Im running XFCE and every time I try to open up a steam game it just crashes with no error message, no new window opening, nothing, unless it’s a linux native game, in which case it works just fine. This problem is only happening on games using Proton. I’m pretty sure that I need to generate a crash log so that you guys can have some actual usable information, but I honestly don’t know how, I’m super new to Linux.
Hello @ondlad and welcome
Just point you in a direction: Proton uses Vulkan and DXVK/VKD3D as translation layer for directx9/10/11/12 … therefore keep sure that your GPU is vulkan capable and vulkan library is installed.
Hello @ondlad,
if you want to get a log start your steam-client from terminal.
I’ve got the crash logs, here they are.
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
wine: Unhandled page fault on execute access to 00007F994A02A3C0 at address 00007F994A02A3C0 (thread 00cc), starting debugger...
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to SynchronizingControllerConfig with ""
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1713610, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1713610, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/myuser/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1713610 -- '/home/myuser/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myuser/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/myuser/.local/share/Steam/steamapps/common/Purrgatory/purrgatory.exe' MESA_GLSL_VERSION_OVERRIDE=410\0
Game process added : AppID 1713610 "/home/myuser/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1713610 -- '/home/myuser/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myuser/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/myuser/.local/share/Steam/steamapps/common/Purrgatory/purrgatory.exe' MESA_GLSL_VERSION_OVERRIDE=410", ProcID 4155, IP 0.0.0.0:0
chdir /home/myuser/.local/share/Steam/steamapps/common/Purrgatory
ERROR: ld.so: object '/home/myuser/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 1713610, ActionID 2] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/myuser/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 4159 != 4156, skipping destruction (fork without exec?)
ThreadGetProcessExitCode: no such process 4270
ThreadGetProcessExitCode: no such process 4268
ThreadGetProcessExitCode: no such process 4157
Game process updated : AppID 1713610 "/home/myuser/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1713610 -- '/home/myuser/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myuser/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/homemyuser/.local/share/Steam/steamapps/common/Purrgatory/purrgatory.exe' MESA_GLSL_VERSION_OVERRIDE=410", ProcID 4269, IP 0.0.0.0:0
Setting breakpad minidump AppID = 1713610
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198190051463 [API loaded no]
*** MESA_GLSL_CACHE_DIR is deprecated; use MESA_SHADER_CACHE_DIR instead ***
*** MESA_GLSL_CACHE_MAX_SIZE is deprecated; use MESA_SHADER_CACHE_MAX_SIZE instead ***
wine: Unhandled page fault on execute access to 00007F33E05F13C0 at address 00007F33E05F13C0 (thread 00c8), starting debugger...
wine: Unhandled page fault on execute access to 00007F7294B4D690 at address 00007F7294B4D690 (thread 00d4), starting debugger...
ThreadGetProcessExitCode: no such process 4273
ThreadGetProcessExitCode: no such process 4328
ThreadGetProcessExitCode: no such process 4310
ThreadGetProcessExitCode: no such process 4304
ThreadGetProcessExitCode: no such process 4298
ThreadGetProcessExitCode: no such process 4278
ThreadGetProcessExitCode: no such process 4275
ThreadGetProcessExitCode: no such process 4267
pid 4271 != 4270, skipping destruction (fork without exec?)
Game process removed: AppID 1713610 "/home/myuser/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1713610 -- '/home/myuser/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myuser/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/myuser/.local/share/Steam/steamapps/common/Purrgatory/purrgatory.exe' MESA_GLSL_VERSION_OVERRIDE=410", ProcID 4269
ThreadGetProcessExitCode: no such process 4286
ThreadGetProcessExitCode: no such process 4269
ThreadGetProcessExitCode: no such process 4156
Game 1713610 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 1713610 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 1713610 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 1713610 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 1713610 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 1713610 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 1713610 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 1713610 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 1713610 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 1713610 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 1713610 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 1713610 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 1713610 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 1713610 created interface SteamController006 / Controller
Game 1713610 created interface SteamFriends015 / Friends
Game 1713610 created interface SteamMatchMaking009 / Matchmaking
Game 1713610 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 1713610 created interface SteamNetworking005 / Networking
Game 1713610 created interface SteamUser019 / User
Game 1713610 created interface SteamUtils009 / Utils
Game 1713610 method call count for IClientAppManager::GetAppInstallState : 2
Game 1713610 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 1713610 method call count for IClientUtils::GetSteamUILanguage : 1
Game 1713610 method call count for IClientUtils::GetAppID : 24
Game 1713610 method call count for IClientUser::GetSteamID : 1
Uploaded AppInterfaceStats to Steam
Hello @ondlad,
Proton DB says “Purrgatory” should run.
The ld.so-Error is normal and could be ignored.
The main fault here I think its a driver problem so that we have to know more about your machine. Please go through these link [HowTo] Provide System Information and provide 'inxi output".
Alright, here’s the inxi output.
Thanks for being so patient with me btw.
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=e4ad1068-6d6b-4f02-a068-e2ee7d48c741 rw quiet
resume=UUID=cbdc6c6e-781b-4ed9-8a04-db72c652d804 udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QM_GA401QM
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA401QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA401QM.410 date: 12/13/2021
ID-1: BAT0 charge: 46.1 Wh (64.0%) condition: 72.0/76.0 Wh (94.8%)
volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging
RAM: total: 15.04 GiB used: 3.38 GiB (22.5%)
RAM Report:
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1398 high: 2985 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1350 2: 1237
3: 2441 4: 1196 5: 1197 6: 1197 7: 1197 8: 1197 9: 1198 10: 1197 11: 1198
12: 1197 13: 1197 14: 1197 15: 1197 16: 2985 bogomips: 105440
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp LQ140M1JW49 built: 2020 res: 1920x1080
hz: 144 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.55-1-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 53.18 GiB (5.6%)
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
rev: FXM7201Q temp: 28.9 C scheme: GPT
ID-1: / raw-size: 576.17 GiB size: 566.06 GiB (98.24%)
used: 53.18 GiB (9.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: e4ad1068-6d6b-4f02-a068-e2ee7d48c741
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
label: NO_LABEL uuid: DC4D-90AE
ID-1: swap-1 type: partition size: 9.47 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: cbdc6c6e-781b-4ed9-8a04-db72c652d804
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: 2EB9-DD46
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 347.33 GiB fs: ntfs label: OS
uuid: 24245B37245B0AE6
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
uuid: E2CA8B9BCA8B6B1D
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 19.5 GiB fs: ntfs label: RESTORE
uuid: 88BA2079BA206642
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 200 MiB fs: vfat label: MYASUS
uuid: 7420-BE8A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-1:5
info: Razer USA RC30-0305 Gaming Mouse Dongle [Viper Ultimate (Wireless)]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:007b class-ID: 0300
Device-2: 1-3:3 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:521d class-ID: ff00
Device-2: 3-4:3 info: IMC Networks Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 367 Uptime: 2h 23m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1093 lib: 390 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
Ok, seems to be your machine is a Laptop with two GPUs and it could be the games uses the false GPU/driver.
My experiences of this topic are very small but perhals another one knows more.
Please post the output of these 2 commands:
mhwd -li
mhwd -l
With these we (and you) see which drivers are installed on your system and which are available for your system.
For systems with two GPUs (often Laptops) are hybrid drivers available.
Okay, here’s the output of
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
and here’s the output of
mhwd -l
0000:01:00.0 (0300:10de:2520) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
Ok, there are drivers installed. I dont know if ‘video-linux’ is needed on your system. Because I have no experience with these (2 gpu) systems.
Megavolt prove me wrong/text only for non steam games
Dieser Text wird ausgeblendet
First I want to ask if you have checked @megavolt’s comment that ‘dxvk’ is installed?
pamac search -i dxvk
Should bring any output! If not you have to install it with these command:
pamac install dxvk-bin
If you need to install it try after install to run the game.
If it is still installed please open ‘steam’ and go to the properties of your game. Now add the following line to the ‘Launch Options’ in the ‘General’-Tab and try to start the game.
prime-run %command%
If it didn’t start at this point I guess the ‘video-linux’ driver could be the problem.
DXVK is included in PROTON
That’s what I mean:
pamac list --installed | grep "vulkan"
pamac search "vulkan" --no-aur
This absolutely needed since it contains the amdgpu driver.
Some Windows Games have indeed problems here… prime-run
will call the nvidia gpu then for acceleration
What makes me think is why you @ondlad have set this?
About this command line,
It was just from some random “solution” i found online, but it did nothing for me and I suppose I forgot to take it out of pre-launch settings.
Well for me it just works:
I choose proton-experimental
But however… it runs in OpenGL, and prime-run seems not to work… hm have to investigate it.
Trying to use pamac to install dxvk-bin is giving me this:
Error: target not found: dxvk-bin
As for:
prime-run %command%
Same thing appears to be happening, crash logs also appear to be the same.
Weird, I’ll try out experimental
Edit: Experimental didn’t work, was worth a shot I suppose
Flatpak version of steam perhaps? The flatpak sandbox can produce such issues on hybrid gpus.
So try the native version.
At least what I can say: It is a pure OpenGL Game for Windows, so no DirectX or Vulkan needed.
I’m on the native version, using Purrgatory as an example game because it’s free and is really small, but the same thing is happening with DirectX games (SCP: Pandemic) and Vulkan games (Devil May Cry 5)
Then lets go a bit lower level. Test this:
glxinfo | grep "OpenGL renderer"
prime-run glxinfo | grep "OpenGL renderer"
glxgears
prime-run glxgears
vulkan-info | egrep "^GPU id"
vkcube
prime-run vkcube
The OpenGL test seems to work just fine, but the output for vkcube looks like this:
bash: vulkan-info: command not found
bash: vkcube: command not found
/usr/bin/prime-run: line 2: vkcube: command not found
Edit: As a side note, I installed Flatpak Steam to see if anything would be different, but it isn’t.
Did you try steam-runtime? I feel the steam-native is always troublesome.
Oh, that means it is not installed…
pamac install vulkan-tools
