Got this error while trying to install from the gnome development ISO with encrypted drive and btrfs.
Welcome to Manjaro!
- Please read this:
How to provide good information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
exact iso name ?
and you can paste here calamares logs /root/.cache/calamares/session.log
Tried with the manjaro-gnome-21.08-development-210810-linux510.iso.zip iso from here:
Also the one from:
Don’t have any more logs since I used the one from Manjaro - Gnome in the end as I was in a hurry.
inxi:
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e456d97d-a0b6-496d-8218-33fa1e3a30ba rw quiet
cryptdevice=UUID=79735e42-7ad3-4840-ab29-b57a2566333c:luks-79735e42-7ad3-4840-ab29-b57a2566333c
root=/dev/mapper/luks-79735e42-7ad3-4840-ab29-b57a2566333c splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: HP product: HP EliteBook 755 G5 v: DBXEnabled
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83D5 v: KBC Version 08.5E.00 serial: <filter> UEFI: HP
v: Q81 Ver. 01.15.00 date: 12/29/2020
ID-1: BAT0 charge: 42.0 Wh (100.0%) condition: 42.0/56.3 Wh (74.7%)
volts: 13.0 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full cycles: 197
RAM: total: 30.31 GiB used: 2.37 GiB (7.8%)
Info: Quad Core model: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101016 cache: L2: 2 MiB bogomips: 35148
Speed: 1223 MHz min/max: 1600/2200 MHz boost: enabled Core speeds (MHz):
1: 1223 2: 1210 3: 1216 4: 1224 5: 1460 6: 1205 7: 1249 8: 1371
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 4-2:3
chip-ID: 04f2:b5ee class-ID: 0e02
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.41.0
5.13.8-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel modules: r8168 port: 3300
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 4-1.1:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-79735e42-7ad3-4840-ab29-b57a2566333c maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 97.7 GiB (10.5%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
used: 97.7 GiB (10.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-79735e42-7ad3-4840-ab29-b57a2566333c label: N/A
uuid: e456d97d-a0b6-496d-8218-33fa1e3a30ba
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 6570-CB4E
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 4-1.1:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 4-1.3:5 info: Validity Sensors type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:00ab
class-ID: ff00 serial: <filter>
Device-3: 4-2:3 info: Chicony HP HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5ee
class-ID: 0e02
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.8 C mobo: 30.0 C gpu: amdgpu temp: 52.0 C
Processes: 301 Uptime: 42m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1441 pacman: 1421 lib: 337
flatpak: 6 snap: 14 Shell: Bash v: 5.1.8 running-in: tmux: inxi: 3.3.06
That’s the development release… Are you a developer?
- If yes: You should know that to do now
- If no: Take the stable releases from the Manjaro Download page
My aim was to have a fresh install with btrfs and encryption activated and the stable ISOs don’t provide that yet.
But don’t worry, you’ve convinced me to never report bugs anymore on the forums as they get discarded.
Correct: Bug reports should be filed against their respective repositories, not on the forum.
For more information, please read this:
Especially the section What’s this upstream/downstream business?
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
