I have recently done the switch to Manjaro (with Gnome environment). Ever since first booting it after installation, I’ve been having this same issue where it will boot, progress past the Manjaro bootsplash and open a blank Gnome login page. I say blank because there are no options for users, even though I can still see the date and time at the top as well as other options for volume, shut down etc.
Usually around 3 times after turning the computer off and on again it will work, but I just figured out an easier workaround which is to select the option to suspend from the options that are visible on the top of the login page and then turn the computer on again, which will then show a proper login page with my user account where I can then enter my password and log in.
I’ve seen similar issues discussed on the forum being solved by opening and closing a TTY or passing certain commands on a TTY, but none of the ctrl+alt+f keys command work, thet only stop the cursor from moving until I click ctrl+alt+f1 (which I suppose is the command to exit from tty?).
I have already researched this issue throughout the forum for many hours in the last three days and tried various solutions in the past few days. My latest attempt has been to simply reinstall the OS from a live USB, but the issue is still present. Normally I would just go to a different OS because this is an extraordinary level of effort for fixing an OS I have not committed to, but I feel it is worth it, because so far I have liked all other aspects of Manjaro
This is my first time posting here, so please let me know if there are additional informations I should provide to help solve this issue.
Thanks in advance
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=f8057430-ac2b-4bcf-85ca-31153e1737bf rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=5b7f731b-fe5c-4b32-b26a-946eff42a200 udev.log_priority=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: ASUSTeK product: X555LB v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X555LB v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X555LB.505 date: 08/24/2015
ID-1: BAT0 charge: 24.8 Wh (97.6%) condition: 25.4/37.3 Wh (68.1%)
volts: 7.5 min: 7.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 1258
RAM: total: 7.67 GiB used: 3.16 GiB (41.3%)
RAM Report:
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1221 high: 2197 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 1090
4: 2197 bogomips: 17580
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: ASUSTeK driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 04:00.0 chip-ID: 10de:1347
class-ID: 0302
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-6:6 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 223.57 GiB used: 10.08 GiB (4.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: AS01
dev-links: cdrom
ID-1: / raw-size: 60.55 GiB size: 60.55 GiB (100.00%) used: 9.05 GiB (15.0%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: f8057430-ac2b-4bcf-85ca-31153e1737bf
used: 568 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 43DB-4469
ID-3: /home raw-size: 158.51 GiB size: 158.51 GiB (100.00%)
used: 1.03 GiB (0.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: e6d907b4-3079-45ab-9ada-87add3b18099
ID-4: /var/cache raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
used: 9.05 GiB (15.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
ID-5: /var/log raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 5b7f731b-fe5c-4b32-b26a-946eff42a200
ID-1: /dev/sda5 maj-min: 8:5 size: 8.6 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 1-6:6 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-8:7 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C pch: 49.5 C mobo: N/A
Fan Speeds (RPM): cpu: 3200
Processes: 280 Uptime: 18m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1152 lib: 309 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.11
