No they, do not reappear
you have these:
org.kde.plasma.pulseaudio: context kaput
post output from:
pacman -Qs 'pulse|pipewire'
Yeah, I noticed them too and am searching at the moment.
pacman
local/gst-plugin-pipewire 1:0.3.56-1
Multimedia graph framework - pipewire plugin
local/lib32-libcanberra 1:0.30+r2+gc0620e4-1
A small and lightweight implementation of the XDG Sound Theme Specification (32-bit)
local/lib32-libpulse 16.1-1
A featureful, general-purpose sound server (32-bit client libraries)
local/libcanberra 1:0.30+r2+gc0620e4-1
local/libpulse 16.1-1
A featureful, general-purpose sound server (client library)
local/manjaro-pipewire 20220217-2
Manjaro meta package for complete PipeWire support.
local/pipewire 1:0.3.56-1
Low-latency audio/video router and processor
local/pipewire-alsa 1:0.3.56-1.0
Low-latency audio/video router and processor - ALSA configuration
local/pipewire-jack 1:0.3.56-1.0
Low-latency audio/video router and processor - JACK support
local/pipewire-media-session 1:0.4.1-2
Example session manager for PipeWire
local/pipewire-pulse 1:0.3.56-1.0
Low-latency audio/video router and processor - PulseAudio replacement
local/pipewire-v4l2 1:0.3.56-1
Low-latency audio/video router and processor - V4L2 interceptor
local/pipewire-zeroconf 1:0.3.56-1
Low-latency audio/video router and processor - Zeroconf support
local/plasma-pa 5.24.6-1 (plasma)
Plasma applet for audio volume management using PulseAudio
local/pulseaudio-alsa 1:1.2.7.1-1
ALSA Configuration for PulseAudio
local/pulseaudio-ctl 1.70-1
Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
local/pulseaudio-qt 1.3-1
Qt bindings for libpulse
Is Jack or v4l2 the problem. I installed them somewhat automatically, and will not do so anymore.
remove the pulse leftovers:
pamac remove pulseaudio-alsa pulseaudio-ctl pulseaudio-qt
and you didnt installed wireplumber but pipewire media session, so install wireplumber:
pamac install wireplumber
it will remove the pipewire session, then reboot
That did the trick. I think it was the leftovers though. In all previous installations I always installed wireplumber as well
so now you dont have any freezes and audio is working?
The audio is working. Firefox froze once at each startup for the last 3 or so boots, but worked nicely afterwards. I did not check video players and strawberry yet. Be back in a moment
you have in logs again the coredump, so maybe removing the libva-vdpau-driver
and lib32-libva-vdpau-driver
may be needed …
but first check the other programs …
Yeah they(VLC, MPC) do. but only with bigger files. VLC just takes long to start, and works afterwards(at least with time jumps). MPV same as VLC, but takes a second or so with time jumps.
MPC does not start playing at all but I can still click things
It does not seem to matter, wether or not the file is on the NVME or an external disk
And Firefox has a freeze just now as well
It all feels like there is very much caching going on somewhere
Probably caching is the wrong word
did you tested all of this on a fresh install before running any update?
booting into linux mint live usb session, and installing vlc/mpv and test in the live session if it there happens too
Sorry no I did not, give me a few
before that though, another topic in the forum caught my eye (Manjaro is lagging & Freezing) and reminded me that I did not setup swap yet either. I did so now, but before I rebooted I took a look at htop. There it said that my RAM was completely full with caching data. This should not be possible, right. I hav 32GB of RAM, so there was at least 28 GB of Caching Data
I tried first with manjaro live, since I had to download mint.
I had no audio, and the starting time was noticable but still faster than on the install.
On Mint I still have no sound!?!!? But starting a video was instantaneous.
I am gonna try live manjaro gnome now, if the issue does not persist I will install and check again. Will probably try KDE in a few months again, but I am beginning to need a working computer again
Edit
Gnome live works fine. Installing now.
Edit 2
Gnome installed. But no audio in settings and from gnome. Still have to test aplay.
Should I open another topic?
that ram usage is not normal … what process was using it? maybe baloo?
no freezes in gnome?
you can switch to pipewire+wireplumber and see if that fixes the audio
no freezes in gnome, but absolutely no audio either, am installing KDE again
Will have to use the laptop for studying, until this is fixed
I have already tried that and rebooted.
Unfortunately I did not note, what the program was. What is baloo, it is at least no a command that is installed on kde
but audio worked before, why its not working anymore…
balloo is a indexer which is known for causing this exact freeze issue … but since the freezes happened also on gnome before you installed kde, it may not be related to it …
you can disable baloo from system settings/search/file search and uncheck all the options, click apply
