when you say download it again you mean:
sudo pacman -Syu ncdu
right?
right?
I did it:
sudo pacman -Syu ncdu ✔
[sudo] password for gideon:
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
warning: dependency cycle detected:
warning: pam will be installed before its systemd-libs dependency
warning: mesa will be installed before its libglvnd dependency
warning: nvidia-utils will be installed before its libglvnd dependency
warning: eglexternalplatform will be installed before its libglvnd dependency
warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd dependency
warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Packages (789) abseil-cpp-20250512.1-1 accent-color-change-r155.f57e60f-1
addwater-1.2.6-1 adw-gtk-theme-6.2-1 adwaita-cursors-48.1-1
adwaita-fonts-48.2-1 adwaita-icon-theme-48.1-1 alacarte-1:3.56.0-1
alsa-card-profiles-1:1.4.5-1 alsa-lib-1.2.14-1 alsa-ucm-conf-1.2.14-2
alsa-utils-1.2.14-1 android-udev-20250525-1 aom-3.12.1-1
apache-2.4.63-3 apparmor-4.1.1-1 appstream-1.0.5-2 apr-1.7.6-1
archlinux-appstream-data-20250529-1 at-spi2-core-2.56.2-1
audit-4.0.5-1 baobab-48.0-3 bash-5.2.037-4 bc-1.08.2-1
binutils-2.44+r94+gfe459e33c676-1 bluez-5.83-1 bluez-libs-5.83-1
bluez-obex-5.83-1 bolt-0.9.9-1 boost-libs-1.88.0-3
breeze-icons-6.15.0-1 btop-1.4.3-3 btrfs-progs-6.14-1
ca-certificates-mozilla-3.112-1 cairo-1.18.4-1 capstone-5.0.6-1
chromaprint-1.5.1-10 chromium-138.0.7204.92-1 cifs-utils-7.4-1
ckbcomp-1.227-2 clang-20.1.6-1 cmus-2.12.0-3 compiler-rt-20.1.6-1
composefs-1.0.8-1 coreutils-9.7-1 cpupower-6.15-1 cups-2:2.4.12-2
cups-pdf-3.0.2-1 curl-8.14.1-1 cython-3.1.2-1 dbus-1.16.2-1
dbus-broker-37-2 dbus-broker-units-37-2 dbus-glib-0.114-1
dconf-editor-45.0.1-3 deja-dup-48.2-1 device-mapper-2.03.32-1
dhcpcd-10.2.4-1 dialog-1:1.3_20250116-1 diffutils-3.12-2
dnsmasq-2.91-1 dnssec-anchors-20250524-1 double-conversion-3.3.1-1
dtc-1.7.2-4 duplicity-3.0.4.1-1 e2fsprogs-1.47.2-2 egl-gbm-1.1.2.1-1
egl-wayland-4:1.1.19-1 egl-x11-1.0.2-1 eglexternalplatform-1.2.1-1
enchant-2.8.2-2 evince-48.0-3 evolution-data-server-3.56.2-2
exempi-2.6.6-1 exfatprogs-1.2.9-1 exiv2-0.28.5-1 expat-2.7.1-1
faac-1.31.1-1 faad2-2.11.2-1 fakeroot-1.37.1.2-1 ffmpeg-2:7.1.1-4
file-5.46-4 file-roller-44.5-1 filesystem-2025.05.03-1 flac-1.5.0-1
flatpak-1:1.16.1-1 fluidsynth-2.4.6-1 folks-0.15.9-2
fontconfig-2:2.16.2-1 foomatic-db-engine-5:20200131-2
foomatic-db-gutenprint-ppds-5.3.5-1 fprintd-1.94.5-1 freeglut-3.6.0-2
fribidi-1.0.16-2 fuse-common-3.17.1-1 fuse3-3.17.1-1 fwupd-2.0.12-1
fzf-0.62.0-1 gawk-5.3.2-1 gcc-15.1.1+r7+gf36ec88aa85a-1
gcc-libs-15.1.1+r7+gf36ec88aa85a-1 gcr-4-4.4.0.1-1 gdbm-1.25-1
gdm-48.0-2 geary-1:46.0-5 gedit-48.2-1 gettext-0.25-1
gfxstream-0.1.2-2 ghostscript-10.05.1-2 giflib-5.2.2-2 git-2.50.0-1
gjs-2:1.84.2-1 glib2-2.84.3-1 glib2-devel-2.84.3-1
glibc-2.41+r48+g5cb575ca9a3d-1 glibc-locales-2.41+r48+g5cb575ca9a3d-1
glibmm-2.66.8-1 glibmm-2.68-2.84.0-1 glm-1.0.1-1
glslang-1:1.4.313.0-1 gmime3-3.2.15-2 gnome-backgrounds-48.2.1-1
gnome-bluetooth-3.0-47.1-2 gnome-boxes-48.0-4 gnome-calculator-48.1-2
gnome-calendar-48.1-1 gnome-characters-48.0-1 gnome-chess-48.0-2
gnome-clocks-48.0-1 gnome-console-48.0.1-1 gnome-contacts-48.0-1
gnome-control-center-48.2-1 gnome-desktop-1:44.3-1
gnome-desktop-4-1:44.3-1 gnome-desktop-common-1:44.3-1
gnome-disk-utility-46.1-2 gnome-firmware-47.0-2
gnome-font-viewer-48.0-1 gnome-keybindings-48.2-1
gnome-keyring-1:48.0-1 gnome-layout-switcher-0.8.39-3
gnome-logs-45.0-2 gnome-mimeapps-0.1-1 gnome-mines-48.1-1
gnome-online-accounts-3.54.3-1 gnome-session-48.0-1
gnome-settings-daemon-48.1-1 gnome-shell-1:48.2-1
gnome-shell-extension-appindicator-1:60-1
gnome-shell-extension-arc-menu-66-1
gnome-shell-extension-dash-to-panel-68-2
gnome-shell-extension-forge-88-1
gnome-shell-extension-gnome-ui-tune-1.10.2-1
gnome-shell-extension-gsconnect-66-1
gnome-shell-extension-gtk4-desktop-icons-ng-1:100.2-1
gnome-shell-extension-legacy-theme-auto-switcher-r25.3d6b167-1
gnome-shell-extension-space-bar-33-1
gnome-shell-extension-x11gestures-25-1 gnome-shell-extensions-48.2-1
gnome-system-monitor-48.1-1 gnome-terminal-3.56.2-1
gnome-user-docs-48.2-1 gnome-user-share-48.0-1 gnome-weather-48.0-2
gnuchess-6.2.11-1 gnutls-3.8.9-1
gobject-introspection-runtime-1.84.0-2 gpgme-2.0.0-1 gpgmepp-2.0.0-2
grep-3.12-2 grilo-0.3.19-1 grilo-plugins-1:0.3.17-1
grub-2:2.12.r292.g73d1c959-1 gsettings-desktop-schemas-48.0-1
gsettings-system-schemas-48.0-1 gspell-1.14.0-2
gst-devtools-libs-1.26.2-2 gst-editing-services-1.26.2-2
gst-libav-1.26.2-2 gst-plugin-gtk-1.26.2-2 gst-plugin-gtk4-0.13.6-1
gst-plugin-pipewire-1:1.4.5-1 gst-plugins-bad-1.26.2-2
gst-plugins-bad-libs-1.26.2-2 gst-plugins-base-1.26.2-2
gst-plugins-base-libs-1.26.2-2 gst-plugins-good-1.26.2-2
gst-plugins-ugly-1.26.2-2 gst-python-1.26.2-2 gstreamer-1.26.2-2
gtest-1.17.0-1 gthumb-3.12.7-1 gtk-update-icon-cache-1:4.18.6-1
gtk-vnc-1.5.0-1 gtk3-1:3.24.49-2 gtk4-1:4.18.6-1 gtkmm-4.0-4.18.0-2
gtkmm3-3.24.10-1 gtksourceview3-1:3.24.11+r30+gd880929f-1
gtksourceview4-4.8.4-2 gtksourceview5-5.16.0-2 gufw-26.04-1
gupnp-1:1.6.8-2 gupnp-av-0.14.3-2 gupnp-dlna-0.12.0-4
gupnp-igd-1.6.0-2 gutenprint-5.3.5-1 gvfs-1.57.2-4 gvfs-afc-1.57.2-4
gvfs-goa-1.57.2-4 gvfs-google-1.57.2-4 gvfs-gphoto2-1.57.2-4
gvfs-mtp-1.57.2-4 gvfs-nfs-1.57.2-4 gvfs-smb-1.57.2-4 gzip-1.14-2
harfbuzz-11.2.1-1 harfbuzz-icu-11.2.1-1 hidapi-0.15.0-1
hplip-1:3.25.2-1 htop-3.4.1-1 hwdata-0.396-1 hwinfo-24.0-1
hwloc-2.12.1-1 iagno-3.38.1+r125+ge144444-1 iana-etc-20250502-1
ibus-1.5.32-1 icu-76.1-1 iio-sensor-proxy-3.7-1
imagemagick-7.1.1.47-2 imath-3.1.12-4 imlib2-1.12.5-1
inetutils-2.6-1 iniparser-4.2.6-1 intel-ucode-20250512-1
inxi-3.3.38.1-1 iperf-2.2.1-1 iproute2-6.15.0-1 iptables-1:1.8.11-2
iputils-20250605-1 iso-codes-4.18.0-1 jansson-2.14.1-1
js115-115.24.0-1 js128-128.11.0-1 json-c-0.18-2 karchive-6.15.0-1
kauth-6.15.0-1 kbd-2.8.0-1 kbookmarks-6.15.0-1 kcodecs-6.15.0-1
kcolorscheme-6.15.0-1 kcompletion-6.15.0-1 kconfig-6.15.0-1
kconfigwidgets-6.15.0-1 kcoreaddons-6.15.0-1 kcrash-6.15.0-1
kdbusaddons-6.15.0-1 kdialog-25.04.2-1 kguiaddons-6.15.0-1
ki18n-6.15.0-1 kiconthemes-6.15.0-1 kio-6.15.0-1 kio5-5.116.0-2
kitemviews-6.15.0-1 kjobwidgets-6.15.0-1 kmod-34.2-1
knotifications-6.15.0-1 kservice-6.15.0-1 ktextwidgets-6.15.0-1
kwallet-6.15.0-1 kwallet5-5.116.0-3 kwidgetsaddons-6.15.0-1
kwindowsystem-6.15.0-1 lcms2-2.17-1 ldb-2:4.22.2-1
leancrypto-1.4.0-1 lib32-curl-8.14.1-1 lib32-expat-2.7.1-1
lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1
lib32-glibc-2.41+r48+g5cb575ca9a3d-1 lib32-icu-76.1-1
lib32-json-c-0.18-2 lib32-libelf-0.193-1 lib32-libffi-3.5.0-1
lib32-libldap-2.6.10-1 lib32-libnghttp2-1.66.0-1
lib32-libnghttp3-1.10.1-1 lib32-libssh2-1.11.1-1
lib32-libunistring-1.3-1 lib32-libx11-1.8.12-1 lib32-libxml2-2.14.4-1
lib32-libxshmfence-1.3.3-1 lib32-llvm-libs-1:20.1.6-1
lib32-lm_sensors-1:3.6.2-2 lib32-mesa-1:25.1.4-1 lib32-ncurses-6.5-2
lib32-nvidia-utils-575.64-1 lib32-openssl-1:3.5.0-1
lib32-spirv-tools-1:1.4.313.0-1 lib32-vulkan-icd-loader-1.4.313.0-1
lib32-xz-5.8.1-1 lib32-zstd-1.5.7-2 libadwaita-1:1.7.4-1
libaemu-0.1.2-5 libarchive-3.8.1-1 libavif-1.3.0-1
libayatana-appindicator-0.5.94-1 libblockdev-3.3.0-1
libblockdev-crypto-3.3.0-1 libblockdev-fs-3.3.0-1
libblockdev-loop-3.3.0-1 libblockdev-mdraid-3.3.0-1
libblockdev-nvme-3.3.0-1 libblockdev-part-3.3.0-1
libblockdev-swap-3.3.0-1 libbluray-1.3.4-3 libbpf-1.5.1-1
libcamera-0.5.1-2 libcamera-ipa-0.5.1-2 libcap-2.76-1
libcbor-0.12.0-1 libcloudproviders-0.3.6-2 libcups-2:2.4.12-2
libcupsfilters-2.1.1-2 libde265-1.0.16-1 libdecor-0.2.3-1
libdiscid-0.6.5-2 libdrm-2.4.125-1 libebur128-1.2.6-2
libedataserverui4-3.56.2-2 libedit-20250104_3.1-1 libei-1.4.1-1
libelf-0.193-2 libevdev-1.13.4-1 libfabric-2.1.0-1 libffi-3.5.0-1
libfprint-1.94.9-1 libfreeaptx-0.2.2-1 libgcrypt-1.11.1-1
libgdata-0.18.1-4 libgdm-48.0-2 libgedit-amtk-5.9.1-1
libgedit-gfls-1:0.3.0-1 libgedit-gtksourceview-299.5.0-2
libgedit-tepl-6.13.0-1 libgexiv2-0.14.5-1 libgirepository-1.84.0-2
libgit2-1:1.9.1-1 libglvnd-1.7.0-3 libgme-0.6.4-1
libgnome-games-support-2-2.0.1-1 libgoa-3.54.3-1 libgpg-error-1.55-1
libgphoto2-2.5.31-4 libgrss-0.7.0+16+g971c421-4 libgsf-1.14.53-2
libgudev-238-3 libgusb-0.4.9-2 libgweather-4-4.4.4-2
libheif-1.19.8-3 libibus-1.5.32-1 libical-3.0.20-2 libidn-1.43-1
libimagequant-4.3.4-1 libimobiledevice-1.3.0-16
libimobiledevice-glue-1.3.2-1 libinput-1.28.1-1 libinstpatch-1.1.7-2
libjcat-0.2.3-2 libjxl-0.11.1-3 libksba-1.6.7-2 liblc3-1.1.3-1
libldap-2.6.10-1 libmanette-0.2.12-1 libmbim-1.32.0-1
libmediaart-1.9.7-1 libmfx-23.2.2-4 libmm-glib-1.24.0-1
libmysofa-1.3.3-1 libnautilus-extension-48.2-1 libnbd-1.22.1-2
libnewt-0.52.25-1 libnfs-6.0.2-5 libnftnl-1.2.9-1
libnghttp2-1.66.0-1 libnghttp3-1.10.1-1 libnice-0.1.22-2
libnm-1.52.0-1 libnotify-0.8.6-1 libnvme-1.13-1 libopenmpt-0.8.0-1
libosinfo-1.12.0-2 libpamac-11.7.3-5 libpamac-flatpak-plugin-11.7.3-5
libpamac-snap-plugin-11.7.3-5 libpcap-1.10.5-3 libpeas-1.36.0-7
libphonenumber-1:9.0.7-2 libpipewire-1:1.4.5-1 libplacebo-7.351.0-1
libplist-2.7.0-1 libpng-1.6.49-1 libportal-0.9.1-2
libportal-gtk3-0.9.1-2 libportal-gtk4-0.9.1-2 libppd-2.1.1-1
libqmi-1.36.0-1 libqrtr-glib-1.2.2-4 librest-0.9.1-3
librsvg-2:2.60.0-2 libseccomp-2.5.6-1 libsecret-0.21.7-1
libshout-1:2.4.6-5 libslirp-4.9.1-1 libsm-1.2.6-1 libsndfile-1.2.2-3
libsoup-2.74.3-3 libsoup3-3.6.5-1 libspeechd-0.12.1-1
libsrtp-1:2.7.0-1 libstemmer-3.0.1-1 libsynctex-2025.2-1
libsysprof-capture-48.0-5 libtasn1-4.20.0-1 libtheora-1.2.0-1
libtirpc-1.3.6-2 libtool-2.5.4+r23+g5b582aed-1 libtracefs-1.8.2-1
liburcu-0.15.1-1 liburing-2.11-1 libusb-1.0.29-1 libusbmuxd-2.1.1-1
libutempter-1.2.3-1 libvirt-1:11.4.0-1 libvirt-glib-5.0.0-3
libvpl-2.15.0-1 libwacom-2.16.1-1 libwbclient-2:4.22.2-1
libwireplumber-0.5.10-1 libwpe-1.16.2-1 libx11-1.8.12-1
libx86emu-3.7-1 libxdp-1.5.5-1 libxft-2.3.9-1 libxkbcommon-1.10.0-1
libxkbcommon-x11-1.10.0-1 libxklavier-5.4-6 libxml2-2.14.4-1
libxmlb-0.3.22-1 libxnvctrl-575.64-1 libxslt-1.1.43-2 lilv-0.24.26-1
linux-api-headers-6.15-1 linux-firmware-20250508.788aadc8-2
linux-firmware-whence-20250508.788aadc8-2 linux515-5.15.185-1
linux515-nvidia-575.64-1 llvm-20.1.6-3 llvm-libs-20.1.6-3
lm_sensors-1:3.6.2-1 localsearch-3.9.0-3 lollypop-1.4.41-1
lua-5.4.8-2 lvm2-2.03.32-1 man-db-2.13.1-1 man-pages-6.14-1
manjaro-application-utility-1.4.1-2
manjaro-gnome-extension-settings-20250311-1
manjaro-gnome-settings-20250504-1 manjaro-hello-0.8.1-2
manjaro-release-25.0.4-1 manjaro-settings-manager-0.5.8-5
manjaro-settings-manager-notifier-0.5.8-5 manjaro-zsh-config-0.26-2
mbedtls-3.6.3-1 mbedtls2-2.28.10-1 mesa-1:25.1.4-1
mesa-utils-9.0.0-7 mhwd-0.6.6-4 mhwd-db-20250113-1
mhwd-nvidia-575.64-1 mhwd-nvidia-390xx-390.157-21
mhwd-nvidia-470xx-470.256.02-14 miniupnpc-2.3.3-1
modemmanager-1.24.0-1 mpdecimal-4.0.1-1 mpfr-4.2.2-1 mpg123-1.33.0-1
mtools-1:4.0.49-1 mutter-48.3.1-2 nano-8.5-1 nautilus-48.2-1
nautilus-admin-1:1.2.0-3 ncurses-6.5-4 neon-0.34.2-1
networkmanager-1.52.0-1 networkmanager-openconnect-1.2.10-3
networkmanager-strongswan-1.6.1-1 nfs-utils-2.8.3-2 nfsidmap-2.8.3-2
nftables-1:1.1.3-1 noto-fonts-1:2025.06.01-1 nss-3.112-1
ntfs-3g-2022.10.3-2 ntp-4.2.8.p18-3
nvidia-driver-assistant-0.21.57.08-1 nvidia-utils-575.64-1
oath-toolkit-2.6.12-2 ocl-icd-2.3.3-1
onlyoffice-desktopeditors-9.0.0-1 openal-1.24.3-1
openconnect-1:9.12-4 openexr-3.3.4-1 openh264-2.6.0-1
openmpi-5.0.8-1 openpmix-5.0.8-1 openresolv-3.16.5-1
openssh-10.0p1-3 openssl-3.5.0-1 openucx-1.18.1-2 openvpn-2.6.14-1
orc-0.4.41-1 os-prober-1.83-1 osinfo-db-20250606-1 ostree-2025.2-3
pacman-7.0.0.r10.ga2d0293-3 pacman-contrib-1.12.0-1
pacman-mirrors-5.0-1 pacui-1.14+100+g4fb3daa-1 pam-1.7.0-2
pamac-cli-11.7.3-2 pamac-gnome-integration-11.7.3-3
pamac-gtk-11.7.3-3 pango-1:1.56.3-1 papirus-icon-theme-20250501-1
papirus-maia-icon-theme-20201007-1 passim-0.1.10-1 pcre2-10.45-1
pcsclite-2.3.3-1 perl-5.40.2-1 perl-alien-libxml2-0.20-1
perl-error-0.17030-1 perl-libwww-6.78-1 perl-path-tiny-0.148-1
perl-xml-libxml-2.0210-3 phodav-3.0-4 pipewire-1:1.4.5-1
pipewire-audio-1:1.4.5-1 pipewire-session-manager-1:1.4.5-1
pixman-0.46.2-1 pkcs11-helper-1.30.0-2 pkgfile-24-1
plymouth-24.004.60-12 poppler-25.06.0-1 poppler-glib-25.06.0-1
power-profiles-daemon-0.30-1 procps-ng-4.0.5-3 protobuf-31.1-1
protobuf-c-1.5.2-4 prrte-3.0.11-1 pugixml-1.15-2 pyside6-6.9.1-2
python-3.13.3-1 python-aiohappyeyeballs-2.6.1-1
python-aiohttp-3.12.13-1 python-aiosignal-1.3.2-1
python-argcomplete-3.5.3-1 python-attrs-25.3.0-1
python-bcrypt-4.3.0-1 python-beautifulsoup4-4.13.3-1
python-cairo-1.28.0-1 python-certifi-2025.06.15-1 python-cgi-3.13.0-2
python-charset-normalizer-3.4.2-1 python-click-8.1.8-1
python-cryptography-45.0.4-1 python-cssselect2-0.8.0-1
python-dbus-1.4.0-1 python-filelock-3.18.0-1
python-frozenlist-1.7.0-1 python-gobject-3.52.3-3
python-google-auth-2.38.0-1 python-googleapis-common-protos-1.70.0-1
python-jinja-1:3.1.6-1 python-legacy-cgi-2.6.3-2 python-lxml-5.4.0-1
python-markupsafe-3.0.2-1 python-more-itertools-10.7.0-1
python-multidict-6.4.4-1 python-packaging-25.0-1
python-pillow-11.2.1-1 python-ply-3.11-15 python-propcache-0.3.2-1
python-protobuf-31.1-1 python-pyaml-24.12.0-1 python-pycurl-7.45.6-1
python-pydantic-2.11.7-1 python-pydantic-core-2:2.33.2-2
python-pyopenssl-25.1.0-1 python-pyparsing-3.2.3-1
python-pytz-2025.2-1 python-requests-2.32.4-1
python-setproctitle-1.3.5-1 python-setuptools-1:80.9.0-1
python-tldextract-5.3.0-1 python-trove-classifiers-2025.5.9.12-1
python-typeguard-4.4.4-1 python-typing-inspection-0.4.1-1
python-typing_extensions-4.13.2-1 python-uritemplate-4.2.0-1
python-urllib3-2.4.0-1 python-validate-pyproject-0.24.1-1
python-wheel-0.45.1-1 python-yarl-1.21.1-1 qca-qt5-2.3.10-2
qca-qt6-2.3.10-2 qemu-audio-alsa-10.0.0-7 qemu-audio-dbus-10.0.0-7
qemu-audio-jack-10.0.0-7 qemu-audio-oss-10.0.0-7
qemu-audio-pa-10.0.0-7 qemu-audio-pipewire-10.0.0-7
qemu-audio-sdl-10.0.0-7 qemu-audio-spice-10.0.0-7 qemu-base-10.0.0-7
qemu-block-curl-10.0.0-7 qemu-block-dmg-10.0.0-7
qemu-block-nfs-10.0.0-7 qemu-block-ssh-10.0.0-7
qemu-chardev-spice-10.0.0-7 qemu-common-10.0.0-7
qemu-desktop-10.0.0-7 qemu-hw-display-qxl-10.0.0-7
qemu-hw-display-virtio-gpu-10.0.0-7
qemu-hw-display-virtio-gpu-gl-10.0.0-7
qemu-hw-display-virtio-gpu-pci-10.0.0-7
qemu-hw-display-virtio-gpu-pci-gl-10.0.0-7
qemu-hw-display-virtio-gpu-pci-rutabaga-10.0.0-7
qemu-hw-display-virtio-gpu-rutabaga-10.0.0-7
qemu-hw-display-virtio-vga-10.0.0-7
qemu-hw-display-virtio-vga-gl-10.0.0-7
qemu-hw-display-virtio-vga-rutabaga-10.0.0-7
qemu-hw-s390x-virtio-gpu-ccw-10.0.0-7 qemu-hw-uefi-vars-10.0.0-7
qemu-hw-usb-host-10.0.0-7 qemu-hw-usb-redirect-10.0.0-7
qemu-hw-usb-smartcard-10.0.0-7 qemu-img-10.0.0-7
qemu-pr-helper-10.0.0-7 qemu-system-x86-10.0.0-7
qemu-system-x86-firmware-10.0.0-7 qemu-tools-10.0.0-7
qemu-ui-curses-10.0.0-7 qemu-ui-dbus-10.0.0-7
qemu-ui-egl-headless-10.0.0-7 qemu-ui-gtk-10.0.0-7
qemu-ui-opengl-10.0.0-7 qemu-ui-sdl-10.0.0-7
qemu-ui-spice-app-10.0.0-7 qemu-ui-spice-core-10.0.0-7
qemu-vhost-user-gpu-10.0.0-7 qpdf-12.2.0-1 qrencode-4.1.1-4
qt5-base-5.15.17+kde+r123-1 qt5-declarative-5.15.17+kde+r21-1
qt5-multimedia-5.15.17+kde+r2-1 qt5-quickcontrols2-5.15.17+kde+r5-1
qt5-speech-5.15.17+kde+r1-1 qt5-svg-5.15.17+kde+r5-1
qt5-translations-5.15.17-1 qt5-wayland-5.15.17+kde+r57-1
qt5-x11extras-5.15.17-1 qt6-5compat-6.9.1-1 qt6-base-6.9.1-1
qt6-declarative-6.9.1-1 qt6-multimedia-6.9.1-1
qt6-multimedia-ffmpeg-6.9.1-1 qt6-shadertools-6.9.1-1
qt6-speech-6.9.1-1 qt6-svg-6.9.1-1 qt6-translations-6.9.1-1
qt6-wayland-6.9.1-1 quadrapassel-40.2-4 ranger-1.9.4-4
raptor-2.0.16-7 re2-1:20240702-5 readline-8.2.013-2 run-parts-5.22-1
rutabaga-ffi-0.1.6-2 rygel-1:0.44.2-3 s-nail-14.9.25-1 sane-1.4.0-1
sdl2-compat-2.32.56-1 sdl2_image-2.8.8-1 sdl3-3.2.16-1
seahorse-1:47.0.1-3 shaderc-2025.2-2 shadow-4.17.4-1
shared-mime-info-2.4-2 shiboken6-6.9.1-2 simple-scan-48.1-1
smbclient-2:4.22.2-1 snapd-2.68.4-1 snapd-glib-1.68-1 snappy-1.2.2-2
sof-firmware-2025.05-1 solid-6.15.0-1 sonnet-6.15.0-1
soundtouch-2.4.0-1 spice-0.16.0-1 spice-protocol-0.14.5-1
spirv-tools-1:1.4.313.0-1 sqlite-3.50.1-1 squashfs-tools-4.7-1
sratom-0.6.18-1 stoken-0.92-5 strongswan-6.0.1-1 sudo-1.9.17.p1-0.1
svt-av1-3.0.2-1 systemd-257.6-1 systemd-libs-257.6-1
systemd-sysvcompat-257.6-1 taglib-2.1-1 talloc-2.4.3-1 tdb-1.4.13-1
tecla-48.0.2-1 tevent-1:0.16.2-1 texinfo-7.2-1 tinysparql-3.9.2-2
totem-43.2-1 totem-pl-parser-3.26.6+r30+g51b8439-2 touche-2.0.15-1
touchegg-2.0.18-1 transmission-cli-4.0.6-10 ttf-hack-nerd-3.4.0-1
ttf-noto-nerd-3.4.0-1 tzdata-2025b-1 unrar-1:7.1.7-1
update-grub-2:2.12.r292.g73d1c959-1 upower-1.90.9-1
usb_modeswitch-2.6.2-1 util-linux-2.41-4 util-linux-libs-2.41-4
v4l-utils-1.30.1-1 virglrenderer-1.1.1-1 virtiofsd-1.13.1-1
volume_key-0.3.12-11 vte-common-0.80.2-1 vte3-0.80.2-1 vte4-0.80.2-1
vulkan-headers-1:1.4.313.0-1 vulkan-icd-loader-1.4.313.0-1
wayland-1.23.1-2 wayland-protocols-1.45-1 webkit2gtk-2.48.3-1
webkit2gtk-4.1-2.48.3-1 webkitgtk-6.0-2.48.3-1
webrtc-audio-processing-1-1.3-5 wget-1.25.0-2 which-2.23-1
wireless-regdb-2025.02.20-1 wireplumber-0.5.10-1 woff2-1.0.2-6
wolfssl-5.8.0-1 wpebackend-fdo-1.16.0-1 x265-4.1-1 xapp-2.8.9-1
xdg-desktop-portal-1.20.3-1 xdg-desktop-portal-gnome-48.0-1
xdg-desktop-portal-gtk-1.15.3-1 xfsprogs-6.14.0-1
xkeyboard-config-2.45-1 xmlsec-1.3.7-2 xorg-server-21.1.18-1
xorg-server-common-21.1.18-1 xorg-twm-1.0.13.1-1 xorg-xauth-1.1.4-1
xorg-xinit-1.4.4-1 xorg-xwayland-24.1.8-1 xz-5.8.1-1 yelp-42.3-1
yelp-xsl-42.4-1 zenity-4.1.90-1 zlib-ng-2.2.4-1
zsh-theme-powerlevel10k-1.20.15-1 zstd-1.5.7-2 zvbi-0.2.44-1
zxing-cpp-2.3.0-5 ncdu-2.8.2-2
Total Download Size: 0.25 MiB
Total Installed Size: 10332.50 MiB
Net Upgrade Size: 603.14 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
ncdu-2.8.2-2-x86_64 261.0 KiB 768 KiB/s 00:00 [###########################] 100%
(789/789) checking keys in keyring [###########################] 100%
(789/789) checking package integrity [###########################] 100%
error: ncdu: signature from "Daurnimator <daurnimator@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ncdu-2.8.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: failed to commit transaction (invalid or corrupted package)
~ find /var/cache/pacman/pkg/ -type f -name "*.sig" -exec file {} \;
/var/cache/pacman/pkg/libarchive-3.8.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sdl2_image-2.8.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtkmm-4.0-4.18.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/virglrenderer-1.1.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libavif-1.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kconfig-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/networkmanager-strongswan-1.6.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sane-1.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-user-docs-48.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/htop-3.4.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-wayland-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mpdecimal-4.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/folks-0.15.9-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gmime3-3.2.15-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zenity-4.1.90-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-spice-app-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xapp-2.8.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-weather-48.0-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libutempter-1.2.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-openssl-1:3.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-base-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-font-viewer-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxkbcommon-1.10.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnuchess-6.2.11-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-base-5.15.17+kde+r123-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/vulkan-headers-1:1.4.313.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gupnp-av-0.14.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kguiaddons-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtest-1.17.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zvbi-0.2.44-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-gnome-extension-settings-20250311-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gdm-48.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/foomatic-db-gutenprint-ppds-5.3.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-lxml-5.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pkgfile-24-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-speech-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-alien-libxml2-0.20-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iso-codes-4.18.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-declarative-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/vte3-0.80.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-cssselect2-0.8.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/file-5.46-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnice-0.1.22-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iio-sensor-proxy-3.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/linux515-5.15.185-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmediaart-1.9.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-loop-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/jansson-2.14.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/hplip-1:3.25.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/grilo-plugins-1:0.3.17-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xfsprogs-6.14.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pyside6-6.9.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-attrs-25.3.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-pr-helper-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nss-3.112-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pipewire-session-manager-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-good-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kcodecs-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libinstpatch-1.1.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/abseil-cpp-20250512.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/baobab-48.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kiconthemes-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsoup-2.74.3-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/intel-ucode-20250512-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/unrar-1:7.1.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/breeze-icons-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/capstone-5.0.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pugixml-1.15-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/imagemagick-7.1.1.47-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtk3-1:3.24.49-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-pa-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-desktop-common-1:44.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openpmix-5.0.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/btrfs-progs-6.14-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gspell-1.14.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcupsfilters-2.1.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-settings-manager-notifier-0.5.8-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lollypop-1.4.41-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtksourceview4-4.8.4-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-tools-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ttf-hack-nerd-3.4.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nautilus-admin-1:1.2.0-3-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libksba-1.6.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-block-nfs-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libphonenumber-1:9.0.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpamac-snap-plugin-11.7.3-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-firmware-47.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/liburing-2.11-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gobject-introspection-runtime-1.84.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libtirpc-1.3.6-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-google-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/double-conversion-3.3.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/rutabaga-ffi-0.1.6-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libspeechd-0.12.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/chromium-138.0.7204.92-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-click-8.1.8-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pamac-gnome-integration-11.7.3-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mhwd-0.6.6-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openvpn-2.6.14-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnfs-6.0.2-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxml2-2.14.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/totem-pl-parser-3.26.6+r30+g51b8439-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ktextwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pyparsing-3.2.3-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-img-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnotify-0.8.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/shadow-4.17.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/util-linux-2.41-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cmus-2.12.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nautilus-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/egl-gbm-1.1.2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgusb-0.4.9-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lvm2-2.03.32-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-gsconnect-66-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/upower-1.90.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/alsa-lib-1.2.14-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-calendar-48.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libedataserverui4-3.56.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcap-2.76-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-multidict-6.4.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pango-1:1.56.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/js115-115.24.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libqmi-1.36.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libportal-0.9.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bluez-libs-5.83-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/os-prober-1.83-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/orc-0.4.41-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-googleapis-common-protos-1.70.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wireplumber-0.5.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libportal-gtk3-0.9.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-x11extras-5.15.17-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-desktop-1:44.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libldap-2.6.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/util-linux-libs-2.41-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpng-1.6.49-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-xml-libxml-2.0210-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libvirt-1:11.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libx11-1.8.12-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ranger-1.9.4-4-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpamac-11.7.3-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-ugly-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ca-certificates-mozilla-3.112-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ckbcomp-1.227-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/systemd-libs-257.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libimagequant-4.3.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nvidia-utils-575.64-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/js128-128.11.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/librest-0.9.1-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/linux-api-headers-6.15-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cups-pdf-3.0.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmysofa-1.3.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-1:48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libwireplumber-0.5.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qca-qt6-2.3.10-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mutter-48.3.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/tevent-1:0.16.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-more-itertools-10.7.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-cairo-1.28.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/apache-2.4.63-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-usb-redirect-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxklavier-5.4-6-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/yelp-42.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/tdb-1.4.13-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-server-21.1.18-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lilv-0.24.26-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fwupd-2.0.12-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-system-x86-firmware-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glib2-devel-2.84.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mhwd-nvidia-575.64-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pyopenssl-25.1.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/addwater-1.2.6-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kbookmarks-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-propcache-0.3.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/oath-toolkit-2.6.12-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kcolorscheme-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/virtiofsd-1.13.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxkbcommon-x11-1.10.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pacman-mirrors-5.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libnghttp3-1.10.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/hidapi-0.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgexiv2-0.14.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ncurses-6.5-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fontconfig-2:2.16.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gutenprint-5.3.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libbpf-1.5.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-uefi-vars-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-declarative-5.15.17+kde+r21-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/clang-20.1.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcbor-0.12.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/noto-fonts-1:2025.06.01-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-multimedia-5.15.17+kde+r2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libnghttp2-1.66.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-quickcontrols2-5.15.17+kde+r5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-sdl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libplist-2.7.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-backgrounds-48.2.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kbd-2.8.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/osinfo-db-20250606-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glibmm-2.68-2.84.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fprintd-1.94.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-base-libs-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-libav-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pydantic-core-2:2.33.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cairo-1.18.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/talloc-2.4.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-multimedia-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gjs-2:1.84.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-dbus-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gcr-4-4.4.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/alsa-utils-1.2.14-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ostree-2025.2-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/egl-wayland-4:1.1.19-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/power-profiles-daemon-0.30-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-pci-gl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-legacy-theme-auto-switcher-r25.3d6b167-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/totem-43.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libimobiledevice-1.3.0-16-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgedit-tepl-6.13.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pyaml-24.12.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmfx-23.2.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libical-3.0.20-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-setproctitle-1.3.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgoa-3.54.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-base-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-contacts-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/usb_modeswitch-2.6.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iniparser-4.2.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-lm_sensors-1:3.6.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/chromaprint-1.5.1-10-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/composefs-1.0.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/touche-2.0.15-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iptables-1:1.8.11-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-gtk-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/papirus-icon-theme-20250501-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-gl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-space-bar-33-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/poppler-glib-25.06.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/duplicity-3.0.4.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/update-grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnftnl-1.2.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ocl-icd-2.3.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/harfbuzz-icu-11.2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-requests-2.32.4-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgedit-gfls-1:0.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openh264-2.6.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/flac-1.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gfxstream-0.1.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/librsvg-2:2.60.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-jack-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glslang-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libtracefs-1.8.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-llvm-libs-1:20.1.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/which-2.23-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-setuptools-1:80.9.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glibmm-2.66.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-afc-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iana-etc-20250502-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-base-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libx86emu-3.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/shaderc-2025.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/hwinfo-24.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-mimeapps-0.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mhwd-db-20250113-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libjxl-0.11.1-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mbedtls2-2.28.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/adwaita-icon-theme-48.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/faac-1.31.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/llvm-20.1.6-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cpupower-6.15-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-block-dmg-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-5compat-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libglvnd-1.7.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-oss-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/re2-1:20240702-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libbluray-1.3.4-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/llvm-libs-20.1.6-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-spice-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mhwd-nvidia-390xx-390.157-21-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/boost-libs-1.88.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtk4-1:4.18.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/webkit2gtk-4.1-2.48.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgudev-238-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/freeglut-3.6.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-curl-8.14.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/karchive-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnautilus-extension-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-speech-5.15.17+kde+r1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libusb-1.0.29-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-xz-5.8.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kcompletion-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gzip-1.14-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgpg-error-1.55-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/localsearch-3.9.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libfabric-2.1.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/archlinux-appstream-data-20250529-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/transmission-cli-4.0.6-10-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-bluetooth-3.0-47.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libunistring-1.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/s-nail-14.9.25-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-swap-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/inetutils-2.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libfprint-1.94.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/prrte-3.0.11-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pacman-contrib-1.12.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-svg-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsndfile-1.2.2-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libffi-3.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libxml2-2.14.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nfs-utils-2.8.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kdbusaddons-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-disk-utility-46.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-sdl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/curl-8.14.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dtc-1.7.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-cgi-3.13.0-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-editing-services-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcamera-0.5.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pixman-0.46.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-bcrypt-4.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libayatana-appindicator-0.5.94-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxnvctrl-575.64-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/vte4-0.80.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/tinysparql-3.9.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kauth-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wget-1.25.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgsf-1.14.53-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-alsa-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/readline-8.2.013-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libstemmer-3.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iputils-20250605-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/filesystem-2025.05.03-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libvpl-2.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bc-1.08.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/apparmor-4.1.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pkcs11-helper-1.30.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/linux515-nvidia-575.64-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libseccomp-2.5.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgweather-4-4.4.4-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-typing-inspection-0.4.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-cryptography-45.0.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mbedtls-3.6.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dbus-broker-37-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsoup3-3.6.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glibc-locales-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/solid-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openexr-3.3.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extensions-48.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/passim-0.1.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/egl-x11-1.0.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-settings-manager-0.5.8-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-legacy-cgi-2.6.3-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-nvme-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mesa-utils-9.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ghostscript-10.05.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lcms2-2.17-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libplacebo-7.351.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xkeyboard-config-2.45-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-3.13.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libwbclient-2:4.22.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libelf-0.193-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-forge-88-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-curses-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xmlsec-1.3.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/protobuf-c-1.5.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-trove-classifiers-2025.5.9.12-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmbim-1.32.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxmlb-0.3.22-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-release-25.0.4-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/harfbuzz-11.2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/soundtouch-2.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libtool-2.5.4+r23+g5b582aed-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iperf-2.2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ntfs-3g-2022.10.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/diffutils-3.12-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/geary-1:46.0-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/spice-protocol-0.14.5-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-xinit-1.4.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gupnp-dlna-0.12.0-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/networkmanager-openconnect-1.2.10-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-arc-menu-66-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wpebackend-fdo-1.16.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/systemd-sysvcompat-257.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/grep-3.12-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-python-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-part-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-block-ssh-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-console-48.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-server-common-21.1.18-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-session-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libvirt-glib-5.0.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnm-1.52.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-mtp-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ttf-noto-nerd-3.4.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/systemd-257.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ncdu-2.8.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sratom-0.6.18-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fluidsynth-2.4.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fuse3-3.17.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-control-center-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-protobuf-31.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/seahorse-1:47.0.1-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/snappy-1.2.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtk-vnc-1.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-goa-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-google-auth-2.38.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/device-mapper-2.03.32-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-keybindings-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pamac-gtk-11.7.3-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxdp-1.5.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugin-gtk4-0.13.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-urllib3-2.4.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libevdev-1.13.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ntp-4.2.8.p18-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pillow-11.2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/flatpak-1:1.16.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zsh-theme-powerlevel10k-1.20.15-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libheif-1.19.8-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kio5-5.116.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pycurl-7.45.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxslt-1.1.43-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-terminal-3.56.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-gl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wayland-1.23.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-aiohttp-3.12.13-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libosinfo-1.12.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/poppler-25.06.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-translations-6.9.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-gnome-ui-tune-1.10.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/simple-scan-48.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dialog-1:1.3_20250116-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pcsclite-2.3.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/shiboken6-6.9.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-characters-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kservice-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libopenmpt-0.8.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/yelp-xsl-42.4-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pam-1.7.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-frozenlist-1.7.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/enchant-2.8.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ibus-1.5.32-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnvme-1.13-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kwallet5-5.116.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kwallet-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fribidi-1.0.16-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/plymouth-24.004.60-12-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kconfigwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libibus-1.5.32-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-devtools-libs-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-system-monitor-48.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iagno-3.38.1+r125+ge144444-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kmod-34.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wolfssl-5.8.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openresolv-3.16.5-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/texinfo-7.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openconnect-1:9.12-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnghttp3-1.10.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libdrm-2.4.125-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/evince-48.0-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openmpi-5.0.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cifs-utils-7.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pacui-1.14+100+g4fb3daa-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-audio-pipewire-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/adwaita-cursors-48.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dbus-broker-units-37-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libtasn1-4.20.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcamera-ipa-0.5.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/imath-3.1.12-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/tzdata-2025b-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/adwaita-fonts-48.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/onlyoffice-desktopeditors-9.0.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pcre2-10.45-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/snapd-2.68.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kdialog-25.04.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-crypto-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libebur128-1.2.6-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-x11gestures-25-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgphoto2-2.5.31-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-egl-headless-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-vga-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libffi-3.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mpfr-4.2.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-jinja-1:3.1.6-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-vhost-user-gpu-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nvidia-driver-assistant-0.21.57.08-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pacman-7.0.0.r10.ga2d0293-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-desktop-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-clocks-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pytz-2025.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libelf-0.193-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcups-2:2.4.12-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mtools-1:4.0.49-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kio-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgedit-amtk-5.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/imlib2-1.12.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lm_sensors-1:3.6.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gpgme-2.0.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-beautifulsoup4-4.13.3-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-wayland-5.15.17+kde+r57-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-nfs-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/volume_key-0.3.12-11-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qrencode-4.1.1-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sqlite-3.50.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-translations-5.15.17-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openssh-10.0p1-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgit2-1:1.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-vulkan-icd-loader-1.4.313.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-zstd-1.5.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-settings-daemon-48.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-bad-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-block-curl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-online-accounts-3.54.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xdg-desktop-portal-1.20.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/hwdata-0.396-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nano-8.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libdiscid-0.6.5-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/exempi-2.6.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-argcomplete-3.5.3-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgme-0.6.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/adw-gtk-theme-6.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libcloudproviders-0.3.6-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-ply-3.11-15-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-chardev-spice-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-json-c-0.18-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libdecor-0.2.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/modemmanager-1.24.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libportal-gtk4-0.9.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-pydantic-2.11.7-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/smbclient-2:4.22.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-mdraid-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pamac-cli-11.7.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xdg-desktop-portal-gtk-1.15.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dnsmasq-2.91-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libxshmfence-1.3.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/tecla-48.0.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-gphoto2-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-spirv-tools-1:1.4.313.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gawk-5.3.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libqrtr-glib-1.2.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lua-5.4.8-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libde265-1.0.16-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgcrypt-1.11.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-user-share-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-yarl-1.21.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgdata-0.18.1-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kitemviews-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/pipewire-audio-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-multimedia-ffmpeg-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gupnp-1:1.6.8-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgrss-0.7.0+16+g971c421-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gvfs-smb-1.57.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-common-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-chess-48.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dbus-1.16.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-wheel-0.45.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libblockdev-fs-3.3.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/json-c-0.18-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nftables-1:1.1.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/inxi-3.3.38.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpamac-flatpak-plugin-11.7.3-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/grilo-0.3.19-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/alsa-ucm-conf-1.2.14-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/hwloc-2.12.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/man-pages-6.14-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/raptor-2.0.16-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sdl3-3.2.16-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/networkmanager-1.52.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sonnet-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/squashfs-tools-4.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gstreamer-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsrtp-1:2.7.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/exiv2-0.28.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libssh2-1.11.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-path-tiny-0.148-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-tldextract-5.3.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-s390x-virtio-gpu-ccw-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-twm-1.0.13.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gpgmepp-2.0.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsysprof-capture-48.0-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kcoreaddons-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnghttp2-1.66.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/iproute2-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/svt-av1-3.0.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gsettings-desktop-schemas-48.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-certifi-2025.06.15-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-application-utility-1.4.1-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/git-2.50.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/stoken-0.92-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gufw-26.04-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qpdf-12.2.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/spice-0.16.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/android-udev-20250525-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wireless-regdb-2025.02.20-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-keyring-1:48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-layout-switcher-0.8.39-3-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtk-update-icon-cache-1:4.18.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/run-parts-5.22-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/protobuf-31.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libidn-1.43-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgirepository-1.84.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpcap-1.10.5-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openal-1.24.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/touchegg-2.0.18-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kjobwidgets-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt5-svg-5.15.17+kde+r5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugin-gtk-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-5.40.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-xwayland-24.1.8-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fuse-common-3.17.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libshout-1:2.4.6-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-gobject-3.52.3-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/knotifications-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/liblc3-1.1.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libwacom-2.16.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cython-3.1.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gupnp-igd-1.6.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libslirp-4.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-appindicator-1:60-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bash-5.2.037-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/coreutils-9.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sdl2-compat-2.32.56-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugin-pipewire-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libpeas-1.36.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/quadrapassel-40.2-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgnome-games-support-2-2.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/woff2-1.0.2-6-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-filelock-3.18.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-validate-pyproject-0.24.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-desktop-4-1:44.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/deja-dup-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-packaging-25.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kcrash-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/webkitgtk-6.0-2.48.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/nfsidmap-2.8.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/v4l-utils-1.30.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/webkit2gtk-2.48.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/alsa-card-profiles-1:1.4.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/aom-3.12.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-boxes-48.0-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bolt-0.9.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtkmm3-3.24.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgedit-gtksourceview-299.5.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-dbus-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/btop-1.4.3-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-spice-core-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gst-plugins-bad-libs-1.26.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kwindowsystem-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libinput-1.28.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/foomatic-db-engine-5:20200131-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-nvidia-utils-575.64-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/papirus-maia-icon-theme-20201007-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bluez-5.83-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ldb-2:4.22.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/miniupnpc-2.3.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libusbmuxd-2.1.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libei-1.4.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-aiohappyeyeballs-2.6.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/audit-4.0.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openucx-1.18.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/shared-mime-info-2.4-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dbus-glib-0.114-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libldap-2.6.10-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libfreeaptx-0.2.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mpg123-1.33.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-uritemplate-4.2.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/eglexternalplatform-1.2.1-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gdbm-1.25-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gettext-0.25-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-typeguard-4.4.4-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-dash-to-panel-68-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/apr-1.7.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/appstream-1.0.5-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libjcat-0.2.3-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/linux-firmware-20250508.788aadc8-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/kwidgetsaddons-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qt6-shadertools-6.9.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/neon-0.34.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/giflib-5.2.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/grub-2:2.12.r292.g73d1c959-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-shell-extension-gtk4-desktop-icons-ng-1:100.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-logs-45.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/compiler-rt-20.1.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/leancrypto-1.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/bluez-obex-5.83-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/file-roller-44.5-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/faad2-2.11.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-zsh-config-0.26-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gthumb-3.12.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/rygel-1:0.44.2-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gsettings-system-schemas-48.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-ncurses-6.5-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsm-1.2.6-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glibc-2.41+r48+g5cb575ca9a3d-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-libwww-6.78-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libedit-20250104_3.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/expat-2.7.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libimobiledevice-glue-1.3.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libadwaita-1:1.7.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-usb-smartcard-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-dbus-1.4.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmm-glib-1.24.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-icu-76.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/wayland-protocols-1.45-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/taglib-2.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/perl-error-0.17030-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libtheora-1.2.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libaemu-0.1.2-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ffmpeg-2:7.1.1-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/strongswan-6.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-ui-opengl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fakeroot-1.37.1.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sof-firmware-2025.05-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zlib-ng-2.2.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-calculator-48.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dhcpcd-10.2.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-typing_extensions-4.13.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libgdm-48.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtksourceview3-1:3.24.11+r30+gd880929f-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zstd-1.5.7-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dnssec-anchors-20250524-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-hello-0.8.1-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gtksourceview5-5.16.0-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/man-db-2.13.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-charset-normalizer-3.4.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libxft-2.3.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xorg-xauth-1.1.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/zxing-cpp-2.3.0-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/ki18n-6.15.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/sudo-1.9.17.p1-0.1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/manjaro-gnome-settings-20250504-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libppd-2.1.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/procps-ng-4.0.5-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libmanette-0.2.12-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/binutils-2.44+r94+gfe459e33c676-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnbd-1.22.1-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/webrtc-audio-processing-1-1.3-5-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-qxl-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/dconf-editor-45.0.1-3-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/icu-76.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/phodav-3.0-4-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/x265-4.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/snapd-glib-1.68-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-markupsafe-3.0.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/liburcu-0.15.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/openssl-3.5.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsecret-0.21.7-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-display-virtio-gpu-rutabaga-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gedit-48.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mesa-1:25.1.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libwpe-1.16.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qca-qt5-2.3.10-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-hw-usb-host-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnutls-3.8.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glm-1.0.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/cups-2:2.4.12-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gcc-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/exfatprogs-1.2.9-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/accent-color-change-r155.f57e60f-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libnewt-0.52.25-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-mesa-1:25.1.4-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/libsynctex-2025.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/qemu-system-x86-10.0.0-7-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/mhwd-nvidia-470xx-470.256.02-14-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/e2fsprogs-1.47.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/python-aiosignal-1.3.2-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/linux-firmware-whence-20250508.788aadc8-2-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xdg-desktop-portal-gnome-48.0-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/evolution-data-server-3.56.2-2-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/xz-5.8.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-expat-2.7.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/vte-common-0.80.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/glib2-2.84.3-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/at-spi2-core-2.56.2-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/gnome-mines-48.1-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/lib32-libx11-1.8.12-1-x86_64.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/alacarte-1:3.56.0-1-any.pkg.tar.zst.sig: data
/var/cache/pacman/pkg/fzf-0.62.0-1-x86_64.pkg.tar.zst.sig: data
$ pacman-key --list-keys daurnimator@archlinux.org
pub rsa4096 2015-01-25 [SC] [expired: 2025-07-01]
954A3772D62EF90E4B31FBC6C91A9911192C187A
uid [ expired] Daurnimator <daurnimator@archlinux.org>
uid [ expired] Daurnimator <quae@daurnimator.com>
I would recommend removing ncdu, and then perform your update. If needed, reinstall ncdu at a later date when the rebuilt version is available in the stable branch.
should I do it by:
sudo pacman -R ncdu
Excellent, thanks… That would be my next step.
sudo pacman -Syu --ignore ncdu
I hope it is only this package.
Thank you very much it worked! Should I try now pacman -Syu (without the --ignore)?
This will not work. The packager’s GPG key has expired. You can install the package, but without the verification created by this user. Here we need to wait until the key is updated.
So that’s something that would probably be resolved eventually when the key is updated or do I need to update it myself somehow?
You can run sudo pacman-key --refresh-keys after some time to update the keys. It will be updated by the next update at the latest.
Good Night!
Goodnight and thank you very much! You really saved me!
A post was split to a new topic: Intermittent issue playing video files after update
Hi @michael-novak ,
The community repo no longer exists. Please remove this from pacman.conf
Regards
I only saw this message now, is it still safe to remove these lines?
Not only is it safe, it is recommended.
The Community repository was merged into the Extra repository two years ago already and has been empty since, and it was then finally deleted from the mirrors a couple of months ago, but because certain people can’t be bothered reading the Stable Updates announcement threads and/or properly maintaining their systems — hint: look for the word pacnew in the Arch Wiki — and were running into update problems, @philm put the empty Community repository back on the mirrors.
O.k, I did it, thank you very much!
The issue is resolved with ncdu 2.8.2-2.0 coming along shortly.
I see the new version but the signature still fails on my machine
sudo pacman -Syu ncdu 1 ✘ 5s
[sudo] password for lcarlier:
:: Synchronising package databases...
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
Packages (1) ncdu-2.8.2-2
Total Installed Size: 0.60 MiB
Net Upgrade Size: 0.09 MiB
ncdu-2.8.2-2-x86_64 261.0 KiB 4.47 MiB/s 00:00 [##############################################################################################] 100%
(1/1) checking keys in keyring [##############################################################################################] 100%
(1/1) checking package integrity [##############################################################################################] 100%
@lcarlier 2.8.2-2.0 is the new version signed by me, 2.8.2-2 is the old version signed by Daurnimator.
Refresh your mirrors and try again. ![]()
Thanks! Refreshing the mirror worked for me
