I recently followed this guide for GPU passthrough: Guide
I have an i5-11600k, and an Aorus Elite Z590 Motherboard both of which support VT-d and IOMMU.
Upon reaching the install step of the VM, the host system locks up after trying to create the storage space. No errors appear, and I cannot take a screenshot of it since it freezes the host. The other monitor that the GPU is connected to shows no change, doesn’t flicker, turn on, or otherwise.
The journalctl is also not logged during this time either, i must restart to gain control of my machine.
This is: lspci -nnk
for the two devices I have passed through
Here is the group listing for my IOMMU groups:
Script:
shopt -s nullglob
for g in find /sys/kernel/iommu_groups/* -maxdepth 0 -type d | sort -V; do
echo "IOMMU Group ${g##/}:"
for d in $g/devices/ ; do
echo -e “\t$(lspci -nns ${d##*/})”
done;
done;
Help on this would be appreciated!
Fabby
6 August 2021 21:37
2
Sorry about that! Forgot all about this forums formatting rules. Thank you for reminding me.
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=8ba57404-e263-4322-9676-1e9b8d434d03 rw quiet apparmor=1
security=apparmor intel_iommu=on
resume=UUID=862427bd-c72a-4e7e-afcf-7c33291eb2ce udev.log_priority=3
pcie_aspm.policy=performance
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX v: x.x serial: N/A
UEFI: American Megatrends LLC. v: F3 date: 01/20/2021
RAM: total: 31.15 GiB used: 2.05 GiB (6.6%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: Controller0-ChannelA-DIMM0 size: No Module Installed
Device-2: Controller0-ChannelA-DIMM1 size: 16 GiB speed: 2666 MT/s
type: DDR4 detail: synchronous bus-width: 64 bits total: 64 bits
manufacturer: G Skill Intl part-no: F4-3200C16-16GVK serial: N/A
Device-3: Controller0-ChannelB-DIMM0 size: No Module Installed
Device-4: Controller0-ChannelB-DIMM1 size: 16 GiB speed: 2666 MT/s
Info: 6-Core model: 11th Gen Intel Core i5-11600K socket: U3E1 bits: 64
type: MT MCP arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1
microcode: 40 cache: L1: 480 KiB L2: 12 MiB L3: 12 MiB bogomips: 93924
Speed: 800 MHz min/max: 800/4900 MHz base/boost: 3861/8500 volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 799 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg
sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Gigabyte
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
Monitor-2: HDMI-A-1-1 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-bf411ced-f63f-4984-87c4-e2d70482f671 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 1.82 TiB
Hardware-1: Intel Device driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
chip-ID: 8086.43d6 rev: 11 class-ID: 0104
Local Storage: total: 2.73 TiB used: 197.07 GiB (7.1%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 613000WD temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 899.22 GiB size: 884.03 GiB (98.31%)
used: 27.24 GiB (3.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: 8ba57404-e263-4322-9676-1e9b8d434d03
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 6E8B-578F
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 169.82 GiB (9.3%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-bf411ced-f63f-4984-87c4-e2d70482f671 label: N/A
uuid: 20cd3e50-e7b9-46e9-a8dd-e341c97f7d1f
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 862427bd-c72a-4e7e-afcf-7c33291eb2ce
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-11:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.1:4 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0084 class-ID: 0300
Device-2: 1-11.2:6 info: Microdia USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0c45:7603 class-ID: 0301
Hub-3: 1-12:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-13:5 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-14:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: amdgpu temp: 31.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 946
Processes: 358 Uptime: 3m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1208 pacman: 1200 lib: 332 flatpak: 0
snap: 8 Shell: Bash (sudo) v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
lspci -nnk
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4c53] (rev 01)
DeviceName: Onboard - Other
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5000]
Kernel driver in use: icl_uncore
00:01.0 PCI bridge [0604]: Intel Corporation Device [8086:4c01] (rev 01)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 750] [8086:4c8a] (rev 04)
DeviceName: Onboard - Video
Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
Kernel driver in use: i915
Kernel modules: i915
00:06.0 PCI bridge [0604]: Intel Corporation Device [8086:4c09] (rev 01)
00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5007]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11)
00:14.3 Network controller [0280]: Intel Corporation Tiger Lake PCH CNVi WiFi [8086:43f0] (rev 11)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Wi-Fi 6 AX201 160MHz [8086:0074]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:1c3a]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller [0104]: Intel Corporation Device [8086:43d6] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:b005]
Kernel driver in use: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c0] (rev 11)
00:1b.2 PCI bridge [0604]: Intel Corporation Device [8086:43c2] (rev 11)
00:1b.4 PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:43b8] (rev 11)
00:1c.4 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port #5 [8086:43bc] (rev 11)
00:1d.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port #9 [8086:43b0] (rev 11)
00:1d.4 PCI bridge [0604]: Intel Corporation Device [8086:43b4] (rev 11)
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4385] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5001]
00:1f.3 Audio device [0403]: Intel Corporation Tiger Lake-H HD Audio Controller [8086:43c8] (rev 11)
DeviceName: Onboard - Sound
Subsystem: Gigabyte Technology Co., Ltd Device [1458:a0c3]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11)
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev e7)
Subsystem: XFX Pine Group Inc. Radeon RX 580 [1682:c580]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
Subsystem: XFX Pine Group Inc. Device [1682:aaf0]
02:00.0 Non-Volatile memory controller [0108]: Sandisk Corp WD Black SN850 [15b7:5011] (rev 01)
Subsystem: Sandisk Corp WD Black SN850 [15b7:5011]
Kernel driver in use: nvme
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Kernel driver in use: r8169
Kernel modules: r8169
I have only passed through my AMD GPU, and AMD Audio (1002:67df, 1002:aaf0)
Fabby
6 August 2021 22:20
4
Kernel 5.12 is EOL so please install both 5.4 and 5.10 LTS (Long Time Support) and see which one of the two troubles you least.
This happens under both of those kernels as well. The host and guest virt-manager session crash during the creation of the VM. In either case, the vm was never successfully created nor the storage file.
It is a hard crash as like mentioned before, I must hard restart via my reset button on the terminal to restart the computer.
Fabby
7 August 2021 06:55
6
Then you probably made an error in the passthrough. Which of the following are you wanting to pass through to the VM? (the AMD driver would be most logical)
and how are you doing that exactly?
Yes it is both AMD devices, the AMD Video and Audio as mentioned before and specifically through this guide: https://wiki.archlinux.org/title/PCI_passthrough_via_OVMF#Binding_vfio-pci_via_device_ID
Summary:
make file vfio.conf in /etc/modprobe.d/
Add the lines
options vfio-pci ids=1002:aaf0,1002:67df
Have vfio-pci load early by editing /etc/mkinitcpio.conf:
Add vfio vfio_iommu_type1 vfio_virqfd to MODULES
Add modconf to HOOKS
Regenerate the intramfs with:
sudo mkinitcpio -p linux512
also tried with linux54 and linux510 as requested.
Result:
The highjack is successful every time
my monitor is disabled
the AMD module shows that it is owned by vfio, and therefore can be handed off.
The issue occurs when I add it to a VM during creation (I’ m using QEMU/KVM, virt-manager)
the lspci -nnk shows the list of my devices and what drivers are in use.
Yesterday I got an error to pop up and i’ve been trying to recreate it. It had something to do with NVRAM being corrupted. But this seems like a side effect of me hard restarting rather than the issue.
It turns out the issue I had is indeed a side effect of me hard resetting my PC during the storage creating domain phase of creating the VM. This corrupts the NVRAM file in
/var/lib/libvirt/qemu/nvram/VM_NAME_VARS.ovmf
This would be fixed by replacing the aforementioned file with the one in
/usr/share/edk2-ovmf/OVMF_VARS.fd
maintaining the vmname_VARS.fd name.
I still have the same issue as mentioned before, my system hard locks when creating a VM after GPU passthrough.
Fabby
12 August 2021 08:30
9
My apologies: you’ve reached the limit of my ability to help you any further…
I appreciate the review of my steps regardless.
My first suspicion was that my CPU didn’t support virtualization, however, the bios has the option to enable vt-d for it, therefore it must have the capabilities.
My CPU has both Vt-d and vt-x, so this is not an issue:
https://www.intel.com/content/www/us/en/products/sku/212275/intel-core-i511600k-processor-12m-cache-up-to-4-90-ghz/specifications.html?wapkw=i5-11600k
My next suspicion was that my motherboard didn’t support something but I can’t imagine where I am going wrong.
My motherboard support IOMMU, so im not sure where the issue could be there:
https://www.gigabyte.com/Motherboard/Z590-AORUS-ELITE-rev-10/sp#sp
Bump:
Error: Hard crashes when using Virtmanager (Virsh) and KVM while performing PCIE passthrough.
I have the required BIOS settings ticked.
Here are the specs of my PC again, still no dice with this on my end.
Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8ba57404-e263-4322-9676-1e9b8d434d03 rw intel_iommu=on iommu=pt
pcie_aspm.policy=performance rd.driver.pre=vfio_pci vfio-pci.ids=
video=vesafb:off,efifb:off quiet apparmor=1 security=apparmor
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
serial: <superuser required> UEFI: American Megatrends LLC. v: F3
date: 01/20/2021
RAM: total: 31.15 GiB used: 4.22 GiB (13.6%)
Info: 6-Core model: 11th Gen Intel Core i5-11600K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1 microcode: 40
cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB bogomips: 93924
Speed: 942 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 942 2: 870 3: 911
4: 1186 5: 2519 6: 919 7: 925 8: 945 9: 3076 10: 2992 11: 4341 12: 4783
xtopology xtpr
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.0x11.3")
s-diag: 1551mm (61")
Monitor-1: HDMI-2 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: DP-1-3 res: 1920x1080 hz: 60 dpi: 103
size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
Monitor-3: HDMI-1-1 res: 1920x1080 hz: 60 dpi: 94
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.2.5
direct render: Yes
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
bus-ID: 1-14:9 chip-ID: 8087:0026 class-ID: e001
Components:
chip-ID: 8086:43d6 rev: N/A class-ID: 0104
Local Storage: total: 5.46 TiB used: 432.04 GiB (7.7%)
rev: 613000WD temp: 41.9 C scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
type: HDD rpm: 7200 serial: <filter> rev: JC4A scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2002FYPS-01U1B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 5G05 scheme: MBR
used: 38.03 GiB (4.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 394.01 GiB (21.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-9:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c541 class-ID: 0300
Hub-2: 1-11:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.1:5 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
Hub-3: 1-11.3:7 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-4: 1-12:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-13:11 info: Integrated Express ITE Device type: HID
Device-2: 1-14:9 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-5: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 803
Processes: 397 Uptime: 14m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1289 pacman: 1284 lib: 372 flatpak: 0
snap: 5 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.09
lspci -nnk
