Hi everyone !
Starting on my computer as everyday, I get my greeter screen to login in my session. I write the password, which is good (I get a confirmation message), then black screen (as usual), and instead of arriving on my desktop I come back on the greeter page…
As well as I installed the lightdm-webkit2-greeter theme, I accessed to the tty to switch on the lightdm-gtk-greeter theme through the lightdm.conf file. It doesn’t change anything. I then tried to update my computer, nothing changed.
Last time I accessed to my session, I only updated Thunderbird, that’s all.
I searched on forums, but I did not found the same issue. So I ask for your help guys ! Thanks !
EDIT : Next to Fabby answer (thanks a lot !), I created another user (called primavalou2 to stay accurate with your proposal), then I tried logging into the GUI with that one, and I could access to the session ! I then tried again with my original session but it still doesn’t work.
As you asked for, here is my inxi output :
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a40fc586-5371-4b6e-baa7-0fae6eaddeea rw quiet
cryptdevice=UUID=5a520a86-b112-4ddb-928a-bc8773e8ca3d:luks-5a520a86-b112-4ddb-928a-bc8773e8ca3d
root=/dev/mapper/luks-5a520a86-b112-4ddb-928a-bc8773e8ca3d apparmor=1
security=apparmor
resume=/dev/mapper/luks-27380bc8-b40a-4238-a301-a1b369044eda
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Micro-Star product: GE60 0NC/GE60 0ND v: REV:1.0
serial: <filter> Chassis: Micro-Star International type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16GA v: REV:1.0 serial: <filter>
BIOS: American Megatrends v: E16GAIMS.10F date: 12/18/2012
ID-1: BAT1 charge: 15.6 Wh (69.3%) condition: 22.5/48.8 Wh (46.0%)
volts: 11.3 min: 11.1 model: NEC PC-VP-BP77 type: Li-ion serial: N/A
status: Discharging
RAM: total: 7.67 GiB used: 2.13 GiB (27.8%)
Info: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 20761
Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1905
3: 1891 4: 1197
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fd1 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: c000 bus-ID: 03:00.0
chip-ID: 1969:e091 class-ID: 0200
Device-2: Intel Centrino Wireless-N 135 driver: iwlwifi v: kernel port: c000
bus-ID: 05:00.0 chip-ID: 8086:0892 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-1: luks-5a520a86-b112-4ddb-928a-bc8773e8ca3d maj-min: 254:0
type: LUKS dm: dm-0 size: 457.53 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 457.53 GiB
Device-2: luks-27380bc8-b40a-4238-a301-a1b369044eda maj-min: 254:1
type: LUKS dm: dm-1 size: 8.23 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 8.23 GiB
Local Storage: total: 465.76 GiB used: 291.16 GiB (62.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPVX-22V0TT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208DB rev: TM00
dev-links: cdrom
ID-1: / raw-size: 457.53 GiB size: 449.27 GiB (98.20%)
used: 291.16 GiB (64.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5a520a86-b112-4ddb-928a-bc8773e8ca3d label: N/A
uuid: a40fc586-5371-4b6e-baa7-0fae6eaddeea
ID-1: swap-1 type: partition size: 8.23 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-27380bc8-b40a-4238-a301-a1b369044eda label: N/A
uuid: 1702c0e3-17a3-486b-b44a-ab154bdc2ddd
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 29.0 C
Processes: 210 Uptime: 6m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1236 pacman: 1226 lib: 338 flatpak: 6
snap: 4 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
If you need more info / log files / anything else to diagnose the issue, feel free to ask !
to give us more information so we can see what’s really going on.
this message and I’ll come back and have another look.
