we dont know if those are responsible for the freezes, thats why the backup …
and if they are, you dont update them only till the next system update, which hopefully will have fixed the issue …
there is nothing that depends on kernel 5.15.60-1 and not on 5.15.60-0 so dont worry about that
Ahh, alright then. THX
I just booted(after a reinstall and snapshots), and synced my firefox settings. That’s when firefox froze first. I removed the vdpau packages rebooted and now I don’t have any audio devices anymore in Plasma, though the settings see them and I can play sound. I did not upgrade anything. I installed mpc-qt and did an automatic upgrade and that at least changed nothing. Will try again without syncing Firefox.
journalctl for the audio devices says:
Sep 01 12:43:28 man-jon-desk systemsettings[6359]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-Lautsprecher_Teufel_GmbH_Teufel_CINEBAR_ONE_ABCDEF0123456789-00.analog-stereo"
Sep 01 12:43:28 man-jon-desk systemsettings[6359]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-Blue_Microphones_Yeti_Stereo_Microphone_RKV8-00.analog-stereo"
Though that’s of course probably not our main issue
install the vdpau packages back, reboot, and see if the audio is restored …
you should have not remove the packages, they were not the reason for the freezes …
did you create a backup of the fresh install?
is firefox working normally without syncing?
did you run a system update with blacklisted kernel + nvidia?
- alright, I’ll try
- Whoops, hadn’t grasped that.
- Yes I did
- It was, I’ll try with a new profile
- I did yesterday and it changed nothing. I blacklisted them today as well(no backup yesterday) and while installing it should have done an upgrade as well, but I’ll do one manually.
- The audio is not restored
- It seems to work normally again
- The system was fully updated
so the system is up to date with blacklisted kernel + nvidia and is working without freezes?
Yes, I’d think it does
so the only think thats now the issue is the audio?
That’s correct. I may not be confident, that it remains that way, but for the moment it is
the audio was working normally before removing the vdpau?
It was
try replacing pulse with pipewire:
pamac install manjaro-pipewire
it will give you pulse dependency issues, so remove them first then run the isntall command again, and select wireplumber when prompted, then reboot and check audio
I like it more anyway, so gladly
It did not fix the audio issue though
the only issue is that the devices are not detected? but the audio works normally?
Not anymore, the devices do not appear in the settings either, though that was before I installed pipewire as well. Sorry, I did not already tell you
if you disconnect/reconnect them again, do they appear?
if not provide logs:
sudo dmesg -l err,warn,emerg,alert,crit
journalctl -b0 -p4 --no-pager
dmesg
[ 0.140123] #9 #10 #11 #12 #13 #14 #15
[ 0.236351] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 0.242310] nvme nvme1: missing or invalid SUBNQN field.
[ 0.716489] ata1.00: supports DRM functions and may not be fully accessible
[ 0.719085] ata1.00: supports DRM functions and may not be fully accessible
[ 1.190619] ata2.00: supports DRM functions and may not be fully accessible
[ 1.193890] ata2.00: supports DRM functions and may not be fully accessible
[ 3.170261] ata6: failed to resume link (SControl 0)
[ 5.015326] sd 6:0:0:0: [sdc] No Caching mode page found
[ 5.015327] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[ 7.870112] sd 7:0:0:0: [sdd] No Caching mode page found
[ 7.870116] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[ 8.789667] nvidia: loading out-of-tree module taints kernel.
[ 8.789673] nvidia: module license 'NVIDIA' taints kernel.
[ 8.789674] Disabling lock debugging due to kernel taint
[ 8.869362] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 9.623810] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 11.050038] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 16.056988] kauditd_printk_skb: 49 callbacks suppressed
[ 16.240977] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 21.360800] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 26.480832] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 31.600496] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 41.101117] kauditd_printk_skb: 12 callbacks suppressed
[ 46.960817] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 52.080838] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 60.186870] Bluetooth: hci0: command 0x0c24 tx timeout
[ 63.174173] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 68.294467] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 73.414179] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 78.534190] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 83.654204] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 84.079984] Bluetooth: hci0: command 0x0c52 tx timeout
[ 88.774105] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 93.894277] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 99.014330] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 104.134447] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 109.253923] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 114.374029] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 115.313105] debugfs: Directory 'card3' with parent 'sound' already present!
[ 117.279688] debugfs: Directory 'card3' with parent 'sound' already present!
[ 119.493748] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 124.614026] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 129.734220] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 134.854303] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 139.974003] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 145.094159] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 146.912706] debugfs: Directory 'card3' with parent 'sound' already present!
[ 150.216966] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 155.333640] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 160.454001] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 164.949603] debugfs: Directory 'card3' with parent 'sound' already present!
[ 165.574746] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 170.694243] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 173.716206] debugfs: Directory 'card3' with parent 'sound' already present!
[ 175.814145] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 176.866341] debugfs: Directory 'card3' with parent 'sound' already present!
[ 180.933877] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 186.054187] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 190.303057] debugfs: Directory 'card3' with parent 'sound' already present!
[ 191.174224] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 195.452387] debugfs: Directory 'card3' with parent 'sound' already present!
[ 196.293980] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 200.069236] debugfs: Directory 'card3' with parent 'sound' already present!
[ 201.414774] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 206.534356] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 206.996618] debugfs: Directory 'card3' with parent 'sound' already present!
[ 211.653931] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 216.774170] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 221.893893] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 227.014092] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 232.133796] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 233.202678] debugfs: Directory 'card3' with parent 'sound' already present!
[ 237.254385] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 241.970287] debugfs: Directory 'card3' with parent 'sound' already present!
[ 242.373836] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 246.852961] debugfs: Directory 'card3' with parent 'sound' already present!
[ 247.493839] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 252.613618] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 257.733853] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 262.854115] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 267.974102] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 273.093958] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 277.329632] debugfs: Directory 'card3' with parent 'sound' already present!
[ 278.214165] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 283.334280] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 288.454217] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 293.573822] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 298.694042] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 303.814250] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 305.747836] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 305.756994] usb 1-2.1: 2:0: usb_set_interface failed (-32)
[ 305.766196] usb 1-2.1: 2:0: usb_set_interface failed (-32)
[ 305.782417] usb 1-2.1: 2:1: usb_set_interface failed (-32)
[ 305.791525] usb 1-2.1: 2:0: usb_set_interface failed (-32)
[ 305.793604] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.801610] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.802029] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.802457] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.810480] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.810899] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.811347] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.819375] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.819779] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.820239] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.828230] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.828691] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.829123] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.837100] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.837502] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.838017] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.845981] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.846383] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.846801] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.854770] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.855174] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.855592] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.863564] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.863966] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.864387] usb 1-2.1: 1:0: usb_set_interface failed (-32)
[ 305.872350] usb 1-2.1: 1:1: usb_set_interface failed (-32)
[ 305.872352] usb 1-2.1: 1:0: usb_set_interface failed (-19)
[ 306.691268] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
journal
Sep 01 13:31:07 man-jon-desk kernel: #9 #10 #11 #12 #13 #14 #15
Sep 01 13:31:07 man-jon-desk kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Sep 01 13:31:07 man-jon-desk kernel: nvme nvme1: missing or invalid SUBNQN field.
Sep 01 13:31:07 man-jon-desk kernel: ata1.00: supports DRM functions and may not be fully accessible
Sep 01 13:31:07 man-jon-desk kernel: ata2.00: supports DRM functions and may not be fully accessible
Sep 01 13:31:07 man-jon-desk kernel: ata6: failed to resume link (SControl 0)
Sep 01 13:31:07 man-jon-desk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
Sep 01 13:31:07 man-jon-desk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
Sep 01 13:31:07 man-jon-desk kernel: sd 7:0:0:0: [sdd] No Caching mode page found
Sep 01 13:31:07 man-jon-desk kernel: sd 7:0:0:0: [sdd] Assuming drive cache: write through
Sep 01 13:31:08 man-jon-desk kernel: nvidia: loading out-of-tree module taints kernel.
Sep 01 13:31:08 man-jon-desk kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 01 13:31:08 man-jon-desk kernel: Disabling lock debugging due to kernel taint
Sep 01 13:31:08 man-jon-desk kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Sep 01 13:31:08 man-jon-desk kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Sep 01 13:31:10 man-jon-desk systemd[713]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 01 13:31:10 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:31:11 man-jon-desk systemd[736]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Sep 01 13:31:11 man-jon-desk systemd[736]: Failed to start Update XDG user dir configuration.
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: QFont::fromString: Invalid description '(empty)'
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd5cb174d0), parent's thread is QThread(0x561f3f766450), current thread is QThread(0x561f3f8449c0)
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 01 13:31:11 man-jon-desk sddm-greeter[745]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Sep 01 13:31:12 man-jon-desk sddm-greeter[745]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Sep 01 13:31:12 man-jon-desk sddm-greeter[745]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Sep 01 13:31:15 man-jon-desk kernel: kauditd_printk_skb: 49 callbacks suppressed
Sep 01 13:31:15 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:20 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:25 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:30 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:30 man-jon-desk ksplashqml[800]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Sep 01 13:31:30 man-jon-desk ksplashqml[800]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Sep 01 13:31:30 man-jon-desk klauncher[821]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Sep 01 13:31:31 man-jon-desk kcminit_startup[826]: QDBusConnection: error: could not send signal to service "" path "//home/filteredusername/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/filteredusername/.kde4/share/config/kdeglobals
Sep 01 13:31:31 man-jon-desk kwin_x11[837]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Sep 01 13:31:31 man-jon-desk kwin_x11[837]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 01 13:31:31 man-jon-desk kwin_x11[837]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 01 13:31:31 man-jon-desk kded5[834]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Sep 01 13:31:31 man-jon-desk ksmserver[879]: Qt: Session management error: networkIdsList argument is NULL
Sep 01 13:31:31 man-jon-desk kwalletd5[890]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
Sep 01 13:31:31 man-jon-desk backlighthelper[963]: org.kde.powerdevil: no kernel backlight interface found
Sep 01 13:31:31 man-jon-desk org_kde_powerdevil[898]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Sep 01 13:31:31 man-jon-desk org_kde_powerdevil[898]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 01 13:31:31 man-jon-desk kwalletd5[890]: Application ' "kded5" ' using kwallet without parent window!
Sep 01 13:31:31 man-jon-desk org_kde_powerdevil[898]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 01 13:31:31 man-jon-desk org_kde_powerdevil[898]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Sep 01 13:31:31 man-jon-desk plasmashell[894]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 01 13:31:31 man-jon-desk plasmashell[894]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 01 13:31:32 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 10 (BadAccess), sequence: 841, resource id: 495, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Sep 01 13:31:32 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 925, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Sep 01 13:31:32 man-jon-desk plasmashell[894]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 01 13:31:32 man-jon-desk plasmashell[894]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 01 13:31:32 man-jon-desk plasmashell[894]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 01 13:31:32 man-jon-desk plasmashell[894]: Error: cannot change the containment to AppletsLayout
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5652ea8dac70)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5652ea112d60)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5652ea8dac70)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5652ea8e0890)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5652ea8dabd0)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5652ea8e0890)
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Both point size and pixel size set. Using pixel size.
Sep 01 13:31:33 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Sep 01 13:31:33 man-jon-desk plasmashell[894]: Error: cannot change the containment to AppletsLayout
Sep 01 13:31:33 man-jon-desk plasmashell[894]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 01 13:31:34 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:34 man-jon-desk plasmashell[894]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 01 13:31:35 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:35 man-jon-desk plasmashell[894]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 01 13:31:36 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:37 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:37 man-jon-desk plasmashell[894]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 01 13:31:38 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:39 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Sep 01 13:31:39 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:31:39 man-jon-desk plasmashell[894]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 01 13:31:40 man-jon-desk kernel: kauditd_printk_skb: 12 callbacks suppressed
Sep 01 13:31:46 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:51 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 13:31:56 man-jon-desk pamac-tray-plasma[915]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 01 13:31:56 man-jon-desk msm_kde_notifier[926]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 01 13:31:56 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14719, resource id: 4194333, major code: 18 (ChangeProperty), minor code: 0
Sep 01 13:31:58 man-jon-desk plasmashell[894]: kde.keyboardlayout: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Sep 01 13:31:59 man-jon-desk kernel: Bluetooth: hci0: command 0x0c24 tx timeout
Sep 01 13:32:02 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14909, resource id: 52428803, major code: 12 (ConfigureWindow), minor code: 0
Sep 01 13:32:02 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:03 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:32:07 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:12 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:17 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 439, resource id: 52428803, major code: 7 (ReparentWindow), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 441, resource id: 52428803, major code: 142 (Unknown), minor code: 1
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 442, resource id: 52428803, major code: 6 (ChangeSaveSet), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 443, resource id: 52428803, major code: 25 (SendEvent), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 444, resource id: 52428803, major code: 12 (ConfigureWindow), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 446, resource id: 52428803, major code: 12 (ConfigureWindow), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 447, resource id: 52428803, major code: 8 (MapWindow), minor code: 0
Sep 01 13:32:21 man-jon-desk xembedsniproxy[897]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 448, resource id: 52428803, major code: 61 (ClearArea), minor code: 0
Sep 01 13:32:21 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16120, resource id: 37748743, major code: 3 (GetWindowAttributes), minor code: 0
Sep 01 13:32:21 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 16121, resource id: 37748743, major code: 14 (GetGeometry), minor code: 0
Sep 01 13:32:21 man-jon-desk plasmashell[894]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 01 13:32:22 man-jon-desk bluetoothd[713]: profiles/audio/media.c:client_ready_cb() No object received
Sep 01 13:32:22 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:23 man-jon-desk kernel: Bluetooth: hci0: command 0x0c52 tx timeout
Sep 01 13:32:26 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Sep 01 13:32:26 man-jon-desk systemd-coredump[1211]: [🡕] Process 1209 (firefox) of user 1000 dumped core.
Module /usr/lib/firefox/libmozsandbox.so with build-id 3c9db5fb3562abc2e78e76bf80291ded455f1f38
Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module librt.so.1 with build-id 837ea1d121976e9fa94acdf79939b387a32531db
Module libplds4.so with build-id 35c8b19ee309f8a4c2a4409568d2ab4f11a6557a
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
Module libssl3.so with build-id 94040772bf0029a13562ab6314237dc26ea29a60
Module libplc4.so with build-id d3b585736c213f75d6d1071f8db9a6219f1dd429
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libxul.so with build-id 3bbdbf34b8993b86340f840ae98cccd9ed6425fc
Module libmozwayland.so with build-id d10ccd85e5bd875d6a89f6f07578976b26ea27f7
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
Module libmozgtk.so with build-id 8027a58caeba8263184a5eed62b27555d21c7736
Module libmozsqlite3.so with build-id 8d0f4ebe7c073f9b72bab3afb37b00c4b7a15652
Module liblgpllibs.so with build-id 33615eeab36653f9841f2828e10c6aebbc2463fb
Module libnspr4.so with build-id 64bc745fdf99e414eeda94b9345af6fa6fcce329
Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
Module firefox with build-id 2b8aea238365eb224accff3ca8a61933202c6214
Stack trace of thread 1209:
#0 0x00007fc0a0d08814 XDisplayString (libX11.so.6 + 0x2b814)
#1 0x00007fc09404aa1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
#2 0x00007fc093bd4c8a n/a (libva.so.2 + 0x3c8a)
#3 0x00007fc093bdabe1 vaInitialize (libva.so.2 + 0x9be1)
#4 0x00007fc09c586117 n/a (libxul.so + 0x8533117)
#5 0x00007fc09c586d29 n/a (libxul.so + 0x8533d29)
#6 0x00007fc098556b4e n/a (libxul.so + 0x4503b4e)
#7 0x00007fc098554955 n/a (libxul.so + 0x4501955)
#8 0x00007fc098547be5 n/a (libxul.so + 0x44f4be5)
#9 0x00007fc098546ead n/a (libxul.so + 0x44f3ead)
#10 0x0000561537820972 n/a (firefox + 0x55972)
#11 0x00007fc0a2afe2d0 n/a (libc.so.6 + 0x232d0)
#12 0x00007fc0a2afe38a __libc_start_main (libc.so.6 + 0x2338a)
#13 0x00005615378300a5 _start (firefox + 0x650a5)
Sep 01 13:32:27 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19253, resource id: 14681850, major code: 3 (GetWindowAttributes), minor code: 0
Sep 01 13:32:27 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 19254, resource id: 14681850, major code: 14 (GetGeometry), minor code: 0
Sep 01 13:32:28 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:33 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:34 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:32:38 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:43 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:45 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20633, resource id: 14681930, major code: 3 (GetWindowAttributes), minor code: 0
Sep 01 13:32:45 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20634, resource id: 14681930, major code: 14 (GetGeometry), minor code: 0
Sep 01 13:32:48 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:53 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:32:54 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:32:56 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:32:58 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:03 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:05 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:33:09 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:14 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:19 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:24 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:26 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:33:29 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:34 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:36 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:33:39 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:44 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:33:44 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:49 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:52 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:33:55 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:33:56 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:00 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:05 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:07 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:34:09 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:10 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:14 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:15 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:19 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:20 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:25 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:26 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:30 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:36 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:38 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:34:41 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:45 man-jon-desk plasmashell[894]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 01 13:34:45 man-jon-desk plasmashell[894]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Sep 01 13:34:46 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:48 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30499, resource id: 14682476, major code: 3 (GetWindowAttributes), minor code: 0
Sep 01 13:34:48 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30500, resource id: 14682476, major code: 14 (GetGeometry), minor code: 0
Sep 01 13:34:48 man-jon-desk systemsettings[1972]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 01 13:34:48 man-jon-desk systemsettings[1972]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 01 13:34:49 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30792, resource id: 71303177, major code: 18 (ChangeProperty), minor code: 0
Sep 01 13:34:51 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:34:51 man-jon-desk systemsettings[1972]: kf.coreaddons: "Could not load plugin from kcm_pulseaudio: Die dynamische Bibliothek konnte nicht gefunden werden."
Sep 01 13:34:51 man-jon-desk systemsettings[1972]: org.kde.plasma.pulseaudio: Settings schema org.freedesktop.pulseaudio.module-group is not installed
Sep 01 13:34:51 man-jon-desk systemsettings[1972]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 01 13:34:52 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:34:56 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:01 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:35:01 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:06 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:35:06 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:09 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:35:11 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:17 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:21 man-jon-desk systemsettings[1972]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:35:22 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 13:35:27 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:32 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:36 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 13:35:37 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:40 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: context kaput
Sep 01 13:35:42 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:47 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:52 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:35:53 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36445, resource id: 69206153, major code: 18 (ChangeProperty), minor code: 0
Sep 01 13:35:53 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36449, resource id: 44040319, major code: 18 (ChangeProperty), minor code: 0
Sep 01 13:35:57 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:36:03 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 2:0: usb_set_interface failed (-32)
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 2:1: usb_set_interface failed (-32)
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 1:0: usb_set_interface failed (-32)
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 1:1: usb_set_interface failed (-32)
Sep 01 13:36:05 man-jon-desk kernel: usb 1-2.1: 1:0: usb_set_interface failed (-19)
Sep 01 13:36:05 man-jon-desk pipewire-media-session[1059]: spa.bluez5: RegisterApplication() failed: org.bluez.Error.Failed
Sep 01 13:36:05 man-jon-desk pipewire-media-session[1059]: spa.bluez5: Using legacy bluez5 API for A2DP - only SBC will be supported. Please upgrade bluez5.
Sep 01 13:36:05 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Sep 01 13:36:05 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Sep 01 13:36:06 man-jon-desk plasmashell[894]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x7fa4b82511c0) QQmlContext(0x5652ead47900) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 01 13:36:06 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 01 13:36:06 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 01 13:36:06 man-jon-desk plasmashell[894]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Sep 01 13:36:06 man-jon-desk plasmashell[894]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5652ed088d40) QQmlContext(0x5652ead47900) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 01 13:36:06 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42352, resource id: 44040320, major code: 15 (QueryTree), minor code: 0
Sep 01 13:36:06 man-jon-desk pipewire-media-session[1059]: ms.core: error id:60 seq:189 res:-38 (Function not implemented): no interface PipeWire:Interface:Client
Sep 01 13:36:06 man-jon-desk pipewire-media-session[1059]: ms.core: error id:62 seq:195 res:-38 (Function not implemented): no interface PipeWire:Interface:Client
Sep 01 13:36:07 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Sep 01 13:36:07 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Sep 01 13:36:07 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_0c_00.4.analog-stereo"
Sep 01 13:36:07 man-jon-desk plasmashell[894]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_0c_00.4.analog-stereo.monitor"
Sep 01 13:36:08 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44091, resource id: 65011790, major code: 15 (QueryTree), minor code: 0
Sep 01 13:36:11 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47427, resource id: 44040322, major code: 15 (QueryTree), minor code: 0
Sep 01 13:36:11 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 152 (BadDamage), sequence: 47471, resource id: 14682753, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 01 13:37:09 man-jon-desk plasmashell[894]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5652ed58e960) QQmlContext(0x5652ead47900) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 01 13:37:09 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 01 13:37:09 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 01 13:37:14 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8980, resource id: 44040338, major code: 15 (QueryTree), minor code: 0
Sep 01 13:37:14 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 152 (BadDamage), sequence: 9030, resource id: 14685077, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 01 13:37:59 man-jon-desk plasmashell[894]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 01 13:38:00 man-jon-desk kate[2765]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 01 13:38:13 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Sep 01 13:38:35 man-jon-desk kwin_x11[837]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 01 13:38:36 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4801, resource id: 14691769, major code: 20 (GetProperty), minor code: 0
Sep 01 13:38:36 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 152 (BadDamage), sequence: 4898, resource id: 14691791, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 01 13:38:39 man-jon-desk plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Sep 01 13:38:41 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10941, resource id: 14692130, major code: 20 (GetProperty), minor code: 0
Sep 01 13:38:41 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 152 (BadDamage), sequence: 11039, resource id: 14692370, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 01 13:38:43 man-jon-desk kwin_x11[837]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12999, resource id: 14692443, major code: 20 (GetProperty), minor code: 0
Sep 01 13:38:43 man-jon-desk kwin_x11[837]: kwin_core: XCB error: 152 (BadDamage), sequence: 13096, resource id: 14692451, major code: 143 (DAMAGE), minor code: 3 (Subtract)
