Grub not updated after system update
pamac does not run grub-mkconfig after system update. i have to execute it manually. where to find the cause and solution?
Prove?
grep "2024-10-10" /var/log/pacman.log
update-grub is not installed, which contains also 99-update-grub.hook for pacman/pamac. Too much cleanup?
Hi @m4jq,
To have it run manually magically, install the Manjaro-made install-grub package from the core repository:
pamac install install-grub
its already installed
Preparation…
Note: install-grub-2.12-5 is in the latest version – skip
There is nothing to do.
Operation successfully completed.
That’s not
:wink:
Please provide the output of:
file $(pamac list -f install-grub)
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
updating the already installed grub’s configuration, and upgrading grub itself are two separate things. Hooks to update its config are already there, otherwise you wouldn’t be able to reboot to the updated kernel. See this for more clarity - Confused about re-installation of grub bootloader - #3 by GeorgeB
I know. Wasn’t even slightly referring to it.
thx! it works!
Any sufficiently under-explained Linux is indistinguishable from magic
Spoiler
$ cat /usr/share/libalpm/hooks/98-install-grub.hook
[Trigger]
Type = Package
Operation = Upgrade
Target = grub
[Action]
Description = Installing Grub to MBR/EFI
When = PostTransaction
Exec = /usr/bin/install-grub
Recent Manjaro ISOs (since 24.0.5) include both update-grub and install-grub
Earlier ISOs included update-grub only
Anyone who is rolling a Manjaro install from an earlier ISO can install install-grub
Below are install-grub and update-grub why are thy not the same?
[robin0800@robins-desktop ~]$ cat /usr/share/libalpm/hooks/98-install-grub.hook
[Trigger]
Type = Package
Operation = Upgrade
Target = grub
[Action]
[robin0800@robins-desktop ~]$ cat /usr/share/libalpm/hooks/99-update-grub.hook
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Operation = Remove
Target = usr/lib/modules//vmlinuz
Target = boot/vmlinuz
[Action]
Description = Updating Grub-Bootmenu
Exec = /usr/bin/update-grub
This one:
…simply updates your grub menu when a new kernel is installed. And this one:
Causes grub to be reinstalled on your MBR/EFI when it gets updated.
