###########################] 100%
 gnome-desktop-1:44...   114.6 KiB   802 KiB/s 00:00 [###########################] 100%
 python-tldextract-...   113.4 KiB   810 KiB/s 00:00 [###########################] 100%
 libedit-20250104_3...   112.3 KiB   820 KiB/s 00:00 [###########################] 100%
 alsa-ucm-conf-1.2....   112.1 KiB   801 KiB/s 00:00 [###########################] 100%
 python-attrs-25.3....   109.5 KiB   761 KiB/s 00:00 [###########################] 100%
 python-pyopenssl-2...   108.1 KiB   772 KiB/s 00:00 [###########################] 100%
 xdg-desktop-portal...   107.0 KiB   748 KiB/s 00:00 [###########################] 100%
 pugixml-1.15-2-x86_64   106.3 KiB   759 KiB/s 00:00 [###########################] 100%
 python-pycurl-7.45...   105.9 KiB   740 KiB/s 00:00 [###########################] 100%
 lib32-xz-5.8.1-1-x...   104.2 KiB   744 KiB/s 00:00 [###########################] 100%
 libei-1.4.1-1-x86_64    104.2 KiB   723 KiB/s 00:00 [###########################] 100%
 python-ply-3.11-15-any  104.2 KiB   728 KiB/s 00:00 [###########################] 100%
 freeglut-3.6.0-2-x...   104.1 KiB   713 KiB/s 00:00 [###########################] 100%
 manjaro-hello-0.8....   103.9 KiB   722 KiB/s 00:00 [###########################] 100%
 mpdecimal-4.0.1-1-...   103.2 KiB   721 KiB/s 00:00 [###########################] 100%
 ocl-icd-2.3.3-1-x86_64  102.4 KiB   652 KiB/s 00:00 [###########################] 100%
 libportal-0.9.1-2-...   101.8 KiB   712 KiB/s 00:00 [###########################] 100%
 zlib-ng-2.2.4-1-x86_64  101.4 KiB   724 KiB/s 00:00 [###########################] 100%
 libgrss-0.7.0+16+g...   101.3 KiB   694 KiB/s 00:00 [###########################] 100%
 gspell-1.14.0-2-x86_64  100.1 KiB   695 KiB/s 00:00 [###########################] 100%
 pcsclite-2.3.3-1-x...    99.5 KiB   711 KiB/s 00:00 [###########################] 100%
 xorg-twm-1.0.13.1-...    98.6 KiB   690 KiB/s 00:00 [###########################] 100%
 gupnp-dlna-0.12.0-...    98.6 KiB   685 KiB/s 00:00 [###########################] 100%
 cifs-utils-7.4-1-x...    98.2 KiB   717 KiB/s 00:00 [###########################] 100%
 gst-libav-1.26.2-2...    97.6 KiB   712 KiB/s 00:00 [###########################] 100%
 python-typing_exte...    96.2 KiB   668 KiB/s 00:00 [###########################] 100%
 python-cairo-1.28....    95.3 KiB   653 KiB/s 00:00 [###########################] 100%
 python-charset-nor...    94.5 KiB   675 KiB/s 00:00 [###########################] 100%
 libxnvctrl-575.64-...    93.2 KiB   652 KiB/s 00:00 [###########################] 100%
 libnghttp2-1.66.0-...    92.8 KiB   663 KiB/s 00:00 [###########################] 100%
 bc-1.08.2-1-x86_64       92.0 KiB   657 KiB/s 00:00 [###########################] 100%
 libnewt-0.52.25-1-...    91.9 KiB   643 KiB/s 00:00 [###########################] 100%
 libedataserverui4-...    91.8 KiB   600 KiB/s 00:00 [###########################] 100%
 bluez-libs-5.83-1-...    91.5 KiB   635 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    89.2 KiB   637 KiB/s 00:00 [###########################] 100%
 libjcat-0.2.3-2-x86_64   89.2 KiB   624 KiB/s 00:00 [###########################] 100%
 libseccomp-2.5.6-1...    88.7 KiB   620 KiB/s 00:00 [###########################] 100%
 libgedit-amtk-5.9....    87.7 KiB   614 KiB/s 00:00 [###########################] 100%
 jansson-2.14.1-1-x...    87.3 KiB   611 KiB/s 00:00 [###########################] 100%
 gzip-1.14-2-x86_64       86.7 KiB   606 KiB/s 00:00 [###########################] 100%
 python-validate-py...    86.6 KiB   589 KiB/s 00:00 [###########################] 100%
 passim-0.1.10-1-x86_64   84.6 KiB   591 KiB/s 00:00 [###########################] 100%
 usb_modeswitch-2.6...    83.3 KiB   595 KiB/s 00:00 [###########################] 100%
 python-typeguard-4...    82.9 KiB   580 KiB/s 00:00 [###########################] 100%
 qemu-ui-dbus-10.0....    81.9 KiB   569 KiB/s 00:00 [###########################] 100%
 mhwd-0.6.6-4-x86_64      80.2 KiB   573 KiB/s 00:00 [###########################] 100%
 nvidia-driver-assi...    79.1 KiB   565 KiB/s 00:00 [###########################] 100%
 pamac-cli-11.7.3-2...    78.2 KiB   558 KiB/s 00:00 [###########################] 100%
 faac-1.31.1-1-x86_64     77.9 KiB   519 KiB/s 00:00 [###########################] 100%
 fakeroot-1.37.1.2-...    77.2 KiB   540 KiB/s 00:00 [###########################] 100%
 giflib-5.2.2-2-x86_64    77.1 KiB   539 KiB/s 00:00 [###########################] 100%
 libusb-1.0.29-1-x86_64   76.3 KiB   533 KiB/s 00:00 [###########################] 100%
 pkcs11-helper-1.30...    75.3 KiB   523 KiB/s 00:00 [###########################] 100%
 lilv-0.24.26-1-x86_64    73.9 KiB   528 KiB/s 00:00 [###########################] 100%
 kdbusaddons-6.15.0...    73.0 KiB   522 KiB/s 00:00 [###########################] 100%
 libnghttp3-1.10.1-...    73.0 KiB   510 KiB/s 00:00 [###########################] 100%
 python-argcomplete...    72.7 KiB   520 KiB/s 00:00 [###########################] 100%
 exfatprogs-1.2.9-1...    72.7 KiB   520 KiB/s 00:00 [###########################] 100%
 manjaro-zsh-config...    72.0 KiB   503 KiB/s 00:00 [###########################] 100%
 pacui-1.14+100+g4f...    71.9 KiB   499 KiB/s 00:00 [###########################] 100%
 tdb-1.4.13-1-x86_64      71.7 KiB   502 KiB/s 00:00 [###########################] 100%
 librest-0.9.1-3-x86_64   71.5 KiB   500 KiB/s 00:00 [###########################] 100%
 fribidi-1.0.16-2-x...    71.1 KiB   498 KiB/s 00:00 [###########################] 100%
 libnftnl-1.2.9-1-x...    69.9 KiB   500 KiB/s 00:00 [###########################] 100%
 libshout-1:2.4.6-5...    69.7 KiB   498 KiB/s 00:00 [###########################] 100%
 enchant-2.8.2-2-x86_64   69.2 KiB   494 KiB/s 00:00 [###########################] 100%
 sdl2_image-2.8.8-1...    69.0 KiB   479 KiB/s 00:00 [###########################] 100%
 libslirp-4.9.1-1-x...    69.0 KiB   493 KiB/s 00:00 [###########################] 100%
 libxklavier-5.4-6-...    68.0 KiB   486 KiB/s 00:00 [###########################] 100%
 libgusb-0.4.9-2-x86_64   68.0 KiB   486 KiB/s 00:00 [###########################] 100%
 lib32-expat-2.7.1-...    67.9 KiB   496 KiB/s 00:00 [###########################] 100%
 python-wheel-0.45....    66.9 KiB   468 KiB/s 00:00 [###########################] 100%
 qemu-audio-dbus-10...    66.7 KiB   476 KiB/s 00:00 [###########################] 100%
 soundtouch-2.4.0-1...    64.8 KiB   463 KiB/s 00:00 [###########################] 100%
 libxdp-1.5.5-1-x86_64    64.4 KiB   470 KiB/s 00:00 [###########################] 100%
 gst-plugin-pipewir...    64.4 KiB   450 KiB/s 00:00 [###########################] 100%
 lib32-libnghttp3-1...    64.2 KiB   449 KiB/s 00:00 [###########################] 100%
 lib32-libnghttp2-1...    64.1 KiB   458 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    64.1 KiB   436 KiB/s 00:00 [###########################] 100%
 libcloudproviders-...    63.6 KiB   909 KiB/s 00:00 [###########################] 100%
 manjaro-applicatio...    63.5 KiB   870 KiB/s 00:00 [###########################] 100%
 phodav-3.0-4-x86_64      63.4 KiB   905 KiB/s 00:00 [###########################] 100%
 python-multidict-6...    60.8 KiB   821 KiB/s 00:00 [###########################] 100%
 libxft-2.3.9-1-x86_64    60.4 KiB   828 KiB/s 00:00 [###########################] 100%
 ckbcomp-1.227-2-any      60.2 KiB   860 KiB/s 00:00 [###########################] 100%
 composefs-1.0.8-1-...    58.7 KiB   803 KiB/s 00:00 [###########################] 100%
 stoken-0.92-5-x86_64     58.6 KiB   792 KiB/s 00:00 [###########################] 100%
 json-c-0.18-2-x86_64     58.5 KiB   835 KiB/s 00:00 [###########################] 100%
 double-conversion-...    58.2 KiB   797 KiB/s 00:00 [###########################] 100%
 libevdev-1.13.4-1-...    58.2 KiB   497 KiB/s 00:00 [###########################] 100%
 woff2-1.0.2-6-x86_64     58.0 KiB   794 KiB/s 00:00 [###########################] 100%
 tevent-1:0.16.2-1-...    56.8 KiB   812 KiB/s 00:00 [###########################] 100%
 libmfx-23.2.2-4-x86_64   56.8 KiB   768 KiB/s 00:00 [###########################] 100%
 vte-common-0.80.2-...    55.6 KiB   732 KiB/s 00:00 [###########################] 100%
 libwpe-1.16.2-1-x86_64   54.9 KiB   785 KiB/s 00:00 [###########################] 100%
 addwater-1.2.6-1-any     54.8 KiB   783 KiB/s 00:00 [###########################] 100%
 libx86emu-3.7-1-x86_64   54.7 KiB   749 KiB/s 00:00 [###########################] 100%
 libmanette-0.2.12-...    54.6 KiB   747 KiB/s 00:00 [###########################] 100%
 kcolorscheme-6.15....    53.5 KiB   723 KiB/s 00:00 [###########################] 100%
 pacman-contrib-1.1...    52.8 KiB   754 KiB/s 00:00 [###########################] 100%
 libgnome-games-sup...    52.3 KiB   716 KiB/s 00:00 [###########################] 100%
 power-profiles-dae...    49.5 KiB   708 KiB/s 00:00 [###########################] 100%
 gst-python-1.26.2-...    49.4 KiB   677 KiB/s 00:00 [###########################] 100%
 libsysprof-capture...    49.3 KiB   667 KiB/s 00:00 [###########################] 100%
 libsrtp-1:2.7.0-1-...    48.9 KiB   699 KiB/s 00:00 [###########################] 100%
 libsynctex-2025.2-...    48.1 KiB   687 KiB/s 00:00 [###########################] 100%
 qt5-speech-5.15.17...    48.1 KiB   625 KiB/s 00:00 [###########################] 100%
 linux-firmware-whe...    47.8 KiB   655 KiB/s 00:00 [###########################] 100%
 miniupnpc-2.3.3-1-...    47.7 KiB   681 KiB/s 00:00 [###########################] 100%
 talloc-2.4.3-1-x86_64    47.6 KiB   652 KiB/s 00:00 [###########################] 100%
 python-pytz-2025.2...    47.5 KiB   642 KiB/s 00:00 [###########################] 100%
 libayatana-appindi...    47.1 KiB   620 KiB/s 00:00 [###########################] 100%
 chromaprint-1.5.1-...    47.1 KiB   672 KiB/s 00:00 [###########################] 100%
 libffi-3.5.0-1-x86_64    46.7 KiB   667 KiB/s 00:00 [###########################] 100%
 perl-path-tiny-0.1...    46.4 KiB   636 KiB/s 00:00 [###########################] 100%
 nfsidmap-2.8.3-2-x...    46.3 KiB   661 KiB/s 00:00 [###########################] 100%
 gvfs-mtp-1.57.2-4-...    46.2 KiB   659 KiB/s 00:00 [###########################] 100%
 gvfs-gphoto2-1.57....    45.9 KiB   629 KiB/s 00:00 [###########################] 100%
 python-frozenlist-...    45.8 KiB   655 KiB/s 00:00 [###########################] 100%
 libsm-1.2.6-1-x86_64     45.6 KiB   651 KiB/s 00:00 [###########################] 100%
 libdecor-0.2.3-1-x...    45.3 KiB   648 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-qx...    45.0 KiB   616 KiB/s 00:00 [###########################] 100%
 libcbor-0.12.0-1-x...    44.0 KiB   628 KiB/s 00:00 [###########################] 100%
 libgudev-238-3-x86_64    43.6 KiB   623 KiB/s 00:00 [###########################] 100%
 libmediaart-1.9.7-...    43.2 KiB   584 KiB/s 00:00 [###########################] 100%
 python-propcache-0...    42.9 KiB   588 KiB/s 00:00 [###########################] 100%
 hidapi-0.15.0-1-x86_64   42.2 KiB   578 KiB/s 00:00 [###########################] 100%
 manjaro-gnome-sett...    42.1 KiB   577 KiB/s 00:00 [###########################] 100%
 gvfs-afc-1.57.2-4-...    41.9 KiB   567 KiB/s 00:00 [###########################] 100%
 libgedit-gfls-1:0....    41.8 KiB   598 KiB/s 00:00 [###########################] 100%
 libblockdev-fs-3.3...    41.4 KiB   568 KiB/s 00:00 [###########################] 100%
 gnome-layout-switc...    41.1 KiB   562 KiB/s 00:00 [###########################] 100%
 qrencode-4.1.1-4-x...    40.9 KiB   560 KiB/s 00:00 [###########################] 100%
 python-legacy-cgi-...    40.1 KiB   573 KiB/s 00:00 [###########################] 100%
 qemu-ui-gtk-10.0.0...    39.0 KiB   528 KiB/s 00:00 [###########################] 100%
 iio-sensor-proxy-3...    38.3 KiB   547 KiB/s 00:00 [###########################] 100%
 egl-x11-1.0.2-1-x86_64   37.8 KiB   540 KiB/s 00:00 [###########################] 100%
 python-cssselect2-...    37.6 KiB   538 KiB/s 00:00 [###########################] 100%
 wpebackend-fdo-1.1...    37.3 KiB   532 KiB/s 00:00 [###########################] 100%
 egl-wayland-4:1.1....    36.8 KiB   505 KiB/s 00:00 [###########################] 100%
 libimobiledevice-g...    36.6 KiB   523 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    36.6 KiB   522 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    36.6 KiB   501 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    36.5 KiB   522 KiB/s 00:00 [###########################] 100%
 libwbclient-2:4.22...    36.3 KiB   519 KiB/s 00:00 [###########################] 100%
 gst-plugin-gtk-1.2...    36.1 KiB   488 KiB/s 00:00 [###########################] 100%
 lib32-json-c-0.18-...    35.6 KiB   508 KiB/s 00:00 [###########################] 100%
 libnotify-0.8.6-1-...    34.6 KiB   474 KiB/s 00:00 [###########################] 100%
 qemu-hw-uefi-vars-...    34.5 KiB   472 KiB/s 00:00 [###########################] 100%
 qemu-hw-usb-redire...    34.4 KiB   471 KiB/s 00:00 [###########################] 100%
 tecla-48.0.2-1-x86_64    34.0 KiB   460 KiB/s 00:00 [###########################] 100%
 qemu-ui-spice-core...    34.0 KiB   485 KiB/s 00:00 [###########################] 100%
 gobject-introspect...    33.9 KiB   465 KiB/s 00:00 [###########################] 100%
 snappy-1.2.2-2-x86_64    33.6 KiB   460 KiB/s 00:00 [###########################] 100%
 libnautilus-extens...    33.0 KiB   446 KiB/s 00:00 [###########################] 100%
 run-parts-5.22-1-x...    31.9 KiB   456 KiB/s 00:00 [###########################] 100%
 xorg-server-common...    31.5 KiB   432 KiB/s 00:00 [###########################] 100%
 qemu-hw-usb-host-1...    31.4 KiB   430 KiB/s 00:00 [###########################] 100%
 python-pyaml-24.12...    30.4 KiB   435 KiB/s 00:00 [###########################] 100%
 libpamac-flatpak-p...    30.1 KiB   430 KiB/s 00:00 [###########################] 100%
 python-uritemplate...    29.6 KiB   399 KiB/s 00:00 [###########################] 100%
 gvfs-google-1.57.2...    29.1 KiB   416 KiB/s 00:00 [###########################] 100%
 kcrash-6.15.0-1-x86_64   28.8 KiB   412 KiB/s 00:00 [###########################] 100%
 accent-color-chang...    28.8 KiB   395 KiB/s 00:00 [###########################] 100%
 qemu-audio-pipewir...    28.7 KiB   410 KiB/s 00:00 [###########################] 100%
 libspeechd-0.12.1-...    28.6 KiB   386 KiB/s 00:00 [###########################] 100%
 python-filelock-3....    28.4 KiB   406 KiB/s 00:00 [###########################] 100%
 gupnp-igd-1.6.0-2-...    28.4 KiB   424 KiB/s 00:00 [###########################] 100%
 manjaro-gnome-exte...    28.3 KiB   387 KiB/s 00:00 [###########################] 100%
 gvfs-smb-1.57.2-4-...    28.2 KiB   403 KiB/s 00:00 [###########################] 100%
 mhwd-nvidia-390xx-...    28.1 KiB   401 KiB/s 00:00 [###########################] 100%
 mhwd-nvidia-575.64...    27.9 KiB   382 KiB/s 00:00 [###########################] 100%
 libusbmuxd-2.1.1-1...    27.9 KiB   399 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    27.7 KiB   395 KiB/s 00:00 [###########################] 100%
 gvfs-goa-1.57.2-4-...    27.5 KiB   377 KiB/s 00:00 [###########################] 100%
 openresolv-3.16.5-...    27.5 KiB   371 KiB/s 00:00 [###########################] 100%
 alsa-card-profiles...    27.4 KiB   375 KiB/s 00:00 [###########################] 100%
 qemu-ui-sdl-10.0.0...    27.2 KiB   388 KiB/s 00:00 [###########################] 100%
 python-cgi-3.13.0-...    27.1 KiB   388 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    27.1 KiB   387 KiB/s 00:00 [###########################] 100%
 libxkbcommon-x11-1...    26.7 KiB   382 KiB/s 00:00 [###########################] 100%
 qemu-block-ssh-10....    26.6 KiB   364 KiB/s 00:00 [###########################] 100%
 libblockdev-crypto...    26.4 KiB   362 KiB/s 00:00 [###########################] 100%
 libpamac-snap-plug...    26.4 KiB   361 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    25.8 KiB   349 KiB/s 00:00 [###########################] 100%
 libqrtr-glib-1.2.2...    25.7 KiB   352 KiB/s 00:00 [###########################] 100%
 python-aiohappyeye...    25.4 KiB   348 KiB/s 00:00 [###########################] 100%
 qemu-system-x86-fi...    25.2 KiB   360 KiB/s 00:00 [###########################] 100%
 libblockdev-nvme-3...    24.8 KiB   335 KiB/s 00:00 [###########################] 100%
 python-typing-insp...    24.7 KiB   352 KiB/s 00:00 [###########################] 100%
 xorg-xauth-1.1.4-1...    23.9 KiB   342 KiB/s 00:00 [###########################] 100%
 qemu-ui-opengl-10....    23.9 KiB   341 KiB/s 00:00 [###########################] 100%
 cups-pdf-3.0.2-1-x...    23.5 KiB   335 KiB/s 00:00 [###########################] 100%
 networkmanager-str...    23.2 KiB   313 KiB/s 00:00 [###########################] 100%
 qemu-ui-curses-10....    23.1 KiB   331 KiB/s 00:00 [###########################] 100%
 qemu-hw-usb-smartc...    23.0 KiB   315 KiB/s 00:00 [###########################] 100%
 qemu-block-curl-10...    22.9 KiB   328 KiB/s 00:00 [###########################] 100%
 lib32-lm_sensors-1...    22.8 KiB   326 KiB/s 00:00 [###########################] 100%
 os-prober-1.83-1-x...    22.4 KiB   321 KiB/s 00:00 [###########################] 100%
 qemu-block-nfs-10....    22.3 KiB   318 KiB/s 00:00 [###########################] 100%
 qemu-audio-alsa-10...    21.6 KiB   292 KiB/s 00:00 [###########################] 100%
 perl-error-0.17030...    21.2 KiB   303 KiB/s 00:00 [###########################] 100%
 spice-protocol-0.1...    21.2 KiB   291 KiB/s 00:00 [###########################] 100%
 qemu-audio-pa-10.0...    20.9 KiB   299 KiB/s 00:00 [###########################] 100%
 gvfs-nfs-1.57.2-4-...    20.1 KiB   287 KiB/s 00:00 [###########################] 100%
 python-markupsafe-...    20.1 KiB   275 KiB/s 00:00 [###########################] 100%
 python-trove-class...    19.9 KiB   269 KiB/s 00:00 [###########################] 100%
 qemu-audio-oss-10....    19.8 KiB   283 KiB/s 00:00 [###########################] 100%
 sratom-0.6.18-1-x86_64   19.5 KiB   279 KiB/s 00:00 [###########################] 100%
 qemu-audio-jack-10...    19.4 KiB   277 KiB/s 00:00 [###########################] 100%
 qemu-chardev-spice...    19.3 KiB   275 KiB/s 00:00 [###########################] 100%
 libfreeaptx-0.2.2-...    19.0 KiB   272 KiB/s 00:00 [###########################] 100%
 lib32-libffi-3.5.0...    18.8 KiB   269 KiB/s 00:00 [###########################] 100%
 xorg-xinit-1.4.4-1...    18.4 KiB   263 KiB/s 00:00 [###########################] 100%
 qemu-audio-sdl-10....    18.4 KiB   262 KiB/s 00:00 [###########################] 100%
 filesystem-2025.05...    18.1 KiB   248 KiB/s 00:00 [###########################] 100%
 iniparser-4.2.6-1-...    18.0 KiB   258 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    17.9 KiB   245 KiB/s 00:00 [###########################] 100%
 libdiscid-0.6.5-2-...    17.7 KiB   253 KiB/s 00:00 [###########################] 100%
 qemu-ui-spice-app-...    17.5 KiB   250 KiB/s 00:00 [###########################] 100%
 libebur128-1.2.6-2...    17.5 KiB   239 KiB/s 00:00 [###########################] 100%
 qemu-audio-spice-1...    17.3 KiB   248 KiB/s 00:00 [###########################] 100%
 qemu-ui-egl-headle...    17.2 KiB   245 KiB/s 00:00 [###########################] 100%
 gtk-update-icon-ca...    16.8 KiB   241 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    16.6 KiB   237 KiB/s 00:00 [###########################] 100%
 qemu-hw-s390x-virt...    16.0 KiB   229 KiB/s 00:00 [###########################] 100%
 which-2.23-1-x86_64      16.0 KiB   228 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    15.9 KiB   228 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    15.9 KiB   218 KiB/s 00:00 [###########################] 100%
 libblockdev-part-3...    15.8 KiB   226 KiB/s 00:00 [###########################] 100%
 qemu-block-dmg-10....    15.8 KiB   214 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    15.7 KiB   225 KiB/s 00:00 [###########################] 100%
 qemu-hw-display-vi...    15.7 KiB   224 KiB/s 00:00 [###########################] 100%
 gnome-shell-extens...    15.5 KiB   221 KiB/s 00:00 [###########################] 100%
 python-setproctitl...    15.0 KiB   202 KiB/s 00:00 [###########################] 100%
 qemu-base-10.0.0-7...    14.8 KiB   211 KiB/s 00:00 [###########################] 100%
 qemu-desktop-10.0....    14.5 KiB   208 KiB/s 00:00 [###########################] 100%
 qt5-x11extras-5.15...    14.0 KiB   201 KiB/s 00:00 [###########################] 100%
 libblockdev-mdraid...    13.8 KiB   197 KiB/s 00:00 [###########################] 100%
 mhwd-db-20250113-1-any   12.8 KiB   183 KiB/s 00:00 [###########################] 100%
 manjaro-release-25...    12.8 KiB   191 KiB/s 00:00 [###########################] 100%
 libportal-gtk4-0.9...    12.7 KiB   182 KiB/s 00:00 [###########################] 100%
 libportal-gtk3-0.9...    12.7 KiB   181 KiB/s 00:00 [###########################] 100%
 egl-gbm-1.1.2.1-1-...    12.6 KiB   180 KiB/s 00:00 [###########################] 100%
 wireless-regdb-202...    11.5 KiB   156 KiB/s 00:00 [###########################] 100%
 android-udev-20250...    11.4 KiB   162 KiB/s 00:00 [###########################] 100%
 python-aiosignal-1...    11.1 KiB   152 KiB/s 00:00 [###########################] 100%
 nautilus-admin-1:1...    10.8 KiB   148 KiB/s 00:00 [###########################] 100%
 libutempter-1.2.3-...     9.4 KiB   134 KiB/s 00:00 [###########################] 100%
 perl-alien-libxml2...     9.1 KiB   130 KiB/s 00:00 [###########################] 100%
 gnome-mimeapps-0.1...     9.0 KiB   129 KiB/s 00:00 [###########################] 100%
 libblockdev-swap-3...     8.7 KiB   125 KiB/s 00:00 [###########################] 100%
 pamac-gnome-integr...     8.6 KiB   123 KiB/s 00:00 [###########################] 100%
 libblockdev-loop-3...     8.4 KiB   121 KiB/s 00:00 [###########################] 100%
 gnome-keybindings-...     8.2 KiB   112 KiB/s 00:00 [###########################] 100%
 python-certifi-202...     8.0 KiB   114 KiB/s 00:00 [###########################] 100%
 harfbuzz-icu-11.2....     7.9 KiB   113 KiB/s 00:00 [###########################] 100%
 eglexternalplatfor...     7.5 KiB   107 KiB/s 00:00 [###########################] 100%
 systemd-sysvcompat...     6.7 KiB  95.1 KiB/s 00:00 [###########################] 100%
 gsettings-system-s...     6.5 KiB  92.2 KiB/s 00:00 [###########################] 100%
 lib32-libxshmfence...     5.1 KiB  70.5 KiB/s 00:00 [###########################] 100%
 mhwd-nvidia-470xx-...     4.3 KiB  60.9 KiB/s 00:00 [###########################] 100%
 update-grub-2:2.12...     4.2 KiB  60.4 KiB/s 00:00 [###########################] 100%
 pipewire-session-m...     3.8 KiB  53.6 KiB/s 00:00 [###########################] 100%
 dnssec-anchors-202...     3.2 KiB  43.5 KiB/s 00:00 [###########################] 100%
 fuse-common-3.17.1...     2.6 KiB  37.5 KiB/s 00:00 [###########################] 100%
 dbus-broker-units-...     2.4 KiB  32.8 KiB/s 00:00 [###########################] 100%
 Total (789/789)           2.7 GiB  8.63 MiB/s 05:17 [###########################] 100%
(789/789) checking keys in keyring                   [###########################] 100%
(789/789) checking package integrity                 [###########################] 100%
error: ncdu: signature from "Daurnimator <daurnimator@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ncdu-2.8.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
error: failed to commit transaction (invalid or corrupted package)
What kind file is it? data ?
file /var/cache/pacman/pkg/ncdu-2.8.2-3-x86_64.pkg.tar.zst.sig
Do you use a VPN?
Is the time set correctly?
timedatectl
I don’t use a VPN. How could I check what kind of file is this? And the time is correct.
I gave you commands. file is command to detect it.
sorry, I didn’t notice at first. This is the output I get:
file /var/cache/pacman/pkg/ncdu-2.8.2-3-x86_64.pkg.tar.zst.sig          ✔
/var/cache/pacman/pkg/ncdu-2.8.2-3-x86_64.pkg.tar.zst.sig: cannot open `/var/cache/pacman/pkg/ncdu-2.8.2-3-x86_64.pkg.tar.zst.sig' (No such file or directory)
Sorry… was typo:
file /var/cache/pacman/pkg/ncdu-2.8.2-2-x86_64.pkg.tar.zst.sig
I still get the message that there is no such file or directory. Maybe there is still a typo?
Wait you did delete it. :man_facepalming: Download again and don’t delete it.
Then use this:
find /var/cache/pacman/pkg/ -type f -name "*.sig" -exec file {} \;
It is a bit late here. I need to go sleep in 10min.
