hello im running manjaro 6.1 kde, i have a gtx 1650ti, and i use the video-hybrid-intel-nvidia driver. i have installed cuda, although im not sure if it’s that causing my issues. but booting up a game results in an instant system freeze/crash. i also have linux61-nvidia installed to further aid. are there missing packages im needing to make my system work? or do i have the wrong things installed, if thats not enough info please comment.
Welcome to the forum! ![]()
What games are you having issues with? Are you using Steam?
Please post your system info as outlined here:
FYI, CUDA has nothing to do with games. The installation is also well over 1.5GB, so I would remove it if nothing requires it.
it is steam i am using, half life 2 is one of the games i am having issues with.
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=958ab089-06d7-47ad-a378-0ec1a3c16f3d rw quiet splash
resume=UUID=e1f9f035-d05a-45c6-9c34-14cf742452c2 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-55 v: V2.06
serial: <superuser required>
Mobo: CML model: Stonic_CMS v: V2.06 serial: <superuser required>
UEFI: Insyde v: 2.06 date: 08/19/2021
ID-1: BAT1 charge: 47.4 Wh (100.0%) condition: 47.4/57.5 Wh (82.5%)
volts: 16.6 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: full
RAM: total: 11.52 GiB used: 3.13 GiB (27.2%)
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2077 high: 2500 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 822 2: 2500 3: 800 4: 2500
5: 2500 6: 2500 7: 2500 8: 2500 bogomips: 40009
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: vesa
alternate: fbdev,nouveau,nv dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 238.47 GiB used: 77.16 GiB (32.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1014 size: 238.47 GiB block-size: physical: 512 B
rev: 21103900 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 77.16 GiB (34.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 958ab089-06d7-47ad-a378-0ec1a3c16f3d
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 03A3-F3BE
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e1f9f035-d05a-45c6-9c34-14cf742452c2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: Logitech G402 Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-2: 1-5:3 info: Chicony HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b64f
Device-3: 1-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C pch: 47.0 C mobo: N/A
Processes: 239 Uptime: 16m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1208 libs: 338 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Half-Life 2 can be played on a wee Intel Atom netbook–I did it. ![]()
Please run Steam from the terminal with the following command. it will upload the output to 0x0.st and display the link after. Please post the link here.
steam-runtime | curl -F 'file=@-' 0x0.st
i know that, but other source/goldsrc games are being that way. i got the problem fixed for a minute like 4 hours ago, and then i accidentally screwed it all over. i removed cuda aswell.
Moderator edit: Fixed link
Sorry, I should have said, “Please run Steam from the terminal with the following command, start Half-Life 2, wait for it to crash, then exit Steam.”
Now the output should yield something useful. ![]()
FYI, I edited your link above so now it’s clickable. I know new users aren’t allowed to post links, just don’t put them in parenthesis–it can’t even be copied that way.
i cant do that. when the game crashes, the entire system crashes. i feel like its a driver issue more than anything.
i cannot get the output, because when i do it, a few minutes in the entire system crashes. unless its my drivers, which ive tried configuring multiple amount of times, are not working. i
I had a similar problem when I bought myself this one 2080 from Asus rankquality. com/en/asus-geforce-turbo-rtx-2080-ti/ you know, it was solved quite simply that the old drivers were not completely uninstalled, due to which the new ones could not be put. Maybe you also have some kind of error associated with it, just try uninstalling all your drivers, then put a new one, maybe it will help you
