On m first try today no problem, then this (2281 lines, have fun
ps: what a pain i the ass was to post this here, first Konsole only allows going back 1000 lines so i couldn’t copy it all, then i had the output automatically on a file; the total was more than the double allowed on a single post here, that is why i am dividing it in 3; here the first 999 lines):
-- Logs begin at Sun 2020-08-02 20:52:54 CEST, end at Mon 2020-09-28 13:41:41 CEST. --
Sep 28 13:15:00 io-hp kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Sep 28 13:15:00 io-hp kernel: ata1.00: configured for UDMA/100
Sep 28 13:15:00 io-hp kscreenlocker_greet[3286]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Sep 28 13:15:00 io-hp kernel: Filesystems sync: 0.178 seconds
Sep 28 13:15:00 io-hp kscreenlocker_greet[3286]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:209:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:00 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MainBlock.qml:88:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:00 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:64:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:00 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:00 io-hp org_kde_powerdevil[1266]: powerdevil: ACTIVE SESSION PATH CHANGED: "/"
Sep 28 13:15:00 io-hp org_kde_powerdevil[1266]: powerdevil: Switched to inactive session - leaving unchanged
Sep 28 13:15:42 io-hp kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
Sep 28 13:15:42 io-hp kernel: OOM killer disabled.
Sep 28 13:15:42 io-hp kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Sep 28 13:15:42 io-hp kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Sep 28 13:15:42 io-hp kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Sep 28 13:15:42 io-hp kernel: sd 0:0:0:0: [sda] Stopping disk
Sep 28 13:15:42 io-hp kernel: ACPI: EC: interrupt blocked
Sep 28 13:15:42 io-hp kernel: ACPI: Preparing to enter system sleep state S3
Sep 28 13:15:42 io-hp kernel: ACPI: EC: event blocked
Sep 28 13:15:42 io-hp kernel: ACPI: EC: EC stopped
Sep 28 13:15:42 io-hp kernel: PM: Saving platform NVS memory
Sep 28 13:15:42 io-hp kernel: Disabling non-boot CPUs ...
Sep 28 13:15:42 io-hp kernel: smpboot: CPU 1 is now offline
Sep 28 13:15:42 io-hp kernel: smpboot: CPU 2 is now offline
Sep 28 13:15:42 io-hp kernel: smpboot: CPU 3 is now offline
Sep 28 13:15:42 io-hp kernel: ACPI: Low-level resume complete
Sep 28 13:15:42 io-hp kernel: ACPI: EC: EC started
Sep 28 13:15:42 io-hp kernel: PM: Restoring platform NVS memory
Sep 28 13:15:42 io-hp kernel: LVT offset 0 assigned for vector 0x400
Sep 28 13:15:42 io-hp kernel: Enabling non-boot CPUs ...
Sep 28 13:15:42 io-hp kernel: x86: Booting SMP configuration:
Sep 28 13:15:42 io-hp kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Sep 28 13:15:42 io-hp kernel: microcode: CPU1: patch_level=0x07030105
Sep 28 13:15:42 io-hp kernel: CPU1 is up
Sep 28 13:15:42 io-hp kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Sep 28 13:15:42 io-hp kernel: microcode: CPU2: patch_level=0x07030105
Sep 28 13:15:42 io-hp kernel: CPU2 is up
Sep 28 13:15:42 io-hp kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Sep 28 13:15:42 io-hp kernel: microcode: CPU3: patch_level=0x07030105
Sep 28 13:15:42 io-hp kernel: CPU3 is up
Sep 28 13:15:42 io-hp kernel: ACPI: Waking up from system sleep state S3
Sep 28 13:15:42 io-hp kernel: ACPI: EC: interrupt unblocked
Sep 28 13:15:42 io-hp kernel: ACPI: EC: event unblocked
Sep 28 13:15:42 io-hp kernel: rtlwifi: rtlwifi: wireless switch is on
Sep 28 13:15:42 io-hp kernel: sd 0:0:0:0: [sda] Starting disk
Sep 28 13:15:42 io-hp kernel: [drm] PCIE GART of 2048M enabled (table at 0x000000000030E000).
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: WB enabled
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0x00000000cd48cea6
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 1 use gpu addr 0x0000000020000c04 and cpu addr 0x000000001eae6757
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 2 use gpu addr 0x0000000020000c08 and cpu addr 0x000000008a0d56b4
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0x000000001486a6b4
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 4 use gpu addr 0x0000000020000c10 and cpu addr 0x00000000892f2763
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 5 use gpu addr 0x0000000000078d30 and cpu addr 0x000000005e27c65e
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 6 use gpu addr 0x0000000020000c18 and cpu addr 0x000000006bdfcf33
Sep 28 13:15:42 io-hp kernel: radeon 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000020000c1c and cpu addr 0x00000000e80a9357
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 0 succeeded in 3 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 1 succeeded in 2 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 2 succeeded in 2 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 3 succeeded in 3 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 4 succeeded in 3 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 5 succeeded in 1 usecs
Sep 28 13:15:42 io-hp kernel: [drm] UVD initialized successfully.
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 6 succeeded in 6 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ring test on 7 succeeded in 2 usecs
Sep 28 13:15:42 io-hp kernel: [drm] VCE initialized successfully.
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Sep 28 13:15:42 io-hp kernel: usb 3-1.1: reset high-speed USB device number 3 using ehci-pci
Sep 28 13:15:42 io-hp kernel: usb 1-1.4: reset full-speed USB device number 4 using ehci-pci
Sep 28 13:15:42 io-hp kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Sep 28 13:15:42 io-hp kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Sep 28 13:15:42 io-hp kernel: ata1.00: configured for UDMA/100
Sep 28 13:15:42 io-hp kernel: ata2.00: configured for UDMA/133
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 5 succeeded
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 6 succeeded
Sep 28 13:15:42 io-hp kernel: [drm] ib test on ring 7 succeeded
Sep 28 13:15:42 io-hp kernel: psmouse serio1: synaptics: queried max coordinates: x [..5652], y [..4846]
Sep 28 13:15:42 io-hp kernel: psmouse serio1: synaptics: queried min coordinates: x [1330..], y [1094..]
Sep 28 13:15:42 io-hp kernel: OOM killer enabled.
Sep 28 13:15:42 io-hp kernel: Restarting tasks ... done.
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: rom_version status=0 version=1
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
Sep 28 13:15:42 io-hp kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
Sep 28 13:15:42 io-hp bluetoothd[819]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Sep 28 13:15:42 io-hp pipewire[1455]: [W][000001860.040232][main-loop.c:157 pw_main_loop_run()] main-loop 0x55aba4dc60c0: iterate error -4 (Interrupted system call)
Sep 28 13:15:42 io-hp systemd[1]: Starting Load/Save RF Kill Switch Status...
Sep 28 13:15:42 io-hp bluetoothd[819]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Sep 28 13:15:42 io-hp pipewire[1457]: [W][000001860.054255][main-loop.c:157 pw_main_loop_run()] main-loop 0x55b215a67e30: iterate error -4 (Interrupted system call)
Sep 28 13:15:42 io-hp systemd[1]: Stopped target Bluetooth.
Sep 28 13:15:42 io-hp bluetoothd[819]: Endpoint unregistered: sender=:1.58 path=/A2DP/SBC/Source/0
Sep 28 13:15:42 io-hp bluetoothd[819]: Endpoint unregistered: sender=:1.58 path=/A2DP/SBC/Sink/1
Sep 28 13:15:42 io-hp dbus-daemon[821]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.58" (uid=1000 pid=1457 comm="/usr/bin/pipewire-media-session ") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.4" (uid=0 pid=819 comm="/usr/lib/bluetooth/bluetoothd ")
Sep 28 13:15:42 io-hp systemd[1068]: Reached target Bluetooth.
Sep 28 13:15:42 io-hp systemd[1]: Reached target Bluetooth.
Sep 28 13:15:42 io-hp systemd[1]: Started Load/Save RF Kill Switch Status.
Sep 28 13:15:42 io-hp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:42 io-hp kernel: audit: type=1130 audit(1601291742.136:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/SessionManagementScreen.qml:64:5: Unable to assign [undefined] to int
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/lib/qt/qml/org/kde/plasma/components/Button.qml:52: ReferenceError: PlasmaCore is not defined
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/ActionButton.qml:33:5: Unable to assign [undefined] to int
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/KeyboardLayoutButton.qml:29:5: Unable to assign [undefined] to int
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/Battery.qml:48:9: Unable to assign [undefined] to double
Sep 28 13:15:42 io-hp systemd-sleep[3312]: System resumed.
Sep 28 13:15:42 io-hp kernel: PM: suspend exit
Sep 28 13:15:42 io-hp org_kde_powerdevil[1266]: powerdevil: ACTIVE SESSION PATH CHANGED: "/org/freedesktop/login1/session/_31"
Sep 28 13:15:42 io-hp org_kde_powerdevil[1266]: powerdevil: Current session is now active
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserDelegate.qml:41:5: Unable to assign [undefined] to int
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:407:126: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:408:126: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:408:385: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:409:125: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:410:124: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:411:125: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:411:371: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kscreenlocker_greet[3286]: qt.svg: <input>:411:619: Could not add child element to parent element because the types are incorrect.
Sep 28 13:15:42 io-hp kernel: Bluetooth: hci0: RTL: fw version 0x0e2f9f73
Sep 28 13:15:43 io-hp kcminit[3551]: Initializing "kcm_mouse" : "kcminit_mouse"
Sep 28 13:15:43 io-hp bluetoothd[819]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Sep 28 13:15:43 io-hp bluetoothd[819]: RFCOMM server failed for :1.58/Profile/HSPHS/00001108-0000-1000-8000-00805F9B34FB: rfcomm_bind: Address already in use (98)
Sep 28 13:15:43 io-hp bluetoothd[819]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Sep 28 13:15:43 io-hp bluetoothd[819]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Sep 28 13:15:43 io-hp kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56224, resource id: 58720261, major code: 18 (ChangeProperty), minor code: 0
Sep 28 13:15:43 io-hp systemd[1]: systemd-suspend.service: Succeeded.
Sep 28 13:15:43 io-hp systemd[1]: Finished Suspend.
Sep 28 13:15:43 io-hp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:43 io-hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:43 io-hp systemd[1]: Stopped target Sleep.
Sep 28 13:15:43 io-hp systemd[1]: Reached target Suspend.
Sep 28 13:15:43 io-hp kernel: audit: type=1130 audit(1601291743.170:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:43 io-hp kernel: audit: type=1131 audit(1601291743.170:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:43 io-hp systemd[1]: Stopped target Suspend.
Sep 28 13:15:43 io-hp systemd-logind[824]: Operation 'sleep' finished.
Sep 28 13:15:43 io-hp ModemManager[845]: <info> [sleep-monitor] system is resuming
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.1779] manager: sleep: wake requested (sleeping: yes enabled: yes)
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.1781] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Sep 28 13:15:43 io-hp kernel: RTL8208 Fast Ethernet r8169-300:00: attached PHY driver [RTL8208 Fast Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
Sep 28 13:15:43 io-hp kscreenlocker_greet[3286]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4327] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Sep 28 13:15:43 io-hp kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4384] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4421] manager: NetworkManager state is now DISCONNECTED
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4762] device (wlo1): supplicant interface state: internal-starting -> disconnected
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4763] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4776] Wi-Fi P2P device controlled by interface wlo1 created
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4781] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4787] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4827] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Sep 28 13:15:43 io-hp NetworkManager[822]: <info> [1601291743.4862] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:43 io-hp NetworkManager[822]: <warn> [1601291743.5022] sup-iface[95639ecd647f2db1,1,wlo1]: call-p2p-cancel: failed with P2P cancel failed
Sep 28 13:15:44 io-hp kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Sep 28 13:15:44 io-hp kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9502] device (enp3s0): carrier: link connected
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9506] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9522] policy: auto-activating connection 'Wired connection 1' (62cb76be-ecad-33c0-b799-972919bb260e)
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9536] device (enp3s0): Activation: starting connection 'Wired connection 1' (62cb76be-ecad-33c0-b799-972919bb260e)
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9539] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9557] manager: NetworkManager state is now CONNECTING
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9562] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9593] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:44 io-hp NetworkManager[822]: <info> [1601291744.9616] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:15:44 io-hp avahi-daemon[818]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::40c9:e254:63df:1cf.
Sep 28 13:15:44 io-hp avahi-daemon[818]: New relevant interface enp3s0.IPv6 for mDNS.
Sep 28 13:15:44 io-hp avahi-daemon[818]: Registering new address record for fe80::40c9:e254:63df:1cf on enp3s0.*.
Sep 28 13:15:45 io-hp ModemManager[845]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.4/0000:02:00.0': not supported by any plugin
Sep 28 13:15:45 io-hp ModemManager[845]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.5/0000:03:00.0': not supported by any plugin
Sep 28 13:15:45 io-hp kcminit[3687]: Initializing "kcm_mouse" : "kcminit_mouse"
Sep 28 13:15:45 io-hp kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58324, resource id: 60817413, major code: 18 (ChangeProperty), minor code: 0
Sep 28 13:15:46 io-hp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Sep 28 13:15:46 io-hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:46 io-hp kernel: audit: type=1131 audit(1601291746.656:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:46 io-hp dbus-daemon[821]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=822 comm="/usr/bin/NetworkManager --no-daemon ")
Sep 28 13:15:46 io-hp systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 28 13:15:46 io-hp dbus-daemon[821]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 28 13:15:46 io-hp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:46 io-hp systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 28 13:15:46 io-hp kernel: audit: type=1130 audit(1601291746.980:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:47 io-hp systemd[1]: systemd-rfkill.service: Succeeded.
Sep 28 13:15:47 io-hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:47 io-hp kernel: audit: type=1131 audit(1601291747.140:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:47 io-hp NetworkManager[822]: <info> [1601291747.6560] dhcp6 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:15:47 io-hp kded5[1167]: bluedevil: About to resume
Sep 28 13:15:48 io-hp avahi-daemon[818]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::40c9:e254:63df:1cf.
Sep 28 13:15:48 io-hp avahi-daemon[818]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fd91:dab6:a2b2:1:5500:d71c:457d:3b36.
Sep 28 13:15:48 io-hp NetworkManager[822]: <info> [1601291748.1205] dhcp6 (enp3s0): option dhcp6_domain_search => 'local'
Sep 28 13:15:48 io-hp avahi-daemon[818]: Registering new address record for fd91:dab6:a2b2:1:5500:d71c:457d:3b36 on enp3s0.*.
Sep 28 13:15:48 io-hp NetworkManager[822]: <info> [1601291748.1205] dhcp6 (enp3s0): option dhcp6_name_servers => 'fd91:dab6:a2b2:1:3e98:72ff:fed6:e058'
Sep 28 13:15:48 io-hp avahi-daemon[818]: Withdrawing address record for fe80::40c9:e254:63df:1cf on enp3s0.
Sep 28 13:15:48 io-hp NetworkManager[822]: <info> [1601291748.1205] dhcp6 (enp3s0): state changed unknown -> bound
Sep 28 13:15:48 io-hp kded5[1167]: plasma-nm: Unhandled active connection state change: 1
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3663] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3761] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3771] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3783] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3813] manager: NetworkManager state is now CONNECTED_SITE
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3817] policy: set 'Wired connection 1' (enp3s0) as default for IPv6 routing and DNS
Sep 28 13:15:49 io-hp NetworkManager[822]: <info> [1601291749.3911] device (enp3s0): Activation: successful, device activated.
Sep 28 13:15:49 io-hp kded5[1167]: plasma-nm: Not emitting connection activated notification as the connection was active prior to suspend
Sep 28 13:15:49 io-hp audit[3701]: USER_AUTH pid=3701 uid=1000 auid=1000 ses=1 msg='op=PAM:unix_chkpwd acct="io" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:49 io-hp kernel: audit: type=1100 audit(1601291749.933:58): pid=3701 uid=1000 auid=1000 ses=1 msg='op=PAM:unix_chkpwd acct="io" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:49 io-hp kscreenlocker_greet[3286]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Sep 28 13:15:50 io-hp kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60749, resource id: 4194368, major code: 18 (ChangeProperty), minor code: 0
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8151] dhcp4 (enp3s0): option dhcp_lease_time => '31536000'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8152] dhcp4 (enp3s0): option domain_name => 'local'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8152] dhcp4 (enp3s0): option domain_name_servers => '192.168.2.1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8153] dhcp4 (enp3s0): option expiry => '1632827749'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8153] dhcp4 (enp3s0): option host_name => 'io-hp'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8154] dhcp4 (enp3s0): option ip_address => '192.168.2.101'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8154] dhcp4 (enp3s0): option next_server => '192.168.2.1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8154] dhcp4 (enp3s0): option requested_broadcast_address => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8155] dhcp4 (enp3s0): option requested_domain_name => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8155] dhcp4 (enp3s0): option requested_domain_name_servers => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8156] dhcp4 (enp3s0): option requested_domain_search => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8156] dhcp4 (enp3s0): option requested_host_name => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8157] dhcp4 (enp3s0): option requested_interface_mtu => '1'
Sep 28 13:15:50 io-hp avahi-daemon[818]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.2.101.
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8157] dhcp4 (enp3s0): option requested_ms_classless_static_routes => '1'
Sep 28 13:15:50 io-hp avahi-daemon[818]: New relevant interface enp3s0.IPv4 for mDNS.
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8157] dhcp4 (enp3s0): option requested_nis_domain => '1'
Sep 28 13:15:50 io-hp avahi-daemon[818]: Registering new address record for 192.168.2.101 on enp3s0.IPv4.
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8158] dhcp4 (enp3s0): option requested_nis_servers => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8158] dhcp4 (enp3s0): option requested_ntp_servers => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8159] dhcp4 (enp3s0): option requested_rfc3442_classless_static_routes => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8159] dhcp4 (enp3s0): option requested_root_path => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8160] dhcp4 (enp3s0): option requested_routers => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8160] dhcp4 (enp3s0): option requested_static_routes => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8161] dhcp4 (enp3s0): option requested_subnet_mask => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8161] dhcp4 (enp3s0): option requested_time_offset => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8162] dhcp4 (enp3s0): option requested_wpad => '1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8162] dhcp4 (enp3s0): option routers => '192.168.2.1'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8162] dhcp4 (enp3s0): option subnet_mask => '255.255.255.0'
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8163] dhcp4 (enp3s0): state changed unknown -> bound
Sep 28 13:15:50 io-hp NetworkManager[822]: <info> [1601291750.8211] policy: set 'Wired connection 1' (enp3s0) as default for IPv4 routing and DNS
Sep 28 13:15:51 io-hp NetworkManager[822]: <info> [1601291751.4508] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 28 13:15:57 io-hp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Sep 28 13:15:57 io-hp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:57 io-hp kernel: audit: type=1131 audit(1601291757.656:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 28 13:15:58 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:59 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:15:59 io-hp plasmashell[1225]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:51: TypeError: Cannot read property 'separatorCount' of null
Sep 28 13:15:59 io-hp plasmashell[1225]: trying to show an empty dialog
Sep 28 13:16:01 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:01 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:01 io-hp plasmashell[1225]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:51: TypeError: Cannot read property 'separatorCount' of null
Sep 28 13:16:01 io-hp plasmashell[1225]: trying to show an empty dialog
Sep 28 13:16:03 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:03 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:03 io-hp plasmashell[1225]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:51: TypeError: Cannot read property 'separatorCount' of null
Sep 28 13:16:03 io-hp plasmashell[1225]: trying to show an empty dialog
Sep 28 13:16:07 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:08 io-hp plasmashell[1225]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 28 13:16:08 io-hp plasmashell[1225]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:51: TypeError: Cannot read property 'separatorCount' of null
Sep 28 13:16:08 io-hp plasmashell[1225]: trying to show an empty dialog
-- Reboot --
Sep 28 13:20:53 io-hp kernel: Linux version 5.4.64-1-MANJARO (builder@d467f31eaa7a) (gcc version 10.2.0 (GCC)) #1 SMP PREEMPT Wed Sep 9 18:26:19 UTC 2020
Sep 28 13:20:53 io-hp kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=3e2010a7-c97f-4294-b887-2952e34fc467 rw quiet pci=nomsi,noaer loglevel=3 rd.systemd.show_status=auto rd.udev.log_priority=3 touch ~/.hushlogin
Sep 28 13:20:53 io-hp kernel: KERNEL supported cpus:
Sep 28 13:20:53 io-hp kernel: Intel GenuineIntel
Sep 28 13:20:53 io-hp kernel: AMD AuthenticAMD
Sep 28 13:20:53 io-hp kernel: Hygon HygonGenuine
Sep 28 13:20:53 io-hp kernel: Centaur CentaurHauls
Sep 28 13:20:53 io-hp kernel: zhaoxin Shanghai
Sep 28 13:20:53 io-hp kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Sep 28 13:20:53 io-hp kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Sep 28 13:20:53 io-hp kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Sep 28 13:20:53 io-hp kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Sep 28 13:20:53 io-hp kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Sep 28 13:20:53 io-hp kernel: BIOS-provided physical RAM map:
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000b3aecfff] usable
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000b3aed000-0x00000000b42edfff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000b42ee000-0x00000000bf17efff] usable
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000bf17f000-0x00000000bf97efff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000bf97f000-0x00000000bfb7efff] ACPI NVS
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000bfb7f000-0x00000000bfbfefff] ACPI data
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000bfbff000-0x00000000bfbfffff] usable
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000bfc00000-0x00000000dfffffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000f0900000-0x00000000f09fffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec01fff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
Sep 28 13:20:53 io-hp kernel: BIOS-e820: [mem 0x0000000100000000-0x000000011effffff] usable
Sep 28 13:20:53 io-hp kernel: NX (Execute Disable) protection: active
Sep 28 13:20:53 io-hp kernel: SMBIOS 2.8 present.
Sep 28 13:20:53 io-hp kernel: DMI: HP HP Notebook/81F5, BIOS F.09 05/19/2016
Sep 28 13:20:53 io-hp kernel: tsc: Fast TSC calibration using PIT
Sep 28 13:20:53 io-hp kernel: tsc: Detected 1996.343 MHz processor
Sep 28 13:20:53 io-hp kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Sep 28 13:20:53 io-hp kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Sep 28 13:20:53 io-hp kernel: last_pfn = 0x11f000 max_arch_pfn = 0x400000000
Sep 28 13:20:53 io-hp kernel: MTRR default type: uncachable
Sep 28 13:20:53 io-hp kernel: MTRR fixed ranges enabled:
Sep 28 13:20:53 io-hp kernel: 00000-9FFFF write-back
Sep 28 13:20:53 io-hp kernel: A0000-BFFFF uncachable
Sep 28 13:20:53 io-hp kernel: C0000-FFFFF write-through
Sep 28 13:20:53 io-hp kernel: MTRR variable ranges enabled:
Sep 28 13:20:53 io-hp kernel: 0 base 0000000000 mask FF80000000 write-back
Sep 28 13:20:53 io-hp kernel: 1 base 0080000000 mask FFC0000000 write-back
Sep 28 13:20:53 io-hp kernel: 2 base 00BFB47000 mask FFFFFFF000 uncachable
Sep 28 13:20:53 io-hp kernel: 3 base 00FF800000 mask FFFF800000 write-protect
Sep 28 13:20:53 io-hp kernel: 4 disabled
Sep 28 13:20:53 io-hp kernel: 5 disabled
Sep 28 13:20:53 io-hp kernel: 6 disabled
Sep 28 13:20:53 io-hp kernel: 7 disabled
Sep 28 13:20:53 io-hp kernel: TOM2: 000000011f000000 aka 4592M
Sep 28 13:20:53 io-hp kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Sep 28 13:20:53 io-hp kernel: last_pfn = 0xbfc00 max_arch_pfn = 0x400000000
Sep 28 13:20:53 io-hp kernel: check: Scanning 1 areas for low memory corruption
Sep 28 13:20:53 io-hp kernel: Using GB pages for direct mapping
Sep 28 13:20:53 io-hp kernel: RAMDISK: [mem 0x36cd9000-0x37663fff]
Sep 28 13:20:53 io-hp kernel: ACPI: Early table checksum verification disabled
Sep 28 13:20:53 io-hp kernel: ACPI: RSDP 0x00000000000FE020 000024 (v02 HPQOEM)
Sep 28 13:20:53 io-hp kernel: ACPI: XSDT 0x00000000BFBD2188 0000C4 (v01 HPQOEM SLIC-MPC 00000001 01000013)
Sep 28 13:20:53 io-hp kernel: ACPI: FACP 0x00000000BFBFB000 00010C (v05 HPQOEM SLIC-MPC 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: DSDT 0x00000000BFBE8000 00EB55 (v01 HPQOEM SLIC-MPC F0000000 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: FACS 0x00000000BFB04000 000040
Sep 28 13:20:53 io-hp kernel: ACPI: TCPA 0x00000000BFBFD000 000032 (v02 HPQOEM INSYDE 00000000 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: UEFI 0x00000000BFBFC000 000236 (v01 HPQOEM INSYDE 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: HPET 0x00000000BFBFA000 000038 (v01 HPQOEM INSYDE 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: APIC 0x00000000BFBF9000 000090 (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: MCFG 0x00000000BFBF8000 00003C (v01 HPQOEM INSYDE 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: ASF! 0x00000000BFBF7000 0000A5 (v32 HPQOEM INSYDE 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: BOOT 0x00000000BFBE7000 000028 (v01 HPQOEM INSYDE 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: FPDT 0x00000000BFBE5000 000044 (v01 HPQOEM SLIC-MPC 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: MSDM 0x00000000BFBE4000 000055 (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBE3000 000CB4 (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBDE000 0048A6 (v02 HPQOEM INSYDE 00000002 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBDD000 00041A (v01 HPQOEM INSYDE 00001000 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: TPM2 0x00000000BFBDC000 000044 (v03 HPQOEM INSYDE 20505350 HP 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBDB000 000692 (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBDA000 000418 (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBD8000 001990 (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBD7000 00008C (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBD5000 001153 (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: SSDT 0x00000000BFBD3000 000F8A (v01 HPQOEM INSYDE 00000001 ACPI 00040000)
Sep 28 13:20:53 io-hp kernel: ACPI: Local APIC address 0xfee00000
Sep 28 13:20:53 io-hp kernel: No NUMA configuration found
Sep 28 13:20:53 io-hp kernel: Faking a node at [mem 0x0000000000000000-0x000000011effffff]
Sep 28 13:20:53 io-hp kernel: NODE_DATA(0) allocated [mem 0x11effc000-0x11effffff]
Sep 28 13:20:53 io-hp kernel: Zone ranges:
Sep 28 13:20:53 io-hp kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Sep 28 13:20:53 io-hp kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Sep 28 13:20:53 io-hp kernel: Normal [mem 0x0000000100000000-0x000000011effffff]
Sep 28 13:20:53 io-hp kernel: Device empty
Sep 28 13:20:53 io-hp kernel: Movable zone start for each node
Sep 28 13:20:53 io-hp kernel: Early memory node ranges
Sep 28 13:20:53 io-hp kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
Sep 28 13:20:53 io-hp kernel: node 0: [mem 0x0000000000100000-0x00000000b3aecfff]
Sep 28 13:20:53 io-hp kernel: node 0: [mem 0x00000000b42ee000-0x00000000bf17efff]
Sep 28 13:20:53 io-hp kernel: node 0: [mem 0x00000000bfbff000-0x00000000bfbfffff]
Sep 28 13:20:53 io-hp kernel: node 0: [mem 0x0000000100000000-0x000000011effffff]
Sep 28 13:20:53 io-hp kernel: Zeroed struct page in unavailable ranges: 9955 pages
Sep 28 13:20:53 io-hp kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000011effffff]
Sep 28 13:20:53 io-hp kernel: On node 0 totalpages: 907549
Sep 28 13:20:53 io-hp kernel: DMA zone: 64 pages used for memmap
Sep 28 13:20:53 io-hp kernel: DMA zone: 21 pages reserved
Sep 28 13:20:53 io-hp kernel: DMA zone: 3998 pages, LIFO batch:0
Sep 28 13:20:53 io-hp kernel: DMA32 zone: 12134 pages used for memmap
Sep 28 13:20:53 io-hp kernel: DMA32 zone: 776575 pages, LIFO batch:63
Sep 28 13:20:53 io-hp kernel: Normal zone: 1984 pages used for memmap
Sep 28 13:20:53 io-hp kernel: Normal zone: 126976 pages, LIFO batch:31
Sep 28 13:20:53 io-hp kernel: ACPI: PM-Timer IO Port: 0x408
Sep 28 13:20:53 io-hp kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Sep 28 13:20:53 io-hp kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Sep 28 13:20:53 io-hp kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Sep 28 13:20:53 io-hp kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Sep 28 13:20:53 io-hp kernel: IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
Sep 28 13:20:53 io-hp kernel: IOAPIC[1]: apic_id 5, version 33, address 0xfec01000, GSI 24-55
Sep 28 13:20:53 io-hp kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Sep 28 13:20:53 io-hp kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Sep 28 13:20:53 io-hp kernel: ACPI: IRQ0 used by override.
Sep 28 13:20:53 io-hp kernel: ACPI: IRQ9 used by override.
Sep 28 13:20:53 io-hp kernel: Using ACPI (MADT) for SMP configuration information
Sep 28 13:20:53 io-hp kernel: ACPI: HPET id: 0x10228210 base: 0xfed00000
Sep 28 13:20:53 io-hp kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xb3aed000-0xb42edfff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xbf17f000-0xbf97efff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xbf97f000-0xbfb7efff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xbfb7f000-0xbfbfefff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xbfc00000-0xdfffffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xe0000000-0xf08fffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xf0900000-0xf09fffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xf0a00000-0xf7ffffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec01fff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfed81000-0xfedfffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xfee01000-0xff7fffff]
Sep 28 13:20:53 io-hp kernel: PM: Registered nosave memory: [mem 0xff800000-0xffffffff]
Sep 28 13:20:53 io-hp kernel: [mem 0xe0000000-0xf08fffff] available for PCI devices
Sep 28 13:20:53 io-hp kernel: Booting paravirtualized kernel on bare hardware
Sep 28 13:20:53 io-hp kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Sep 28 13:20:53 io-hp kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
Sep 28 13:20:53 io-hp kernel: percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u524288
Sep 28 13:20:53 io-hp kernel: pcpu-alloc: s184320 r8192 d28672 u524288 alloc=1*2097152
Sep 28 13:20:53 io-hp kernel: pcpu-alloc: [0] 0 1 2 3
Sep 28 13:20:53 io-hp kernel: Built 1 zonelists, mobility grouping on. Total pages: 893346
Sep 28 13:20:53 io-hp kernel: Policy zone: Normal
Sep 28 13:20:53 io-hp kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=3e2010a7-c97f-4294-b887-2952e34fc467 rw quiet pci=nomsi,noaer loglevel=3 rd.systemd.show_status=auto rd.udev.log_priority=3 touch ~/.hushlogin
Sep 28 13:20:53 io-hp kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Sep 28 13:20:53 io-hp kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Sep 28 13:20:53 io-hp kernel: mem auto-init: stack:byref_all, heap alloc:on, heap free:off
Sep 28 13:20:53 io-hp kernel: Calgary: detecting Calgary via BIOS EBDA area
Sep 28 13:20:53 io-hp kernel: Calgary: Unable to locate Rio Grande table in EBDA - bailing!
Sep 28 13:20:53 io-hp kernel: Memory: 3461276K/3630196K available (12291K kernel code, 1329K rwdata, 4092K rodata, 1644K init, 3396K bss, 168920K reserved, 0K cma-reserved)
Sep 28 13:20:53 io-hp kernel: random: get_random_u64 called from __kmem_cache_create+0x3e/0x610 with crng_init=0
Sep 28 13:20:53 io-hp kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Sep 28 13:20:53 io-hp kernel: ftrace: allocating 37556 entries in 147 pages
Sep 28 13:20:53 io-hp kernel: rcu: Preemptible hierarchical RCU implementation.
Sep 28 13:20:53 io-hp kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
Sep 28 13:20:53 io-hp kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
Sep 28 13:20:53 io-hp kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
Sep 28 13:20:53 io-hp kernel: Tasks RCU enabled.
Sep 28 13:20:53 io-hp kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Sep 28 13:20:53 io-hp kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Sep 28 13:20:53 io-hp kernel: NR_IRQS: 20736, nr_irqs: 1000, preallocated irqs: 16
Sep 28 13:20:53 io-hp kernel: spurious 8259A interrupt: IRQ7.
Sep 28 13:20:53 io-hp kernel: Console: colour dummy device 80x25
Sep 28 13:20:53 io-hp kernel: printk: console [tty0] enabled
Sep 28 13:20:53 io-hp kernel: ACPI: Core revision 20190816
Sep 28 13:20:53 io-hp kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
Sep 28 13:20:53 io-hp kernel: APIC: Switch to symmetric I/O mode setup
Sep 28 13:20:53 io-hp kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Sep 28 13:20:53 io-hp kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x398d5fbf489, max_idle_ns: 881590646357 ns
Sep 28 13:20:53 io-hp kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 3994.04 BogoMIPS (lpj=6654476)
Sep 28 13:20:53 io-hp kernel: pid_max: default: 32768 minimum: 301
Sep 28 13:20:53 io-hp kernel: LSM: Security Framework initializing
Sep 28 13:20:53 io-hp kernel: Yama: becoming mindful.
Sep 28 13:20:53 io-hp kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Sep 28 13:20:53 io-hp kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Sep 28 13:20:53 io-hp kernel: *** VALIDATE tmpfs ***
Sep 28 13:20:53 io-hp kernel: *** VALIDATE proc ***
Sep 28 13:20:53 io-hp kernel: *** VALIDATE cgroup1 ***
Sep 28 13:20:53 io-hp kernel: *** VALIDATE cgroup2 ***
Sep 28 13:20:53 io-hp kernel: BIOS may not properly restore RDRAND after suspend, hiding RDRAND via CPUID. Use rdrand=force to reenable.
Sep 28 13:20:53 io-hp kernel: LVT offset 1 assigned for vector 0xf9
Sep 28 13:20:53 io-hp kernel: Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
Sep 28 13:20:53 io-hp kernel: Last level dTLB entries: 4KB 512, 2MB 256, 4MB 128, 1GB 0
Sep 28 13:20:53 io-hp kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Sep 28 13:20:53 io-hp kernel: Spectre V2 : Mitigation: Full AMD retpoline
Sep 28 13:20:53 io-hp kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Sep 28 13:20:53 io-hp kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Sep 28 13:20:53 io-hp kernel: Freeing SMP alternatives memory: 32K
Sep 28 13:20:53 io-hp kernel: smpboot: CPU0: AMD A6-7310 APU with AMD Radeon R4 Graphics (family: 0x16, model: 0x30, stepping: 0x1)
Sep 28 13:20:53 io-hp kernel: Performance Events: AMD PMU driver.
Sep 28 13:20:53 io-hp kernel: ... version: 0
Sep 28 13:20:53 io-hp kernel: ... bit width: 48
Sep 28 13:20:53 io-hp kernel: ... generic registers: 4
Sep 28 13:20:53 io-hp kernel: ... value mask: 0000ffffffffffff
Sep 28 13:20:53 io-hp kernel: ... max period: 00007fffffffffff
Sep 28 13:20:53 io-hp kernel: ... fixed-purpose events: 0
Sep 28 13:20:53 io-hp kernel: ... event mask: 000000000000000f
Sep 28 13:20:53 io-hp kernel: rcu: Hierarchical SRCU implementation.
Sep 28 13:20:53 io-hp kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Sep 28 13:20:53 io-hp kernel: smp: Bringing up secondary CPUs ...
Sep 28 13:20:53 io-hp kernel: x86: Booting SMP configuration:
Sep 28 13:20:53 io-hp kernel: .... node #0, CPUs: #1
Sep 28 13:20:53 io-hp kernel: do_IRQ: 1.55 No irq handler for vector
Sep 28 13:20:53 io-hp kernel: #2
Sep 28 13:20:53 io-hp kernel: do_IRQ: 2.55 No irq handler for vector
Sep 28 13:20:53 io-hp kernel: #3
Sep 28 13:20:53 io-hp kernel: do_IRQ: 3.55 No irq handler for vector
Sep 28 13:20:53 io-hp kernel: smp: Brought up 1 node, 4 CPUs
Sep 28 13:20:53 io-hp kernel: smpboot: Max logical packages: 1
Sep 28 13:20:53 io-hp kernel: smpboot: Total of 4 processors activated (15977.19 BogoMIPS)
Sep 28 13:20:53 io-hp kernel: devtmpfs: initialized
Sep 28 13:20:53 io-hp kernel: x86/mm: Memory block size: 128MB
Sep 28 13:20:53 io-hp kernel: PM: Registering ACPI NVS region [mem 0xbf97f000-0xbfb7efff] (2097152 bytes)
Sep 28 13:20:53 io-hp kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Sep 28 13:20:53 io-hp kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Sep 28 13:20:53 io-hp kernel: pinctrl core: initialized pinctrl subsystem
Sep 28 13:20:53 io-hp kernel: PM: RTC time: 11:20:50, date: 2020-09-28
Sep 28 13:20:53 io-hp kernel: NET: Registered protocol family 16
Sep 28 13:20:53 io-hp kernel: audit: initializing netlink subsys (disabled)
Sep 28 13:20:53 io-hp kernel: audit: type=2000 audit(1601292049.139:1): state=initialized audit_enabled=0 res=1
Sep 28 13:20:53 io-hp kernel: cpuidle: using governor ladder
Sep 28 13:20:53 io-hp kernel: cpuidle: using governor menu
Sep 28 13:20:53 io-hp kernel: Simple Boot Flag at 0x44 set to 0x1
Sep 28 13:20:53 io-hp kernel: ACPI: bus type PCI registered
Sep 28 13:20:53 io-hp kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Sep 28 13:20:53 io-hp kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Sep 28 13:20:53 io-hp kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Sep 28 13:20:53 io-hp kernel: PCI: Using configuration type 1 for base access
Sep 28 13:20:53 io-hp kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Sep 28 13:20:53 io-hp kernel: mtrr: probably your BIOS does not setup all CPUs.
Sep 28 13:20:53 io-hp kernel: mtrr: corrected configuration.
Sep 28 13:20:53 io-hp kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Sep 28 13:20:53 io-hp kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Sep 28 13:20:53 io-hp kernel: fbcon: Taking over console
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Module Device)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Processor Device)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Processor Aggregator Device)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Linux-Dell-Video)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Sep 28 13:20:53 io-hp kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Sep 28 13:20:53 io-hp kernel: ACPI: 10 ACPI AML tables successfully acquired and loaded
Sep 28 13:20:53 io-hp kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Sep 28 13:20:53 io-hp kernel: ACPI: EC: EC started
Sep 28 13:20:53 io-hp kernel: ACPI: EC: interrupt blocked
Sep 28 13:20:53 io-hp kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Used as first EC
Sep 28 13:20:53 io-hp kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Sep 28 13:20:53 io-hp kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
Sep 28 13:20:53 io-hp kernel: ACPI: Interpreter enabled
Sep 28 13:20:53 io-hp kernel: ACPI: (supports S0 S3 S4 S5)
Sep 28 13:20:53 io-hp kernel: ACPI: Using IOAPIC for interrupt routing
Sep 28 13:20:53 io-hp kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Sep 28 13:20:53 io-hp kernel: ACPI: Enabled 5 GPEs in block 00 to 1F
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Sep 28 13:20:53 io-hp kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments HPX-Type3]
Sep 28 13:20:53 io-hp kernel: acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
Sep 28 13:20:53 io-hp kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
Sep 28 13:20:53 io-hp kernel: acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cebff])
Sep 28 13:20:53 io-hp kernel: PCI host bridge to bus 0000:00
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:00.0: [1022:1566] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: [1002:9851] type 00 class 0x030000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: reg 0x20: [io 0x4000-0x40ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: reg 0x24: [mem 0xf0d00000-0xf0d3ffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: enabling Extended Tags
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: PME# supported from D1 D2 D3hot
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.1: [1002:9840] type 00 class 0x040300
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.1: reg 0x10: [mem 0xf0d60000-0xf0d63fff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.1: enabling Extended Tags
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.1: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.0: [1022:156b] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: [1022:1439] type 01 class 0x060400
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: enabling Extended Tags
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: [1022:1439] type 01 class 0x060400
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: enabling Extended Tags
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: [1022:1439] type 01 class 0x060400
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: enabling Extended Tags
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: PME# supported from D0 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:08.0: [1022:1537] type 00 class 0x108000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:08.0: reg 0x10: [mem 0xf0d40000-0xf0d5ffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:08.0: reg 0x18: [mem 0xf0a00000-0xf0afffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:08.0: reg 0x1c: [mem 0xf0d70000-0xf0d70fff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:08.0: reg 0x24: [mem 0xf0d6a000-0xf0d6bfff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
Sep 28 13:20:53 io-hp kernel: pci 0000:00:10.0: reg 0x10: [mem 0xf0d68000-0xf0d69fff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: [1022:7804] type 00 class 0x010601
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x10: [io 0x4118-0x411f]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x14: [io 0x4124-0x4127]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x18: [io 0x4110-0x4117]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x1c: [io 0x4120-0x4123]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x20: [io 0x4100-0x410f]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: reg 0x24: [mem 0xf0d6f000-0xf0d6f3ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:11.0: PME# supported from D3hot
Sep 28 13:20:53 io-hp kernel: pci 0000:00:12.0: [1022:7808] type 00 class 0x0c0320
Sep 28 13:20:53 io-hp kernel: pci 0000:00:12.0: reg 0x10: [mem 0xf0d6e000-0xf0d6e0ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:12.0: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:13.0: [1022:7808] type 00 class 0x0c0320
Sep 28 13:20:53 io-hp kernel: pci 0000:00:13.0: reg 0x10: [mem 0xf0d6d000-0xf0d6d0ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:13.0: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:00:13.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.2: reg 0x10: [mem 0xf0d64000-0xf0d67fff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.7: [1022:7813] type 00 class 0x080501
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.7: reg 0x10: [mem 0xf0d6c000-0xf0d6c0ff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:14.7: PME# supported from D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.0: [1022:1580] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.1: [1022:1581] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.2: [1022:1582] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.3: [1022:1583] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.4: [1022:1584] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:18.5: [1022:1585] type 00 class 0x060000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: PCI bridge to [bus 01]
Sep 28 13:20:53 io-hp kernel: pci 0000:02:00.0: [10ec:b723] type 00 class 0x028000
Sep 28 13:20:53 io-hp kernel: pci 0000:02:00.0: reg 0x10: [io 0x3000-0x30ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:02:00.0: reg 0x18: [mem 0xf0c00000-0xf0c03fff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:02:00.0: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: PCI bridge to [bus 02]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: bridge window [io 0x3000-0x3fff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.4: bridge window [mem 0xf0c00000-0xf0cfffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: [10ec:8136] type 00 class 0x020000
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: reg 0x10: [io 0x2000-0x20ff]
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: reg 0x18: [mem 0xf0b00000-0xf0b00fff 64bit]
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: reg 0x20: [mem 0xf0800000-0xf0803fff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: supports D1 D2
Sep 28 13:20:53 io-hp kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: PCI bridge to [bus 03]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: bridge window [io 0x2000-0x2fff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: bridge window [mem 0xf0b00000-0xf0bfffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.5: bridge window [mem 0xf0800000-0xf08fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
Sep 28 13:20:53 io-hp kernel: platform MSFT0101:00: failed to claim resource 0: [mem 0xbfb6e000-0xbfc6dfff]
Sep 28 13:20:53 io-hp kernel: acpi MSFT0101:00: platform device creation failed: -16
Sep 28 13:20:53 io-hp kernel: ACPI: EC: interrupt unblocked
Sep 28 13:20:53 io-hp kernel: ACPI: EC: event unblocked
Sep 28 13:20:53 io-hp kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions and events
Sep 28 13:20:53 io-hp kernel: iommu: Default domain type: Translated
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: vgaarb: setting as boot VGA device
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: vgaarb: bridge control possible
Sep 28 13:20:53 io-hp kernel: vgaarb: loaded
Sep 28 13:20:53 io-hp kernel: ACPI: bus type USB registered
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver usbfs
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver hub
Sep 28 13:20:53 io-hp kernel: usbcore: registered new device driver usb
Sep 28 13:20:53 io-hp kernel: pps_core: LinuxPPS API ver. 1 registered
Sep 28 13:20:53 io-hp kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Sep 28 13:20:53 io-hp kernel: PTP clock support registered
Sep 28 13:20:53 io-hp kernel: EDAC MC: Ver: 3.0.0
Sep 28 13:20:53 io-hp kernel: PCI: Using ACPI for IRQ routing
Sep 28 13:20:53 io-hp kernel: PCI: pci_cache_line_size set to 64 bytes
Sep 28 13:20:53 io-hp kernel: e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
Sep 28 13:20:53 io-hp kernel: e820: reserve RAM buffer [mem 0xb3aed000-0xb3ffffff]
Sep 28 13:20:53 io-hp kernel: e820: reserve RAM buffer [mem 0xbf17f000-0xbfffffff]
Sep 28 13:20:53 io-hp kernel: e820: reserve RAM buffer [mem 0xbfc00000-0xbfffffff]
Sep 28 13:20:53 io-hp kernel: e820: reserve RAM buffer [mem 0x11f000000-0x11fffffff]
Sep 28 13:20:53 io-hp kernel: NetLabel: Initializing
Sep 28 13:20:53 io-hp kernel: NetLabel: domain hash size = 128
Sep 28 13:20:53 io-hp kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Sep 28 13:20:53 io-hp kernel: NetLabel: unlabeled traffic allowed by default
Sep 28 13:20:53 io-hp kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Sep 28 13:20:53 io-hp kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
Sep 28 13:20:53 io-hp kernel: clocksource: Switched to clocksource tsc-early
Sep 28 13:20:53 io-hp kernel: *** VALIDATE bpf ***
Sep 28 13:20:53 io-hp kernel: VFS: Disk quotas dquot_6.6.0
Sep 28 13:20:53 io-hp kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Sep 28 13:20:53 io-hp kernel: *** VALIDATE ramfs ***
Sep 28 13:20:53 io-hp kernel: *** VALIDATE hugetlbfs ***
Sep 28 13:20:53 io-hp kernel: pnp: PnP ACPI init
Sep 28 13:20:53 io-hp kernel: system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
Sep 28 13:20:53 io-hp kernel: system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 13:20:53 io-hp kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
Sep 28 13:20:53 io-hp kernel: pnp 00:02: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
Sep 28 13:20:53 io-hp kernel: pnp 00:03: Plug and Play ACPI device, IDs SYN3222 PNP0f13 (active)
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0400-0x04cf] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x04d0-0x04d1] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x04d6] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0680-0x06ff] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x077a] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0c00-0x0c01] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0c14] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0c50-0x0c52] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0c6c] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0c6f] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0cd0-0x0cdb] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: [io 0x0840-0x0847] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 28 13:20:53 io-hp kernel: system 00:05: [mem 0x000e0000-0x000fffff] could not be reserved
Sep 28 13:20:53 io-hp kernel: system 00:05: [mem 0xff800000-0xffffffff] has been reserved
Sep 28 13:20:53 io-hp kernel: system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
Sep 28 13:20:53 io-hp kernel: pnp: PnP ACPI: found 6 devices
Sep 28 13:20:53 io-hp kernel: thermal_sys: Registered thermal governor 'fair_share'
Sep 28 13:20:53 io-hp kernel: thermal_sys: Registered thermal governor 'bang_bang'
Sep 28 13:20:53 io-hp kernel: thermal_sys: Registered thermal governor 'step_wise'
Sep 28 13:20:53 io-hp kernel: thermal_sys: Registered thermal governor 'user_space'
Sep 28 13:20:53 io-hp kernel: thermal_sys: Registered thermal governor 'power_allocator'
Sep 28 13:20:53 io-hp kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: address conflict with Reserved [mem 0xff800000-0xffffffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: BAR 14: assigned [mem 0xf0e00000-0xf0ffffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: BAR 15: assigned [mem 0xf1000000-0xf11fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: BAR 6: assigned [mem 0xf0d80000-0xf0d9ffff pref]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: BAR 13: assigned [io 0x1000-0x1fff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [io 0x1000-0x1fff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [mem 0xf0e00000-0xf0ffffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:02.1: bridge window [mem 0xf1000000-0xf11fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 18 [mem 0xe0000000-0xf7ffffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfed3ffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:00: resource 20 [mem 0xfed45000-0xffffffff window]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:01: resource 1 [mem 0xf0e00000-0xf0ffffff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:01: resource 2 [mem 0xf1000000-0xf11fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:02: resource 1 [mem 0xf0c00000-0xf0cfffff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:03: resource 1 [mem 0xf0b00000-0xf0bfffff]
Sep 28 13:20:53 io-hp kernel: pci_bus 0000:03: resource 2 [mem 0xf0800000-0xf08fffff 64bit pref]
Sep 28 13:20:53 io-hp kernel: NET: Registered protocol family 2
Sep 28 13:20:53 io-hp kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Sep 28 13:20:53 io-hp kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Sep 28 13:20:53 io-hp kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Sep 28 13:20:53 io-hp kernel: TCP: Hash tables configured (established 32768 bind 32768)
Sep 28 13:20:53 io-hp kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Sep 28 13:20:53 io-hp kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Sep 28 13:20:53 io-hp kernel: NET: Registered protocol family 44
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Sep 28 13:20:53 io-hp kernel: pci 0000:00:01.1: D0 power state depends on 0000:00:01.0
Sep 28 13:20:53 io-hp kernel: pci 0000:00:10.0: quirk_usb_early_handoff+0x0/0x6d5 took 13833 usecs
Sep 28 13:20:53 io-hp kernel: pci 0000:00:12.0: PME# does not work under D3, disabling it
Sep 28 13:20:53 io-hp kernel: pci 0000:00:13.0: PME# does not work under D3, disabling it
Sep 28 13:20:53 io-hp kernel: PCI: CLS 64 bytes, default 64
Sep 28 13:20:53 io-hp kernel: Trying to unpack rootfs image as initramfs...
Sep 28 13:20:53 io-hp kernel: Freeing initrd memory: 9772K
Sep 28 13:20:53 io-hp kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Sep 28 13:20:53 io-hp kernel: software IO TLB: mapped [mem 0xbb17f000-0xbf17f000] (64MB)
Sep 28 13:20:53 io-hp kernel: amd_uncore: AMD NB counters detected
Sep 28 13:20:53 io-hp kernel: amd_uncore: AMD LLC counters detected
Sep 28 13:20:53 io-hp kernel: LVT offset 0 assigned for vector 0x400
Sep 28 13:20:53 io-hp kernel: perf: AMD IBS detected (0x000000ff)
Sep 28 13:20:53 io-hp kernel: check: Scanning for low memory corruption every 60 seconds
Sep 28 13:20:53 io-hp kernel: Initialise system trusted keyrings
Sep 28 13:20:53 io-hp kernel: Key type blacklist registered
Sep 28 13:20:53 io-hp kernel: workingset: timestamp_bits=41 max_order=20 bucket_order=0
Sep 28 13:20:53 io-hp kernel: zbud: loaded
Sep 28 13:20:53 io-hp kernel: Key type asymmetric registered
Sep 28 13:20:53 io-hp kernel: Asymmetric key parser 'x509' registered
Sep 28 13:20:53 io-hp kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Sep 28 13:20:53 io-hp kernel: io scheduler mq-deadline registered
Sep 28 13:20:53 io-hp kernel: io scheduler kyber registered
Sep 28 13:20:53 io-hp kernel: io scheduler bfq registered
Sep 28 13:20:53 io-hp kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Sep 28 13:20:53 io-hp kernel: vesafb: mode is 1920x1080x32, linelength=7680, pages=0
Sep 28 13:20:53 io-hp kernel: vesafb: scrolling: redraw
Sep 28 13:20:53 io-hp kernel: vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
Sep 28 13:20:53 io-hp kernel: vesafb: framebuffer at 0xe0000000, mapped to 0x(____ptrval____), using 8128k, total 8128k
Sep 28 13:20:53 io-hp kernel: Console: switching to colour frame buffer device 240x67
Sep 28 13:20:53 io-hp kernel: fb0: VESA VGA frame buffer device
Sep 28 13:20:53 io-hp kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Sep 28 13:20:53 io-hp kernel: ACPI: Power Button [PWRB]
Sep 28 13:20:53 io-hp kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
Sep 28 13:20:53 io-hp kernel: ACPI: Lid Switch [LID]
Sep 28 13:20:53 io-hp kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Sep 28 13:20:53 io-hp kernel: ACPI: Power Button [PWRF]
Sep 28 13:20:53 io-hp kernel: ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
Sep 28 13:20:53 io-hp kernel: acpi device:00: registered as cooling_device0
Sep 28 13:20:53 io-hp kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
Sep 28 13:20:53 io-hp kernel: thermal LNXTHERM:00: registered as thermal_zone0
Sep 28 13:20:53 io-hp kernel: ACPI: Thermal Zone [TSZ0] (49 C)
Sep 28 13:20:53 io-hp kernel: thermal LNXTHERM:01: registered as thermal_zone1
Sep 28 13:20:53 io-hp kernel: ACPI: Thermal Zone [TSZ2] (20 C)
Sep 28 13:20:53 io-hp kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Sep 28 13:20:53 io-hp kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Sep 28 13:20:53 io-hp kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver usbserial_generic
Sep 28 13:20:53 io-hp kernel: usbserial: USB Serial support registered for generic
Sep 28 13:20:53 io-hp kernel: rtc_cmos 00:01: RTC can wake from S4
Sep 28 13:20:53 io-hp kernel: rtc_cmos 00:01: registered as rtc0
Sep 28 13:20:53 io-hp kernel: rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
Sep 28 13:20:53 io-hp kernel: ledtrig-cpu: registered to indicate activity on CPUs
Sep 28 13:20:53 io-hp kernel: x86/pm: family 0x16 cpu detected, MSR saving is needed during suspending.
Sep 28 13:20:53 io-hp kernel: drop_monitor: Initializing network drop monitor service
Sep 28 13:20:53 io-hp kernel: NET: Registered protocol family 10
Sep 28 13:20:53 io-hp kernel: Segment Routing with IPv6
Sep 28 13:20:53 io-hp kernel: NET: Registered protocol family 17
Sep 28 13:20:53 io-hp kernel: RAS: Correctable Errors collector initialized.
Sep 28 13:20:53 io-hp kernel: microcode: CPU0: patch_level=0x07030105
Sep 28 13:20:53 io-hp kernel: microcode: CPU1: patch_level=0x07030105
Sep 28 13:20:53 io-hp kernel: microcode: CPU2: patch_level=0x07030105
Sep 28 13:20:53 io-hp kernel: microcode: CPU3: patch_level=0x07030105
Sep 28 13:20:53 io-hp kernel: microcode: Microcode Update Driver: v2.2.
Sep 28 13:20:53 io-hp kernel: IPI shorthand broadcast: enabled
Sep 28 13:20:53 io-hp kernel: sched_clock: Marking stable (1183304828, 610357)->(1194200968, -10285783)
Sep 28 13:20:53 io-hp kernel: registered taskstats version 1
Sep 28 13:20:53 io-hp kernel: Loading compiled-in X.509 certificates
Sep 28 13:20:53 io-hp kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 7fbb312bfb3cf269e5386db02d784b9215478897'
Sep 28 13:20:53 io-hp kernel: zswap: loaded using pool lzo/zbud
Sep 28 13:20:53 io-hp kernel: Key type ._fscrypt registered
Sep 28 13:20:53 io-hp kernel: Key type .fscrypt registered
Sep 28 13:20:53 io-hp kernel: Key type big_key registered
Sep 28 13:20:53 io-hp kernel: PM: Magic number: 4:560:328
Sep 28 13:20:53 io-hp kernel: rtc_cmos 00:01: setting system clock to 2020-09-28T11:20:50 UTC (1601292050)
Sep 28 13:20:53 io-hp kernel: Freeing unused decrypted memory: 2040K
Sep 28 13:20:53 io-hp kernel: Freeing unused kernel image memory: 1644K
Sep 28 13:20:53 io-hp kernel: Write protecting the kernel read-only data: 18432k
Sep 28 13:20:53 io-hp kernel: Freeing unused kernel image memory: 2008K
Sep 28 13:20:53 io-hp kernel: Freeing unused kernel image memory: 4K
Sep 28 13:20:53 io-hp kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Sep 28 13:20:53 io-hp kernel: Run /init as init process
Sep 28 13:20:53 io-hp kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Sep 28 13:20:53 io-hp kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sep 28 13:20:53 io-hp kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Sep 28 13:20:53 io-hp kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Sep 28 13:20:53 io-hp kernel: ehci-pci: EHCI PCI platform driver
Sep 28 13:20:53 io-hp kernel: SCSI subsystem initialized
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: EHCI Host Controller
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: debug port 2
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: irq 18, io mem 0xf0d6e000
Sep 28 13:20:53 io-hp kernel: sdhci: Secure Digital Host Controller Interface driver
Sep 28 13:20:53 io-hp kernel: sdhci: Copyright(c) Pierre Ossman
Sep 28 13:20:53 io-hp kernel: sdhci-pci 0000:00:14.7: SDHCI controller found [1022:7813] (rev 1)
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:12.0: USB 2.0 started, EHCI 1.00
Sep 28 13:20:53 io-hp kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Sep 28 13:20:53 io-hp kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 28 13:20:53 io-hp kernel: usb usb1: Product: EHCI Host Controller
Sep 28 13:20:53 io-hp kernel: usb usb1: Manufacturer: Linux 5.4.64-1-MANJARO ehci_hcd
Sep 28 13:20:53 io-hp kernel: usb usb1: SerialNumber: 0000:00:12.0
Sep 28 13:20:53 io-hp kernel: mmc0: SDHCI controller on PCI [0000:00:14.7] using ADMA
Sep 28 13:20:53 io-hp kernel: hub 1-0:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 1-0:1.0: 2 ports detected
Sep 28 13:20:53 io-hp kernel: xhci_hcd 0000:00:10.0: xHCI Host Controller
Sep 28 13:20:53 io-hp kernel: xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
Sep 28 13:20:53 io-hp kernel: xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000410
Sep 28 13:20:53 io-hp kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Sep 28 13:20:53 io-hp kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 28 13:20:53 io-hp kernel: usb usb2: Product: xHCI Host Controller
Sep 28 13:20:53 io-hp kernel: usb usb2: Manufacturer: Linux 5.4.64-1-MANJARO xhci-hcd
Sep 28 13:20:53 io-hp kernel: usb usb2: SerialNumber: 0000:00:10.0
Sep 28 13:20:53 io-hp kernel: hub 2-0:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 2-0:1.0: 2 ports detected
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: EHCI Host Controller
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: new USB bus registered, assigned bus number 3
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: debug port 2
Sep 28 13:20:53 io-hp kernel: xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
Sep 28 13:20:53 io-hp kernel: xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: irq 18, io mem 0xf0d6d000
Sep 28 13:20:53 io-hp kernel: libata version 3.00 loaded.
Sep 28 13:20:53 io-hp kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Sep 28 13:20:53 io-hp kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
Sep 28 13:20:53 io-hp kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 28 13:20:53 io-hp kernel: usb usb4: Product: xHCI Host Controller
Sep 28 13:20:53 io-hp kernel: usb usb4: Manufacturer: Linux 5.4.64-1-MANJARO xhci-hcd
Sep 28 13:20:53 io-hp kernel: usb usb4: SerialNumber: 0000:00:10.0
Sep 28 13:20:53 io-hp kernel: hub 4-0:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 4-0:1.0: 2 ports detected
Sep 28 13:20:53 io-hp kernel: ahci 0000:00:11.0: version 3.0
Sep 28 13:20:53 io-hp kernel: ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Sep 28 13:20:53 io-hp kernel: ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp fbs pio slum part
Sep 28 13:20:53 io-hp kernel: ehci-pci 0000:00:13.0: USB 2.0 started, EHCI 1.00
Sep 28 13:20:53 io-hp kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Sep 28 13:20:53 io-hp kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 28 13:20:53 io-hp kernel: usb usb3: Product: EHCI Host Controller
Sep 28 13:20:53 io-hp kernel: usb usb3: Manufacturer: Linux 5.4.64-1-MANJARO ehci_hcd
Sep 28 13:20:53 io-hp kernel: usb usb3: SerialNumber: 0000:00:13.0
Sep 28 13:20:53 io-hp kernel: hub 3-0:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 3-0:1.0: 2 ports detected
Sep 28 13:20:53 io-hp kernel: scsi host0: ahci
Sep 28 13:20:53 io-hp kernel: scsi host1: ahci
Sep 28 13:20:53 io-hp kernel: ata1: SATA max UDMA/133 abar m1024@0xf0d6f000 port 0xf0d6f100 irq 19
Sep 28 13:20:53 io-hp kernel: ata2: SATA max UDMA/133 abar m1024@0xf0d6f000 port 0xf0d6f180 irq 19
Sep 28 13:20:53 io-hp kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
Sep 28 13:20:53 io-hp kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
Sep 28 13:20:53 io-hp kernel: usb 2-1: new high-speed USB device number 2 using xhci_hcd
Sep 28 13:20:53 io-hp kernel: usb 3-1: new high-speed USB device number 2 using ehci-pci
Sep 28 13:20:53 io-hp kernel: usb 2-1: New USB device found, idVendor=0781, idProduct=5567, bcdDevice= 1.00
Sep 28 13:20:53 io-hp kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 28 13:20:53 io-hp kernel: usb 2-1: Product: Cruzer Blade
Sep 28 13:20:53 io-hp kernel: usb 2-1: Manufacturer: SanDisk
Sep 28 13:20:53 io-hp kernel: usb 2-1: SerialNumber: 4C530000220620210592
Sep 28 13:20:53 io-hp kernel: usb 1-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
Sep 28 13:20:53 io-hp kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 28 13:20:53 io-hp kernel: hub 1-1:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 1-1:1.0: 4 ports detected
Sep 28 13:20:53 io-hp kernel: usb-storage 2-1:1.0: USB Mass Storage device detected
Sep 28 13:20:53 io-hp kernel: scsi host2: usb-storage 2-1:1.0
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver usb-storage
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver uas
Sep 28 13:20:53 io-hp kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Sep 28 13:20:53 io-hp kernel: usb 3-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
Sep 28 13:20:53 io-hp kernel: usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 28 13:20:53 io-hp kernel: hub 3-1:1.0: USB hub found
Sep 28 13:20:53 io-hp kernel: hub 3-1:1.0: 4 ports detected
Sep 28 13:20:53 io-hp kernel: ata1.00: ATA-10: SAMSUNG MZNTY256HDHP-000H1, MAT21H3Q, max UDMA/100
Sep 28 13:20:53 io-hp kernel: ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
Sep 28 13:20:53 io-hp kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Sep 28 13:20:53 io-hp kernel: ata1.00: configured for UDMA/100
Sep 28 13:20:53 io-hp kernel: scsi 0:0:0:0: Direct-Access ATA SAMSUNG MZNTY256 1H3Q PQ: 0 ANSI: 5
Sep 28 13:20:53 io-hp kernel: ata2.00: ATAPI: hp DVDRW GUD1N, MD00, max UDMA/133
Sep 28 13:20:53 io-hp kernel: ata2.00: configured for UDMA/133
Sep 28 13:20:53 io-hp kernel: scsi 1:0:0:0: CD-ROM hp DVDRW GUD1N MD00 PQ: 0 ANSI: 5
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] Write Protect is off
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 13:20:53 io-hp kernel: sda: sda1 sda2 sda3 sda4
Sep 28 13:20:53 io-hp kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Sep 28 13:20:53 io-hp kernel: usb 2-2: new high-speed USB device number 3 using xhci_hcd
Sep 28 13:20:53 io-hp kernel: sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Sep 28 13:20:53 io-hp kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Sep 28 13:20:53 io-hp kernel: tsc: Refined TSC clocksource calibration: 1996.256 MHz
Sep 28 13:20:53 io-hp kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x398cbb98ce6, max_idle_ns: 881590701561 ns
Sep 28 13:20:53 io-hp kernel: sr 1:0:0:0: Attached scsi CD-ROM sr0
Sep 28 13:20:53 io-hp kernel: random: fast init done
Sep 28 13:20:53 io-hp kernel: usb 2-2: New USB device found, idVendor=043e, idProduct=70f5, bcdDevice= 1.00
Sep 28 13:20:53 io-hp kernel: usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Sep 28 13:20:53 io-hp kernel: usb 2-2: Product: LG External HDD
Sep 28 13:20:53 io-hp kernel: usb 2-2: Manufacturer: LG Electronics Inc.
Sep 28 13:20:53 io-hp kernel: usb 2-2: SerialNumber: A31103000009
Sep 28 13:20:53 io-hp kernel: usb-storage 2-2:1.0: USB Mass Storage device detected
Sep 28 13:20:53 io-hp kernel: scsi host3: usb-storage 2-2:1.0
Sep 28 13:20:53 io-hp kernel: usb 1-1.1: new full-speed USB device number 3 using ehci-pci
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: new high-speed USB device number 3 using ehci-pci
Sep 28 13:20:53 io-hp kernel: usb 1-1.1: New USB device found, idVendor=3938, idProduct=1031, bcdDevice= 1.08
Sep 28 13:20:53 io-hp kernel: usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 28 13:20:53 io-hp kernel: usb 1-1.1: Product: 2.4G Wireless Mouse
Sep 28 13:20:53 io-hp kernel: usb 1-1.1: Manufacturer: MOSART Semi.
Sep 28 13:20:53 io-hp kernel: hidraw: raw HID events driver (C) Jiri Kosina
Sep 28 13:20:53 io-hp kernel: usbcore: registered new interface driver usbhid
Sep 28 13:20:53 io-hp kernel: usbhid: USB HID core driver
Sep 28 13:20:53 io-hp kernel: input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:3938:1031.0001/input/input6
Sep 28 13:20:53 io-hp kernel: input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:3938:1031.0001/input/input7
Sep 28 13:20:53 io-hp kernel: hid-generic 0003:3938:1031.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:12.0-1.1/input0
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: New USB device found, idVendor=0c45, idProduct=651b, bcdDevice= 0.02
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: Product: HP Webcam
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: Manufacturer: DEYXL019I30ORC
Sep 28 13:20:53 io-hp kernel: usb 3-1.1: SerialNumber: HP Webcam
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: new full-speed USB device number 4 using ehci-pci
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: New USB device found, idVendor=0bda, idProduct=b008, bcdDevice= 2.00
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: Product: Bluetooth Radio
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: Manufacturer: Realtek
Sep 28 13:20:53 io-hp kernel: usb 1-1.4: SerialNumber: 00e04c000001
Sep 28 13:20:53 io-hp kernel: random: crng init done
Sep 28 13:20:53 io-hp kernel: scsi 2:0:0:0: Direct-Access SanDisk Cruzer Blade 1.00 PQ: 0 ANSI: 6
Sep 28 13:20:53 io-hp kernel: sd 2:0:0:0: [sdb] 240451584 512-byte logical blocks: (123 GB/115 GiB)
Sep 28 13:20:53 io-hp kernel: sd 2:0:0:0: [sdb] Write Protect is off
Sep 28 13:20:53 io-hp kernel: sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00
Sep 28 13:20:53 io-hp kernel: sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Sep 28 13:20:53 io-hp kernel: sdb: sdb1
